[QGIS Commit] r13459 - in trunk/qgis/src: app plugins/spit
providers/ogr
svn_qgis at osgeo.org
Mon May 10 09:01:48 EDT 2010
Author: mhugent
Date: 2010-05-10 09:01:47 -0400 (Mon, 10 May 2010)
New Revision: 13459
trunk/qgis/src/app/qgsconfigureshortcutsdialog.cpp
trunk/qgis/src/app/qgsspatialitesourceselect.cpp
trunk/qgis/src/plugins/spit/qgsspit.cpp
trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
Consider also files without extensions in the file dialog filters
Modified: trunk/qgis/src/app/qgsconfigureshortcutsdialog.cpp
--- trunk/qgis/src/app/qgsconfigureshortcutsdialog.cpp 2010-05-10 13:00:39 UTC (rev 13458)
+++ trunk/qgis/src/app/qgsconfigureshortcutsdialog.cpp 2010-05-10 13:01:47 UTC (rev 13459)
@@ -73,7 +73,7 @@
void QgsConfigureShortcutsDialog::saveShortcuts()
- QString fileName = QFileDialog::getSaveFileName( this, tr( "Save shortcuts" ), ".", tr( "XML file (*.xml);; All files (*.*)" ) );
+ QString fileName = QFileDialog::getSaveFileName( this, tr( "Save shortcuts" ), ".", tr( "XML file (*.xml);; All files (*)" ) );
if ( fileName.isEmpty() )
return;
@@ -125,7 +125,7 @@
void QgsConfigureShortcutsDialog::loadShortcuts()
- QString fileName = QFileDialog::getOpenFileName( this, tr( "Load shortcuts" ), ".", tr( "XML file (*.xml);; All files (*.*)" ) );
+ QString fileName = QFileDialog::getOpenFileName( this, tr( "Load shortcuts" ), ".", tr( "XML file (*.xml);; All files (*)" ) );
Modified: trunk/qgis/src/app/qgsspatialitesourceselect.cpp
--- trunk/qgis/src/app/qgsspatialitesourceselect.cpp 2010-05-10 13:00:39 UTC (rev 13458)
+++ trunk/qgis/src/app/qgsspatialitesourceselect.cpp 2010-05-10 13:01:47 UTC (rev 13459)
@@ -300,7 +300,7 @@
QString myFile = QFileDialog::getOpenFileName( this,
tr( "Choose a SpatiaLite/SQLite DB to open" ),
- lastUsedDir, QObject::tr( "SQLite DB (*.sqlite *.db);;All files (*.*)" ) );
+ lastUsedDir, QObject::tr( "SQLite DB (*.sqlite *.db);;All files (*)" ) );
if ( myFile.isEmpty() )
return;
Modified: trunk/qgis/src/plugins/spit/qgsspit.cpp
--- trunk/qgis/src/plugins/spit/qgsspit.cpp 2010-05-10 13:00:39 UTC (rev 13458)
+++ trunk/qgis/src/plugins/spit/qgsspit.cpp 2010-05-10 13:01:47 UTC (rev 13459)
@@ -161,7 +161,7 @@
QgsEncodingFileDialog dlg( this,
tr( "Add Shapefiles" ),
settings.value( "/Plugin-Spit/last_directory" ).toString(),
- tr( "Shapefiles (*.shp);;All files (*.*)" ),
+ tr( "Shapefiles (*.shp);;All files (*)" ),
settings.value( "/Plugin-Spit/last_encoding" ).toString() );
dlg.setFileMode( QFileDialog::ExistingFiles );
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2010-05-10 13:00:39 UTC (rev 13458)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2010-05-10 13:01:47 UTC (rev 13459)
@@ -1373,7 +1373,7 @@
// can't forget the default case
- myFileFilters += "All files (*.*)";
+ myFileFilters += "All files (*)";
if ( type == "file" )
