[QGIS Commit] r13489 - in trunk/qgis: cmake python
src/providers/grass
svn_qgis at osgeo.org
Sat May 15 04:21:44 EDT 2010
Author: jef
Date: 2010-05-15 04:21:42 -0400 (Sat, 15 May 2010)
New Revision: 13489
trunk/qgis/cmake/FindPyQt.py
trunk/qgis/cmake/FindPyQt4.cmake
trunk/qgis/python/CMakeLists.txt
trunk/qgis/src/providers/grass/qgis.g.info.c
trunk/qgis/src/providers/grass/qgsgrass.cpp
working fix for #2670 and fix for GRASS 6.2 support (as found on debian lenny)
Modified: trunk/qgis/cmake/FindPyQt.py
--- trunk/qgis/cmake/FindPyQt.py 2010-05-15 07:28:28 UTC (rev 13488)
+++ trunk/qgis/cmake/FindPyQt.py 2010-05-15 08:21:42 UTC (rev 13489)
@@ -6,6 +6,7 @@
pyqtcfg = PyQt4.pyqtconfig.Configuration()
print("pyqt_version:%06.0x" % pyqtcfg.pyqt_version)
+print("pyqt_version_num:%d" % pyqtcfg.pyqt_version)
print("pyqt_version_str:%s" % pyqtcfg.pyqt_version_str)
pyqt_version_tag = ""
Modified: trunk/qgis/cmake/FindPyQt4.cmake
--- trunk/qgis/cmake/FindPyQt4.cmake 2010-05-15 07:28:28 UTC (rev 13488)
+++ trunk/qgis/cmake/FindPyQt4.cmake 2010-05-15 08:21:42 UTC (rev 13489)
@@ -34,6 +34,7 @@
STRING(REGEX REPLACE "^pyqt_version:([^\n]+).*$" "\\1" PYQT4_VERSION ${pyqt_config})
STRING(REGEX REPLACE ".*\npyqt_version_str:([^\n]+).*$" "\\1" PYQT4_VERSION_STR ${pyqt_config})
STRING(REGEX REPLACE ".*\npyqt_version_tag:([^\n]+).*$" "\\1" PYQT4_VERSION_TAG ${pyqt_config})
+ STRING(REGEX REPLACE ".*\npyqt_version_num:([^\n]+).*$" "\\1" PYQT4_VERSION_NUM ${pyqt_config})
STRING(REGEX REPLACE ".*\npyqt_sip_dir:([^\n]+).*$" "\\1" PYQT4_SIP_DIR ${pyqt_config})
STRING(REGEX REPLACE ".*\npyqt_sip_flags:([^\n]+).*$" "\\1" PYQT4_SIP_FLAGS ${pyqt_config})
@@ -51,3 +52,5 @@
ENDIF(PYQT4_FOUND)
ENDIF(EXISTS PYQT4_VERSION)
Modified: trunk/qgis/python/CMakeLists.txt
--- trunk/qgis/python/CMakeLists.txt 2010-05-15 07:28:28 UTC (rev 13488)
+++ trunk/qgis/python/CMakeLists.txt 2010-05-15 08:21:42 UTC (rev 13489)
@@ -35,9 +35,9 @@
ADD_DEFINITIONS(-DNOMINMAX)
ENDIF(MSVC)
-IF(PYQT4_VERSION_TAG LESS 263680) # 0x040600
+IF(PYQT4_VERSION_NUM LESS 263680) # 0x040600
SET(SIP_DISABLE_FEATURES ${SIP_DISABLE_FEATURES} PROXY_FACTORY)
-ENDIF(PYQT4_VERSION_TAG LESS 263680)
+ENDIF(PYQT4_VERSION_NUM LESS 263680)
# core module
FILE(GLOB sip_files_core core/*.sip)
Modified: trunk/qgis/src/providers/grass/qgis.g.info.c
--- trunk/qgis/src/providers/grass/qgis.g.info.c 2010-05-15 07:28:28 UTC (rev 13488)
+++ trunk/qgis/src/providers/grass/qgis.g.info.c 2010-05-15 08:21:42 UTC (rev 13489)
@@ -108,7 +108,12 @@
void *ptr;
double val;
+#if defined(GRASS_VERSION_MAJOR) && defined(GRASS_VERSION_MINOR) && \
+ ( ( GRASS_VERSION_MAJOR == 6 && GRASS_VERSION_MINOR > 2 ) || GRASS_VERSION_MAJOR > 6 )
rast_type = G_get_raster_map_type( fd );
+#else
+ rast_type = G_raster_map_type( rast_opt->answer, "" );
+#endif
cell = G_allocate_c_raster_buf();
dcell = G_allocate_d_raster_buf();
@@ -120,7 +125,7 @@
rast_opt->answer, row );
val = cell[col];
- ptr = &(cell[col]);
+ ptr = &( cell[col] );
else
@@ -130,7 +135,7 @@
val = dcell[col];
- ptr = &(dcell[col]);
+ ptr = &( dcell[col] );
if ( G_is_null_value( ptr, rast_type ) )
Modified: trunk/qgis/src/providers/grass/qgsgrass.cpp
--- trunk/qgis/src/providers/grass/qgsgrass.cpp 2010-05-15 07:28:28 UTC (rev 13488)
+++ trunk/qgis/src/providers/grass/qgsgrass.cpp 2010-05-15 08:21:42 UTC (rev 13489)
@@ -40,6 +40,13 @@
#include <grass/version.h>
+#if !defined(GRASS_VERSION_MAJOR) || \
+ !defined(GRASS_VERSION_MINOR) || \
+ GRASS_VERSION_MAJOR<6 || \
+ (GRASS_VERSION_MAJOR == 6 && GRASS_VERSION_MINOR <= 2)
+#define G__setenv(name,value) G__setenv( ( char * ) (name), (char *) (value) )
+#endif
#if defined(WIN32)
#include <windows.h>
QString GRASS_EXPORT QgsGrass::shortPath( const QString &path )
@@ -333,14 +340,14 @@
// Set principal GRASS variables (in memory)
#if defined(WIN32)
- G__setenv(( char * ) "GISDBASE", shortPath( gisdbase ).toLocal8Bit().data() );
+ G__setenv( "GISDBASE", shortPath( gisdbase ).toLocal8Bit().data() );
#else
- // This does not work for GISBAS with non ascii chars on Windows XP,
+ // This does not work for GISBASE with non ascii chars on Windows XP,
// gives error 'LOCATION ... not available':
- G__setenv(( char * ) "GISDBASE", gisdbase.toUtf8().constData() );
+ G__setenv( "GISDBASE", gisdbase.toUtf8().constData() );
#endif
- G__setenv(( char * ) "LOCATION_NAME", location.toUtf8().constData() );
- G__setenv(( char * ) "MAPSET", ( char * ) "PERMANENT" ); // PERMANENT must always exist
+ G__setenv( "LOCATION_NAME", location.toUtf8().constData() );
+ G__setenv( "MAPSET", "PERMANENT" ); // PERMANENT must always exist
// Add all available mapsets to search path
char **ms = G_available_mapsets();
@@ -354,12 +361,12 @@
#if defined(WIN32)
- G__setenv(( char * ) "GISDBASE", shortPath( gisdbase ).toUtf8().data() );
+ G__setenv( "GISDBASE", shortPath( gisdbase ).toUtf8().data() );
#else
- G__setenv(( char * ) "GISDBASE", gisdbase.toUtf8().data() );
+ G__setenv( "GISDBASE", gisdbase.toUtf8().data() );
#endif
- G__setenv(( char * ) "LOCATION_NAME", location.toUtf8().data() );
- G__setenv(( char * ) "MAPSET", mapset.toUtf8().data() );
+ G__setenv( "LOCATION_NAME", location.toUtf8().data() );
+ G__setenv( "MAPSET", mapset.toUtf8().data() );
@@ -560,14 +567,14 @@
putEnv( "GISRC", mGisrc );
// Reinitialize GRASS
- G__setenv(( char * ) "GISRC", mGisrc.toUtf8().data() );
+ G__setenv( "GISRC", mGisrc.toUtf8().data() );
#if defined(WIN32)
#else
#endif
- G__setenv(( char * ) "LOCATION_NAME", location.toLocal8Bit().data() );
- G__setenv(( char * ) "MAPSET", mapset.toLocal8Bit().data() );
+ G__setenv( "LOCATION_NAME", location.toLocal8Bit().data() );
+ G__setenv( "MAPSET", mapset.toLocal8Bit().data() );
defaultGisdbase = gisdbase;
defaultLocation = location;
defaultMapset = mapset;
@@ -602,15 +609,15 @@
putenv(( char * ) "GISRC" );
- G__setenv(( char * ) "GISRC", ( char * ) "" );
+ G__setenv( "GISRC", ( char * ) "" );
// Temporarily commented because of
// http://trac.osgeo.org/qgis/ticket/1900
// http://trac.osgeo.org/gdal/ticket/3313
// it can be uncommented once GDAL with patch gets deployed (probably GDAL 1.8)
- //G__setenv(( char * ) "GISDBASE", ( char * ) "" );
- //G__setenv(( char * ) "LOCATION_NAME", ( char * ) "" );
- //G__setenv(( char * ) "MAPSET", ( char * ) "" );
+ //G__setenv( "GISDBASE", ( char * ) "" );
+ //G__setenv( "LOCATION_NAME", ( char * ) "" );
+ //G__setenv( "MAPSET", ( char * ) "" );
defaultGisdbase = "";
defaultLocation = "";
