[QGIS Commit] r14593 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 13 08:49:30 EST 2010
Author: pcav
Date: 2010-11-13 05:49:30 -0800 (Sat, 13 Nov 2010)
New Revision: 14593
Added:
   trunk/qgis/src/plugins/grass/modules-common/r.cost.coord.1.png
   trunk/qgis/src/plugins/grass/modules-common/r.cost.coord.2.png
   trunk/qgis/src/plugins/grass/modules-common/r.cost.rast.1.png
   trunk/qgis/src/plugins/grass/modules-common/r.cost.rast.2.png
   trunk/qgis/src/plugins/grass/modules-common/r.cost.vect.1.png
   trunk/qgis/src/plugins/grass/modules-common/r.cost.vect.2.png
Removed:
   trunk/qgis/src/plugins/grass/modules-common/r.cost.1.png
   trunk/qgis/src/plugins/grass/modules-common/r.cost.2.png
   trunk/qgis/src/plugins/grass/modules-common/r.cost.qgm
Followup of r14591 - some icons done
Deleted: trunk/qgis/src/plugins/grass/modules-common/r.cost.1.png
(Binary files differ)
Deleted: trunk/qgis/src/plugins/grass/modules-common/r.cost.2.png
Added: trunk/qgis/src/plugins/grass/modules-common/r.cost.coord.1.png
Property changes on: trunk/qgis/src/plugins/grass/modules-common/r.cost.coord.1.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules-common/r.cost.coord.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-common/r.cost.coord.2.png
Deleted: trunk/qgis/src/plugins/grass/modules-common/r.cost.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.cost.qgm	2010-11-13 13:44:44 UTC (rev 14592)
+++ trunk/qgis/src/plugins/grass/modules-common/r.cost.qgm	2010-11-13 13:49:30 UTC (rev 14593)
@@ -1,10 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Generate raster of cumulative cost of moving between locations based on cost input raster" module="r.cost">
-	<option key="input"/>
-	<option key="output"/>
-	<option key="start_rast"/>
-	<option key="max_cost" answer="0" hidden="no"/>
-	<flag key="k" answer="off" hidden="no" />
-</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules-common/r.cost.rast.1.png
Property changes on: trunk/qgis/src/plugins/grass/modules-common/r.cost.rast.1.png
Added: trunk/qgis/src/plugins/grass/modules-common/r.cost.rast.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-common/r.cost.rast.2.png
Added: trunk/qgis/src/plugins/grass/modules-common/r.cost.vect.1.png
Property changes on: trunk/qgis/src/plugins/grass/modules-common/r.cost.vect.1.png
Added: trunk/qgis/src/plugins/grass/modules-common/r.cost.vect.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-common/r.cost.vect.2.png
More information about the QGIS-commit mailing list
