[QGIS Commit] r13554 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org
Sun May 23 09:47:07 EDT 2010
Author: mmassing
Date: 2010-05-23 09:47:07 -0400 (Sun, 23 May 2010)
New Revision: 13554
trunk/qgis/src/plugins/georeferencer/qgsgcplistwidget.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
georeferencer: Fix parameter reporting when enabling/disabling GCPs.
Updates the model before emiting pointEnabled signal, so that downstream
handlers work with up-to-date transform parameters.
Modified: trunk/qgis/src/plugins/georeferencer/qgsgcplistwidget.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgcplistwidget.cpp 2010-05-23 13:46:56 UTC (rev 13553)
+++ trunk/qgis/src/plugins/georeferencer/qgsgcplistwidget.cpp 2010-05-23 13:47:07 UTC (rev 13554)
@@ -109,15 +109,14 @@
if ( item->checkState() == Qt::Checked )
p->setEnabled( true );
- emit pointEnabled( p, index.row() );
else // Qt::Unchecked
p->setEnabled( false );
mGCPListModel->updateModel();
+ emit pointEnabled( p, index.row() );
adjustTableContent();
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-05-23 13:46:56 UTC (rev 13553)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-05-23 13:47:07 UTC (rev 13554)
@@ -1345,16 +1345,6 @@
parameterLabel->setSceneRect( QRectF( 2, composerMap->rect().bottom() + composerMap->transform().dy() + 5, composition->paperWidth(), 8 ) );
parameterLabel->setFrame( false );
- int nPointsEnabled = 0;
- QgsGCPList::const_iterator gcpIt = mPoints.constBegin();
- for ( ; gcpIt != mPoints.constEnd(); ++gcpIt )
- if (( *gcpIt )->isEnabled() )
- ++nPointsEnabled;
//calculate mean error
double meanError = 0;
calculateMeanError( meanError );
