[QGIS Commit] r13110 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sat Mar 20 14:43:36 EDT 2010
Author: jef
Date: 2010-03-20 14:43:35 -0400 (Sat, 20 Mar 2010)
New Revision: 13110
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
hide url exclusion for Qt<4.5
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2010-03-20 17:50:00 UTC (rev 13109)
+++ trunk/qgis/src/app/qgsoptions.cpp 2010-03-20 18:43:35 UTC (rev 13110)
@@ -117,7 +117,7 @@
#if QT_VERSION < 0x40500
- mExcludeUrlListWidget->setDisabled( true );
+ grpUrlExclude->setHidden( true );
#endif
// cache settings
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2010-03-20 17:50:00 UTC (rev 13109)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2010-03-20 18:43:35 UTC (rev 13110)
@@ -165,7 +165,7 @@
<item row="0" column="1">
<widget class="QStackedWidget" name="stackedWidget">
<property name="currentIndex">
- <number>0</number>
+ <number>7</number>
</property>
<widget class="QWidget" name="stackedWidgetPage1">
<layout class="QGridLayout">
@@ -1294,7 +1294,7 @@
</property>
</widget>
</item>
- <item row="0" column="1" colspan="5">
+ <item row="0" column="1" colspan="4">
<widget class="QLineEdit" name="leProxyHost"/>
</item>
<item row="1" column="0">
@@ -1304,7 +1304,7 @@
</property>
</widget>
</item>
- <item row="1" column="1" colspan="5">
+ <item row="1" column="1" colspan="4">
<widget class="QLineEdit" name="leProxyPort"/>
</item>
<item row="2" column="0">
@@ -1314,7 +1314,7 @@
</property>
</widget>
</item>
- <item row="2" column="1" colspan="5">
+ <item row="2" column="1" colspan="4">
<widget class="QLineEdit" name="leProxyUser">
<property name="toolTip">
<string>Leave this blank if no proxy username / password are required</string>
@@ -1328,7 +1328,7 @@
</property>
</widget>
</item>
- <item row="3" column="1" colspan="5">
+ <item row="3" column="1" colspan="4">
<widget class="QLineEdit" name="leProxyPassword">
@@ -1348,7 +1348,7 @@
<item row="4" column="1" colspan="2">
<widget class="QComboBox" name="mProxyTypeComboBox"/>
</item>
- <item row="4" column="3" colspan="3">
+ <item row="4" column="3" colspan="2">
<spacer>
<property name="orientation">
<enum>Qt::Horizontal</enum>
@@ -1361,43 +1361,48 @@
</property>
</spacer>
</item>
- <item row="5" column="0" colspan="2">
- <widget class="QLabel" name="mExcludeUrlsLabel">
- <property name="text">
+ <item row="5" column="0" rowspan="2" colspan="5">
+ <widget class="QGroupBox" name="grpUrlExclude">
+ <property name="title">
<string>Exclude URLs (starting with):</string>
</property>
- </widget>
- </item>
- <item row="5" column="2" colspan="2">
- <widget class="QPushButton" name="mAddUrlPushButton">
- <string>Add</string>
+ <property name="flat">
+ <bool>true</bool>
</property>
+ <layout class="QGridLayout" name="gridLayout_5">
+ <item row="2" column="2">
+ <widget class="QPushButton" name="mRemoveUrlPushButton">
+ <property name="text">
+ <string>Remove</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0">
+ <widget class="QPushButton" name="mAddUrlPushButton">
+ <string>Add</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="0" colspan="4">
+ <widget class="QListWidget" name="mExcludeUrlListWidget"/>
+ </item>
+ <item row="2" column="1">
+ <spacer name="horizontalSpacer">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
</widget>
</item>
- <item row="5" column="4">
- <widget class="QPushButton" name="mRemoveUrlPushButton">
- <string>Remove</string>
- </property>
- </widget>
- </item>
- <item row="5" column="5">
- <spacer>
- <property name="orientation">
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>391</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="6" column="0" colspan="6">
- <widget class="QListWidget" name="mExcludeUrlListWidget"/>
- </item>
</layout>
</widget>
</item>
@@ -1540,9 +1545,6 @@
<tabstop>leProxyUser</tabstop>
<tabstop>leProxyPassword</tabstop>
<tabstop>mProxyTypeComboBox</tabstop>
- <tabstop>mAddUrlPushButton</tabstop>
- <tabstop>mRemoveUrlPushButton</tabstop>
- <tabstop>mExcludeUrlListWidget</tabstop>
<tabstop>buttonBox</tabstop>
</tabstops>
<resources>
