[QGIS Commit] r13519 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Mon May 17 18:31:16 EDT 2010
Author: jef
Date: 2010-05-17 18:31:16 -0400 (Mon, 17 May 2010)
New Revision: 13519
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
append space to list widgets in options and vector and raster layer property dialogs (fixes #2554)
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2010-05-17 22:20:07 UTC (rev 13518)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2010-05-17 22:31:16 UTC (rev 13519)
@@ -145,7 +145,7 @@
mOverlayDialogs.push_back( d );
//shamelessly hard coded - what will we do if other types of layer plugins exist? TS
QListWidgetItem * mypItem = new QListWidgetItem( QgisApp::getThemeIcon( "propertyicons/diagram.png" ), ( *it )->name() );
- listWidget->insertItem( stackedWidget->count(), mypItem );
+ listWidget->insertItem( stackedWidget->count()-1, mypItem );
stackedWidget->setCurrentIndex( 0 );
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2010-05-17 22:20:07 UTC (rev 13518)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2010-05-17 22:31:16 UTC (rev 13519)
@@ -49,9 +49,6 @@
<property name="showDropIndicator" stdset="0">
<bool>false</bool>
</property>
- <property name="alternatingRowColors">
- <bool>false</bool>
- </property>
<property name="iconSize">
<size>
<width>64</width>
@@ -76,12 +73,12 @@
<property name="viewMode">
<enum>QListView::IconMode</enum>
</property>
- <property name="uniformItemSizes">
- </property>
<property name="wordWrap">
<bool>true</bool>
</property>
+ <property name="currentRow">
+ <number>0</number>
+ </property>
<item>
<property name="text">
<string>General</string>
@@ -93,6 +90,9 @@
<iconset resource="../../images/images.qrc">
<normaloff>:/images/themes/default/propertyicons/general.png</normaloff>:/images/themes/default/propertyicons/general.png</iconset>
</property>
+ <property name="flags">
+ <set>ItemIsSelectable|ItemIsUserCheckable|ItemIsEnabled</set>
+ </property>
</item>
<item>
@@ -105,61 +105,111 @@
<normaloff>:/images/themes/default/propertyicons/rendering.png</normaloff>:/images/themes/default/propertyicons/rendering.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Map tools</string>
</property>
+ <property name="textAlignment">
+ <set>AlignHCenter|AlignVCenter|AlignCenter</set>
+ </property>
<property name="icon">
<normaloff>:/images/themes/default/propertyicons/map_tools.png</normaloff>:/images/themes/default/propertyicons/map_tools.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Overlay</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/overlay.png</normaloff>:/images/themes/default/propertyicons/overlay.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Digitising</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/digitising.png</normaloff>:/images/themes/default/propertyicons/digitising.png</iconset>
</property>
+ </property>
</item>
<item>
<string>CRS</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/CRS.png</normaloff>:/images/themes/default/propertyicons/CRS.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Locale</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/locale.png</normaloff>:/images/themes/default/propertyicons/locale.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Network & Proxy</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/network_and_proxy.png</normaloff>:/images/themes/default/propertyicons/network_and_proxy.png</iconset>
</property>
+ </property>
</item>
+ <item>
+ <property name="text">
+ <string notr="true"/>
+ </property>
+ </property>
+ <set>NoItemFlags</set>
+ </property>
+ </item>
</widget>
</item>
<item row="0" column="1">
@@ -168,19 +218,13 @@
<number>7</number>
</property>
<widget class="QWidget" name="stackedWidgetPage1">
- <layout class="QGridLayout">
- <property name="margin">
- <number>0</number>
- </property>
- <item row="0" column="0">
+ <layout class="QVBoxLayout" name="verticalLayout_10">
+ <item>
<widget class="QGroupBox" name="groupBox_11">
<property name="title">
<string>Project files</string>
</property>
<layout class="QVBoxLayout">
- <number>11</number>
- </property>
<item>
<widget class="QCheckBox" name="chbAskToSaveProjectChanges">
@@ -198,7 +242,7 @@
</layout>
</widget>
</item>
- <item row="1" column="0">
+ <item>
<widget class="QGroupBox" name="groupBox_9">
<string>Default Map Appearance (overridden by project properties)</string>
@@ -273,96 +317,97 @@
</layout>
</widget>
</item>
- <item row="2" column="0">
+ <item>
<widget class="QGroupBox" name="groupBox">
<string>&Application</string>
</property>
- <widget class="QLabel" name="textLabel1_4">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="text">
- <string>Icon theme</string>
- </property>
- </widget>
+ <layout class="QVBoxLayout" name="verticalLayout_9">
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_3">
+ <item>
+ <widget class="QLabel" name="textLabel1_4">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <string>Icon theme</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_2">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QComboBox" name="cmbTheme">
+ <property name="duplicatesEnabled">
+ <bool>false</bool>
+ </property>
+ <item>
+ <string/>
+ </property>
+ </item>
+ </widget>
+ </item>
+ </layout>
</item>
- <item row="1" column="0" colspan="2">
- <spacer>
- <property name="orientation">
- <enum>Qt::Vertical</enum>
- </property>
- <property name="sizeType">
- <enum>QSizePolicy::Fixed</enum>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>20</width>
- <height>10</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="2" column="0" colspan="2">
+ <item>
<widget class="QCheckBox" name="capitaliseCheckBox">
<string>Capitalise layer names in legend</string>
</property>
</widget>
</item>
- <item row="3" column="0" colspan="2">
+ <item>
<widget class="QCheckBox" name="cbxLegendClassifiers">
<string>Display classification attribute names in legend</string>
</property>
</widget>
</item>
- <item row="4" column="0" colspan="2">
+ <item>
<widget class="QCheckBox" name="cbxHideSplash">
<string>Hide splash screen at startup</string>
</property>
</widget>
</item>
- <item row="5" column="0">
+ <item>
<widget class="QCheckBox" name="cbxIdentifyResultsDocked">
<string>Open identify results in a dock window (QGIS restart required)</string>
</property>
</widget>
</item>
- <item row="6" column="0" colspan="2">
+ <item>
<widget class="QCheckBox" name="cbxAttributeTableDocked">
<string>Open attribute table in a dock window</string>
</property>
</widget>
</item>
- <item row="7" column="0" colspan="2">
+ <item>
<widget class="QCheckBox" name="cbxAddPostgisDC">
<string>Add PostGIS layers with double click and select in extended mode</string>
</property>
</widget>
</item>
- <item row="0" column="1">
- <widget class="QComboBox" name="cmbTheme">
- <property name="duplicatesEnabled">
- </property>
- <item>
- <string/>
- </property>
- </item>
- </widget>
- </item>
- <item row="8" column="0">
+ <item>
<widget class="QCheckBox" name="cbxAddNewLayersToCurrentGroup">
<string>Add new layers to selected group</string>
@@ -372,14 +417,24 @@
</layout>
</widget>
</item>
+ <item>
+ <spacer name="verticalSpacer">
+ <enum>Qt::Vertical</enum>
+ </property>
+ <size>
+ <width>20</width>
+ <height>40</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="stackedWidgetPage2">
- </property>
+ <layout class="QVBoxLayout" name="verticalLayout_2">
+ <item>
<widget class="QGroupBox" name="groupBox_5">
<string>Rendering behavior</string>
@@ -429,7 +484,7 @@
</layout>
</widget>
</item>
+ <item>
<widget class="QGroupBox" name="groupBox_8">
<string>Rendering quality</string>
@@ -458,7 +513,23 @@
</layout>
</widget>
</item>
- <item row="3" column="0">
+ <item>
+ <widget class="QGroupBox" name="groupBox_3">
+ <property name="title">
+ <string>Compatibility</string>
+ </property>
+ <layout class="QVBoxLayout" name="verticalLayout">
+ <item>
+ <widget class="QCheckBox" name="chkUseSymbologyNG">
+ <string>Use new generation symbology for rendering</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <item>
<widget class="QGroupBox" name="groupBox_2">
<string>SVG paths</string>
@@ -504,27 +575,11 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_3">
- <property name="title">
- <string>Compatibility</string>
- </property>
- <layout class="QVBoxLayout" name="verticalLayout">
- <item>
- <widget class="QCheckBox" name="chkUseSymbologyNG">
- <string>Use new generation symbology for rendering</string>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
</layout>
</widget>
<widget class="QWidget" name="stackedWidgetPage3">
- <layout class="QGridLayout" name="gridLayout_4">
+ <layout class="QVBoxLayout" name="verticalLayout_3">
+ <item>
<widget class="QGroupBox" name="groupBox_7">
<string>Identify</string>
@@ -586,7 +641,7 @@
</layout>
</widget>
</item>
+ <item>
<widget class="QGroupBox" name="groupBox_6">
<string>Measure tool</string>
@@ -687,7 +742,7 @@
</layout>
</widget>
</item>
+ <item>
<widget class="QGroupBox" name="groupBox_10">
<string>Panning and zooming</string>
@@ -750,7 +805,7 @@
</layout>
</widget>
</item>
+ <item>
<spacer>
@@ -766,27 +821,21 @@
</layout>
</widget>
<widget class="QWidget" name="stackedWidgetPage4">
- </property>
+ <layout class="QVBoxLayout" name="verticalLayout_4">
+ <item>
<widget class="QGroupBox" name="mPositionGroupBox">
<string>Position</string>
</property>
+ <layout class="QHBoxLayout" name="horizontalLayout_4">
+ <item>
<widget class="QLabel" name="mAlgorithmLabel">
<string>Placement algorithm:</string>
</property>
</widget>
</item>
- <widget class="QComboBox" name="mOverlayAlgorithmComboBox"/>
- </item>
- <item row="0" column="2">
+ <item>
<spacer>
@@ -799,10 +848,13 @@
</property>
</spacer>
</item>
+ <item>
+ <widget class="QComboBox" name="mOverlayAlgorithmComboBox"/>
+ </item>
</layout>
</widget>
</item>
+ <item>
<spacer>
@@ -818,11 +870,8 @@
</layout>
</widget>
<widget class="QWidget" name="stackedWidgetPage5">
- </property>
+ <layout class="QVBoxLayout" name="verticalLayout_5">
+ <item>
<widget class="QGroupBox" name="mRubberBandGroupBox">
<string>Rubberband</string>
@@ -868,7 +917,7 @@
</layout>
</widget>
</item>
+ <item>
<widget class="QGroupBox" name="mSnappingGroupBox">
<string>Snapping</string>
@@ -881,19 +930,6 @@
</property>
</widget>
</item>
- <item row="0" column="1" colspan="3">
- <spacer>
- <enum>Qt::Horizontal</enum>
- </property>
- <size>
- <width>311</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
<item row="0" column="4" colspan="2">
<widget class="QComboBox" name="mDefaultSnapModeComboBox">
@@ -911,19 +947,6 @@
</property>
</widget>
</item>
- <item row="1" column="2" colspan="2">
- <spacer>
- </property>
- <size>
- <width>241</width>
- </size>
- </property>
- </spacer>
- </item>
<item row="1" column="4">
<widget class="QDoubleSpinBox" name="mDefaultSnappingToleranceSpinBox">
<property name="decimals">
@@ -941,19 +964,6 @@
</property>
</widget>
</item>
- <item row="2" column="3">
- <spacer>
- </property>
- <size>
- <width>61</width>
- </size>
- </property>
- </spacer>
- </item>
<item row="2" column="4">
<widget class="QDoubleSpinBox" name="mSearchRadiusVertexEditSpinBox">
@@ -998,10 +1008,49 @@
</item>
</widget>
</item>
+ <item row="2" column="3">
+ <spacer>
+ </property>
+ <size>
+ <width>61</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="1" column="2" colspan="2">
+ <spacer>
+ </property>
+ <size>
+ <width>241</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="0" column="1" colspan="3">
+ <spacer>
+ </property>
+ <size>
+ <width>311</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
</item>
+ <item>
<widget class="QGroupBox" name="mVertexMarkerGroupBox">
<string>Vertex markers</string>
@@ -1080,7 +1129,7 @@
</layout>
</widget>
</item>
+ <item>
<widget class="QGroupBox" name="mEnterAttributeValuesGroupBox">
<string>Enter attribute values</string>
@@ -1099,7 +1148,7 @@
</layout>
</widget>
</item>
- <item row="4" column="0">
+ <item>
<spacer>
@@ -1115,34 +1164,8 @@
</layout>
</widget>
<widget class="QWidget" name="stackedWidgetPage6">
- </property>
- <spacer>
- </property>
- <size>
- <width>51</width>
- <height>31</height>
- </size>
- </property>
- </spacer>
- </item>
- <widget class="QPushButton" name="pbnSelectProjection">
- <string>Select Global Default ...</string>
- </property>
- </widget>
- </item>
- <widget class="QTextBrowser" name="txtGlobalWkt"/>
- </item>
+ <layout class="QVBoxLayout" name="verticalLayout_6">
+ <item>
<widget class="QGroupBox" name="grpProjectionBehaviour">
<string>Default Coordinate Reference System</string>
@@ -1185,14 +1208,34 @@
</layout>
</widget>
</item>
+ <item>
+ <widget class="QTextBrowser" name="txtGlobalWkt"/>
+ </item>
+ <item>
+ <widget class="QPushButton" name="pbnSelectProjection">
+ <string>Select Global Default ...</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer>
+ </property>
+ <size>
+ <width>51</width>
+ <height>31</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="stackedWidgetPage7">
- </property>
+ <layout class="QVBoxLayout" name="verticalLayout_7">
+ <item>
<widget class="QGroupBox" name="grpLocale">
<string>Override system locale</string>
@@ -1224,20 +1267,7 @@
</layout>
</widget>
</item>
- <spacer>
- </property>
- <size>
- <width>501</width>
- <height>51</height>
- </size>
- </property>
- </spacer>
- </item>
+ <item>
<widget class="QGroupBox" name="groupBox_12">
<string>Additional Info</string>
@@ -1253,29 +1283,24 @@
</layout>
</widget>
</item>
+ <item>
+ <spacer>
+ </property>
+ <size>
+ <width>501</width>
+ <height>51</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="stackedWidgetPage8">
- <layout class="QVBoxLayout" name="verticalLayout_3">
+ <layout class="QVBoxLayout" name="verticalLayout_8">
<item>
- <layout class="QHBoxLayout" name="horizontalLayout">
- <item>
- <widget class="QLabel" name="mNetworkTimeoutLabel">
- <string>Timeout for network requests (ms):</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QSpinBox" name="mNetworkTimeoutSpinBox">
- <property name="maximum">
- <number>100000000</number>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item>
<widget class="QGroupBox" name="grpProxy">
<string>Use proxy for web access</string>
@@ -1466,6 +1491,37 @@
</item>
</layout>
</item>
+ <item>
+ <spacer name="verticalSpacer_2">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout">
+ <item>
+ <widget class="QLabel" name="mNetworkTimeoutLabel">
+ <string>Timeout for network requests (ms):</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QSpinBox" name="mNetworkTimeoutSpinBox">
+ <property name="maximum">
+ <number>100000000</number>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
</layout>
</widget>
</widget>
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-05-17 22:20:07 UTC (rev 13518)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-05-17 22:31:16 UTC (rev 13519)
@@ -54,9 +54,6 @@
<bool>false</bool>
</property>
- </property>
<size>
<width>64</width>
@@ -81,9 +78,6 @@
</property>
- </property>
<bool>true</bool>
</property>
@@ -91,65 +85,115 @@
<string>Symbology</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/symbology.png</normaloff>:/images/themes/default/propertyicons/symbology.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Transparency</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/transparency.png</normaloff>:/images/themes/default/propertyicons/transparency.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Colormap</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/colormap.png</normaloff>:/images/themes/default/propertyicons/colormap.png</iconset>
</property>
+ </property>
</item>
<item>
</property>
+ </property>
</property>
+ </property>
</item>
<item>
<string>Metadata</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/metadata.png</normaloff>:/images/themes/default/propertyicons/metadata.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Pyramids</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/pyramids.png</normaloff>:/images/themes/default/propertyicons/pyramids.png</iconset>
</property>
+ </property>
</item>
<item>
<string>Histogram</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/histogram.png</normaloff>:/images/themes/default/propertyicons/histogram.png</iconset>
</property>
+ </property>
</item>
+ <item>
+ </property>
+ </property>
+ </item>
</widget>
</item>
<item row="0" column="1" colspan="4">
Modified: trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2010-05-17 22:20:07 UTC (rev 13518)
+++ trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2010-05-17 22:31:16 UTC (rev 13519)
@@ -50,9 +50,6 @@
<bool>false</bool>
</property>
- </property>
<size>
<width>64</width>
@@ -77,9 +74,6 @@
</property>
- </property>
<bool>true</bool>
</property>
@@ -87,6 +81,9 @@
</property>
+ </property>
@@ -96,6 +93,9 @@
<string>Labels</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/labels.png</normaloff>:/images/themes/default/propertyicons/labels.png</iconset>
@@ -105,6 +105,9 @@
<string>Attributes</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/attributes.png</normaloff>:/images/themes/default/propertyicons/attributes.png</iconset>
@@ -114,6 +117,9 @@
</property>
+ </property>
@@ -123,6 +129,9 @@
</property>
+ </property>
@@ -132,11 +141,22 @@
<string>Actions</string>
</property>
+ </property>
<normaloff>:/images/themes/default/propertyicons/action.png</normaloff>:/images/themes/default/propertyicons/action.png</iconset>
</property>
</item>
+ <item>
+ </property>
+ </property>
+ </item>
</widget>
</item>
@@ -424,7 +444,7 @@
<x>0</x>
<y>0</y>
<width>514</width>
- <height>428</height>
+ <height>378</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_3">
