[QGIS Commit] r14508 - trunk/qgis/src/analysis/raster
svn_qgis at osgeo.org
Thu Nov 4 19:16:23 EDT 2010
Author: jef
Date: 2010-11-04 16:16:23 -0700 (Thu, 04 Nov 2010)
New Revision: 14508
trunk/qgis/src/analysis/raster/qgsrastercalculator.cpp
trunk/qgis/src/analysis/raster/qgsrastermatrix.cpp
fix vc warnings
Modified: trunk/qgis/src/analysis/raster/qgsrastercalculator.cpp
--- trunk/qgis/src/analysis/raster/qgsrastercalculator.cpp 2010-11-04 22:49:47 UTC (rev 14507)
+++ trunk/qgis/src/analysis/raster/qgsrastercalculator.cpp 2010-11-04 23:16:23 UTC (rev 14508)
@@ -84,7 +84,6 @@
GDALDatasetH outputDataset = openOutputFile( outputDriver );
GDALRasterBandH outputRasterBand = GDALGetRasterBand( outputDataset, 1 );
- int nodataSuccess;
float outputNodataValue = -FLT_MAX;
GDALSetRasterNoDataValue( outputRasterBand, outputNodataValue );
@@ -127,7 +126,7 @@
bool resultIsNumber = resultMatrix.isNumber();
float* calcData;
- if( resultIsNumber ) //scalar result. Insert number for every pixel
+ if( resultIsNumber ) //scalar result. Insert number for every pixel
calcData = new float[mNumOutputColumns];
for( int j = 0; j < mNumOutputColumns; ++j )
Modified: trunk/qgis/src/analysis/raster/qgsrastermatrix.cpp
--- trunk/qgis/src/analysis/raster/qgsrastermatrix.cpp 2010-11-04 22:49:47 UTC (rev 14507)
+++ trunk/qgis/src/analysis/raster/qgsrastermatrix.cpp 2010-11-04 23:16:23 UTC (rev 14508)
@@ -178,32 +178,32 @@
switch( op )
case opSQRT:
- if( value < 0 ) //no complex numbers
+ if( value < 0 ) //no complex numbers
- mData[i] = mNodataValue;
+ mData[i] = static_cast<float>( mNodataValue );
else
- mData[i] = sqrt( value );
+ mData[i] = static_cast<float>( sqrt( value ) );
break;
case opSIN:
- mData[i] = sin( value );
+ mData[i] = static_cast<float>( sin( value ) );
break;
case opCOS:
- mData[i] = cos( value );
+ mData[i] = static_cast<float>( cos( value ) );
break;
case opTAN:
- mData[i] = tan( value );
+ mData[i] = static_cast<float>( tan( value ) );
break;
case opASIN:
- mData[i] = asin( value );
+ mData[i] = static_cast<float>( asin( value ) );
break;
case opACOS:
- mData[i] = acos( value );
+ mData[i] = static_cast<float>( acos( value ) );
break;
case opATAN:
- mData[i] = atan( value );
+ mData[i] = static_cast<float>( atan( value ) );
break;
@@ -218,34 +218,34 @@
//operations with nodata values always generate nodata
if( mData[0] == mNodataValue || other.number() == other.nodataValue() )
- mData[0] = mNodataValue;
+ mData[0] = static_cast<float>( mNodataValue );
return true;
switch( op )
case opPLUS:
- mData[0] = number() + other.number();
+ mData[0] = static_cast<float>( number() + other.number() );
break;
case opMINUS:
- mData[0] = number() - other.number();
+ mData[0] = static_cast<float>( number() - other.number() );
break;
case opMUL:
- mData[0] = number() * other.number();
+ mData[0] = static_cast<float>( number() * other.number() );
break;
case opDIV:
if( other.number() == 0 )
else
- mData[0] = number() / other.number();
+ mData[0] = static_cast<float>( number() / other.number() );
break;
case opPOW:
if( !testPowerValidity( mData[0], ( float ) other.number() ) )
else
@@ -253,22 +253,22 @@
break;
case opEQ:
- mData[0] = ( mData[0] == other.number() ? 1 : 0 );
+ mData[0] = mData[0] == other.number() ? 1.0f : 0.0f;
break;
case opNE:
- mData[0] = ( mData[0] == other.number() ? 0 : 1 );
+ mData[0] = mData[0] == other.number() ? 0.0f : 1.0f;
break;
case opGT:
- mData[0] = ( mData[0] > other.number() ? 1 : 0 );
+ mData[0] = mData[0] > other.number() ? 1.0f : 0.0f;
break;
case opLT:
- mData[0] = ( mData[0] < other.number() ? 1 : 0 );
+ mData[0] = mData[0] < other.number() ? 1.0f : 0.0f;
break;
case opGE:
- mData[0] = ( mData[0] >= other.number() ? 1 : 0 );
+ mData[0] = mData[0] >= other.number() ? 1.0f : 0.0f;
break;
case opLE:
- mData[0] = ( mData[0] <= other.number() ? 1 : 0 );
+ mData[0] = mData[0] <= other.number() ? 1.0f : 0.0f;
break;
return true;
@@ -286,58 +286,58 @@
value1 = mData[i]; value2 = matrix[i];
if( value1 == mNodataValue || value2 == other.mNodataValue )
else
switch( op )
case opPLUS:
- mData[i] = value1 + value2;
+ mData[i] = static_cast<float>( value1 + value2 );
break;
case opMINUS:
- mData[i] = value1 - value2;
+ mData[i] = static_cast<float>( value1 - value2 );
break;
case opMUL:
- mData[i] = value1 * value2;
+ mData[i] = static_cast<float>( value1 * value2 );
break;
case opDIV:
if( value2 == 0 )
else
- mData[i] = value1 / value2;
+ mData[i] = static_cast<float>( value1 / value2 );
break;
case opPOW:
if( !testPowerValidity( value1, value2 ) )
else
- mData[i] = pow( value1, value2 );
+ mData[i] = static_cast<float>( pow( value1, value2 ) );
break;
case opEQ:
- mData[i] = ( value1 == value2 ? 1 : 0 );
+ mData[i] = value1 == value2 ? 1.0f : 0.0f;
break;
case opNE:
- mData[i] = ( value1 == value2 ? 0 : 1 );
+ mData[i] = value1 == value2 ? 0.0f : 1.0f;
break;
case opGT:
- mData[i] = ( value1 > value2 ? 1 : 0 );
+ mData[i] = value1 > value2 ? 1.0f : 0.0f;
break;
case opLT:
- mData[i] = ( value1 < value2 ? 1 : 0 );
+ mData[i] = value1 < value2 ? 1.0f : 0.0f;
break;
case opGE:
- mData[i] = ( value1 >= value2 ? 1 : 0 );
+ mData[i] = value1 >= value2 ? 1.0f : 0.0f;
break;
case opLE:
- mData[i] = ( value1 <= value2 ? 1 : 0 );
+ mData[i] = value1 <= value2 ? 1.0f : 0.0f;
break;
@@ -359,7 +359,7 @@
for( int i = 0; i < nEntries; ++i )
return true;
@@ -368,58 +368,58 @@
if( matrix[i] == other.mNodataValue )
continue;
switch( op )
case opPLUS:
- mData[i] = value + matrix[i];
+ mData[i] = static_cast<float>( value + matrix[i] );
break;
case opMINUS:
- mData[i] = value - matrix[i];
+ mData[i] = static_cast<float>( value - matrix[i] );
break;
case opMUL:
- mData[i] = value * matrix[i];
+ mData[i] = static_cast<float>( value * matrix[i] );
break;
case opDIV:
if( matrix[i] == 0 )
else
- mData[i] = value / matrix[i];
+ mData[i] = static_cast<float>( value / matrix[i] );
break;
case opPOW:
if( !testPowerValidity( value, matrix[i] ) )
else
- mData[i] = pow(( float ) value, matrix[i] );
+ mData[i] = pow( static_cast<float>( value ), matrix[i] );
break;
case opEQ:
- mData[i] = ( value == matrix[i] ? 1 : 0 );
+ mData[i] = value == matrix[i] ? 1.0f : 0.0f;
break;
case opNE:
- mData[i] = ( value == matrix[i] ? 0 : 1 );
+ mData[i] = value == matrix[i] ? 0.0f : 1.0f;
break;
case opGT:
- mData[i] = ( value > matrix[i] ? 1 : 0 );
+ mData[i] = value > matrix[i] ? 1.0f : 0.0f;
break;
case opLT:
- mData[i] = ( value < matrix[i] ? 1 : 0 );
+ mData[i] = value < matrix[i] ? 1.0f : 0.0f;
break;
case opGE:
- mData[i] = ( value >= matrix[i] ? 1 : 0 );
+ mData[i] = value >= matrix[i] ? 1.0f : 0.0f;
break;
case opLE:
- mData[i] = ( value <= matrix[i] ? 1 : 0 );
+ mData[i] = value <= matrix[i] ? 1.0f : 0.0f;
break;
@@ -434,7 +434,7 @@
return true;
@@ -449,28 +449,28 @@
switch( op )
case opPLUS:
- mData[i] = mData[i] + value;
+ mData[i] = static_cast<float>( mData[i] + value );
break;
case opMINUS:
- mData[i] = mData[i] - value;
+ mData[i] = static_cast<float>( mData[i] - value );
break;
case opMUL:
- mData[i] = mData[i] * value;
+ mData[i] = static_cast<float>( mData[i] * value );
break;
case opDIV:
if( value == 0 )
else
- mData[i] = mData[i] / value;
+ mData[i] = static_cast<float>( mData[i] / value );
break;
case opPOW:
if( !testPowerValidity( mData[i], value ) )
else
@@ -478,22 +478,22 @@
break;
case opEQ:
- mData[i] = ( mData[i] == value ? 1 : 0 );
+ mData[i] = mData[i] == value ? 1.0f : 0.0f;
break;
case opNE:
- mData[i] = ( mData[i] == value ? 0 : 1 );
+ mData[i] = mData[i] == value ? 0.0f : 1.0f;
break;
case opGT:
- mData[i] = ( mData[i] > value ? 1 : 0 );
+ mData[i] = mData[i] > value ? 1.0f : 0.0f;
break;
case opLT:
- mData[i] = ( mData[i] < value ? 1 : 0 );
+ mData[i] = mData[i] < value ? 1.0f : 0.0f;
break;
case opGE:
- mData[i] = ( mData[i] >= value ? 1 : 0 );
+ mData[i] = mData[i] >= value ? 1.0f : 0.0f;
break;
case opLE:
- mData[i] = ( mData[i] <= value ? 1 : 0 );
+ mData[i] = mData[i] <= value ? 1.0f : 0.0f;
break;
