[QGIS Commit] r14637 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sun Nov 14 08:27:03 EST 2010
Author: borysiasty
Date: 2010-11-14 05:27:03 -0800 (Sun, 14 Nov 2010)
New Revision: 14637
trunk/qgis/src/app/qgsprojectproperties.cpp
trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
Fix QgsProjectProperties dialog - first cpp patch from Milena
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp 2010-11-14 10:45:10 UTC (rev 14636)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp 2010-11-14 13:27:03 UTC (rev 14637)
@@ -79,6 +79,8 @@
if ( automaticPrecision )
radAutomatic->setChecked( true );
+ spinBoxDP->setDisabled( true );
+ labelDP->setDisabled( true );
else
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2010-11-14 10:45:10 UTC (rev 14636)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2010-11-14 13:27:03 UTC (rev 14637)
@@ -267,7 +267,7 @@
</widget>
</item>
<item row="0" column="3">
- <widget class="QLabel" name="textLabel3">
+ <widget class="QLabel" name="labelDP">
<property name="sizePolicy">
<sizepolicy hsizetype="Fixed" vsizetype="Fixed">
<horstretch>0</horstretch>
@@ -452,7 +452,7 @@
<connection>
<sender>radManual</sender>
<signal>clicked(bool)</signal>
- <receiver>textLabel3</receiver>
+ <receiver>labelDP</receiver>
<slot>setEnabled(bool)</slot>
<hints>
<hint type="sourcelabel">
@@ -484,7 +484,7 @@
<connection>
<sender>radAutomatic</sender>
<slot>setDisabled(bool)</slot>
<hints>
