[QGIS Commit] r13107 - in docs/trunk/english_us/user_guide: . features_at_a_glance_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Mar 20 09:54:41 EDT 2010
Author: dassau
Date: 2010-03-20 09:54:41 -0400 (Sat, 20 Mar 2010)
New Revision: 13107
   docs/trunk/english_us/user_guide/features_at_a_glance_screenies/startup.png
   docs/trunk/english_us/user_guide/working_with_vector.tex
image update and description of new .qpj files
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/startup.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2010-03-20 13:32:22 UTC (rev 13106)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2010-03-20 13:54:41 UTC (rev 13107)
@@ -47,6 +47,22 @@
 Shapefiles also can include a file with a \filename{.prj} suffix, which contains
 the projection information. While it is very useful to have a projection file, it is not mandatory. A shapefile dataset can contain additional files. For further details see the ESRI technical specification at \url{http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf}.
+\minisec{Problem loading a shape .prj file}
+If you load a shapefile with \filename{.prj} file and QGIS is not
+able to read the coordinate reference system from that file, you have to define the
+proper projection manually within the \tab{General} tab of the \dialog{Layer
+Properties} dialog. This is due to the fact, that \filename{.prj} files often
+do not provide the complete projection parameters, as used in QGIS and listed in
+the \dialog{CRS} dialog.
+For that reason, if you create a new shapefile with QGIS, two different projection
+files are created. A \filename{.prj} file with limited projection parameters,
+compatible with ESRI software, and a \filename{.qpj} file, providing the complete
+parameters of the used CRS. Whenever QGIS finds a \filename{.qpj} file, it will be
+used instead of the \filename{.prj}.
 \index{shapefile!specification}.
 \subsubsection{Loading a Shapefile}\label{sec:load_shapefile}
More information about the QGIS-commit mailing list
