[QGIS Commit] r13592 - in trunk/qgis/src: app app/ogr core
svn_qgis at osgeo.org
Sat May 29 09:37:51 EDT 2010
Author: jef
Date: 2010-05-29 09:37:51 -0400 (Sat, 29 May 2010)
New Revision: 13592
trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/core/qgsvectorfilewriter.cpp
followup r13591: force KML encoding to utf-8 in save as dialog and move filename/encoding validation to vector file write
Modified: trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp
--- trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp 2010-05-29 12:44:11 UTC (rev 13591)
+++ trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp 2010-05-29 13:37:51 UTC (rev 13592)
@@ -74,6 +74,16 @@
browseFilename->setEnabled( true );
leFilename->setEnabled( true );
+ if( format() == "KML" )
+ mEncodingComboBox->setCurrentIndex( mEncodingComboBox->findText( "UTF-8" ) );
+ mEncodingComboBox->setDisabled( true );
+ else
+ mEncodingComboBox->setEnabled( true );
void QgsVectorLayerSaveAsDialog::on_browseFilename_clicked()
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-05-29 12:44:11 UTC (rev 13591)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-05-29 13:37:51 UTC (rev 13592)
@@ -2700,19 +2700,6 @@
-/** This helper checks to see whether the file name appears to be a valid vector file name */
-bool QgisApp::isValidShapeFileName( QString theFileNameQString )
- return theFileNameQString.endsWith( ".shp", Qt::CaseInsensitive );
-/** Overloaded of the above function provided for convenience that takes a qstring pointer */
-bool QgisApp::isValidShapeFileName( QString * theFileNameQString )
- //dereference and delegate
- return isValidShapeFileName( *theFileNameQString );
#ifndef HAVE_POSTGRESQL
void QgisApp::addDatabaseLayer() {}
#else
@@ -3030,32 +3017,8 @@
openFileDialog->selectFilter( lastUsedFilter );
- int res;
- while (( res = openFileDialog->exec() ) == QDialog::Accepted )
+ if( openFileDialog->exec() == QDialog::Rejected )
- fileName = openFileDialog->selectedFiles().first();
- if ( fileformat == "ESRI Shapefile" )
- if ( !isValidShapeFileName( fileName ) )
- fileName += ".shp";
- QMessageBox::information( this,
- tr( "New Shapefile" ),
- tr( "Shapefiles must end on .shp" ) );
- continue;
- break;
- if ( res == QDialog::Rejected )
delete openFileDialog;
return;
@@ -3864,29 +3827,6 @@
destCRS = QgsCoordinateReferenceSystem( dialog->crs(), QgsCoordinateReferenceSystem::InternalCrsId );
- // overwrite the file - user will already have been prompted
- // to verify they want to overwrite by the file dialog above
- // might not even exists in the given case.
- // add the extension if not present
- if ( format == "ESRI Shapefile" )
- if ( !vectorFilename.endsWith( ".shp", Qt::CaseInsensitive ) )
- vectorFilename += ".shp";
- QgsVectorFileWriter::deleteShapeFile( vectorFilename );
- //GE does not open files without extensions. Therefore we append it automatically for kml files
- if ( format == "KML" )
- if ( !vectorFilename.endsWith( ".kml", Qt::CaseInsensitive ) )
- vectorFilename += ".kml";
- encoding = "UTF-8";
// ok if the file existed it should be deleted now so we can continue...
QApplication::setOverrideCursor( Qt::WaitCursor );
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2010-05-29 12:44:11 UTC (rev 13591)
+++ trunk/qgis/src/app/qgisapp.h 2010-05-29 13:37:51 UTC (rev 13592)
@@ -742,11 +742,7 @@
* It won't force a refresh.
bool addRasterLayer( QgsRasterLayer * theRasterLayer );
- //@todo We should move these next two into vector layer class
- /** This helper checks to see whether the file name appears to be a valid shape file name */
- bool isValidShapeFileName( QString theFileNameQString );
- /** Overloaded version of the above function provided for convenience that takes a qstring pointer */
- bool isValidShapeFileName( QString * theFileNameQString );
/** add this file to the recently opened/saved projects list
* pass settings by reference since creating more than one
* instance simultaneously results in data loss.
Modified: trunk/qgis/src/core/qgsvectorfilewriter.cpp
--- trunk/qgis/src/core/qgsvectorfilewriter.cpp 2010-05-29 12:44:11 UTC (rev 13591)
+++ trunk/qgis/src/core/qgsvectorfilewriter.cpp 2010-05-29 13:37:51 UTC (rev 13592)
@@ -43,7 +43,7 @@
QgsVectorFileWriter::QgsVectorFileWriter(
const QString &theVectorFileName,
- const QString& fileEncoding,
+ const QString &theFileEncoding,
const QgsFieldMap& fields,
QGis::WkbType geometryType,
const QgsCoordinateReferenceSystem* srs,
@@ -54,6 +54,7 @@
, mError( NoError )
QString vectorFileName = theVectorFileName;
+ QString fileEncoding = theFileEncoding;
// find driver in OGR
OGRSFDriverH poDriver;
@@ -91,8 +92,29 @@
fieldNames << name;
+ deleteShapeFile( vectorFileName );
+ else if( driverName == "KML" )
+ if( !vectorFileName.endsWith( ".kml", Qt::CaseInsensitive ) )
+ vectorFileName += ".kml";
+ if( fileEncoding.compare( "UTF-8", Qt::CaseInsensitive )!=0 )
+ QgsDebugMsg( "forced UTF-8 encoding for KML" );
+ fileEncoding = "UTF-8";
+ QFile::remove( vectorFileName );
+ else
// create the data source
mDS = OGR_Dr_CreateDataSource( poDriver, vectorFileName.toLocal8Bit().data(), NULL );
if ( mDS == NULL )
