[QGIS Commit] r13102 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Mar 20 07:43:28 EDT 2010
Author: dassau
Date: 2010-03-20 07:43:28 -0400 (Sat, 20 Mar 2010)
New Revision: 13102
   docs/trunk/english_us/user_guide/plugins_interpolation.tex
   docs/trunk/english_us/user_guide/print_composer.tex
   docs/trunk/english_us/user_guide/working_with_vector.tex
more updates from the task list
Modified: docs/trunk/english_us/user_guide/plugins_interpolation.tex
--- docs/trunk/english_us/user_guide/plugins_interpolation.tex	2010-03-20 09:54:17 UTC (rev 13101)
+++ docs/trunk/english_us/user_guide/plugins_interpolation.tex	2010-03-20 11:43:28 UTC (rev 13102)
@@ -28,7 +28,7 @@
 \begin{figure}[ht]
    \begin{center}
    \caption{Interpolation Plugin \nixcaption}\label{fig:interpolation_dialog}\smallskip
-   \includegraphics[clip=true, width=9cm]{interpolate_dialog}
+   \includegraphics[clip=true, width=14cm]{interpolate_dialog}
 \end{center}
 \end{figure}
@@ -54,7 +54,7 @@
 \begin{figure}[ht]
    \begin{center}
    \caption{Interpolation of elevp data using TIN method \nixcaption}\label{fig:interpolation_idw}\smallskip
-   \includegraphics[clip=true, width=14cm]{interpolate_tin}
+   \includegraphics[clip=true, width=10cm]{interpolate_tin}
 \end{center}
 \end{figure}
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex	2010-03-20 09:54:17 UTC (rev 13101)
+++ docs/trunk/english_us/user_guide/print_composer.tex	2010-03-20 11:43:28 UTC (rev 13102)
@@ -321,7 +321,8 @@
 \item The \textbf{Preview} field then shows all pictures stored in the
 selected directories.
 \item The \textbf{Options} area shows the current selected picture and allows
-to define width, height and clockwise rotation of the picture. Activating the
+to define width, height and clockwise rotation of the picture. It is also possible
+to add a user specific SVG path. Activating the
 \checkbox{Sync from map} checkbox synchronizes the rotation of a picture in
 the qgis map canvas (i.e. a rotated north arrow) with the appropriate print
 composer image.
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2010-03-20 09:54:17 UTC (rev 13101)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2010-03-20 11:43:28 UTC (rev 13102)
@@ -1725,7 +1725,9 @@
 attribute table allows to perform calculations on basis of existing
 attribute values or defined functions, e.g to calculate length or area
 of geometry features. The results can be written to a new attribute column
-or it can be used to update values in an already existing column.
+or it can be used to update values in an already existing column. The creation
+of new attribute fields is currently only possible in PostGIS and with OGR
+formats, if GDAL version is >= 1.6.0.
 You have to bring the vector layer in editing mode, before you can click on
 the field calculator icon to open the dialog (see Figure
More information about the QGIS-commit mailing list
