[QGIS Commit] r13447 - in trunk/qgis: python python/core src/core src/plugins/spatialquery
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat May 8 20:45:18 EDT 2010
Author: jef
Date: 2010-05-08 20:45:17 -0400 (Sat, 08 May 2010)
New Revision: 13447
   trunk/qgis/python/CMakeLists.txt
   trunk/qgis/python/core/qgsnetworkaccessmanager.sip
   trunk/qgis/src/core/qgsnetworkaccessmanager.cpp
   trunk/qgis/src/core/qgsnetworkaccessmanager.h
   trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp
resolve Qt 4.5 dependency
Modified: trunk/qgis/python/CMakeLists.txt
--- trunk/qgis/python/CMakeLists.txt	2010-05-08 23:50:32 UTC (rev 13446)
+++ trunk/qgis/python/CMakeLists.txt	2010-05-09 00:45:17 UTC (rev 13447)
@@ -35,6 +35,10 @@
   ADD_DEFINITIONS(-DNOMINMAX)
 ENDIF(MSVC)
+MATH(EXPR QT_VERSION "${QT_VERSION_MAJOR}*10000 + ${QT_VERSION_MINOR}*100")
+IF(QT_VERSION LESS 40500)
+  SET(SIP_DISABLE_FEATURES ${SIP_DISABLE_FEATURES} PROXY_FACTORY)
+ENDIF(QT_VERSION LESS 40500)
 # core module
 FILE(GLOB sip_files_core core/*.sip)
Modified: trunk/qgis/python/core/qgsnetworkaccessmanager.sip
--- trunk/qgis/python/core/qgsnetworkaccessmanager.sip	2010-05-08 23:50:32 UTC (rev 13446)
+++ trunk/qgis/python/core/qgsnetworkaccessmanager.sip	2010-05-09 00:45:17 UTC (rev 13447)
@@ -16,29 +16,31 @@
+%Feature PROXY_FACTORY
 class QgsNetworkAccessManager : QNetworkAccessManager
 %TypeHeaderCode
 #include <qgsnetworkaccessmanager.h>
 %End
-    //! returns a point to the single instance
+  public:
+    //! returns a pointer to the single instance
     // and creates that instance on the first call.
     static QgsNetworkAccessManager *instance();
     //! destructor
     ~QgsNetworkAccessManager();
+%If (PROXY_FACTORY)
     //! insert a factory into the proxy factories list
     void insertProxyFactory(QNetworkProxyFactory *factory /TransferTo/);
     //! remove a factory from the proxy factories list
     void removeProxyFactory(QNetworkProxyFactory *factory /TransferBack/);
-    //! retrieve proxy factory list
-    void setDiskCache( QString directory, qint64 size );
     //! retrieve fall back proxy (for urls that no factory returned proxies for)
     const QList<QNetworkProxyFactory *> proxyFactories() const;
+%End
     //! retrieve exclude list (urls shouldn't use the fallback proxy)
     const QStringList &excludeList() const;
Modified: trunk/qgis/src/core/qgsnetworkaccessmanager.cpp
--- trunk/qgis/src/core/qgsnetworkaccessmanager.cpp	2010-05-08 23:50:32 UTC (rev 13446)
+++ trunk/qgis/src/core/qgsnetworkaccessmanager.cpp	2010-05-09 00:45:17 UTC (rev 13447)
@@ -25,6 +25,7 @@
 #include <QUrl>
+#if QT_VERSION >= 0x40500
 class QgsNetworkProxyFactory : public QNetworkProxyFactory
   public:
@@ -62,6 +63,7 @@
       return QList<QNetworkProxy>() << nam->fallbackProxy();
+#endif
 QgsNetworkAccessManager *QgsNetworkAccessManager::smNAM = 0;
@@ -78,13 +80,16 @@
 QgsNetworkAccessManager::QgsNetworkAccessManager( QObject *parent )
     : QNetworkAccessManager( parent )
   setProxyFactory( new QgsNetworkProxyFactory() );
+#endif
 QgsNetworkAccessManager::~QgsNetworkAccessManager()
 void QgsNetworkAccessManager::insertProxyFactory( QNetworkProxyFactory *factory )
   mProxyFactories.insert( 0, factory );
@@ -99,6 +104,7 @@
   return mProxyFactories;
+#endif
 const QStringList &QgsNetworkAccessManager::excludeList() const
Modified: trunk/qgis/src/core/qgsnetworkaccessmanager.h
--- trunk/qgis/src/core/qgsnetworkaccessmanager.h	2010-05-08 23:50:32 UTC (rev 13446)
+++ trunk/qgis/src/core/qgsnetworkaccessmanager.h	2010-05-09 00:45:17 UTC (rev 13447)
@@ -46,13 +46,14 @@
     Q_OBJECT
   public:
     //! destructor
     void insertProxyFactory( QNetworkProxyFactory *factory );
@@ -61,6 +62,7 @@
+#endif
     const QNetworkProxy &fallbackProxy() const;
@@ -73,7 +75,9 @@
   private:
     QgsNetworkAccessManager( QObject *parent = 0 );
     QList<QNetworkProxyFactory*> mProxyFactories;
+#endif
     QNetworkProxy mFallbackProxy;
     QStringList mExcludedURLs;
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp	2010-05-08 23:50:32 UTC (rev 13446)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp	2010-05-09 00:45:17 UTC (rev 13447)
@@ -239,6 +239,9 @@
     case Intersects:
       operation = &QgsGeometry::intersects;
       break;
+    default:
+      qWarning( "undefined operation" );
+      return;
   // Transform referencer Target = Reference
More information about the QGIS-commit mailing list
