[QGIS Commit] r13433 - in trunk/qgis: python/core src/core
svn_qgis at osgeo.org
Fri May 7 04:39:41 EDT 2010
Author: wonder
Date: 2010-05-07 04:39:37 -0400 (Fri, 07 May 2010)
New Revision: 13433
trunk/qgis/python/core/qgssearchtreenode.sip
trunk/qgis/src/core/qgssearchtreenode.cpp
trunk/qgis/src/core/qgssearchtreenode.h
Added optional geometry parameter when evaluating predicates
Modified: trunk/qgis/python/core/qgssearchtreenode.sip
--- trunk/qgis/python/core/qgssearchtreenode.sip 2010-05-06 20:12:59 UTC (rev 13432)
+++ trunk/qgis/python/core/qgssearchtreenode.sip 2010-05-07 08:39:37 UTC (rev 13433)
@@ -90,7 +90,8 @@
QString makeSearchString();
//! checks whether the node tree is valid against supplied attributes
- bool checkAgainst( const QMap<int,QgsField>& fields, const QMap<int, QVariant>& attributes );
+ //! @note optional geom parameter added in 1.5
+ bool checkAgainst( const QMap<int,QgsField>& fields, const QMap<int, QVariant>& attributes, QgsGeometry* geom = 0 );
//! checks if there were errors during evaluation
bool hasError();
@@ -99,6 +100,7 @@
const QString& errorMsg();
//! wrapper around valueAgainst()
+ //! @note added in 1.4
bool getValue( QgsSearchTreeValue& value /Out/, QgsSearchTreeNode* node,
const QMap<int,QgsField>& fields, const QMap<int,QVariant>& attributes, QgsGeometry* geom = 0 );
Modified: trunk/qgis/src/core/qgssearchtreenode.cpp
--- trunk/qgis/src/core/qgssearchtreenode.cpp 2010-05-06 20:12:59 UTC (rev 13432)
+++ trunk/qgis/src/core/qgssearchtreenode.cpp 2010-05-07 08:39:37 UTC (rev 13433)
@@ -250,7 +250,7 @@
-bool QgsSearchTreeNode::checkAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes )
+bool QgsSearchTreeNode::checkAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes, QgsGeometry* geom )
QgsDebugMsgLevel( "checkAgainst: " + makeSearchString(), 2 );
@@ -269,21 +269,21 @@
switch ( mOp )
case opNOT:
- return !mLeft->checkAgainst( fields, attributes );
+ return !mLeft->checkAgainst( fields, attributes, geom );
case opAND:
- if ( !mLeft->checkAgainst( fields, attributes ) )
+ if ( !mLeft->checkAgainst( fields, attributes, geom ) )
return false;
- return mRight->checkAgainst( fields, attributes );
+ return mRight->checkAgainst( fields, attributes, geom );
case opOR:
- if ( mLeft->checkAgainst( fields, attributes ) )
+ if ( mLeft->checkAgainst( fields, attributes, geom ) )
return true;
case opISNULL:
case opISNOTNULL:
- if ( !getValue( value1, mLeft, fields, attributes ) )
+ if ( !getValue( value1, mLeft, fields, attributes, geom ) )
return false;
if ( mOp == opISNULL )
@@ -302,7 +302,7 @@
case opGE:
case opLE:
- if ( !getValue( value1, mLeft, fields, attributes ) || !getValue( value2, mRight, fields, attributes ) )
+ if ( !getValue( value1, mLeft, fields, attributes, geom ) || !getValue( value2, mRight, fields, attributes, geom ) )
return false;
if ( value1.isNull() || value2.isNull() )
@@ -329,8 +329,8 @@
case opRegexp:
case opLike:
- !getValue( value2, mRight, fields, attributes ) )
+ !getValue( value2, mRight, fields, attributes, geom ) )
return false;
// value1 is string to be matched
Modified: trunk/qgis/src/core/qgssearchtreenode.h
--- trunk/qgis/src/core/qgssearchtreenode.h 2010-05-06 20:12:59 UTC (rev 13432)
+++ trunk/qgis/src/core/qgssearchtreenode.h 2010-05-07 08:39:37 UTC (rev 13433)
@@ -127,7 +127,8 @@
- bool checkAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes );
+ bool checkAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes, QgsGeometry* geom = 0 );
bool hasError() { return ( !mError.isEmpty() ); }
@@ -136,6 +137,7 @@
const QString& errorMsg() { return mError; }
bool getValue( QgsSearchTreeValue& value, QgsSearchTreeNode* node,
