[QGIS Commit] r14614 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sat Nov 13 13:24:48 EST 2010
Author: timlinux
Date: 2010-11-13 10:24:48 -0800 (Sat, 13 Nov 2010)
New Revision: 14614
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
Tidy up for the options window to use top tabs as per gui discussion at Wroclaw Hackfest
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2010-11-13 18:06:19 UTC (rev 14613)
+++ trunk/qgis/src/app/qgsoptions.cpp 2010-11-13 18:24:48 UTC (rev 14614)
@@ -389,7 +389,7 @@
} //default is central point
restoreGeometry( settings.value( "/Windows/Options/geometry" ).toByteArray() );
- listWidget->setCurrentRow( settings.value( "/Windows/Options/row" ).toInt() );
+ tabWidget->setCurrentIndex( settings.value( "/Windows/Options/row" ).toInt() );
//! Destructor
@@ -397,7 +397,7 @@
QSettings settings;
settings.setValue( "/Windows/Options/geometry", saveGeometry() );
- settings.setValue( "/Windows/Options/row", listWidget->currentRow() );
+ settings.setValue( "/Windows/Options/row", tabWidget->currentIndex() );
void QgsOptions::on_pbnSelectionColor_clicked()
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2010-11-13 18:06:19 UTC (rev 14613)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2010-11-13 18:24:48 UTC (rev 14614)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>700</width>
- <height>442</height>
+ <width>804</width>
+ <height>567</height>
</rect>
</property>
<property name="windowTitle">
@@ -20,199 +20,7 @@
<bool>true</bool>
</property>
<layout class="QGridLayout" name="gridLayout_3">
- <item row="0" column="0">
- <widget class="QListWidget" name="listWidget">
- <property name="minimumSize">
- <size>
- <width>110</width>
- <height>0</height>
- </size>
- </property>
- <property name="maximumSize">
- <size>
- <height>16777215</height>
- </size>
- </property>
- <property name="frameShape">
- <enum>QFrame::NoFrame</enum>
- </property>
- <property name="frameShadow">
- <enum>QFrame::Plain</enum>
- </property>
- <property name="horizontalScrollBarPolicy">
- <enum>Qt::ScrollBarAlwaysOff</enum>
- </property>
- <property name="editTriggers">
- <set>QAbstractItemView::NoEditTriggers</set>
- </property>
- <property name="showDropIndicator" stdset="0">
- <bool>false</bool>
- </property>
- <property name="iconSize">
- <size>
- <width>64</width>
- <height>64</height>
- </size>
- </property>
- <property name="textElideMode">
- <enum>Qt::ElideNone</enum>
- </property>
- <property name="flow">
- <enum>QListView::TopToBottom</enum>
- </property>
- <property name="isWrapping" stdset="0">
- </property>
- <property name="resizeMode">
- <enum>QListView::Adjust</enum>
- </property>
- <property name="spacing">
- <number>9</number>
- </property>
- <property name="viewMode">
- <enum>QListView::IconMode</enum>
- </property>
- <property name="wordWrap">
- <bool>true</bool>
- </property>
- <property name="currentRow">
- <number>0</number>
- </property>
- <item>
- <property name="text">
- <string>General</string>
- </property>
- <property name="textAlignment">
- <set>AlignHCenter|AlignVCenter|AlignCenter</set>
- </property>
- <property name="icon">
- <iconset resource="../../images/images.qrc">
- <normaloff>:/images/themes/default/propertyicons/general.png</normaloff>:/images/themes/default/propertyicons/general.png</iconset>
- </property>
- <property name="flags">
- <set>ItemIsSelectable|ItemIsUserCheckable|ItemIsEnabled</set>
- </property>
- </item>
- <item>
- <string>Rendering & SVG</string>
- </property>
- </property>
- <normaloff>:/images/themes/default/propertyicons/rendering.png</normaloff>:/images/themes/default/propertyicons/rendering.png</iconset>
- </property>
- </property>
- </item>
- <item>
- <string>Map tools</string>
- </property>
- </property>
- <normaloff>:/images/themes/default/propertyicons/map_tools.png</normaloff>:/images/themes/default/propertyicons/map_tools.png</iconset>
- </property>
- </property>
- </item>
- <item>
- <string>Overlay</string>
- </property>
- </property>
- <normaloff>:/images/themes/default/propertyicons/overlay.png</normaloff>:/images/themes/default/propertyicons/overlay.png</iconset>
- </property>
- </property>
- </item>
- <item>
- <string>Digitizing</string>
- </property>
- </property>
- <normaloff>:/images/themes/default/propertyicons/digitising.png</normaloff>:/images/themes/default/propertyicons/digitising.png</iconset>
- </property>
- </property>
- </item>
- <item>
- <string>CRS</string>
- </property>
- </property>
- <normaloff>:/images/themes/default/propertyicons/CRS.png</normaloff>:/images/themes/default/propertyicons/CRS.png</iconset>
- </property>
- </property>
- </item>
- <item>
- <string>Locale</string>
- </property>
- </property>
- <normaloff>:/images/themes/default/propertyicons/locale.png</normaloff>:/images/themes/default/propertyicons/locale.png</iconset>
- </property>
- </property>
- </item>
- <item>
- <string>Network & Proxy</string>
- </property>
- </property>
- <normaloff>:/images/themes/default/propertyicons/network_and_proxy.png</normaloff>:/images/themes/default/propertyicons/network_and_proxy.png</iconset>
- </property>
- </property>
- </item>
- <item>
- <string notr="true"/>
- </property>
- </property>
- <set>NoItemFlags</set>
- </property>
- </item>
- </widget>
- </item>
- <item row="1" column="0" colspan="2">
+ <item row="1" column="0">
<widget class="QDialogButtonBox" name="buttonBox">
<property name="orientation">
<enum>Qt::Horizontal</enum>
@@ -222,12 +30,25 @@
</property>
</widget>
</item>
- <item row="0" column="1">
- <widget class="QStackedWidget" name="stackedWidget">
+ <item row="0" column="0">
+ <widget class="QTabWidget" name="tabWidget">
<property name="currentIndex">
<number>0</number>
</property>
- <widget class="QWidget" name="stackedWidgetPage1">
+ <property name="iconSize">
+ <size>
+ <width>32</width>
+ <height>32</height>
+ </size>
+ </property>
+ <widget class="QWidget" name="tabWidgetPage1" native="true">
+ <attribute name="icon">
+ <iconset resource="../../images/images.qrc">
+ <normaloff>:/images/themes/default/propertyicons/general.png</normaloff>:/images/themes/default/propertyicons/general.png</iconset>
+ </attribute>
+ <attribute name="title">
+ <string>General</string>
+ </attribute>
<layout class="QGridLayout" name="gridLayout_7">
<widget class="QScrollArea" name="scrollArea_2">
@@ -239,7 +60,7 @@
<rect>
<x>0</x>
<y>0</y>
- <width>530</width>
+ <width>746</width>
<height>530</height>
</rect>
</property>
@@ -497,7 +318,14 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage2">
+ <widget class="QWidget" name="tabWidgetPage2" native="true">
+ <normaloff>:/images/themes/default/propertyicons/rendering.png</normaloff>:/images/themes/default/propertyicons/rendering.png</iconset>
+ </attribute>
+ <string>Rendering</string>
+ </attribute>
<layout class="QGridLayout" name="gridLayout_9">
<widget class="QScrollArea" name="scrollArea_3">
@@ -509,8 +337,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>659</width>
- <height>551</height>
+ <height>473</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_8">
@@ -661,7 +489,14 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage3">
+ <widget class="QWidget" name="tabWidgetPage3" native="true">
+ <normaloff>:/images/themes/default/propertyicons/map_tools.png</normaloff>:/images/themes/default/propertyicons/map_tools.png</iconset>
+ </attribute>
+ <string>Map tools</string>
+ </attribute>
<layout class="QGridLayout" name="gridLayout_6">
<widget class="QScrollArea" name="scrollArea">
@@ -673,8 +508,8 @@
<rect>
<x>0</x>
<y>0</y>
+ <height>490</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_4">
@@ -934,7 +769,14 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage4">
+ <widget class="QWidget" name="tabWidgetPage4" native="true">
+ <normaloff>:/images/themes/default/propertyicons/overlay.png</normaloff>:/images/themes/default/propertyicons/overlay.png</iconset>
+ </attribute>
+ <string>Overlays</string>
+ </attribute>
<layout class="QGridLayout" name="gridLayout_11">
<widget class="QScrollArea" name="scrollArea_4">
@@ -946,8 +788,8 @@
<rect>
<x>0</x>
<y>0</y>
+ <width>762</width>
+ <height>448</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_10">
@@ -1002,7 +844,14 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage5">
+ <widget class="QWidget" name="tabWidgetPage5" native="true">
+ <normaloff>:/images/themes/default/propertyicons/digitising.png</normaloff>:/images/themes/default/propertyicons/digitising.png</iconset>
+ </attribute>
+ <string>Digitizing</string>
+ </attribute>
<layout class="QGridLayout" name="gridLayout_14">
<widget class="QScrollArea" name="scrollArea_5">
@@ -1014,8 +863,8 @@
<rect>
<x>0</x>
<y>0</y>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_13">
@@ -1289,7 +1138,7 @@
<string>Reuse last entered attribute values</string>
</property>
<property name="tristate">
+ <bool>false</bool>
</property>
</widget>
</item>
@@ -1325,7 +1174,14 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage6">
+ <widget class="QWidget" name="tabWidgetPage6" native="true">
+ <normaloff>:/images/themes/default/propertyicons/CRS.png</normaloff>:/images/themes/default/propertyicons/CRS.png</iconset>
+ </attribute>
+ <string>CRS</string>
+ </attribute>
<layout class="QGridLayout" name="gridLayout_16">
<widget class="QScrollArea" name="scrollArea_6">
@@ -1337,8 +1193,8 @@
<rect>
<x>0</x>
<y>0</y>
+ <height>531</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_15">
@@ -1414,7 +1270,14 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage7">
+ <widget class="QWidget" name="tabWidgetPage7" native="true">
+ <normaloff>:/images/themes/default/propertyicons/locale.png</normaloff>:/images/themes/default/propertyicons/locale.png</iconset>
+ </attribute>
+ <string>Locale</string>
+ </attribute>
<layout class="QGridLayout" name="gridLayout_18">
<widget class="QScrollArea" name="scrollArea_7">
@@ -1426,8 +1289,8 @@
<rect>
<x>0</x>
<y>0</y>
+ <height>548</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_17">
@@ -1498,7 +1361,14 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage8">
+ <widget class="QWidget" name="tabWidgetPage8" native="true">
+ <normaloff>:/images/themes/default/propertyicons/network_and_proxy.png</normaloff>:/images/themes/default/propertyicons/network_and_proxy.png</iconset>
+ </attribute>
+ <string>Network</string>
+ </attribute>
<layout class="QGridLayout" name="gridLayout_19">
<widget class="QScrollArea" name="scrollArea_8">
@@ -1510,8 +1380,8 @@
<rect>
<x>0</x>
<y>0</y>
+ <height>538</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_20">
@@ -1696,9 +1566,6 @@
<string>WMS search address</string>
</property>
- <property name="buddy">
- <cstring>leWmsSearch</cstring>
- </property>
</widget>
</item>
<item>
@@ -1743,7 +1610,7 @@
</customwidget>
</customwidgets>
<tabstops>
- <tabstop>stackedWidget</tabstop>
+ <tabstop>tabWidget</tabstop>
<tabstop>chbAskToSaveProjectChanges</tabstop>
<tabstop>chbWarnOldProjectVersion</tabstop>
<tabstop>pbnSelectionColor</tabstop>
@@ -1835,21 +1702,5 @@
</hint>
</hints>
</connection>
- <connection>
- <sender>listWidget</sender>
- <signal>currentRowChanged(int)</signal>
- <receiver>stackedWidget</receiver>
- <slot>setCurrentIndex(int)</slot>
- <hints>
- <hint type="sourcelabel">
- <x>113</x>
- <y>25</y>
- </hint>
- <hint type="destinationlabel">
- <x>808</x>
- <y>18</y>
- </hint>
- </hints>
- </connection>
</connections>
</ui>
