[QGIS Commit] r14582 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Sat Nov 13 05:19:52 EST 2010
Author: jef
Date: 2010-11-13 02:19:52 -0800 (Sat, 13 Nov 2010)
New Revision: 14582
trunk/qgis/src/ui/qgsattributetabledialog.ui
apply #1468
Modified: trunk/qgis/src/ui/qgsattributetabledialog.ui
--- trunk/qgis/src/ui/qgsattributetabledialog.ui 2010-11-13 10:10:46 UTC (rev 14581)
+++ trunk/qgis/src/ui/qgsattributetabledialog.ui 2010-11-13 10:19:52 UTC (rev 14582)
@@ -96,7 +96,7 @@
<item>
<widget class="QToolButton" name="mRemoveSelectionButton">
<property name="toolTip">
- <string>Unselect all</string>
+ <string>Unselect all (Ctrl+U)</string>
</property>
<property name="text">
<string/>
@@ -112,14 +112,14 @@
</size>
</property>
<property name="shortcut">
- <string/>
+ <string>Ctrl+U</string>
</property>
</widget>
</item>
<item>
<widget class="QToolButton" name="mSelectedToTopButton">
- <string>Move selection to top</string>
+ <string>Move selection to top (Ctrl+T)</string>
</property>
<string/>
@@ -142,7 +142,7 @@
<item>
<widget class="QToolButton" name="mInvertSelectionButton">
- <string>Invert selection</string>
+ <string>Invert selection (Ctrl+S)</string>
</property>
<string/>
@@ -191,7 +191,7 @@
<item>
<widget class="QToolButton" name="mZoomMapToSelectedRowsButton">
- <string>Zoom map to the selected rows (Ctrl-J)</string>
+ <string>Zoom map to the selected rows (Ctrl+J)</string>
</property>
<property name="whatsThis">
<string/>
@@ -217,7 +217,7 @@
<item>
<widget class="QToolButton" name="mToggleEditingButton">
- <string>Toggle editing mode</string>
+ <string>Toggle editing mode (Ctrl+E)</string>
</property>
<string/>
@@ -235,6 +235,9 @@
<height>18</height>
</size>
</property>
+ <property name="shortcut">
+ <string>Ctrl+E</string>
+ </property>
<property name="checkable">
<bool>true</bool>
</property>
@@ -243,7 +246,7 @@
<item>
<widget class="QToolButton" name="mDeleteSelectedButton">
- <string>Delete selected features</string>
+ <string>Delete selected features (Ctrl+D)</string>
</property>
<string>...</string>
@@ -258,12 +261,15 @@
<height>18</height>
</size>
</property>
+ <string>Ctrl+D</string>
+ </property>
</widget>
</item>
<item>
<widget class="QToolButton" name="mAddAttribute">
- <string>New column</string>
+ <string>New column (Ctrl+W)</string>
</property>
<string/>
@@ -278,12 +284,15 @@
<height>18</height>
</size>
</property>
+ <string>Ctrl+W</string>
+ </property>
</widget>
</item>
<item>
<widget class="QToolButton" name="mRemoveAttribute">
- <string>Delete column</string>
+ <string>Delete column (Ctrl+L)</string>
</property>
<string/>
@@ -298,12 +307,15 @@
<height>18</height>
</size>
</property>
+ <string>Ctrl+L</string>
+ </property>
</widget>
</item>
<item>
<widget class="QToolButton" name="mOpenFieldCalculator">
- <string>Open field calculator</string>
+ <string>Open field calculator (Ctrl+I)</string>
</property>
<string/>
@@ -318,6 +330,9 @@
<height>18</height>
</size>
</property>
+ <string>Ctrl+I</string>
+ </property>
</widget>
</item>
<item>
