[QGIS Commit] r13042 - in trunk/qgis/src: app app/composer core gui plugins/copyright_label plugins/grass plugins/grass/qtermwidget plugins/quick_print
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Mar 10 17:19:32 EST 2010
Author: jef
Date: 2010-03-10 17:19:31 -0500 (Wed, 10 Mar 2010)
New Revision: 13042
   trunk/qgis/src/app/composer/qgscomposer.cpp
   trunk/qgis/src/app/main.cpp
   trunk/qgis/src/app/qgsattributeactiondialog.cpp
   trunk/qgis/src/app/qgsquerybuilder.cpp
   trunk/qgis/src/app/qgssearchquerybuilder.cpp
   trunk/qgis/src/app/qgssearchquerybuilder.h
   trunk/qgis/src/app/qgsvectorlayerproperties.cpp
   trunk/qgis/src/core/qgshttptransaction.cpp
   trunk/qgis/src/gui/qgisgui.h
   trunk/qgis/src/gui/qgsattributeeditor.cpp
   trunk/qgis/src/gui/qgscolorbutton.cpp
   trunk/qgis/src/plugins/copyright_label/plugingui.cpp
   trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
   trunk/qgis/src/plugins/grass/qtermwidget/KeyboardTranslator.h
   trunk/qgis/src/plugins/quick_print/quickprintgui.cpp
remove #ifdefs related to no longer supported Qt versions
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -59,11 +59,7 @@
 #include <QSettings>
 #include <QIcon>
 #include <QPixmap>
-#if QT_VERSION < 0x040300
-#include <Q3Picture>
-#else
 #include <QSvgGenerator>
-#endif
 #include <QToolBar>
 #include <QToolButton>
 #include <QImageWriter>
@@ -554,16 +550,10 @@
   else
-#if QT_VERSION < 0x040400
-    QRectF paperRect( 0, 0, mComposition->paperWidth(), mComposition->paperHeight() );
-    QRect pageRect = printer.pageRect();
-    mComposition->render( &p, pageRect, paperRect );
-#else
     //better in case of custom page size, but only possible with Qt>=4.4.0
     QRectF paperRectMM = printer.pageRect( QPrinter::Millimeter );
     QRectF paperRectPixel = printer.pageRect( QPrinter::DevicePixel );
     mComposition->render( &p, paperRectPixel, paperRectMM );
-#endif
   mComposition->setPlotStyle( savedPlotStyle );
   QApplication::restoreOverrideCursor();
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/app/main.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -555,15 +555,8 @@
   else
-#if defined(Q_OS_MACX) && QT_VERSION < 0x040300
-    //on mac automasking as done below does not work (as of qt 4.2.1)
-    //so we do it the old way see bug #387
-    QPixmap myMaskPixmap( mySplashPath + QString( "splash_mask.png" ), 0, Qt::ThresholdDither | Qt::ThresholdAlphaDither | Qt::AvoidDither );
-    mypSplash->setMask( myMaskPixmap.createHeuristicMask() );
-#else
     //for win and linux we can just automask and png transparency areas will be used
     mypSplash->setMask( myPixmap.mask() );
-#endif
     mypSplash->show();
Modified: trunk/qgis/src/app/qgsattributeactiondialog.cpp
--- trunk/qgis/src/app/qgsattributeactiondialog.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/app/qgsattributeactiondialog.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -40,9 +40,7 @@
   header->setStretchLastSection( true );
   attributeActionTable->setColumnWidth( 0, 100 );
   attributeActionTable->setColumnWidth( 1, 230 );
-#if QT_VERSION >= 0x040300
   attributeActionTable->setCornerButtonEnabled( false );
-#endif
   connect( attributeActionTable, SIGNAL( itemSelectionChanged() ),
            this, SLOT( itemSelectionChanged() ) );
@@ -271,16 +269,6 @@
   QList<QTableWidgetItem *> selection = attributeActionTable->selectedItems();
   if ( !selection.isEmpty() )
-    // Supress multiple selection and select row where mouse release occurs.
-    // Workaround for Qt 4.3 bug which allows multiple rows to be selected if
-    // the user presses the mouse in one row header and releases in another.
-    if ( attributeActionTable->row( selection.first() ) != attributeActionTable->row( selection.last() ) )
-      attributeActionTable->selectRow( attributeActionTable->currentRow() );
-      selection = attributeActionTable->selectedItems();
-#endif
     rowSelected( attributeActionTable->row( selection.first() ) );
Modified: trunk/qgis/src/app/qgsquerybuilder.cpp
--- trunk/qgis/src/app/qgsquerybuilder.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/app/qgsquerybuilder.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -23,11 +23,6 @@
 #include "qgsvectorlayer.h"
 #include "qgsvectordataprovider.h"
-#define toPlainText() text()
-#endif
 // constructor used when the query builder must make its own
 // connection to the database
 QgsQueryBuilder::QgsQueryBuilder( QgsVectorLayer *layer,
Modified: trunk/qgis/src/app/qgssearchquerybuilder.cpp
--- trunk/qgis/src/app/qgssearchquerybuilder.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/app/qgssearchquerybuilder.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -26,11 +26,6 @@
 #include "qgslogger.h"
-#endif
 QgsSearchQueryBuilder::QgsSearchQueryBuilder( QgsVectorLayer* layer,
     QWidget *parent, Qt::WFlags fl )
     : QDialog( parent, fl ), mLayer( layer )
@@ -49,9 +44,9 @@
   connect( pbn, SIGNAL( clicked() ), this, SLOT( on_btnClear_clicked() ) );
   // disable unsupported operators
-  btnIn->setEnabled( false );
-  btnNotIn->setEnabled( false );
-  btnPct->setEnabled( false );
+  btnIn->setHidden( true );
+  btnNotIn->setHidden( true );
+  btnPct->setHidden( true );
   // change to ~
   btnILike->setText( "~" );
@@ -264,21 +259,6 @@
   txtSQL->insertPlainText( " > " );
-void QgsSearchQueryBuilder::on_btnPct_clicked()
-  txtSQL->insertPlainText( " % " );
-void QgsSearchQueryBuilder::on_btnIn_clicked()
-  txtSQL->insertPlainText( " IN " );
-void QgsSearchQueryBuilder::on_btnNotIn_clicked()
-  txtSQL->insertPlainText( " NOT IN " );
 void QgsSearchQueryBuilder::on_btnLike_clicked()
   txtSQL->insertPlainText( " LIKE " );
Modified: trunk/qgis/src/app/qgssearchquerybuilder.h
--- trunk/qgis/src/app/qgssearchquerybuilder.h	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/app/qgssearchquerybuilder.h	2010-03-10 22:19:31 UTC (rev 13042)
@@ -55,9 +55,6 @@
     void on_btnOk_clicked();
     void on_btnLessThan_clicked();
     void on_btnGreaterThan_clicked();
-    void on_btnPct_clicked();
-    void on_btnIn_clicked();
-    void on_btnNotIn_clicked();
     void on_btnLike_clicked();
     void on_btnILike_clicked();
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -59,11 +59,7 @@
 #include "qgsstylev2.h"
 #include "qgssymbologyv2conversion.h"
-#endif
 QgsVectorLayerProperties::QgsVectorLayerProperties(
   QgsVectorLayer *lyr,
   QWidget * parent,
Modified: trunk/qgis/src/core/qgshttptransaction.cpp
--- trunk/qgis/src/core/qgshttptransaction.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/core/qgshttptransaction.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -532,7 +532,6 @@
     proxyType = QNetworkProxy::HttpProxy;
-#if QT_VERSION >= 0x040400
   else if ( proxyTypeString == "HttpCachingProxy" )
     proxyType = QNetworkProxy::HttpCachingProxy;
@@ -541,7 +540,6 @@
     proxyType = QNetworkProxy::FtpCachingProxy;
-#endif
   http.setProxy( QNetworkProxy( proxyType, proxyHost, proxyPort, proxyUser, proxyPassword ) );
   return true;
Modified: trunk/qgis/src/gui/qgisgui.h
--- trunk/qgis/src/gui/qgisgui.h	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/gui/qgisgui.h	2010-03-10 22:19:31 UTC (rev 13042)
@@ -44,12 +44,7 @@
    * Qt::WindowMaximizeButtonHint is included but will be ignored if
    * the dialog is a fixed size and does not have a size grip.
-  static const Qt::WFlags ModalDialogFlags =
-#if QT_VERSION < 0x040200
-    Qt::WindowTitleHint | Qt::WindowSystemMenuHint | Qt::WindowMaximizeButtonHint;
-#else
-    0;
-#endif
+  static const Qt::WFlags ModalDialogFlags = 0;
     Open files, preferring to have the default file selector be the
Modified: trunk/qgis/src/gui/qgsattributeeditor.cpp
--- trunk/qgis/src/gui/qgsattributeeditor.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/gui/qgsattributeeditor.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -32,10 +32,7 @@
 #include <QSpinBox>
 #include <QCompleter>
 #include <QHBoxLayout>
 #include <QPlainTextEdit>
-#endif
 void QgsAttributeEditor::selectFileName( void )
@@ -274,26 +271,17 @@
       QLineEdit *le = NULL;
       QTextEdit *te = NULL;
       QPlainTextEdit *pte = NULL;
-#endif
       if ( editor )
         le = qobject_cast<QLineEdit *>( editor );
         te = qobject_cast<QTextEdit *>( editor );
         pte = qobject_cast<QPlainTextEdit *>( editor );
-#endif
       else if ( editType == QgsVectorLayer::TextEdit )
         pte = new QPlainTextEdit( parent );
-#else
-        te = new QTextEdit( parent );
-        te->setAcceptRichText( false );
-#endif
       else
@@ -331,18 +319,14 @@
       if ( te )
         te->setAcceptRichText( true );
-#endif
         myWidget = te;
       if ( pte )
         myWidget = pte;
-#endif
     break;
@@ -424,11 +408,7 @@
   QTextEdit *te = qobject_cast<QTextEdit *>( widget );
   if ( te )
     text = te->toHtml();
-#else
-    text = te->toPlainText();
-#endif
     modified = te->document()->isModified();
     if ( text == "NULL" )
@@ -436,7 +416,6 @@
   QPlainTextEdit *pte = qobject_cast<QPlainTextEdit *>( widget );
   if ( pte )
@@ -447,7 +426,6 @@
       text = QString::null;
-#endif
   QComboBox *cb = qobject_cast<QComboBox *>( widget );
   if ( cb )
@@ -614,14 +592,9 @@
       QLineEdit *le = qobject_cast<QLineEdit *>( editor );
       QTextEdit *te = qobject_cast<QTextEdit *>( editor );
       QPlainTextEdit *pte = qobject_cast<QPlainTextEdit *>( editor );
       if ( !le && !te && !pte )
         return false;
-#else
-      if ( !le && !te )
-        return false;
-#endif
       QString text;
       if ( value.isNull() )
@@ -634,15 +607,10 @@
       if ( le )
         le->setText( text );
       if ( te )
         te->setHtml( text );
       if ( pte )
         pte->setPlainText( text );
-#else
-      if ( te )
-        te->setPlainText( text );
-#endif
     break;
Modified: trunk/qgis/src/gui/qgscolorbutton.cpp
--- trunk/qgis/src/gui/qgscolorbutton.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/gui/qgscolorbutton.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -76,7 +76,7 @@
 QgsColorButtonV2::QgsColorButtonV2( QString text, QWidget* parent )
-  : QPushButton( text, parent )
+    : QPushButton( text, parent )
@@ -95,11 +95,7 @@
   p.setPen( Qt::NoPen );
   p.setRenderHint( QPainter::Antialiasing );
   p.setBrush( color );
   p.drawRoundedRect( rect, 4, 4 );
-#else
-  p.drawRect( rect );
-#endif
   p.end();
   // set this pixmap as icon
Modified: trunk/qgis/src/plugins/copyright_label/plugingui.cpp
--- trunk/qgis/src/plugins/copyright_label/plugingui.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/plugins/copyright_label/plugingui.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -36,11 +36,7 @@
   hide();
   //close the dialog
   emit changeFont( txtCopyrightText->currentFont() );
-  emit changeLabel( txtCopyrightText->text() );
-#else
   emit changeLabel( txtCopyrightText->toPlainText() );
-#endif
   emit changeColor( pbnColorChooser->color() );
   emit changePlacement( cboPlacement->currentIndex() );
   emit enableCopyrightLabel( cboxEnabled->isChecked() );
Modified: trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -60,15 +60,6 @@
   QgsDebugMsg( "QgsGrassNewMapset()" );
   setupUi( this );
-  // this is not done by Qt4.3 uic
-  addPage( WizardPage1 );
-  addPage( WizardPage2 );
-  addPage( WizardPage3 );
-  addPage( WizardPage4 );
-  addPage( WizardPage5 );
-  addPage( WizardPage6 );
-#endif
 #ifdef Q_WS_MAC
   setWizardStyle( QWizard::ClassicStyle );
 #endif
Modified: trunk/qgis/src/plugins/grass/qtermwidget/KeyboardTranslator.h
--- trunk/qgis/src/plugins/grass/qtermwidget/KeyboardTranslator.h	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/plugins/grass/qtermwidget/KeyboardTranslator.h	2010-03-10 22:19:31 UTC (rev 13042)
@@ -53,11 +53,6 @@
 # define K_GLOBAL_STATIC_STRUCT_NAME(NAME)
-# define Q_BASIC_ATOMIC_INITIALIZER     Q_ATOMIC_INIT
-# define testAndSetOrdered              testAndSet
-#endif
 #define K_GLOBAL_STATIC(TYPE, NAME) K_GLOBAL_STATIC_WITH_ARGS(TYPE, NAME, ())
 #define K_GLOBAL_STATIC_WITH_ARGS(TYPE, NAME, ARGS)                            \
Modified: trunk/qgis/src/plugins/quick_print/quickprintgui.cpp
--- trunk/qgis/src/plugins/quick_print/quickprintgui.cpp	2010-03-10 22:01:22 UTC (rev 13041)
+++ trunk/qgis/src/plugins/quick_print/quickprintgui.cpp	2010-03-10 22:19:31 UTC (rev 13042)
@@ -21,11 +21,6 @@
 #include <QPrinter>
-#endif
 //standard includes
 QuickPrintGui::QuickPrintGui( QgsMapCanvas * thepMapCanvas,
More information about the QGIS-commit mailing list
