[QGIS Commit] r13149 - trunk/qgis/src/gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Mar 23 15:57:27 EDT 2010
Author: jef
Date: 2010-03-23 15:57:26 -0400 (Tue, 23 Mar 2010)
New Revision: 13149
   trunk/qgis/src/gui/qgsprojectionselector.cpp
more case-insensitive projection searches
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp	2010-03-23 18:42:50 UTC (rev 13148)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp	2010-03-23 19:57:26 UTC (rev 13149)
@@ -245,21 +245,21 @@
     if ( parts.size() < 2 )
       continue;
-    authParts[ parts.at( 0 )].append( parts.at( 1 ) );
+    authParts[ parts.at( 0 ).toUpper()].append( parts.at( 1 ).toUpper() );
   if ( authParts.isEmpty() )
     return sqlExpression;
-  if( authParts.size() > 0 )
+  if ( authParts.size() > 0 )
     QString prefix = " AND (";
     foreach( QString auth_name, authParts.keys() )
-      sqlExpression += QString( "%1(lower(auth_name)=lower('%2') AND auth_id IN ('%3'))" )
-                        .arg( prefix )
-                        .arg( auth_name )
-                        .arg( authParts[auth_name].join( "','" ) );
+      sqlExpression += QString( "%1(upper(auth_name)='%2' AND upper(auth_id) IN ('%3'))" )
+                       .arg( prefix )
+                       .arg( auth_name )
+                       .arg( authParts[auth_name].join( "','" ) );
       prefix = " OR ";
     sqlExpression += ")";
@@ -620,7 +620,7 @@
 QString QgsProjectionSelector::selectedAuthId()
-  return getSelectedExpression( "auth_name||':'||auth_id" );
+  return getSelectedExpression( "upper(auth_name||':'||auth_id)" );
@@ -788,7 +788,7 @@
   // Set up the query to retrieve the projection information needed to populate the list
   //note I am giving the full field names for clarity here and in case someone
   //changes the underlying view TS
-  sql = QString( "select description, srs_id, auth_name||':'||auth_id, is_geo, name, parameters, deprecated from vw_srs where %1 order by name,description" )
+  sql = QString( "select description, srs_id, upper(auth_name||':'||auth_id), is_geo, name, parameters, deprecated from vw_srs where %1 order by name,description" )
         .arg( sqlFilter );
   rc = sqlite3_prepare( db, sql.toUtf8(), sql.toUtf8().length(), &ppStmt, &pzTail );
@@ -897,24 +897,24 @@
 void QgsProjectionSelector::hideDeprecated( QTreeWidgetItem *item )
-  if( item->data( 0, Qt::UserRole ).toBool() )
+  if ( item->data( 0, Qt::UserRole ).toBool() )
     item->setHidden( cbxHideDeprecated->isChecked() );
-    if( item->isSelected() && item->isHidden() )
+    if ( item->isSelected() && item->isHidden() )
       teProjection->setText( "" );
       item->setSelected( false );
-  for( int i=0; i < item->childCount(); i++ )
-    hideDeprecated( item->child(i) );
+  for ( int i = 0; i < item->childCount(); i++ )
+    hideDeprecated( item->child( i ) );
 void QgsProjectionSelector::on_cbxHideDeprecated_stateChanged()
-  for( int i = 0; i<lstCoordinateSystems->topLevelItemCount(); i++ )
-    hideDeprecated( lstCoordinateSystems->topLevelItem(i) );
+  for ( int i = 0; i < lstCoordinateSystems->topLevelItemCount(); i++ )
+    hideDeprecated( lstCoordinateSystems->topLevelItem( i ) );
 void QgsProjectionSelector::on_pbnPopular1_clicked()
@@ -946,14 +946,14 @@
   QString mySql;
   if ( radAuthId->isChecked() )
-    mySql = QString( "select srs_id from tbl_srs where auth_name||':'||auth_id='%1'" ).arg( mySearchString );
+    mySql = QString( "select srs_id from tbl_srs where upper(auth_name||':'||auth_id)='%1'" ).arg( mySearchString.toUpper() );
   else if ( radName->isChecked() ) //name search
     //we need to find what the largest srsid matching our query so we know whether to
     //loop backto the beginning
-    mySql = "select srs_id from tbl_srs where description like '%" + mySearchString + "%'";
-    if( cbxHideDeprecated->isChecked() )
+    mySql = "select srs_id from tbl_srs where upper(description) like '%" + mySearchString.toUpper() + "%'";
+    if ( cbxHideDeprecated->isChecked() )
       mySql += " and not deprecated";
     mySql += " order by srs_id desc limit 1";
     long myLargestSrsId = getLargestCRSIDMatch( mySql );
@@ -963,16 +963,16 @@
     if ( myLargestSrsId <= selectedCrsId() )
       //roll search around to the beginning
       mySql += " order by srs_id limit 1";
     else
       // search ahead of the current position
       mySql += " and srs_id > " + QString::number( selectedCrsId() ) + " order by srs_id limit 1";
More information about the QGIS-commit mailing list
