[QGIS Commit] r13418 - in trunk/qgis: python/core src/core
src/core/composer
svn_qgis at osgeo.org
Tue May 4 04:48:43 EDT 2010
Author: wonder
Date: 2010-05-04 04:48:43 -0400 (Tue, 04 May 2010)
New Revision: 13418
trunk/qgis/python/core/qgsrendercontext.sip
trunk/qgis/src/core/composer/qgscomposermap.cpp
trunk/qgis/src/core/qgsrendercontext.cpp
trunk/qgis/src/core/qgsrendercontext.h
Do not force vector output by default (use only in composer map), enable setting of the flag
Modified: trunk/qgis/python/core/qgsrendercontext.sip
--- trunk/qgis/python/core/qgsrendercontext.sip 2010-05-03 21:02:05 UTC (rev 13417)
+++ trunk/qgis/python/core/qgsrendercontext.sip 2010-05-04 08:48:43 UTC (rev 13418)
@@ -47,6 +47,8 @@
void setRasterScaleFactor(double factor);
void setRendererScale( double scale );
void setPainter(QPainter* p);
+ //! Added in QGIS v1.5
+ void setForceVectorOutput( bool force );
//! Added in QGIS v1.4
void setLabelingEngine(QgsLabelingEngineInterface* iface);
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp 2010-05-03 21:02:05 UTC (rev 13417)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp 2010-05-04 08:48:43 UTC (rev 13418)
@@ -142,6 +142,9 @@
theRendererContext->setRenderingStopped( false );
+ // force vector output (no caching of marker images etc.)
+ theRendererContext->setForceVectorOutput( true );
//force composer map scale for scale dependent visibility
double bk_scale = theMapRenderer.scale();
theMapRenderer.setScale( scale() );
Modified: trunk/qgis/src/core/qgsrendercontext.cpp
--- trunk/qgis/src/core/qgsrendercontext.cpp 2010-05-03 21:02:05 UTC (rev 13417)
+++ trunk/qgis/src/core/qgsrendercontext.cpp 2010-05-04 08:48:43 UTC (rev 13418)
@@ -22,7 +22,7 @@
: mPainter( 0 ),
mCoordTransform( 0 ),
mDrawEditingInformation( false ),
- mForceVectorOutput( true ),
+ mForceVectorOutput( false ),
mRenderingStopped( false ),
mScaleFactor( 1.0 ),
mRasterScaleFactor( 1.0 ),
Modified: trunk/qgis/src/core/qgsrendercontext.h
--- trunk/qgis/src/core/qgsrendercontext.h 2010-05-03 21:02:05 UTC (rev 13417)
+++ trunk/qgis/src/core/qgsrendercontext.h 2010-05-04 08:48:43 UTC (rev 13418)
@@ -75,6 +75,8 @@
void setRasterScaleFactor( double factor ) {mRasterScaleFactor = factor;}
void setRendererScale( double scale ) {mRendererScale = scale;}
void setPainter( QPainter* p ) {mPainter = p;}
+ void setForceVectorOutput( bool force ) {mForceVectorOutput = force;}
void setLabelingEngine( QgsLabelingEngineInterface* iface ) { mLabelingEngine = iface; }
