[QGIS Commit] r13095 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Mar 20 05:08:05 EDT 2010
Author: dassau
Date: 2010-03-20 05:08:05 -0400 (Sat, 20 Mar 2010)
New Revision: 13095
   docs/trunk/english_us/user_guide/features_at_a_glance.tex
added infos about snapping settings in measure tools
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex	2010-03-20 09:01:13 UTC (rev 13094)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex	2010-03-20 09:08:05 UTC (rev 13095)
@@ -818,7 +818,9 @@
 the loaded map is defined with a geographic coordinate system
 (latitude/longitude), the results from line or area measurements will be
 incorrect. To fix this you need to set an appropriate map coordinate system
-(See Section~\ref{label_projections}).
+(See Section~\ref{label_projections}). Both measuring modules also use the
+snapping settings from the digitizing module. This is useful, if you want to
+measure along lines or areas in vector layers.
 \subsubsection{Measure length and areas}
 \index{measure:line length}
More information about the QGIS-commit mailing list
