[QGIS Commit] r13441 - trunk/qgis/src/plugins/spatialquery
svn_qgis at osgeo.org
Sat May 8 15:07:13 EDT 2010
Author: jef
Date: 2010-05-08 15:07:12 -0400 (Sat, 08 May 2010)
New Revision: 13441
trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui
apply #2634
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp 2010-05-08 15:53:24 UTC (rev 13440)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp 2010-05-08 19:07:12 UTC (rev 13441)
@@ -190,6 +190,7 @@
buttonBox->button( QDialogButtonBox::Close )->show();
buttonBox->button( QDialogButtonBox::Cancel )->hide();
buttonBox->button( QDialogButtonBox::Ok )->hide();
+ adjustSize();
} // void QgsSpatialQueryDialog::runQuery()
void QgsSpatialQueryDialog::setInputsVisible( bool show )
@@ -586,8 +587,19 @@
void QgsSpatialQueryDialog::on_buttonBox_rejected()
- reject();
+ if ( grpResults->isHidden() )
+ reject();
+ else
+ grpResults->hide();
+ setInputsVisible( true );
+ progressBarStatus->show();
+ buttonBox->button( QDialogButtonBox::Close )->hide();
+ buttonBox->button( QDialogButtonBox::Cancel )->show();
+ buttonBox->button( QDialogButtonBox::Ok )->show();
} // void QgsSpatialQueryDialog::on_buttonBox_rejected()
void QgsSpatialQueryDialog::on_targetLayerComboBox_currentIndexChanged( int index )
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui 2010-05-08 15:53:24 UTC (rev 13440)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui 2010-05-08 19:07:12 UTC (rev 13441)
@@ -315,22 +315,4 @@
</layout>
</widget>
<resources/>
- <connections>
- <connection>
- <sender>buttonBox</sender>
- <signal>rejected()</signal>
- <receiver>QgsSpatialQueryDialogBase</receiver>
- <slot>reject()</slot>
- <hints>
- <hint type="sourcelabel">
- <x>288</x>
- <y>438</y>
- </hint>
- <hint type="destinationlabel">
- <x>292</x>
- <y>459</y>
- </hint>
- </hints>
- </connection>
- </connections>
</ui>
