[QGIS Commit] r13588 - in trunk/qgis: python/core src/analysis/vector src/core src/plugins/labeling
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat May 29 07:03:31 EDT 2010
Author: jef
Date: 2010-05-29 07:03:30 -0400 (Sat, 29 May 2010)
New Revision: 13588
   trunk/qgis/python/core/qgsgeometry.sip
   trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp
   trunk/qgis/src/core/qgsgeometry.cpp
   trunk/qgis/src/core/qgsgeometry.h
   trunk/qgis/src/plugins/labeling/pallabeling.cpp
add length() and area() methods to QgsGeometry
and use it in labeling and zonal statistics
Modified: trunk/qgis/python/core/qgsgeometry.sip
--- trunk/qgis/python/core/qgsgeometry.sip	2010-05-29 10:32:56 UTC (rev 13587)
+++ trunk/qgis/python/core/qgsgeometry.sip	2010-05-29 11:03:30 UTC (rev 13588)
@@ -111,6 +111,16 @@
     // TODO: unsupported class... would be possible to use PyGEOS?
     //void fromGeos(geos::Geometry* geos);
+    /** get area using GEOS
+      @note added in 1.5
+    double area();
+    /** get length using GEOS
+    double length();
     double distance(QgsGeometry& geom);
Modified: trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp
--- trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp	2010-05-29 10:32:56 UTC (rev 13587)
+++ trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp	2010-05-29 11:03:30 UTC (rev 13588)
@@ -23,13 +23,19 @@
 #include "cpl_string.h"
 #include <QProgressDialog>
-QgsZonalStatistics::QgsZonalStatistics( QgsVectorLayer* polygonLayer, const QString& rasterFile, const QString& attributePrefix, int rasterBand ) :
-    mRasterFilePath( rasterFile ), mRasterBand( rasterBand ), mPolygonLayer( polygonLayer ), mAttributePrefix( attributePrefix ), mInputNodataValue( -1 )
+QgsZonalStatistics::QgsZonalStatistics( QgsVectorLayer* polygonLayer, const QString& rasterFile, const QString& attributePrefix, int rasterBand )
+    : mRasterFilePath( rasterFile )
+    , mRasterBand( rasterBand )
+    , mPolygonLayer( polygonLayer )
+    , mAttributePrefix( attributePrefix )
+    , mInputNodataValue( -1 )
-QgsZonalStatistics::QgsZonalStatistics(): mRasterBand( 0 ), mPolygonLayer( 0 )
+QgsZonalStatistics::QgsZonalStatistics()
+    : mRasterBand( 0 )
+    , mPolygonLayer( 0 )
@@ -162,13 +168,13 @@
       continue;
-    statisticsFromMiddlePointTest_improved( rasterBand, featureGeometry, offsetX, offsetY, nCellsX, nCellsY, cellsizeX, cellsizeY, \
+    statisticsFromMiddlePointTest_improved( rasterBand, featureGeometry, offsetX, offsetY, nCellsX, nCellsY, cellsizeX, cellsizeY,
                                             rasterBBox, sum, count );
     if ( count <= 1 )
       //the cell resolution is probably larger than the polygon area. We switch to precise pixel - polygon intersection in this case
-      statisticsFromPreciseIntersection( rasterBand, featureGeometry, offsetX, offsetY, nCellsX, nCellsY, cellsizeX, cellsizeY, \
+      statisticsFromPreciseIntersection( rasterBand, featureGeometry, offsetX, offsetY, nCellsX, nCellsY, cellsizeX, cellsizeY,
@@ -227,7 +233,7 @@
   return 0;
-void QgsZonalStatistics::statisticsFromMiddlePointTest( void* band, QgsGeometry* poly, int pixelOffsetX, \
+void QgsZonalStatistics::statisticsFromMiddlePointTest( void* band, QgsGeometry* poly, int pixelOffsetX,
     int pixelOffsetY, int nCellsX, int nCellsY, double cellSizeX, double cellSizeY, const QgsRectangle& rasterBBox, double& sum, double& count )
   double cellCenterX, cellCenterY;
@@ -260,7 +266,7 @@
   CPLFree( scanLine );
-void QgsZonalStatistics::statisticsFromPreciseIntersection( void* band, QgsGeometry* poly, int pixelOffsetX, \
+void QgsZonalStatistics::statisticsFromPreciseIntersection( void* band, QgsGeometry* poly, int pixelOffsetX,
   sum = 0;
@@ -268,12 +274,10 @@
   double currentY = rasterBBox.yMaximum() - pixelOffsetY * cellSizeY - cellSizeY / 2;
   float* pixelData = ( float * ) CPLMalloc( sizeof( float ) );
   QgsGeometry* pixelRectGeometry = 0;
-  QgsGeometry* intersectGeometry = 0;
   double hCellSizeX = cellSizeX / 2.0;
   double hCellSizeY = cellSizeY / 2.0;
   double pixelArea = cellSizeX * cellSizeY;
-  double intersectionArea = 0;
   double weight = 0;
   for ( int row = 0; row < nCellsY; ++row )
@@ -286,10 +290,11 @@
       if ( pixelRectGeometry )
         //intersection
-        intersectGeometry = pixelRectGeometry->intersection( poly );
+        QgsGeometry *intersectGeometry = pixelRectGeometry->intersection( poly );
         if ( intersectGeometry )
-          if ( GEOSArea( intersectGeometry->asGeos(), &intersectionArea ) )
+          double intersectionArea = intersectGeometry->area();
+          if ( intersectionArea >= 0.0 )
             weight = intersectionArea / pixelArea;
             count += weight;
@@ -305,7 +310,7 @@
   CPLFree( pixelData );
-void QgsZonalStatistics::statisticsFromMiddlePointTest_improved( void* band, QgsGeometry* poly, int pixelOffsetX, int pixelOffsetY, int nCellsX, int nCellsY, \
+void QgsZonalStatistics::statisticsFromMiddlePointTest_improved( void* band, QgsGeometry* poly, int pixelOffsetX, int pixelOffsetY, int nCellsX, int nCellsY,
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp	2010-05-29 10:32:56 UTC (rev 13587)
+++ trunk/qgis/src/core/qgsgeometry.cpp	2010-05-29 11:03:30 UTC (rev 13588)
@@ -5859,6 +5859,43 @@
   return polygons;
+double QgsGeometry::area()
+  if ( !mGeos )
+    exportWkbToGeos();
+  double area;
+  try
+    if ( GEOSArea( mGeos, &area ) == 0 )
+      return -1.0;
+  CATCH_GEOS( -1.0 )
+  return area;
+double QgsGeometry::length()
+  if ( !mGeos )
+  double length;
+  try
+    if ( GEOSLength( mGeos, &length ) == 0 )
+      return -1.0;
+  return length;
 double QgsGeometry::distance( QgsGeometry& geom )
   if ( !mGeos )
Modified: trunk/qgis/src/core/qgsgeometry.h
--- trunk/qgis/src/core/qgsgeometry.h	2010-05-29 10:32:56 UTC (rev 13587)
+++ trunk/qgis/src/core/qgsgeometry.h	2010-05-29 11:03:30 UTC (rev 13588)
@@ -146,6 +146,16 @@
     bool isGeosEmpty();
+    /** get area of geometry using GEOS
+    double area();
+    /** get length of geometry using GEOS
+    double length();
     double distance( QgsGeometry& geom );
Modified: trunk/qgis/src/plugins/labeling/pallabeling.cpp
--- trunk/qgis/src/plugins/labeling/pallabeling.cpp	2010-05-29 10:32:56 UTC (rev 13587)
+++ trunk/qgis/src/plugins/labeling/pallabeling.cpp	2010-05-29 11:03:30 UTC (rev 13588)
@@ -229,25 +229,19 @@
     return true;
-  GEOSGeometry* geosGeom = geom->asGeos();
-  if ( !geosGeom )
-    return true;
   double mapUnitsPerMM = ct.mapToPixel().mapUnitsPerPixel() * ct.scaleFactor();
   if ( featureType == QGis::Line )
-    double length;
-    if ( GEOSLength( geosGeom, &length ) )
+    double length = geom->length();
+    if ( length >= 0.0 )
       return ( length >= ( minSize * mapUnitsPerMM ) );
   else if ( featureType == QGis::Polygon )
-    double area;
-    if ( GEOSArea( geosGeom, &area ) )
+    double area = geom->area();
+    if ( area >= 0.0 )
       return ( sqrt( area ) >= ( minSize * mapUnitsPerMM ) );
More information about the QGIS-commit mailing list
