[QGIS Commit] r14633 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Sat Nov 13 20:09:56 EST 2010
Author: timlinux
Date: 2010-11-13 17:09:55 -0800 (Sat, 13 Nov 2010)
New Revision: 14633
trunk/qgis/src/ui/qgssymbolv2propertiesdialogbase.ui
Use nicer terms for start and end colours
Modified: trunk/qgis/src/ui/qgssymbolv2propertiesdialogbase.ui
--- trunk/qgis/src/ui/qgssymbolv2propertiesdialogbase.ui 2010-11-14 00:55:18 UTC (rev 14632)
+++ trunk/qgis/src/ui/qgssymbolv2propertiesdialogbase.ui 2010-11-14 01:09:55 UTC (rev 14633)
@@ -6,18 +6,18 @@
<rect>
<x>0</x>
<y>0</y>
- <width>634</width>
+ <width>674</width>
<height>396</height>
</rect>
</property>
<property name="windowTitle">
<string>Symbol properties</string>
</property>
- <layout class="QGridLayout">
+ <layout class="QGridLayout" name="gridLayout">
<item row="0" column="0">
- <widget class="QLabel" name="label">
+ <widget class="QLabel" name="label_3">
<property name="text">
- <string>Symbol preview</string>
+ <string>Symbol layers</string>
</property>
</widget>
</item>
@@ -76,32 +76,6 @@
</layout>
</item>
<item row="1" column="0">
- <widget class="QLabel" name="lblPreview">
- <property name="minimumSize">
- <size>
- <width>100</width>
- <height>100</height>
- </size>
- </property>
- <property name="frameShape">
- <enum>QFrame::StyledPanel</enum>
- </property>
- <property name="frameShadow">
- <enum>QFrame::Sunken</enum>
- </property>
- <property name="alignment">
- <set>Qt::AlignCenter</set>
- </property>
- </widget>
- </item>
- <item row="2" column="0">
- <widget class="QLabel" name="label_3">
- <property name="text">
- <string>Symbol layers</string>
- </property>
- </widget>
- </item>
- <item row="3" column="0">
<widget class="QListView" name="listLayers">
<property name="sizePolicy">
<sizepolicy hsizetype="Preferred" vsizetype="Expanding">
@@ -111,7 +85,7 @@
</property>
</widget>
</item>
- <item row="4" column="0">
+ <item row="2" column="0">
<layout class="QHBoxLayout">
<item>
<widget class="QPushButton" name="btnAddLayer">
@@ -215,6 +189,32 @@
</item>
</layout>
</item>
+ <item row="3" column="0">
+ <widget class="QLabel" name="label">
+ <property name="text">
+ <string>Symbol preview</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="0">
+ <widget class="QLabel" name="lblPreview">
+ <property name="minimumSize">
+ <size>
+ <width>100</width>
+ <height>100</height>
+ </size>
+ </property>
+ <property name="frameShape">
+ <enum>QFrame::StyledPanel</enum>
+ </property>
+ <property name="frameShadow">
+ <enum>QFrame::Sunken</enum>
+ </property>
+ <property name="alignment">
+ <set>Qt::AlignCenter</set>
+ </property>
+ </widget>
+ </item>
<item row="5" column="0" colspan="2">
<widget class="QDialogButtonBox" name="buttonBox">
<property name="orientation">
