[QGIS Commit] r13473 - in trunk/qgis: cmake debian python
src/core/symbology-ng
svn_qgis at osgeo.org
Thu May 13 04:58:57 EDT 2010
Author: jef
Date: 2010-05-13 04:58:55 -0400 (Thu, 13 May 2010)
New Revision: 13473
trunk/qgis/cmake/FindPyQt4.cmake
trunk/qgis/debian/changelog
trunk/qgis/debian/control
trunk/qgis/python/CMakeLists.txt
trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
make PyQt4 detection work with CMake 2.6.0 as found in Debian lenny
Modified: trunk/qgis/cmake/FindPyQt4.cmake
--- trunk/qgis/cmake/FindPyQt4.cmake 2010-05-12 22:53:01 UTC (rev 13472)
+++ trunk/qgis/cmake/FindPyQt4.cmake 2010-05-13 08:58:55 UTC (rev 13473)
@@ -22,10 +22,10 @@
# PYQT4_SIP_FLAGS - The SIP flags used to build PyQt.
-IF(EXISTS PYQT4_VERSION)
+IF(EXISTS PYQT4_VERSION_STR)
# Already in cache, be silent
SET(PYQT4_FOUND TRUE)
-ELSE(EXISTS PYQT4_VERSION)
+ELSE(EXISTS PYQT4_VERSION_STR)
FIND_FILE(_find_pyqt_py FindPyQt.py PATHS ${CMAKE_MODULE_PATH})
@@ -50,4 +50,10 @@
ENDIF(PYQT4_FIND_REQUIRED)
ENDIF(PYQT4_FOUND)
-ENDIF(EXISTS PYQT4_VERSION)
+ENDIF(EXISTS PYQT4_VERSION_STR)
+STRING(REGEX REPLACE "^([0-9]*)\\.[0-9]*\\.[0-9]*$" "\\1" PYQT4_MAJOR_VERSION ${PYQT4_VERSION_STR})
+STRING(REGEX REPLACE "^[0-9]*\\.([0-9]*)\\.[0-9]*$" "\\1" PYQT4_MINOR_VERSION ${PYQT4_VERSION_STR})
+STRING(REGEX REPLACE "^[0-9]*\\.[0-9]*\\.([0-9]*)$" "\\1" PYQT4_PATCH_VERSION ${PYQT4_VERSION_STR})
+MATH( EXPR PYQT4_NUM_VERSION "${PYQT4_MAJOR_VERSION}*10000 + ${PYQT4_MINOR_VERSION}*100 + ${PYQT4_PATCH_VERSION}")
Modified: trunk/qgis/debian/changelog
--- trunk/qgis/debian/changelog 2010-05-12 22:53:01 UTC (rev 13472)
+++ trunk/qgis/debian/changelog 2010-05-13 08:58:55 UTC (rev 13473)
@@ -2,15 +2,15 @@
* new development version after 1.5 branch
* adapted Francesco Paolo Lovergine's updates to Debian qgis 1.4 package
- * require CMake >2.6 and Qt 4.4 for sid
+ * require CMake >2.6 and Qt 4.4
* remove circular dependencies
* integrate new GRASS raster provider and remove dependency to
libgdal1-$VERSION-grass
* add spatialquery plugin
* include qgis.g.browser in grass plugin
- * drop symbol tracking, C++ ABIs change too frequently
+ * drop symbol tracking as C++ ABIs change too frequently
- -- Jürgen E. Fischer <jef at norbit.de> Sat, 08 May 2010 13:26:13 +0200
+ -- Jürgen E. Fischer <jef at norbit.de> Thu, 13 May 2010 10:54:06 +0200
qgis (1.4.0) UNRELEASED; urgency=low
Modified: trunk/qgis/debian/control
--- trunk/qgis/debian/control 2010-05-12 22:53:01 UTC (rev 13472)
+++ trunk/qgis/debian/control 2010-05-13 08:58:55 UTC (rev 13473)
@@ -3,7 +3,7 @@
Priority: extra
Maintainer: Quantum GIS developers <qgis-developer at lists.osgeo.org>
Build-Depends: debhelper (>= 7), libgdal1-dev, libpq-dev,
- libgeos-dev (>= 3.0.0), grass-dev, libsqlite3-dev, libgsl0-dev, libproj-dev, libexpat1-dev,
+ libgeos-dev (>= 3.0.0), grass-dev, libsqlite3-dev, libgsl0-dev, proj (< 4.7.0) | libproj-dev (>= 4.7.0), libexpat1-dev,
flex, bison, python-dev, cmake (>= 2.6), python-sip4 (>= 4.5.0), python-central (>=0.5), python,
sharutils, sip4 (>= 4.5), libqt4-core (>=4.4.0), libqt4-dev (>=4.4.0), libqt4-gui (>=4.4.0),
libqt4-sql (>=4.4.0), python-qt4 (>=4.1.0), python-qt4-dev (>=4.1.0),
Modified: trunk/qgis/python/CMakeLists.txt
--- trunk/qgis/python/CMakeLists.txt 2010-05-12 22:53:01 UTC (rev 13472)
+++ trunk/qgis/python/CMakeLists.txt 2010-05-13 08:58:55 UTC (rev 13473)
@@ -35,9 +35,9 @@
ADD_DEFINITIONS(-DNOMINMAX)
ENDIF(MSVC)
-IF(${PYQT4_VERSION_STR} VERSION_LESS "4.6.0")
+IF(${PYQT4_NUM_VERSION} LESS 40600)
SET(SIP_DISABLE_FEATURES ${SIP_DISABLE_FEATURES} PROXY_FACTORY)
-ENDIF(${PYQT4_VERSION_STR} VERSION_LESS "4.6.0")
+ENDIF(${PYQT4_NUM_VERSION} LESS 40600)
# core module
FILE(GLOB sip_files_core core/*.sip)
Modified: trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp 2010-05-12 22:53:01 UTC (rev 13472)
+++ trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp 2010-05-13 08:58:55 UTC (rev 13473)
@@ -342,7 +342,7 @@
QMatrix transform;
- bool hasDataDefinedRotation = context.renderHints() & QgsSymbolV2::DataDefinedRotation;
+ // bool hasDataDefinedRotation = context.renderHints() & QgsSymbolV2::DataDefinedRotation;
bool hasDataDefinedSize = context.renderHints() & QgsSymbolV2::DataDefinedSizeScale;
// move to the desired position
