[QGIS Commit] r13523 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org
Tue May 18 06:26:14 EDT 2010
Author: mhugent
Date: 2010-05-18 06:26:11 -0400 (Tue, 18 May 2010)
New Revision: 13523
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.cpp
Add transformation name in georef pdf report
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-05-18 06:45:58 UTC (rev 13522)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-05-18 10:26:11 UTC (rev 13523)
@@ -1237,9 +1237,18 @@
if ( wldTransform )
+ QString parameterTitle = tr( "Transformation parameters" );
+ if ( transform.transformParametrisation() == QgsGeorefTransform::Helmert )
+ parameterTitle += " (Helmert)";
+ else if ( transform.transformParametrisation() == QgsGeorefTransform::Linear )
+ parameterTitle += " (Linear)";
parameterLabel = new QgsComposerLabel( composition );
parameterLabel->setFont( titleFont );
- parameterLabel->setText( tr( "Transformation parameters" ) );
+ parameterLabel->setText( parameterTitle );
parameterLabel->adjustSizeToText();
composition->addItem( parameterLabel );
parameterLabel->setSceneRect( QRectF( 2, composerMap->rect().bottom() + composerMap->transform().dy() + 5, composition->paperWidth(), 8 ) );
@@ -1366,8 +1375,8 @@
currentGCPStrings << tr( "no" );
- currentGCPStrings << QString::number(( *gcpIt )->pixelCoords().x() ) << QString::number(( *gcpIt )->pixelCoords().y() ) << QString::number(( *gcpIt )->mapCoords().x() )\
- << QString::number(( *gcpIt )->mapCoords().y() ) << QString::number( residualX ) << QString::number( residualY ) << QString::number( residualTot );
+ currentGCPStrings << QString::number(( *gcpIt )->pixelCoords().x(), 'f', 2 ) << QString::number(( *gcpIt )->pixelCoords().y(), 'f', 2 ) << QString::number(( *gcpIt )->mapCoords().x(), 'f', 2 )\
+ << QString::number(( *gcpIt )->mapCoords().y(), 'f', 2 ) << QString::number( residualX ) << QString::number( residualY ) << QString::number( residualTot );
gcpTable->addRow( currentGCPStrings );
Modified: trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.cpp 2010-05-18 06:45:58 UTC (rev 13522)
+++ trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.cpp 2010-05-18 10:26:11 UTC (rev 13523)
@@ -58,6 +58,7 @@
if ( !ok ) dsbHorizRes->setValue( 1.0 );
dsbVerticalRes->setValue( s.value( "/Plugin-GeoReferencer/user_specified_resy", -1.0 ).toDouble( &ok ) );
if ( !ok ) dsbHorizRes->setValue( -1.0 );
// Activate spin boxes for vertical/horizontal resolution, if the option is checked
dsbHorizRes->setEnabled( cbxUserResolution->isChecked() );
dsbVerticalRes->setEnabled( cbxUserResolution->isChecked() );
@@ -112,6 +113,7 @@
s.setValue( "/Plugin-GeoReferencer/user_specified_resolution", false );
s.setValue( "/Plugin-GeoReferencer/user_specified_resx", 1.0 );
s.setValue( "/Plugin-GeoReferencer/user_specified_resy", -1.0 );
+ s.setValue( "/Plugin-GeoReferencer/lastPDFReportDir", "" );
void QgsTransformSettingsDialog::changeEvent( QEvent *e )
