[QGIS Commit] r13480 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu May 13 18:52:11 EDT 2010
Author: cfarmer
Date: 2010-05-13 18:52:11 -0400 (Thu, 13 May 2010)
New Revision: 13480
   trunk/qgis/python/plugins/fTools/tools/frmJoinAttributes.ui
Quick typo fix.
Modified: trunk/qgis/python/plugins/fTools/tools/frmJoinAttributes.ui
--- trunk/qgis/python/plugins/fTools/tools/frmJoinAttributes.ui	2010-05-13 22:48:49 UTC (rev 13479)
+++ trunk/qgis/python/plugins/fTools/tools/frmJoinAttributes.ui	2010-05-13 22:52:11 UTC (rev 13480)
@@ -1,102 +1,103 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>Dialog</class>
- <widget class="QDialog" name="Dialog" >
-  <property name="windowModality" >
+ <widget class="QDialog" name="Dialog">
+  <property name="windowModality">
    <enum>Qt::NonModal</enum>
   </property>
-  <property name="geometry" >
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>377</width>
+    <width>417</width>
     <height>562</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Join Attributes</string>
   </property>
-  <property name="sizeGripEnabled" >
+  <property name="sizeGripEnabled">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout" name="gridLayout" >
-   <item row="0" column="0" colspan="2" >
-    <layout class="QVBoxLayout" >
+  <layout class="QGridLayout" name="gridLayout">
+   <item row="0" column="0" colspan="2">
+    <layout class="QVBoxLayout">
      <item>
-      <widget class="QLabel" name="label_3" >
-       <property name="text" >
+      <widget class="QLabel" name="label_3">
+       <property name="text">
         <string>Target vector layer</string>
        </property>
       </widget>
      </item>
      <item>
-      <widget class="QComboBox" name="inShape" />
+      <widget class="QComboBox" name="inShape"/>
      </item>
     </layout>
    </item>
-   <item row="1" column="0" colspan="2" >
+   <item row="1" column="0" colspan="2">
      <item>
-      <widget class="QLabel" name="label_4" >
+      <widget class="QLabel" name="label_4">
         <string>Target join field</string>
        </property>
       </widget>
      </item>
      <item>
-      <widget class="QComboBox" name="inField" />
+      <widget class="QComboBox" name="inField"/>
      </item>
     </layout>
    </item>
-   <item row="2" column="0" colspan="2" >
-    <widget class="QGroupBox" name="groupBox" >
-     <property name="title" >
+   <item row="2" column="0" colspan="2">
+    <widget class="QGroupBox" name="groupBox">
+     <property name="title">
       <string>Join data</string>
      </property>
-     <layout class="QGridLayout" >
-      <item row="0" column="0" >
+     <layout class="QGridLayout">
+      <item row="0" column="0">
         <item>
-         <widget class="QRadioButton" name="rdoVector" >
+         <widget class="QRadioButton" name="rdoVector">
            <string>Join vector layer</string>
           </property>
-          <property name="checked" >
+          <property name="checked">
            <bool>true</bool>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QComboBox" name="joinShape" />
+         <widget class="QComboBox" name="joinShape"/>
         </item>
        </layout>
       </item>
-      <item row="1" column="0" >
+      <item row="1" column="0">
         <item>
-         <widget class="QRadioButton" name="rdoTable" >
+         <widget class="QRadioButton" name="rdoTable">
            <string>Join dbf table</string>
           </property>
          </widget>
         </item>
         <item>
-         <layout class="QHBoxLayout" >
+         <layout class="QHBoxLayout">
           <item>
-           <widget class="QLineEdit" name="inTable" >
-            <property name="enabled" >
+           <widget class="QLineEdit" name="inTable">
+            <property name="enabled">
              <bool>false</bool>
             </property>
-            <property name="readOnly" >
+            <property name="readOnly">
              <bool>true</bool>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QToolButton" name="toolTable" >
+           <widget class="QToolButton" name="toolTable">
              <bool>false</bool>
             </property>
              <string>Browse</string>
             </property>
            </widget>
@@ -105,44 +106,44 @@
         </item>
        </layout>
       </item>
-      <item row="2" column="0" >
+      <item row="2" column="0">
         <item>
-         <widget class="QLabel" name="label_6" >
+         <widget class="QLabel" name="label_6">
            <string>Join field</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QComboBox" name="joinField" />
+         <widget class="QComboBox" name="joinField"/>
         </item>
        </layout>
       </item>
      </layout>
     </widget>
    </item>
-   <item row="3" column="0" colspan="2" >
+   <item row="3" column="0" colspan="2">
      <item>
-      <widget class="QLabel" name="label_2" >
+      <widget class="QLabel" name="label_2">
         <string>Output Shapefile</string>
        </property>
       </widget>
      </item>
      <item>
        <item>
-        <widget class="QLineEdit" name="outShape" >
+        <widget class="QLineEdit" name="outShape">
           <bool>true</bool>
          </property>
         </widget>
        </item>
        <item>
-        <widget class="QToolButton" name="toolOut" >
+        <widget class="QToolButton" name="toolOut">
          </property>
         </widget>
@@ -151,51 +152,51 @@
      </item>
     </layout>
    </item>
-   <item row="4" column="0" colspan="2" >
-    <widget class="QGroupBox" name="groupBox_2" >
+   <item row="4" column="0" colspan="2">
+    <widget class="QGroupBox" name="groupBox_2">
       <string>Output table</string>
      </property>
-       <widget class="QRadioButton" name="rdoMatch" >
+       <widget class="QRadioButton" name="rdoMatch">
          <string>Only keep matching records</string>
         </property>
          <bool>true</bool>
         </property>
        </widget>
       </item>
-       <widget class="QRadioButton" name="rdoKeep" >
-         <string>Keep all records (includeing non-matching target records)</string>
+       <widget class="QRadioButton" name="rdoKeep">
+         <string>Keep all records (including non-matching target records)</string>
         </property>
        </widget>
       </item>
      </layout>
     </widget>
    </item>
-   <item row="5" column="0" >
-    <widget class="QProgressBar" name="progressBar" >
-     <property name="value" >
+   <item row="5" column="0">
+    <widget class="QProgressBar" name="progressBar">
+     <property name="value">
       <number>0</number>
      </property>
-     <property name="alignment" >
+     <property name="alignment">
       <set>Qt::AlignCenter</set>
      </property>
-     <property name="textVisible" >
+     <property name="textVisible">
       <bool>true</bool>
      </property>
     </widget>
    </item>
-   <item row="5" column="1" >
-    <widget class="QDialogButtonBox" name="buttonBox_2" >
-     <property name="orientation" >
+   <item row="5" column="1">
+    <widget class="QDialogButtonBox" name="buttonBox_2">
+     <property name="orientation">
       <enum>Qt::Horizontal</enum>
      </property>
-     <property name="standardButtons" >
+     <property name="standardButtons">
       <set>QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
      </property>
     </widget>
@@ -210,11 +211,11 @@
    <receiver>Dialog</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>133</x>
      <y>512</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>215</x>
      <y>290</y>
     </hint>
@@ -226,11 +227,11 @@
    <slot>close()</slot>
    <hints>
      <x>59</x>
      <y>512</y>
     </hint>
      <x>132</x>
      <y>239</y>
     </hint>
@@ -242,11 +243,11 @@
    <receiver>joinField</receiver>
    <slot>clear()</slot>
    <hints>
      <x>68</x>
      <y>226</y>
     </hint>
      <x>47</x>
      <y>305</y>
     </hint>
@@ -258,11 +259,11 @@
    <hints>
      <x>107</x>
      <y>162</y>
     </hint>
      <x>104</x>
      <y>309</y>
     </hint>
@@ -274,11 +275,11 @@
    <receiver>joinShape</receiver>
    <slot>setEnabled(bool)</slot>
    <hints>
      <x>222</x>
      <y>164</y>
     </hint>
      <x>226</x>
      <y>186</y>
     </hint>
@@ -290,11 +291,11 @@
    <receiver>inTable</receiver>
    <hints>
      <x>91</x>
      <y>227</y>
     </hint>
      <x>91</x>
      <y>255</y>
     </hint>
@@ -306,11 +307,11 @@
    <receiver>toolTable</receiver>
    <hints>
      <x>281</x>
      <y>227</y>
     </hint>
      <x>332</x>
      <y>256</y>
     </hint>
More information about the QGIS-commit mailing list
