[QGIS Commit] r14619 - in branches/raster-providers/src: core core/raster providers/gdal providers/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 13 15:17:49 EST 2010
Author: rblazek
Date: 2010-11-13 12:17:49 -0800 (Sat, 13 Nov 2010)
New Revision: 14619
   branches/raster-providers/src/core/qgsrasterdataprovider.cpp
   branches/raster-providers/src/core/qgsrasterdataprovider.h
   branches/raster-providers/src/core/raster/qgsrasterlayer.cpp
   branches/raster-providers/src/core/raster/qgsrasterlayer.h
   branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp
   branches/raster-providers/src/providers/gdal/qgsgdalprovider.h
   branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp
   branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h
movin more gdal to gdal, partialy broken
Modified: branches/raster-providers/src/core/qgsrasterdataprovider.cpp
--- branches/raster-providers/src/core/qgsrasterdataprovider.cpp	2010-11-13 20:15:46 UTC (rev 14618)
+++ branches/raster-providers/src/core/qgsrasterdataprovider.cpp	2010-11-13 20:17:49 UTC (rev 14619)
@@ -120,4 +120,12 @@
   return "text/plain";
+//void QgsRasterDataProvider::buildSupportedRasterFileFilter( QString & theFileFiltersString )
+void QgsRasterDataProvider::buildSupportedRasterFileFilter( QString & theFileFiltersString )
+  QgsDebugMsg ( "Entered" );
 // ENDS
Modified: branches/raster-providers/src/core/qgsrasterdataprovider.h
--- branches/raster-providers/src/core/qgsrasterdataprovider.h	2010-11-13 20:15:46 UTC (rev 14618)
+++ branches/raster-providers/src/core/qgsrasterdataprovider.h	2010-11-13 20:17:49 UTC (rev 14619)
@@ -53,7 +53,9 @@
       Draw =                   1 << 1,
       // Data: the provider is capable to return data values, so that
       // QgsRasterLayer can render them using selected rendering mode, e.g. GDAL, GRASS
-      Data =          1 << 2
+      Data =          1 << 2,
+      ExactMinimumMaximum =   1 << 3,
+      EstimatedMinimumMaximum =  1 << 4,
     // This is modified copy of GDALDataType
@@ -310,6 +312,9 @@
     /** \brief Is the NoDataValue Valid */
     bool isNoDataValueValid() const { return mValidNoDataValue; }
+    void buildSupportedRasterFileFilter( QString & theFileFiltersString ) ;
     static QStringList cStringList2Q_( char ** stringList );
     static QString makeTableCell( QString const & value );
Modified: branches/raster-providers/src/core/raster/qgsrasterlayer.cpp
--- branches/raster-providers/src/core/raster/qgsrasterlayer.cpp	2010-11-13 20:15:46 UTC (rev 14618)
+++ branches/raster-providers/src/core/raster/qgsrasterlayer.cpp	2010-11-13 20:17:49 UTC (rev 14619)
@@ -92,84 +92,11 @@
   QgsDebugMsg("Entered");
   // TODO, call constructor with provider key for now
-  setDataProvider( "gdal", QStringList(), QStringList(), QString(), QString() );
+  init();
+  setDataProvider( "gdal", QStringList(), QStringList(), QString(), QString(), loadDefaultStyleFlag );
   return;
-  // TODO: add this somewhere - in another constructor
-  mRasterType = QgsRasterLayer::GrayOrUndefined;
-  mRedBandName = TRSTRING_NOT_SET;
-  mGreenBandName = TRSTRING_NOT_SET;
-  mBlueBandName = TRSTRING_NOT_SET;
-  mGrayBandName = TRSTRING_NOT_SET;
-  mTransparencyBandName = TRSTRING_NOT_SET;
-  mUserDefinedRGBMinimumMaximum = false; //defaults needed to bypass enhanceContrast
-  mUserDefinedGrayMinimumMaximum = false;
-  mRGBMinimumMaximumEstimated = true;
-  mGrayMinimumMaximumEstimated = true;
-  mDrawingStyle = QgsRasterLayer::UndefinedDrawingStyle;
-  mContrastEnhancementAlgorithm = QgsContrastEnhancement::NoEnhancement;
-  mColorShadingAlgorithm = QgsRasterLayer::UndefinedShader;
-  mRasterShader = new QgsRasterShader();
-  mBandCount = 0;
-  mHasPyramids = false;
-  mNoDataValue = -9999.0;
-  mValidNoDataValue = false;
-  mGdalBaseDataset = 0;
-  mGdalDataset = 0;
-  // Initialise the affine transform matrix
-  mGeoTransform[0] =  0;
-  mGeoTransform[1] =  1;
-  mGeoTransform[2] =  0;
-  mGeoTransform[3] =  0;
-  mGeoTransform[4] =  0;
-  mGeoTransform[5] = -1;
-  // set the layer name (uppercase first character)
-  if ( ! baseName.isEmpty() )   // XXX shouldn't this happen in parent?
-    setLayerName( baseName );
-  // load the file if one specified
-  if ( ! path.isEmpty() )
-    readFile( path ); // XXX check for failure?
-    //readFile() is really an extension of the constructor as many imporant fields are set in this method
-    //loadDefaultStyle() can not be called before the layer has actually be opened
-    if ( loadDefaultStyleFlag )
-      bool defaultLoadedFlag = false;
-      loadDefaultStyle( defaultLoadedFlag );
-      if ( defaultLoadedFlag )
-        return;
-  //Initialize the last view port structure, should really be a class
-  mLastViewPort.rectXOffset = 0;
-  mLastViewPort.rectXOffsetFloat = 0.0;
-  mLastViewPort.rectYOffset = 0;
-  mLastViewPort.rectYOffsetFloat = 0.0;
-  mLastViewPort.clippedXMin = 0.0;
-  mLastViewPort.clippedXMax = 0.0;
-  mLastViewPort.clippedYMin = 0.0;
-  mLastViewPort.clippedYMax = 0.0;
-  mLastViewPort.clippedWidth = 0;
-  mLastViewPort.clippedHeight = 0;
-  mLastViewPort.drawableAreaXDim = 0;
-  mLastViewPort.drawableAreaYDim = 0;
 } // QgsRasterLayer ctor
@@ -199,8 +126,10 @@
                format +  " and CRS of " + crs );
+  init();
   // if we're given a provider type, try to create and bind one to this layer
-  setDataProvider( providerKey, layers, styles, format, crs );
+  bool loadDefaultStyleFlag = false ; // ???
+  setDataProvider( providerKey, layers, styles, format, crs, loadDefaultStyleFlag);
   // Default for the popup menu
   // TODO: popMenu = 0;
@@ -230,20 +159,9 @@
 QgsRasterLayer::~QgsRasterLayer()
-  if ( mProviderKey.isEmpty() )
-    if ( mGdalBaseDataset )
-      GDALDereferenceDataset( mGdalBaseDataset );
-    if ( mGdalDataset )
-      GDALClose( mGdalDataset );
+  mValid = false;
   delete mRasterShader;
+  delete mDataProvider;
@@ -257,190 +175,35 @@
   Builds the list of file filter strings to later be used by
-  QgisApp::addRasterLayer()
+  QgisApp::addRasterLayer()
   We query GDAL for a list of supported raster formats; we then build
   a list of file filter strings from that list.  We return a string
   that contains this list that is suitable for use in a
   QFileDialog::getOpenFileNames() call.
 void QgsRasterLayer::buildSupportedRasterFileFilter( QString & theFileFiltersString )
-  // first get the GDAL driver manager
-  //registerGdalDrivers();
-  // then iterate through all of the supported drivers, adding the
-  // corresponding file filter
-  GDALDriverH myGdalDriver;           // current driver
-  char **myGdalDriverMetadata;        // driver metadata strings
-  QString myGdalDriverLongName( "" ); // long name for the given driver
-  QString myGdalDriverExtension( "" );  // file name extension for given driver
-  QString myGdalDriverDescription;    // QString wrapper of GDAL driver description
-  QStringList metadataTokens;   // essentially the metadata string delimited by '='
-  QStringList catchallFilter;   // for Any file(*.*), but also for those
-  // drivers with no specific file filter
-  GDALDriverH jp2Driver = NULL; // first JPEG2000 driver found
-  // Grind through all the drivers and their respective metadata.
-  // We'll add a file filter for those drivers that have a file
-  // extension defined for them; the others, well, even though
-  // theoreticaly we can open those files because there exists a
-  // driver for them, the user will have to use the "All Files" to
-  // open datasets with no explicitly defined file name extension.
-  // Note that file name extension strings are of the form
-  // "DMD_EXTENSION=.*".  We'll also store the long name of the
-  // driver, which will be found in DMD_LONGNAME, which will have the
-  // same form.
-  // start with the default case
-  theFileFiltersString = tr( "[GDAL] All files (*)" );
-  for ( int i = 0; i < GDALGetDriverCount(); ++i )
+  QgsDebugMsg( "Entered" );
+  QgsRasterDataProvider *myDataProvider = QgsRasterLayer::loadProvider ( "gdal" );
+  if ( !myDataProvider )
-    myGdalDriver = GDALGetDriver( i );
+    QgsDebugMsg( "Could not createe gdal provider" );
+    return;
+  myDataProvider->buildSupportedRasterFileFilter( theFileFiltersString );
+  // crash
+  //delete myDataProvider;
+  QgsDebugMsg( "file filter: " + theFileFiltersString );
+  exit(0);
-    Q_CHECK_PTR( myGdalDriver );
-    if ( !myGdalDriver )
-      QgsLogger::warning( "unable to get driver " + QString::number( i ) );
-      continue;
-    // now we need to see if the driver is for something currently
-    // supported; if not, we give it a miss for the next driver
-    myGdalDriverDescription = GDALGetDescription( myGdalDriver );
-    // QgsDebugMsg(QString("got driver string %1").arg(myGdalDriverDescription));
-    myGdalDriverMetadata = GDALGetMetadata( myGdalDriver, NULL );
-    // presumably we know we've run out of metadta if either the
-    // address is 0, or the first character is null
-    while ( myGdalDriverMetadata && '\0' != myGdalDriverMetadata[0] )
-      metadataTokens = QString( *myGdalDriverMetadata ).split( "=", QString::SkipEmptyParts );
-      // QgsDebugMsg(QString("\t%1").arg(*myGdalDriverMetadata));
-      // XXX add check for malformed metadataTokens
-      // Note that it's oddly possible for there to be a
-      // DMD_EXTENSION with no corresponding defined extension
-      // string; so we check that there're more than two tokens.
-      if ( metadataTokens.count() > 1 )
-        if ( "DMD_EXTENSION" == metadataTokens[0] )
-          myGdalDriverExtension = metadataTokens[1];
-        else if ( "DMD_LONGNAME" == metadataTokens[0] )
-          myGdalDriverLongName = metadataTokens[1];
-          // remove any superfluous (.*) strings at the end as
-          // they'll confuse QFileDialog::getOpenFileNames()
-          myGdalDriverLongName.remove( QRegExp( "\\(.*\\)$" ) );
-      // if we have both the file name extension and the long name,
-      // then we've all the information we need for the current
-      // driver; therefore emit a file filter string and move to
-      // the next driver
-      if ( !( myGdalDriverExtension.isEmpty() || myGdalDriverLongName.isEmpty() ) )
-        // XXX add check for SDTS; in that case we want (*CATD.DDF)
-        QString glob = "*." + myGdalDriverExtension.replace( "/", " *." );
-        // Add only the first JP2 driver found to the filter list (it's the one GDAL uses)
-        if ( myGdalDriverDescription == "JPEG2000" ||
-             myGdalDriverDescription.startsWith( "JP2" ) ) // JP2ECW, JP2KAK, JP2MrSID
-          if ( jp2Driver )
-            break; // skip if already found a JP2 driver
-          jp2Driver = myGdalDriver;   // first JP2 driver found
-          glob += " *.j2k";           // add alternate extension
-        else if ( myGdalDriverDescription == "GTiff" )
-          glob += " *.tiff";
-        else if ( myGdalDriverDescription == "JPEG" )
-          glob += " *.jpeg";
-        theFileFiltersString += ";;[GDAL] " + myGdalDriverLongName + " (" + glob.toLower() + " " + glob.toUpper() + ")";
-        break;            // ... to next driver, if any.
-      ++myGdalDriverMetadata;
-    }                       // each metadata item
-    if ( myGdalDriverExtension.isEmpty() && !myGdalDriverLongName.isEmpty() )
-      // Then what we have here is a driver with no corresponding
-      // file extension; e.g., GRASS.  In which case we append the
-      // string to the "catch-all" which will match all file types.
-      // (I.e., "*.*") We use the driver description intead of the
-      // long time to prevent the catch-all line from getting too
-      // large.
-      // ... OTOH, there are some drivers with missing
-      // DMD_EXTENSION; so let's check for them here and handle
-      // them appropriately
-      // USGS DEMs use "*.dem"
-      if ( myGdalDriverDescription.startsWith( "USGSDEM" ) )
-        QString glob = "*.dem";
-      else if ( myGdalDriverDescription.startsWith( "DTED" ) )
-        // DTED use "*.dt0, *.dt1, *.dt2"
-        QString glob = "*.dt0";
-        glob += " *.dt1";
-        glob += " *.dt2";
-      else if ( myGdalDriverDescription.startsWith( "MrSID" ) )
-        // MrSID use "*.sid"
-        QString glob = "*.sid";
-      else
-        catchallFilter << QString( GDALGetDescription( myGdalDriver ) );
-    myGdalDriverExtension = myGdalDriverLongName = "";  // reset for next driver
-  }                           // each loaded GDAL driver
-  QgsDebugMsg( "Raster filter list built: " + theFileFiltersString );
-}                               // buildSupportedRasterFileFilter_()
  * This helper checks to see whether the file name appears to be a valid raster file name
 bool QgsRasterLayer::isValidRasterFileName( QString const & theFileNameQString, QString & retErrMsg )
   GDALDatasetH myDataset;
   // TODO
   return true;
@@ -771,6 +534,7 @@
         for ( int iX = 0; iX < nXValid; iX++ )
           double myValue = readValue( myData, myDataType, iX + ( iY * myXBlockSize ) );
+          QgsDebugMsg ( QString ( "%1 %2 value %3" ).arg (iX).arg(iY).arg( myValue ) );
           if ( mValidNoDataValue && ( fabs( myValue - mNoDataValue ) <= TINY_VALUE || myValue != myValue ) )
@@ -3034,25 +2798,9 @@
   mBlueBandName = validateBandName( theBandName );
-/** Copied from QgsVectorLayer::setDataProvider
- *  TODO: Make it work in the raster environment
-void QgsRasterLayer::setDataProvider( QString const & provider,
-                                      QStringList const & layers,
-                                      QStringList const & styles,
-                                      QString const & format,
-                                      QString const & crs )
+void QgsRasterLayer::init()
-  // XXX should I check for and possibly delete any pre-existing providers?
-  // XXX How often will that scenario occur?
-  mProviderKey = provider;     // XXX is this necessary?  Usually already set
-  // XXX when execution gets here.
-  mBandCount = 0;
+  // keep this until mGeoTransform occurences are removed !
@@ -3060,9 +2808,56 @@
+  mRasterType = QgsRasterLayer::GrayOrUndefined;
+  mRedBandName = TRSTRING_NOT_SET;
+  mGreenBandName = TRSTRING_NOT_SET;
+  mBlueBandName = TRSTRING_NOT_SET;
+  mGrayBandName = TRSTRING_NOT_SET;
+  mTransparencyBandName = TRSTRING_NOT_SET;
+  mUserDefinedRGBMinimumMaximum = false; //defaults needed to bypass enhanceContrast
+  mUserDefinedGrayMinimumMaximum = false;
+  mRGBMinimumMaximumEstimated = true;
+  mGrayMinimumMaximumEstimated = true;
+  mDrawingStyle = QgsRasterLayer::UndefinedDrawingStyle;
+  mContrastEnhancementAlgorithm = QgsContrastEnhancement::NoEnhancement;
+  mColorShadingAlgorithm = QgsRasterLayer::UndefinedShader;
+  mRasterShader = new QgsRasterShader();
+  mBandCount = 0;
+  mHasPyramids = false;
+  mNoDataValue = -9999.0;
+  mValidNoDataValue = false;
+  mGdalBaseDataset = 0;
+  mGdalDataset = 0;
+  //Initialize the last view port structure, should really be a class
+  mLastViewPort.rectXOffset = 0;
+  mLastViewPort.rectXOffsetFloat = 0.0;
+  mLastViewPort.rectYOffset = 0;
+  mLastViewPort.rectYOffsetFloat = 0.0;
+  mLastViewPort.clippedXMin = 0.0;
+  mLastViewPort.clippedXMax = 0.0;
+  mLastViewPort.clippedYMin = 0.0;
+  mLastViewPort.clippedYMax = 0.0;
+  mLastViewPort.clippedWidth = 0;
+  mLastViewPort.clippedHeight = 0;
+  mLastViewPort.drawableAreaXDim = 0;
+  mLastViewPort.drawableAreaYDim = 0;
+// This code should be shared also by vector layer -> move it to QgsMapLayer
+QgsRasterDataProvider* QgsRasterLayer::loadProvider( QString theProviderKey, QString theDataSource )
   // load the plugin
   QgsProviderRegistry * pReg = QgsProviderRegistry::instance();
-  QString ogrlib = pReg->library( provider );
+  QString ogrlib = pReg->library( theProviderKey );
   //QString ogrlib = libDir + "/libpostgresprovider.so";
@@ -3084,25 +2879,24 @@
 #endif
   // load the data provider
-  mLib = new QLibrary( ogrlib );
-  QgsDebugMsg( "Library name is " + mLib->fileName() );
-  bool loaded = mLib->load();
+  QLibrary*  myLib = new QLibrary( ogrlib );
+  QgsDebugMsg( "Library name is " + myLib->fileName() );
+  bool loaded = myLib->load();
-  mValid = false;            // assume the layer is invalid until we determine otherwise
   if ( !loaded )
-    mValid = false;
-    QgsLogger::warning( "QgsRasterLayer::setDataProvider: Failed to load ../providers/libproviders.so" );
+    QgsLogger::warning( "QgsRasterLayer::setDataProvider: Failed to load " );
   QgsDebugMsg( "Loaded data provider library" );
   QgsDebugMsg( "Attempting to resolve the classFactory function" );
-  classFactoryFunction_t * classFactory = ( classFactoryFunction_t * ) cast_to_fptr( mLib->resolve( "classFactory" ) );
+  classFactoryFunction_t * classFactory = ( classFactoryFunction_t * ) cast_to_fptr( myLib->resolve( "classFactory" ) );
   if ( !classFactory )
       QgsLogger::warning( "QgsRasterLayer::setDataProvider: Cannot resolve the classFactory function" );
-      return;
+      return NULL;
   QgsDebugMsg( "Getting pointer to a mDataProvider object from the library" );
   //XXX - This was a dynamic cast but that kills the Windows
@@ -3111,13 +2905,58 @@
   //                                              char*)(dataSource.utf8())));
   // Copied from qgsproviderregistry in preference to the above.
-  mDataProvider = ( QgsRasterDataProvider* )( *classFactory )( &mDataSource );
+  QgsRasterDataProvider* myDataProvider = ( QgsRasterDataProvider* )( *classFactory )( &theDataSource );
-  if ( !mDataProvider )
     QgsLogger::warning( "QgsRasterLayer::setDataProvider: Unable to instantiate the data provider plugin" );
+    return NULL;
+  QgsDebugMsg( "Data driver created" );
+  return myDataProvider;
+void QgsRasterLayer::setDataProvider( QString const & provider,
+                                      QStringList const & layers,
+                                      QStringList const & styles,
+                                      QString const & format,
+                                      QString const & crs) {
+  setDataProvider ( provider, layers, styles, format, crs, false );
+/** Copied from QgsVectorLayer::setDataProvider
+ *  TODO: Make it work in the raster environment
+                                      QString const & crs,
+                                      bool loadDefaultStyleFlag )
+  // XXX should I check for and possibly delete any pre-existing providers?
+  // XXX How often will that scenario occur?
+  mProviderKey = provider;
+  mValid = false;            // assume the layer is invalid until we determine otherwise
+  // set the layer name (uppercase first character)
+  if ( ! mLayerName.isEmpty() )   // XXX shouldn't this happen in parent?
+    setLayerName( mLayerName );
+  mBandCount = 0;
+  mDataProvider = QgsRasterLayer::loadProvider ( mProviderKey, mDataSource );
+  if ( !mDataProvider )
     return;
   QgsDebugMsg( "Instantiated the data provider plugin"
               + QString( " with layer list of " ) + layers.join( ", " )
               + " and style list of " + styles.join( ", " )
@@ -3173,11 +3012,9 @@
   QgsDebugMsg( "using wkt:\n" + mySourceWkt );
-  //mBandCount = GDALGetRasterCount( mGdalDataset );
   mBandCount = mDataProvider->bandCount( );
   for ( int i = 1; i <= mBandCount; i++ )
-    //GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, i );
     QgsRasterBandStats myRasterBandStats;
     myRasterBandStats.bandName = generateBandName( i );
     myRasterBandStats.bandNumber = i;
@@ -3192,7 +3029,6 @@
     mRasterStatsList.push_back( myRasterBandStats );
     //Build a new contrast enhancement for the band and store in list
-    //QgsContrastEnhancement myContrastEnhancement(( QgsContrastEnhancement::QgsRasterDataType )GDALGetRasterDataType( myGdalBand ) );
     QgsContrastEnhancement myContrastEnhancement(( QgsContrastEnhancement::QgsRasterDataType )mDataProvider->dataType( i ) );
     mContrastEnhancementList.append( myContrastEnhancement );
@@ -3205,7 +3041,6 @@
   //decide what type of layer this is...
   //TODO Change this to look at the color interp and palette interp to decide which type of layer it is
-  //if (( GDALGetRasterCount( mGdalDataset ) > 1 ) )
   if (( mDataProvider->bandCount() > 1 ) )
     mRasterType = Multiband;
@@ -3259,7 +3094,6 @@
     //for the third layer we cant be sure so..
-    //if ( GDALGetRasterCount( mGdalDataset ) > 2 )
     if (( mDataProvider->bandCount() > 2 ) )
       mBlueBandName = bandName( myQSettings.value( "/Raster/defaultBlueBand", 3 ).toInt() ); // sensible default
@@ -3307,6 +3141,19 @@
   //mark the layer as valid
   mValid = true;
+  //loadDefaultStyle() can not be called before the layer has actually be opened
+  // TODO ???
+  //if ( loadDefaultStyleFlag )
+    //bool defaultLoadedFlag = false;
+    //loadDefaultStyle( defaultLoadedFlag );
+    //if ( defaultLoadedFlag )
+      //return;
   QgsDebugMsg( "exiting." );
 } // QgsRasterLayer::setDataProvider
@@ -4905,11 +4752,7 @@
     QgsDebugMsg( "XXX use provider minmax" );
     //This case will be true the first time the image is loaded, so just approimate the min max to keep
     //from calling generate raster band stats
-    double GDALrange[2];
-    //GDALComputeRasterMinMax( myGdalBand, 1, GDALrange ); //Approximate
-    //setMaximumValue( theBandNo, GDALrange[1] );
-    //setMinimumValue( theBandNo, GDALrange[0] );
     setMaximumValue( theBandNo, mDataProvider->maximumValue ( theBandNo ) );
     setMinimumValue( theBandNo, mDataProvider->minimumValue ( theBandNo ) );
@@ -4918,12 +4761,14 @@
   QgsDebugMsg( " -> imageBuffer.nextScanLine");
   while ( imageBuffer.nextScanLine( &imageScanLine, &rasterScanLine ) )
+    //QgsDebugMsg( " rendering line");
     for ( int i = 0; i < theRasterViewPort->drawableAreaXDim; ++i )
       myGrayValue = readValue( rasterScanLine, myDataType, i );
-      if ( myGrayValue != -2147483647 ) {
+      //QgsDebugMsg( QString( "i = %1 myGrayValue = %2 ").arg(i).arg( myGrayValue ) );
+      //if ( myGrayValue != -2147483647 ) {
         //QgsDebugMsg( "myGrayValue = " + QString::number( myGrayValue ) );
       if ( mValidNoDataValue && ( fabs( myGrayValue - mNoDataValue ) <= TINY_VALUE || myGrayValue != myGrayValue ) )
@@ -4952,7 +4797,7 @@
         myGrayVal = 255 - myGrayVal;
-      //QgsDebugMsg( QString( "i = %1 myGrayValue = %2").arg(i).arg( myGrayValue ) );
+      //QgsDebugMsg( QString( "i = %1 myGrayValue = %2 myAlphaValue = %3").arg(i).arg( myGrayValue ).arg(myAlphaValue) );
       imageScanLine[ i ] = qRgba( myGrayVal, myGrayVal, myGrayVal, myAlphaValue );
@@ -5046,6 +4891,7 @@
         //Normal
         imageScanLine[ i ] = qRgba( myRedValue, myGreenValue, myBlueValue, myAlphaValue );
+        QgsDebugMsg ( QString ( "%1 value :  %2 rgba : %3 %4 %5 %6" ).arg (i).arg( myPixelValue ).arg(myRedValue).arg(myGreenValue).arg(myBlueValue).arg(myAlphaValue) );
@@ -5487,7 +5333,7 @@
 bool QgsRasterImageBuffer::nextScanLine( QRgb** imageScanLine, void** rasterScanLine )
-  QgsDebugMsg( "mCurrentRow = " + QString::number( mCurrentRow ) );
+  //QgsDebugMsg( "mCurrentRow = " + QString::number( mCurrentRow ) );
   if ( !mValid )
     return false;
@@ -5512,8 +5358,6 @@
     *imageScanLine = 0;
-  //GDALDataType type = GDALGetRasterDataType( mRasterBand );
-  //int size = GDALGetDataTypeSize( type ) / 8;
   int size = mDataProvider->dataTypeSize(mBandNo)/8;
   *rasterScanLine = ( unsigned char * )mCurrentGDALData + mCurrentPartImageRow * mViewPort->drawableAreaXDim * size;
Modified: branches/raster-providers/src/core/raster/qgsrasterlayer.h
--- branches/raster-providers/src/core/raster/qgsrasterlayer.h	2010-11-13 20:15:46 UTC (rev 14618)
+++ branches/raster-providers/src/core/raster/qgsrasterlayer.h	2010-11-13 20:17:49 UTC (rev 14619)
@@ -296,13 +296,30 @@
     /** \brief ensures that GDAL drivers are registered, but only once */
     static void registerGdalDrivers();
     // Non Static inline methods
+    /** \brief Initialize default values */
+    void init ();
+    // For backward compatibility (Python) get rid of it once python is updated
+    void setDataProvider( const QString & provider,
+                          const QStringList & layers,
+                          const QStringList & styles,
+                          const QString & format,
+                          const QString & crs);
+    /**  [ data provider interface ] Set the data provider */
+                          const QString & crs,
+                          bool loadDefaultStyleFlag );
+    static QgsRasterDataProvider* loadProvider( QString theProviderKey, QString theDataSource = 0);
     /** \brief  Accessor for blue band name mapping */
     QString blueBandName() const { return mBlueBandName; }
@@ -363,12 +380,6 @@
     /** \brief Accessor for red band name (allows alternate mappings e.g. map blue as red color) */
     QString redBandName() const { return mRedBandName; }
-    /**  [ data provider interface ] Set the data provider */
-    void setDataProvider( const QString & provider,
-                          const QStringList & layers,
-                          const QStringList & styles,
-                          const QString & format,
-                          const QString & crs );
     /** \brief Mutator for drawing style */
     void setDrawingStyle( const DrawingStyle &  theDrawingStyle ) { mDrawingStyle = theDrawingStyle; }
@@ -864,7 +875,7 @@
     QgsRasterViewPort mLastViewPort;
     /**  [ data provider interface ] pointer for loading the provider library */
-    QLibrary* mLib;
+    //QLibrary* mLib;
     /**  [ data provider interface ] Flag indicating whether the layer has been modified since the last commit*/
     bool mModified;
Modified: branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp
--- branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp	2010-11-13 20:15:46 UTC (rev 14618)
+++ branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp	2010-11-13 20:17:49 UTC (rev 14619)
@@ -52,7 +52,14 @@
   QgsDebugMsg( "QgsGdalProvider: constructing with uri '" + uri + "'." );
   mValid = false;
+  mGdalDataset = 0;
+  registerGdalDrivers();
+  // To get buildSupportedRasterFileFilter the provider is called with empty uri
+  if ( uri.isEmpty() ) return;
@@ -62,7 +69,6 @@
-  registerGdalDrivers();
   mGdalDataset = NULL;
   mGdalBaseDataset = GDALOpen( QFile::encodeName( uri ).constData(), GA_ReadOnly );
@@ -78,6 +84,12 @@
   QgsDebugMsg ("GdalDataset opened" );
+  for ( int i = 0; i < GDALGetRasterCount( mGdalDataset ); i++ )
+    mMinMaxComputed.append(false);
+    mMinimum.append(0);
+    mMaximum.append(0);
   // Check if we need a warped VRT for this file.
   if (( GDALGetGeoTransform( mGdalBaseDataset, mGeoTransform ) == CE_None
         && ( mGeoTransform[1] < 0.0
@@ -201,6 +213,14 @@
 QgsGdalProvider::~QgsGdalProvider()
   QgsDebugMsg( "QgsGdalProvider: deconstructing." );
+  if ( mGdalBaseDataset )
+    GDALDereferenceDataset( mGdalBaseDataset );
+  if ( mGdalDataset )
+    GDALClose( mGdalDataset );
@@ -451,9 +471,10 @@
   GDALDestroyGenImgProjTransformer( myWarpOptions->pTransformerArg );
   GDALDestroyWarpOptions( myWarpOptions );
-  // without this it does not work (data not written),
-  GDALFlushCache  (  myGdalMemDataset );
-  // with this it is causing crash ???
+  // flush should not be necessary
+  //GDALFlushCache  (  myGdalMemDataset );
+  // this was causing crash ???
+  // The MEM driver does not free() the memory passed as DATAPOINTER so we can closee the dataset
   GDALClose( myGdalMemDataset );
@@ -462,18 +483,26 @@
   return mNoDataValue;
-double  QgsGdalProvider::minimumValue( int theBandNo ) const {
+void QgsGdalProvider::computeMinMax ( int theBandNo )
+  if ( mMinMaxComputed[theBandNo-1] ) return;
   GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
-  return  GDALrange[0];
+  mMinimum[theBandNo-1] = GDALrange[0];
+  mMaximum[theBandNo-1] = GDALrange[1];
-double  QgsGdalProvider::maximumValue( int theBandNo ) const {
-  GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
-  GDALComputeRasterMinMax( myGdalBand, 1, GDALrange ); //Approximate
-  return  GDALrange[1];
+double  QgsGdalProvider::minimumValue( int theBandNo )
+  computeMinMax ( theBandNo );
+  return  mMinimum[theBandNo-1];
+double  QgsGdalProvider::maximumValue( int theBandNo )
+  return  mMaximum[theBandNo-1];
 QList<QgsColorRampShader::ColorRampItem> QgsGdalProvider::colorTable(int bandNo)const {
   // TODO
@@ -531,7 +560,8 @@
 int QgsGdalProvider::capabilities() const
   int capability = QgsRasterDataProvider::Identify
-                 | QgsRasterDataProvider::Data;
+                 | QgsRasterDataProvider::Data
+                 | QgsRasterDataProvider::EstimatedMinimumMaximum;
   return capability;
@@ -633,7 +663,186 @@
   return PROVIDER_DESCRIPTION;
+  Builds the list of file filter strings to later be used by
+  We query GDAL for a list of supported raster formats; we then build
+  a list of file filter strings from that list.  We return a string
+  that contains this list that is suitable for use in a
+  QFileDialog::getOpenFileNames() call.
+void QgsGdalProvider::buildSupportedRasterFileFilter( QString & theFileFiltersString )
+  QgsDebugMsg("Entered");
+  // first get the GDAL driver manager
+  //registerGdalDrivers();
+  // then iterate through all of the supported drivers, adding the
+  // corresponding file filter
+  GDALDriverH myGdalDriver;           // current driver
+  char **myGdalDriverMetadata;        // driver metadata strings
+  QString myGdalDriverLongName( "" ); // long name for the given driver
+  QString myGdalDriverExtension( "" );  // file name extension for given driver
+  QString myGdalDriverDescription;    // QString wrapper of GDAL driver description
+  QStringList metadataTokens;   // essentially the metadata string delimited by '='
+  QStringList catchallFilter;   // for Any file(*.*), but also for those
+  // drivers with no specific file filter
+  GDALDriverH jp2Driver = NULL; // first JPEG2000 driver found
+  // Grind through all the drivers and their respective metadata.
+  // We'll add a file filter for those drivers that have a file
+  // extension defined for them; the others, well, even though
+  // theoreticaly we can open those files because there exists a
+  // driver for them, the user will have to use the "All Files" to
+  // open datasets with no explicitly defined file name extension.
+  // Note that file name extension strings are of the form
+  // "DMD_EXTENSION=.*".  We'll also store the long name of the
+  // driver, which will be found in DMD_LONGNAME, which will have the
+  // same form.
+  // start with the default case
+  theFileFiltersString = QObject::tr( "[GDAL] All files (*)" );
+  for ( int i = 0; i < GDALGetDriverCount(); ++i )
+    myGdalDriver = GDALGetDriver( i );
+    Q_CHECK_PTR( myGdalDriver );
+    if ( !myGdalDriver )
+      QgsLogger::warning( "unable to get driver " + QString::number( i ) );
+      continue;
+    // now we need to see if the driver is for something currently
+    // supported; if not, we give it a miss for the next driver
+    myGdalDriverDescription = GDALGetDescription( myGdalDriver );
+    // QgsDebugMsg(QString("got driver string %1").arg(myGdalDriverDescription));
+    myGdalDriverMetadata = GDALGetMetadata( myGdalDriver, NULL );
+    // presumably we know we've run out of metadta if either the
+    // address is 0, or the first character is null
+    while ( myGdalDriverMetadata && '\0' != myGdalDriverMetadata[0] )
+      metadataTokens = QString( *myGdalDriverMetadata ).split( "=", QString::SkipEmptyParts );
+      // QgsDebugMsg(QString("\t%1").arg(*myGdalDriverMetadata));
+      // XXX add check for malformed metadataTokens
+      // Note that it's oddly possible for there to be a
+      // DMD_EXTENSION with no corresponding defined extension
+      // string; so we check that there're more than two tokens.
+      if ( metadataTokens.count() > 1 )
+        if ( "DMD_EXTENSION" == metadataTokens[0] )
+          myGdalDriverExtension = metadataTokens[1];
+        else if ( "DMD_LONGNAME" == metadataTokens[0] )
+          myGdalDriverLongName = metadataTokens[1];
+          // remove any superfluous (.*) strings at the end as
+          // they'll confuse QFileDialog::getOpenFileNames()
+          myGdalDriverLongName.remove( QRegExp( "\\(.*\\)$" ) );
+      // if we have both the file name extension and the long name,
+      // then we've all the information we need for the current
+      // driver; therefore emit a file filter string and move to
+      // the next driver
+      if ( !( myGdalDriverExtension.isEmpty() || myGdalDriverLongName.isEmpty() ) )
+        // XXX add check for SDTS; in that case we want (*CATD.DDF)
+        QString glob = "*." + myGdalDriverExtension.replace( "/", " *." );
+        // Add only the first JP2 driver found to the filter list (it's the one GDAL uses)
+        if ( myGdalDriverDescription == "JPEG2000" ||
+             myGdalDriverDescription.startsWith( "JP2" ) ) // JP2ECW, JP2KAK, JP2MrSID
+          if ( jp2Driver )
+            break; // skip if already found a JP2 driver
+          jp2Driver = myGdalDriver;   // first JP2 driver found
+          glob += " *.j2k";           // add alternate extension
+        else if ( myGdalDriverDescription == "GTiff" )
+          glob += " *.tiff";
+        else if ( myGdalDriverDescription == "JPEG" )
+          glob += " *.jpeg";
+        theFileFiltersString += ";;[GDAL] " + myGdalDriverLongName + " (" + glob.toLower() + " " + glob.toUpper() + ")";
+        break;            // ... to next driver, if any.
+      ++myGdalDriverMetadata;
+    }                       // each metadata item
+    if ( myGdalDriverExtension.isEmpty() && !myGdalDriverLongName.isEmpty() )
+      // Then what we have here is a driver with no corresponding
+      // file extension; e.g., GRASS.  In which case we append the
+      // string to the "catch-all" which will match all file types.
+      // (I.e., "*.*") We use the driver description intead of the
+      // long time to prevent the catch-all line from getting too
+      // large.
+      // ... OTOH, there are some drivers with missing
+      // DMD_EXTENSION; so let's check for them here and handle
+      // them appropriately
+      // USGS DEMs use "*.dem"
+      if ( myGdalDriverDescription.startsWith( "USGSDEM" ) )
+        QString glob = "*.dem";
+      else if ( myGdalDriverDescription.startsWith( "DTED" ) )
+        // DTED use "*.dt0, *.dt1, *.dt2"
+        QString glob = "*.dt0";
+        glob += " *.dt1";
+        glob += " *.dt2";
+      else if ( myGdalDriverDescription.startsWith( "MrSID" ) )
+        // MrSID use "*.sid"
+        QString glob = "*.sid";
+      else
+        catchallFilter << QString( GDALGetDescription( myGdalDriver ) );
+    myGdalDriverExtension = myGdalDriverLongName = "";  // reset for next driver
+  }                           // each loaded GDAL driver
+  QgsDebugMsg( "Raster filter list built: " + theFileFiltersString );
+}                               // buildSupportedRasterFileFilter_()
  * Class factory to return a pointer to a newly created
  * QgsGdalProvider object
Modified: branches/raster-providers/src/providers/gdal/qgsgdalprovider.h
--- branches/raster-providers/src/providers/gdal/qgsgdalprovider.h	2010-11-13 20:15:46 UTC (rev 14618)
+++ branches/raster-providers/src/providers/gdal/qgsgdalprovider.h	2010-11-13 20:17:49 UTC (rev 14619)
@@ -201,8 +201,9 @@
     void readBlock( int bandNo, QgsRectangle  const & viewExtent, int width, int height,  void *data );
     double noDataValue() const;
-    double minimumValue(int bandNo)const;
-    double maximumValue(int bandNo)const;
+    void computeMinMax(int bandNo);
+    double minimumValue(int bandNo);
+    double maximumValue(int bandNo);
     QList<QgsColorRampShader::ColorRampItem> colorTable(int bandNo)const;
@@ -223,6 +224,8 @@
+    void buildSupportedRasterFileFilter( QString & theFileFiltersString );
   private:
@@ -244,6 +247,14 @@
     int mXBlockSize;
     int mYBlockSize;
+    QList<bool> mMinMaxComputed;
+    // List of estimated min values, index 0 for band 1
+    QList<double> mMinimum;
+    // List of estimated max values, index 0 for band 1
+    QList<double> mMaximum;
     //GDALDataType mGdalDataType;
     /** \brief Pointer to the gdaldataset */
Modified: branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp
--- branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp	2010-11-13 20:15:46 UTC (rev 14618)
+++ branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp	2010-11-13 20:17:49 UTC (rev 14619)
@@ -75,6 +75,8 @@
   QgsDebugMsg( QString( "mapset: %1" ).arg( mMapset ) );
   QgsDebugMsg( QString( "mapName: %1" ).arg( mMapName ) );
+  mValidNoDataValue = true;
   mCrs = QgsGrass::crs( mGisdbase, mLocation );
   // the block size can change of course when the raster is overridden
@@ -188,7 +190,13 @@
   QgsDebugMsg( QString( "%1 bytes read from modules stdout" ).arg( data.size() ) );
   // byteCount() in Qt >= 4.6
   //int size = image->byteCount() < data.size() ? image->byteCount() : data.size();
-  int size = mCols * dataTypeSize(bandNo) < data.size() ? mCols * dataTypeSize(bandNo) : data.size();
+  int size = mCols * mYBlockSize * dataTypeSize(bandNo) / 8;
+  QgsDebugMsg ( QString ( "mCols = %1 mYBlockSize = %2 dataTypeSize = %3" ).arg ( mCols ).arg ( mYBlockSize ).arg ( dataTypeSize(bandNo) ) );
+  if ( size != data.size() ) {
+    QMessageBox::warning( 0, QObject::tr( "Warning" ),
+      QString( "%1 bytes expected but %2 byte were read from qgis.d.rast" ).arg(size).arg(data.size() )   );
+    size = size < data.size() ? size : data.size();
   memcpy( block, data.data(), size );
@@ -228,7 +236,12 @@
-  int size = pixelWidth * pixelHeight * dataTypeSize(bandNo) < data.size() ? pixelWidth * pixelHeight * dataTypeSize(bandNo) : data.size();
+  int size = pixelWidth * pixelHeight * dataTypeSize(bandNo) / 8;
@@ -321,7 +334,8 @@
 int QgsGrassRasterProvider::capabilities() const
+                 | QgsRasterDataProvider::ExactMinimumMaximum;
   return capability;
@@ -352,6 +366,26 @@
   return QgsRasterDataProvider::GrayIndex;
+QString QgsGrassRasterProvider::metadata()
+  QString myMetadata ;
+  QStringList myList;
+  myList.append ( "GISDBASE: " + mGisdbase );
+  myList.append ( "LOCATION: " + mLocation );
+  myList.append ( "MAPSET: " + mMapset );
+  myList.append ( "MAP: " + mMapName );
+  QHash<QString, QString>::iterator i;
+  for (i = mInfo.begin(); i != mInfo.end(); ++i)
+     myList.append ( i.key() + " : " + i.value() );
+  myMetadata += QgsRasterDataProvider::makeTableCells( myList );
+  return myMetadata;
 bool QgsGrassRasterProvider::isValid()
   return mValid;
@@ -387,6 +421,10 @@
+void QgsGrassRasterProvider::buildSupportedRasterFileFilter( QString & theFileFiltersString )
  * QgsGrassRasterProvider object
@@ -417,3 +455,4 @@
   return true;
Modified: branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h
--- branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h	2010-11-13 20:15:46 UTC (rev 14618)
+++ branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h	2010-11-13 20:17:49 UTC (rev 14619)
@@ -199,6 +199,7 @@
      * Get metadata in a format suitable for feeding directly
More information about the QGIS-commit mailing list
