[QGIS Commit] r13030 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Mar 8 18:15:12 EST 2010
Author: cfarmer
Date: 2010-03-08 18:15:11 -0500 (Mon, 08 Mar 2010)
New Revision: 13030
   trunk/qgis/python/plugins/fTools/tools/doMeanCoords.py
Means for unique values now properly calculated. Fixes #2509.
Modified: trunk/qgis/python/plugins/fTools/tools/doMeanCoords.py
--- trunk/qgis/python/plugins/fTools/tools/doMeanCoords.py	2010-03-08 22:40:39 UTC (rev 13029)
+++ trunk/qgis/python/plugins/fTools/tools/doMeanCoords.py	2010-03-08 23:15:11 UTC (rev 13030)
@@ -1,3 +1,4 @@
+# -*- coding: utf-8 -*-
 from PyQt4.QtCore import *
 from PyQt4.QtGui import *
 import ftools_utils
@@ -6,235 +7,206 @@
 from ui_frmMeanCoords import Ui_Dialog
 class Dialog(QDialog, Ui_Dialog):
-	def __init__(self, iface, function):
-		QDialog.__init__(self)
-		self.iface = iface
-		self.function = function
-		self.setupUi(self)
-		self.updateUi()
-		QObject.connect(self.toolOut, SIGNAL("clicked()"), self.outFile)
-		QObject.connect(self.inShape, SIGNAL("currentIndexChanged(QString)"), self.update)
+    def __init__(self, iface, function):
+        QDialog.__init__(self)
+        self.iface = iface
+        self.function = function
+        self.setupUi(self)
+        self.updateUi()
+        QObject.connect(self.toolOut, SIGNAL("clicked()"), self.outFile)
+        QObject.connect(self.inShape, SIGNAL("currentIndexChanged(QString)"), self.update)
-		# populate layer list
-		self.progressBar.setValue(0)
-		mapCanvas = self.iface.mapCanvas()
-		for i in range(mapCanvas.layerCount()):
-			layer = mapCanvas.layer(i)
-			if layer.type() == layer.VectorLayer:
-				self.inShape.addItem(layer.name())
+        # populate layer list
+        self.progressBar.setValue(0)
+        mapCanvas = self.iface.mapCanvas()
+        for i in range(mapCanvas.layerCount()):
+            layer = mapCanvas.layer(i)
+            if layer.type() == layer.VectorLayer:
+                self.inShape.addItem(layer.name())
-	def updateUi(self):
-		if self.function == 1:
-			self.setWindowTitle( self.tr("Mean coordinates") )
-			self.sizeValue.setVisible(False)
-			self.label_size.setVisible(False)
-		elif self.function == 2:
-			self.setWindowTitle( self.tr("Standard distance") )
-		self.resize(381, 100)
+    def updateUi(self):
+        if self.function == 1:
+            self.setWindowTitle( self.tr("Mean coordinates") )
+            self.sizeValue.setVisible(False)
+            self.label_size.setVisible(False)
+        elif self.function == 2:
+            self.setWindowTitle( self.tr("Standard distance") )
+        self.resize(381, 100)
-	def update(self, inputLayer):
-		self.weightField.clear()
-		self.uniqueField.clear()
-		self.weightField.addItem( self.tr("(Optional) Weight field") )
-		self.uniqueField.addItem( self.tr("(Optional) Unique ID field") )
-		self.changedLayer = self.getVectorLayerByName(inputLayer)
-		changedField = self.getFieldList(self.changedLayer)
-		for i in changedField:
-			if changedField[i].type() == QVariant.Int or changedField[i].type() == QVariant.Double:
-				self.weightField.addItem(unicode(changedField[i].name()))
-			self.uniqueField.addItem(unicode(changedField[i].name()))
+    def update(self, inputLayer):
+        self.weightField.clear()
+        self.uniqueField.clear()
+        self.weightField.addItem( self.tr("(Optional) Weight field") )
+        self.uniqueField.addItem( self.tr("(Optional) Unique ID field") )
+        self.changedLayer = ftools_utils.getVectorLayerByName(inputLayer)
+        changedField = ftools_utils.getFieldList(self.changedLayer)
+        for i in changedField:
+            if changedField[i].type() == QVariant.Int or changedField[i].type() == QVariant.Double:
+                self.weightField.addItem(unicode(changedField[i].name()))
+            self.uniqueField.addItem(unicode(changedField[i].name()))
-	def accept(self):
-		if self.inShape.currentText() == "":
-			QMessageBox.information(self, self.tr("Coordinate statistics"), self.tr("No input vector layer specified"))
-		elif self.outShape.text() == "":
-			QMessageBox.information(self, self.tr("Coordinate statistics"), self.tr("Please specify output shapefile"))
-		else:
-			inName = self.inShape.currentText()
-			outPath = self.outShape.text()
+    def accept(self):
+        if self.inShape.currentText() == "":
+            QMessageBox.information(self, self.tr("Coordinate statistics"), self.tr("No input vector layer specified"))
+        elif self.outShape.text() == "":
+            QMessageBox.information(self, self.tr("Coordinate statistics"), self.tr("Please specify output shapefile"))
+        else:
+            inName = self.inShape.currentText()
+            outPath = self.outShape.text()
-			if outPath.contains("\\"):
-				outName = outPath.right((outPath.length() - outPath.lastIndexOf("\\")) - 1)
-			else:
-				outName = outPath.right((outPath.length() - outPath.lastIndexOf("/")) - 1)
-			if outName.endsWith(".shp"):
-				outName = outName.left(outName.length() - 4)
-			self.compute(inName, outPath, self.weightField.currentText(), self.sizeValue.value(), self.uniqueField.currentText())
-			self.progressBar.setValue(100)
-			self.outShape.clear()
-			addToTOC = QMessageBox.question(self, self.tr("Coordinate statistics"), self.tr("Created output point shapefile:\n%1\n\nWould you like to add the new layer to the TOC?").arg( outPath ), QMessageBox.Yes, QMessageBox.No, QMessageBox.NoButton)
-			if addToTOC == QMessageBox.Yes:
-				self.vlayer = QgsVectorLayer(outPath, unicode(outName), "ogr")
-				if self.vlayer.geometryType() == QGis.Point:
-					render = QgsSingleSymbolRenderer(QGis.Point)
-					symbol = QgsSymbol(QGis.Point)
-					symbol.setFillColor(Qt.red)
-					symbol.setFillStyle(Qt.SolidPattern)
-					symbol.setColor(Qt.red)
-					symbol.setPointSize(5)
-					render.addSymbol(symbol)
-					self.vlayer.setRenderer(render)
-				QgsMapLayerRegistry.instance().addMapLayer(self.vlayer)
+            if outPath.contains("\\"):
+                outName = outPath.right((outPath.length() - outPath.lastIndexOf("\\")) - 1)
+            else:
+                outName = outPath.right((outPath.length() - outPath.lastIndexOf("/")) - 1)
+            if outName.endsWith(".shp"):
+                outName = outName.left(outName.length() - 4)
+            self.compute(inName, outPath, self.weightField.currentText(), self.sizeValue.value(), self.uniqueField.currentText())
+            self.progressBar.setValue(100)
+            self.outShape.clear()
+            addToTOC = QMessageBox.question(self, self.tr("Coordinate statistics"), self.tr("Created output point shapefile:\n%1\n\nWould you like to add the new layer to the TOC?").arg( outPath ), QMessageBox.Yes, QMessageBox.No, QMessageBox.NoButton)
+            if addToTOC == QMessageBox.Yes:
+                self.vlayer = QgsVectorLayer(outPath, unicode(outName), "ogr")
+                if self.vlayer.geometryType() == QGis.Point:
+                    render = QgsSingleSymbolRenderer(QGis.Point)
+                    symbol = QgsSymbol(QGis.Point)
+                    symbol.setFillColor(Qt.red)
+                    symbol.setFillStyle(Qt.SolidPattern)
+                    symbol.setColor(Qt.red)
+                    symbol.setPointSize(5)
+                    render.addSymbol(symbol)
+                    self.vlayer.setRenderer(render)
+                QgsMapLayerRegistry.instance().addMapLayer(self.vlayer)
-	def outFile(self):
-		( self.shapefileName, self.encoding ) = ftools_utils.saveDialog( self )
-		if self.shapefileName is None or self.encoding is None:
-			return
-		self.outShape.setText( QString( self.shapefileName ) )
+    def outFile(self):
+        ( self.shapefileName, self.encoding ) = ftools_utils.saveDialog( self )
+        if self.shapefileName is None or self.encoding is None:
+            return
+        self.outShape.setText( QString( self.shapefileName ) )
-	def compute(self, inName, outName, weightField="", times=1, uniqueField=""):
-		vlayer = self.getVectorLayerByName(inName)
-		provider = vlayer.dataProvider()
-		weightIndex = provider.fieldNameIndex(weightField)
-		uniqueIndex = provider.fieldNameIndex(uniqueField)
-		feat = QgsFeature()
-		allAttrs = provider.attributeIndexes()
-		provider.select(allAttrs)
-		sRs = provider.crs()
-		check = QFile(self.shapefileName)
-		if check.exists():
-			if not QgsVectorFileWriter.deleteShapeFile(self.shapefileName):
-				return
-		if uniqueIndex <> -1:
-			uniqueValues = self.getUniqueValues(provider, int(uniqueIndex))
-			single = False
-		else:
-			uniqueValues = [QVariant(1)]
-			single = True
-		if self.function == 2:
-			fieldList = { 0 : QgsField("STD_DIST", QVariant.Double), 1 : QgsField("UID", QVariant.String) }
-			writer = QgsVectorFileWriter(self.shapefileName, self.encoding, fieldList, QGis.WKBPolygon, sRs)
-		else:
-			fieldList = { 0 : QgsField("MEAN_X", QVariant.Double), 1 : QgsField("MEAN_Y", QVariant.Double), 2 : QgsField("UID", QVariant.String)  }
-			writer = QgsVectorFileWriter(self.shapefileName, self.encoding, fieldList, QGis.WKBPoint, sRs)
-		outfeat = QgsFeature()
-		points = []
-		weights = []
-		nFeat = provider.featureCount() * len(uniqueValues)
-		nElement = 0
-		self.progressBar.setRange(0, nFeat)
-		for j in uniqueValues:
-			provider.rewind()
-			while provider.nextFeature(feat):
-				nElement += 1
-				self.progressBar.setValue(nElement)
-				if single:
-					check = j.toString().trimmed()
-				else:
-					check = feat.attributeMap()[uniqueIndex].toString().trimmed()
-				if check == j.toString().trimmed():
-					cx = 0.00
-					cy = 0.00
-					if weightIndex == -1:
-						weight = 1.00
-					else:
-						weight = float(feat.attributeMap()[weightIndex].toDouble()[0])
-					geom = QgsGeometry(feat.geometry())
-					geom = self.extract(geom)
-					for i in geom:
-						cx += i.x()
-						cy += i.y()
-					points.append(QgsPoint((cx / len(geom)), (cy / len(geom))))
-					weights.append(weight)
-			sumWeight = sum(weights)
-			cx = 0.00
-			cy = 0.00
-			item = 0
-			for i in points:
-				cx += i.x() * weights[item]
-				cy += i.y() * weights[item]
-				item += 1
-			cx = cx / sumWeight
-			cy = cy / sumWeight
-			meanPoint = QgsPoint(cx, cy)
-				values = []
-				md = 0.00
-				sd = 0.00
-				dist = QgsDistanceArea()
-				item = 0
-				for i in points:
-					tempDist = dist.measureLine(i, meanPoint)
-					values.append(tempDist)
-					item += 1
-					md += tempDist
-				md = md / item
-				for i in values:
-					sd += (i-md)*(i-md)
-				sd = sqrt(sd/item)
-				outfeat.setGeometry(QgsGeometry.fromPoint(meanPoint).buffer(sd * times, 10))
-				outfeat.addAttribute(0, QVariant(sd))
-				outfeat.addAttribute(1, QVariant(j))
-			else:
-				outfeat.setGeometry(QgsGeometry.fromPoint(meanPoint))
-				outfeat.addAttribute(0, QVariant(cx))
-				outfeat.addAttribute(1, QVariant(cy))
-				outfeat.addAttribute(2, QVariant(j))
-			writer.addFeature(outfeat)
-			if single:
-				break
-		del writer
-# Gets vector layer by layername in canvas
-	def getVectorLayerByName(self, myName):
-		mc = self.iface.mapCanvas()
-		nLayers = mc.layerCount()
-		for l in range(nLayers):
-			layer = mc.layer(l)
-			if layer.name() == unicode(myName):
-				vlayer = QgsVectorLayer(unicode(layer.source()),  unicode(myName),  unicode(layer.dataProvider().name()))
-				if vlayer.isValid():
-					return vlayer
+    def compute(self, inName, outName, weightField="", times=1, uniqueField=""):
+        vlayer = ftools_utils.getVectorLayerByName(inName)
+        provider = vlayer.dataProvider()
+        weightIndex = provider.fieldNameIndex(weightField)
+        uniqueIndex = provider.fieldNameIndex(uniqueField)
+        feat = QgsFeature()
+        allAttrs = provider.attributeIndexes()
+        provider.select(allAttrs)
+        sRs = provider.crs()
+        check = QFile(self.shapefileName)
+        if check.exists():
+            if not QgsVectorFileWriter.deleteShapeFile(self.shapefileName):
+                return
+        if uniqueIndex <> -1:
+            uniqueValues = ftools_utils.getUniqueValues(provider, int( uniqueIndex ) )
+            single = False
+        else:
+            uniqueValues = [QVariant(1)]
+            single = True
+        if self.function == 2:
+            fieldList = { 0 : QgsField("STD_DIST", QVariant.Double), 1 : QgsField("UID", QVariant.String) }
+            writer = QgsVectorFileWriter(self.shapefileName, self.encoding, fieldList, QGis.WKBPolygon, sRs)
+        else:
+            fieldList = { 0 : QgsField("MEAN_X", QVariant.Double), 1 : QgsField("MEAN_Y", QVariant.Double), 2 : QgsField("UID", QVariant.String)  }
+            writer = QgsVectorFileWriter(self.shapefileName, self.encoding, fieldList, QGis.WKBPoint, sRs)
+        outfeat = QgsFeature()
+        points = []
+        weights = []
+        nFeat = provider.featureCount() * len(uniqueValues)
+        nElement = 0
+        self.progressBar.setRange(0, nFeat)
+        for j in uniqueValues:
+            provider.rewind()
+            cx = 0.00
+            cy = 0.00
+            points = []
+            weights = []
+            while provider.nextFeature(feat):
+                nElement += 1
+                self.progressBar.setValue(nElement)
+                if single:
+                    check = j.toString().trimmed()
+                else:
+                    check = feat.attributeMap()[uniqueIndex].toString().trimmed()
+                if check == j.toString().trimmed():
+                    cx = 0.00
+                    cy = 0.00
+                    if weightIndex == -1:
+                        weight = 1.00
+                    else:
+                        weight = float(feat.attributeMap()[weightIndex].toDouble()[0])
+                    geom = QgsGeometry(feat.geometry())
+                    geom = self.extract(geom)
+                    for i in geom:
+                        cx += i.x()
+                        cy += i.y()
+                    points.append(QgsPoint((cx / len(geom)), (cy / len(geom))))
+                    weights.append(weight)
+            sumWeight = sum(weights)
+            cx = 0.00
+            cy = 0.00
+            item = 0
+            for item, i in enumerate(points):
+                cx += i.x() * weights[item]
+                cy += i.y() * weights[item]
+            cx = cx / sumWeight
+            cy = cy / sumWeight
+            meanPoint = QgsPoint(cx, cy)
+                values = []
+                md = 0.00
+                sd = 0.00
+                dist = QgsDistanceArea()
+                item = 0
+                for i in points:
+                    tempDist = dist.measureLine(i, meanPoint)
+                    values.append(tempDist)
+                    item += 1
+                    md += tempDist
+                md = md / item
+                for i in values:
+                    sd += (i-md)*(i-md)
+                sd = sqrt(sd/item)
+                outfeat.setGeometry(QgsGeometry.fromPoint(meanPoint).buffer(sd * times, 10))
+                outfeat.addAttribute(0, QVariant(sd))
+                outfeat.addAttribute(1, QVariant(j))
+            else:
+                outfeat.setGeometry(QgsGeometry.fromPoint(meanPoint))
+                outfeat.addAttribute(0, QVariant(cx))
+                outfeat.addAttribute(1, QVariant(cy))
+                outfeat.addAttribute(2, QVariant(j))
+            writer.addFeature(outfeat)
+            if single:
+                break
+        del writer
-# Retrieve the field map of a vector Layer
-	def getFieldList(self, vlayer):
-		fProvider = vlayer.dataProvider()
-		allAttrs = fProvider.attributeIndexes()
-		# fetch all attributes for each feature
-		fProvider.select(allAttrs)
-		# retrieve all fields
-		myFields = fProvider.fields()
-		return myFields
+    def extract(self, geom):
+        multi_geom = QgsGeometry()
+        temp_geom = []
+        if geom.type() == 0: # it's a point
+            if geom.isMultipart():
+                temp_geom = geom.asMultiPoint()
+            else:
+                temp_geom.append(geom.asPoint())
+        if geom.type() == 1: # it's a line
+                multi_geom = geom.asMultiPolyline() #multi_geog is a multiline
+                for i in multi_geom: #i is a line
+                    temp_geom.extend(i)
+            else:
+                temp_geom = geom.asPolyline()
+        elif geom.type() == 2: # it's a polygon
+                multi_geom = geom.asMultiPolygon() #multi_geom is a multipolygon
+                for i in multi_geom: #i is a polygon
+                    for j in i: #j is a line
+                        temp_geom.extend(j)
+            else:
+                multi_geom = geom.asPolygon() #multi_geom is a polygon
+        return temp_geom
-	def extract(self, geom):
-		multi_geom = QgsGeometry()
-		temp_geom = []
-		if geom.type() == 0: # it's a point
-			if geom.isMultipart():
-				temp_geom = geom.asMultiPoint()
-			else:
-				temp_geom.append(geom.asPoint())
-		if geom.type() == 1: # it's a line
-				multi_geom = geom.asMultiPolyline() #multi_geog is a multiline
-				for i in multi_geom: #i is a line
-					temp_geom.extend(i)
-			else:
-				temp_geom = geom.asPolyline()
-		elif geom.type() == 2: # it's a polygon
-				multi_geom = geom.asMultiPolygon() #multi_geom is a multipolygon
-				for i in multi_geom: #i is a polygon
-					for j in i: #j is a line
-						temp_geom.extend(j)
-			else:
-				multi_geom = geom.asPolygon() #multi_geom is a polygon
-		return temp_geom
-	def getUniqueValues(self, provider, index):
-		f = QgsFeature()
-		values = []
-		check = []
-		while provider.nextFeature( f ):
-			if not f.attributeMap()[index].toString() in check:
-				values.append( f.attributeMap()[index] )
-				check.append( f.attributeMap()[index].toString() )
-		return values
More information about the QGIS-commit mailing list
