[QGIS Commit] r14642 - in trunk/qgis/src: plugins/delimited_text
providers/delimitedtext
svn_qgis at osgeo.org
Sun Nov 14 09:49:17 EST 2010
Author: jef
Date: 2010-11-14 06:49:17 -0800 (Sun, 14 Nov 2010)
New Revision: 14642
trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugin.cpp
trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp
trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.h
trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui
trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.h
improve delimited text plugin ui and allow skipping lines
Modified: trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugin.cpp
--- trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugin.cpp 2010-11-14 14:48:12 UTC (rev 14641)
+++ trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugin.cpp 2010-11-14 14:49:17 UTC (rev 14642)
@@ -124,7 +124,7 @@
connect( myQgsDelimitedTextPluginGui,
SIGNAL( drawVectorLayer( QString, QString, QString ) ),
this, SLOT( drawVectorLayer( QString, QString, QString ) ) );
- myQgsDelimitedTextPluginGui->show();
+ myQgsDelimitedTextPluginGui->exec();
//!draw a vector layer in the qui - intended to respond to signal
//sent by diolog when it as finished creating a layer
Modified: trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp
--- trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp 2010-11-14 14:48:12 UTC (rev 14641)
+++ trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp 2010-11-14 14:49:17 UTC (rev 14642)
@@ -32,10 +32,9 @@
setupUi( this );
pbnOK = buttonBox->button( QDialogButtonBox::Ok );
- pbnParse = buttonBox->addButton( tr( "Parse" ), QDialogButtonBox::ActionRole );
- connect( pbnParse, SIGNAL( clicked() ), this, SLOT( pbnParse_clicked() ) );
- connect( txtFilePath, SIGNAL( textChanged( const QString& ) ), this, SLOT( pbnParse_clicked() ) );
- enableButtons();
+ enableAccept();
// at startup, fetch the last used delimiter and directory from
// settings
QSettings settings;
@@ -43,21 +42,40 @@
txtDelimiter->setText( settings.value( key + "/delimiter" ).toString() );
// and how to use the delimiter
- QString delimiterType = settings.value( key + "/delimiterType",
- "plain" ).toString();
- if ( delimiterType == "plain" )
+ QString delimiterType = settings.value( key + "/delimiterType", "plain" ).toString();
+ if ( delimiterType == "selection" )
+ delimiterSelection->setChecked( true );
+ else if ( delimiterType == "plain" )
delimiterPlain->setChecked( true );
- delimiterRegexp->setChecked( false );
else
- delimiterPlain->setChecked( false );
delimiterRegexp->setChecked( true );
- txtSample->setFixedHeight( 120 );
+ cmbXField->setDisabled( true );
+ cmbYField->setDisabled( true );
+ connect( txtFilePath, SIGNAL( textChanged( QString ) ), this, SLOT( enableAccept() ) );
+ connect( delimiterSelection, SIGNAL( toggled( bool ) ), this, SLOT( enableAccept() ) );
+ connect( delimiterPlain, SIGNAL( toggled( bool ) ), this, SLOT( enableAccept() ) );
+ connect( delimiterRegexp, SIGNAL( toggled( bool ) ), this, SLOT( enableAccept() ) );
+ connect( cbxDelimSpace, SIGNAL( stateChanged( int ) ), this, SLOT( enableAccept() ) );
+ connect( cbxDelimTab, SIGNAL( stateChanged( int ) ), this, SLOT( enableAccept() ) );
+ connect( cbxDelimSemicolon, SIGNAL( stateChanged( int ) ), this, SLOT( enableAccept() ) );
+ connect( cbxDelimComma, SIGNAL( stateChanged( int ) ), this, SLOT( enableAccept() ) );
+ connect( cbxDelimColon, SIGNAL( stateChanged( int ) ), this, SLOT( enableAccept() ) );
+ connect( txtDelimiter, SIGNAL( editingFinished() ), this, SLOT( enableAccept() ) );
+ connect( rowCounter, SIGNAL( valueChanged( int ) ), this, SLOT( enableAccept() ) );
QgsDelimitedTextPluginGui::~QgsDelimitedTextPluginGui()
@@ -66,26 +84,36 @@
getOpenFileName();
-void QgsDelimitedTextPluginGui::pbnParse_clicked()
- updateFieldLists();
void QgsDelimitedTextPluginGui::on_buttonBox_accepted()
- if ( txtLayerName->text().length() > 0 )
+ if ( !txtLayerName->text().isEmpty() )
//Build the delimited text URI from the user provided information
- QString delimiterType = "plain";
- if ( delimiterRegexp->isChecked() )
+ QString delimiterType;
+ if ( delimiterSelection->isChecked() )
delimiterType = "regexp";
+ else if ( delimiterPlain->isChecked() )
+ delimiterType = "plain";
+ else if ( delimiterRegexp->isChecked() )
+ delimiterType = "regexp";
- QString uri = QString( "%1?delimiter=%2&delimiterType=%3&xField=%4&yField=%5" )
+ QString uri = QString( "%1?delimiter=%2&delimiterType=%3" )
.arg( txtFilePath->text() )
.arg( txtDelimiter->text() )
- .arg( delimiterType )
- .arg( cmbXField->currentText() )
- .arg( cmbYField->currentText() );
+ .arg( delimiterType );
+ if ( !cmbXField->currentText().isEmpty() && !cmbYField->currentText().isEmpty() )
+ uri += QString( "&xField=%1&yField=%2" )
+ .arg( cmbXField->currentText() )
+ .arg( cmbYField->currentText() );
+ int skipLines = rowCounter->value();
+ if ( skipLines > 0 )
+ uri += QString( "&skipLines=%1" ).arg( skipLines );
// add the layer to the map
emit drawVectorLayer( uri, txtLayerName->text(), "delimitedtext" );
// store the settings
@@ -96,6 +124,8 @@
QFileInfo fi( txtFilePath->text() );
settings.setValue( key + "/text_path", fi.path() );
+ settings.setValue( key + "/delimiterType", "selection" );
settings.setValue( key + "/delimiterType", "plain" );
else
@@ -114,120 +144,170 @@
reject();
+QStringList QgsDelimitedTextPluginGui::splitLine( QString line )
+ QStringList fieldList;
+ QString delimiter = txtDelimiter->text();
+ if ( delimiterPlain->isChecked() )
+ // convert \t to tabulator
+ delimiter = txtDelimiter->text();
+ delimiter.replace( "\\t", "\t" );
+ fieldList = line.split( delimiter );
+ else if ( delimiterSelection->isChecked() )
+ delimiter = "[";
+ if ( cbxDelimSpace->isChecked() ) delimiter += " ";
+ if ( cbxDelimTab->isChecked() ) delimiter += "\t";
+ if ( cbxDelimSemicolon->isChecked() ) delimiter += ";";
+ if ( cbxDelimComma->isChecked() ) delimiter += ",";
+ if ( cbxDelimColon->isChecked() ) delimiter += ":";
+ delimiter += "]";
+ txtDelimiter->setText( delimiter );
+ fieldList = line.split( QRegExp( delimiter ) );
+ else
+ QRegExp del( delimiter );
+ return fieldList;
void QgsDelimitedTextPluginGui::updateFieldLists()
// Update the x and y field dropdown boxes
QgsDebugMsg( "Updating field lists" );
- // open the file
- if ( QFile::exists( txtFilePath->text() ) )
+ disconnect( cmbXField, SIGNAL( currentIndexChanged( int ) ), this, SLOT( enableAccept() ) );
+ disconnect( cmbYField, SIGNAL( currentIndexChanged( int ) ), this, SLOT( enableAccept() ) );
+ QString columnX = cmbXField->currentText();
+ QString columnY = cmbYField->currentText();
+ // clear the field lists
+ cmbXField->clear();
+ cmbYField->clear();
+ cmbXField->setEnabled( false );
+ cmbYField->setEnabled( false );
+ QFile file( txtFilePath->text() );
+ if ( !file.open( QIODevice::ReadOnly ) )
+ return;
+ QTextStream stream( &file );
+ QString line;
+ do
- QFile *file = new QFile( txtFilePath->text() );
- if ( file->open( QIODevice::ReadOnly ) )
- // clear the field lists
- cmbXField->clear();
- cmbYField->clear();
- QTextStream stream( file );
- QString line;
- line = readLine( stream ); // line of text excluding '\n'
- if ( txtDelimiter->text().length() > 0 )
- QgsDebugMsg( QString( "Attempting to split the input line: %1 using delimiter %2" ).arg( line ).arg( txtDelimiter->text() ) );
- QString delimiter = txtDelimiter->text();
+ line = readLine( stream ); // line of text excluding '\n'
+ while ( !line.isEmpty() && skipLines-- > 0 );
- QStringList fieldList;
+ QgsDebugMsg( QString( "Attempting to split the input line: %1 using delimiter %2" ).arg( line ).arg( txtDelimiter->text() ) );
- if ( delimiterPlain->isChecked() )
- // convert \t to tabulator
- delimiter.replace( "\\t", "\t" );
- fieldList = line.split( delimiter );
- else
- QRegExp del( delimiter );
- fieldList = line.split( QRegExp( delimiter ) );
- QgsDebugMsg( QString( "Split line into %1 parts" ).arg( fieldList.size() ) );
- // We don't know anything about a text based field other
- // than its name. All fields are assumed to be text
- foreach( QString field, fieldList )
- if (( field.left( 1 ) == "'" || field.left( 1 ) == "\"" ) &&
- field.left( 1 ) == field.right( 1 ) )
- // eat quotes
- field = field.mid( 1, field.length() - 2 );
+ QStringList fieldList = splitLine( line );
- if ( field.length() == 0 )
- // skip empty field names
- continue;
+ QgsDebugMsg( QString( "Split line into %1 parts" ).arg( fieldList.size() ) );
- cmbXField->addItem( field );
- cmbYField->addItem( field );
+ // We don't know anything about a text based field other
+ // than its name. All fields are assumed to be text
+ foreach( QString field, fieldList )
+ if (( field.left( 1 ) == "'" || field.left( 1 ) == "\"" ) &&
+ field.left( 1 ) == field.right( 1 ) )
+ // eat quotes
+ field = field.mid( 1, field.length() - 2 );
- //x/y fields might be missing
- cmbXField->addItem( "" );
- cmbYField->addItem( "" );
+ if ( field.length() == 0 )
+ // skip empty field names
+ continue;
- // Have a go at setting the selected items in the X and Y
- // combo boxes to something sensible.
- int indexX = cmbXField->findText( "lon", Qt::MatchContains );
- int indexY = cmbXField->findText( "lat", Qt::MatchContains );
- if ( indexX != -1 && indexY != -1 )
- cmbXField->setCurrentIndex( indexX );
- cmbYField->setCurrentIndex( indexY );
- else
- indexX = cmbXField->findText( "x", Qt::MatchContains );
- indexY = cmbXField->findText( "y", Qt::MatchContains );
- //leave x- and y-field empty by default if no match found
- if ( indexX == -1 )
- indexX = cmbXField->findText( "" );
- if ( indexY == -1 )
- indexY = cmbYField->findText( "" );
- // enable the buttons
- enableButtons();
- else
- QMessageBox::warning( this, tr( "No delimiter" ), tr( "Please specify a delimiter prior to parsing the file" ) );
- // clear the sample text box
- txtSample->clear();
- // put the header row in the sample box
- txtSample->insertPlainText( line + "\n" );
- // put a few more lines into the sample box
- int counter = 0;
- while ( !line.isEmpty() && ( counter < 20 ) )
- counter++;
- // close the file
- file->close();
- // put a default layer name in the text entry
- QFileInfo finfo( txtFilePath->text() );
- txtLayerName->setText( finfo.completeBaseName() );
+ cmbXField->addItem( field );
+ cmbYField->addItem( field );
+ cmbXField->setEnabled( cmbXField->count() > 0 );
+ cmbYField->setEnabled( cmbYField->count() > 0 );
+ int indexX = -1;
+ if ( !columnX.isEmpty() )
+ indexX = cmbXField->findText( columnX );
+ if ( indexX < 0 )
+ indexX = cmbXField->findText( "lon", Qt::MatchContains );
+ if ( indexX < 0 )
+ indexX = cmbXField->findText( "x", Qt::MatchContains );
+ cmbXField->setCurrentIndex( indexX );
+ int indexY = -1;
+ if ( !columnY.isEmpty() )
+ indexY = cmbYField->findText( columnY );
+ if ( indexY < 0 )
+ indexY = cmbYField->findText( "lat", Qt::MatchContains );
+ if ( indexY < 0 )
+ indexY = cmbYField->findText( "y", Qt::MatchContains );
+ cmbYField->setCurrentIndex( indexY );
+ connect( cmbXField, SIGNAL( currentIndexChanged( int ) ), this, SLOT( enableAccept() ) );
+ connect( cmbYField, SIGNAL( currentIndexChanged( int ) ), this, SLOT( enableAccept() ) );
+ // clear the sample text box
+ tblSample->clear();
+ tblSample->setColumnCount( fieldList.size() );
+ tblSample->setHorizontalHeaderLabels( fieldList );
+ // put a few more lines into the sample box
+ int counter = 0;
+ while ( !line.isEmpty() && counter < 20 )
+ QStringList values = splitLine( line );
+ tblSample->setRowCount( counter + 1 );
+ for ( int i = 0; i < tblSample->columnCount(); i++ )
+ tblSample->setItem( counter, i, new QTableWidgetItem( i < values.size() ? values[i] : "" ) );
+ counter++;
+ // close the file
+ file.close();
+ // put a default layer name in the text entry
+ QFileInfo finfo( txtFilePath->text() );
+ txtLayerName->setText( finfo.completeBaseName() );
void QgsDelimitedTextPluginGui::getOpenFileName()
// Get a file to process, starting at the current directory
@@ -242,21 +322,40 @@
// set path
txtFilePath->setText( s );
- // update the field drop-down boxes by parsing and splitting
- // the header row
-void QgsDelimitedTextPluginGui::enableButtons()
+void QgsDelimitedTextPluginGui::enableAccept()
- pbnParse->setEnabled( txtDelimiter->text().length() > 0 && txtFilePath->text().length() > 0 );
- pbnOK->setEnabled( txtDelimiter->text().length() > 0 && txtFilePath->text().length() > 0 );
-void QgsDelimitedTextPluginGui::on_txtDelimiter_textChanged( const QString & text )
- if ( !text.isEmpty() )
+ bool enabled = false;
+ if ( txtFilePath->text().isEmpty() || !QFile( txtFilePath->text() ).exists() )
- pbnParse->setEnabled( true );
+ enabled = false;
+ enabled =
+ cbxDelimSpace->isChecked() ||
+ cbxDelimTab->isChecked() ||
+ cbxDelimSemicolon->isChecked() ||
+ cbxDelimComma->isChecked() ||
+ cbxDelimColon->isChecked();
+ else
+ enabled = !txtDelimiter->text().isEmpty();
+ if ( enabled )
+ updateFieldLists();
+ enabled = ( cmbXField->currentText().isEmpty() && cmbYField->currentText().isEmpty() )
+ || ( !cmbXField->currentText().isEmpty() && !cmbYField->currentText().isEmpty() && cmbXField->currentText() != cmbYField->currentText() );
+ pbnOK->setEnabled( enabled );
QString QgsDelimitedTextPluginGui::readLine( QTextStream &stream )
Modified: trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.h
--- trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.h 2010-11-14 14:48:12 UTC (rev 14641)
+++ trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.h 2010-11-14 14:49:17 UTC (rev 14642)
@@ -30,25 +30,25 @@
QgsDelimitedTextPluginGui( QgisInterface * _qI, QWidget* parent = 0, Qt::WFlags fl = 0 );
~QgsDelimitedTextPluginGui();
- static QString readLine( QTextStream & stream );
+ QString readLine( QTextStream & stream );
+ QStringList splitLine( QString line );
private:
void updateFieldLists();
void getOpenFileName();
- void enableButtons();
QgisInterface * qI;
QAbstractButton *pbnOK;
- QAbstractButton *pbnParse;
private slots:
void on_buttonBox_accepted();
void on_buttonBox_rejected();
void on_buttonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
void on_btnBrowseForFile_clicked();
- void on_txtDelimiter_textChanged( const QString & text );
- void pbnParse_clicked();
+ public slots:
+ void enableAccept();
signals:
void drawRasterLayer( QString );
void drawVectorLayer( QString, QString, QString );
Modified: trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui
--- trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui 2010-11-14 14:48:12 UTC (rev 14641)
+++ trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui 2010-11-14 14:49:17 UTC (rev 14642)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>522</width>
- <height>424</height>
+ <width>532</width>
+ <height>513</height>
</rect>
</property>
<property name="windowTitle">
@@ -20,104 +20,150 @@
</property>
<layout class="QVBoxLayout" name="verticalLayout">
<item>
- <layout class="QGridLayout" name="gridLayout_3">
- <item row="0" column="0">
- <widget class="QLabel" name="textLabel1">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Minimum" vsizetype="Preferred">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="text">
- <string>Delimited text file</string>
- </property>
- <property name="buddy">
- <cstring>txtFilePath</cstring>
- </property>
- </widget>
- </item>
- <item row="0" column="1">
- <widget class="QgsFileDropEdit" name="txtFilePath">
- <property name="toolTip">
- <string>Full path to the delimited text file</string>
- </property>
- <property name="whatsThis">
- <string>Full path to the delimited text file. In order to properly parse the fields in the file, the delimiter must be defined prior to entering the file name. Use the Browse button to the right of this field to choose the input file.</string>
- </property>
- <property name="readOnly">
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item row="0" column="2">
- <widget class="QPushButton" name="btnBrowseForFile">
- <property name="enabled">
- <bool>true</bool>
- </property>
- <string>Browse to find the delimited text file to be processed</string>
- </property>
- <string>Use this button to browse to the location of the delimited text file. This button will not be enabled until a delimiter has been entered in the <i>Delimiter</i> box. Once a file is chosen, the X and Y field drop-down boxes will be populated with the fields from the delimited text file.</string>
- </property>
- <string>...</string>
- </property>
- </widget>
- </item>
- <item row="1" column="0">
- <widget class="QLabel" name="textLabel1_2">
- </sizepolicy>
- </property>
- <string>Layer name</string>
- </property>
- <cstring>txtLayerName</cstring>
- </property>
- </widget>
- </item>
- <item row="1" column="1">
- <widget class="QLineEdit" name="txtLayerName">
- <string>Name to display in the map legend</string>
- </property>
- <string>Name displayed in the map legend</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item>
- <widget class="QGroupBox" name="groupBox">
- <property name="title">
- <string>Delimiter</string>
+ <widget class="QWidget" name="widget_3" native="true">
+ <property name="acceptDrops">
+ <bool>true</bool>
</property>
- <layout class="QGridLayout" name="gridLayout">
+ <layout class="QGridLayout" name="gridLayout_4">
- <widget class="QLabel" name="textLabel3">
+ <widget class="QLabel" name="textLabelFileName">
+ <sizepolicy hsizetype="Minimum" vsizetype="Minimum">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="text">
+ <string>File Name</string>
+ </property>
+ <property name="indent">
+ <number>0</number>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <widget class="QgsFileDropEdit" name="txtFilePath">
+ <property name="toolTip">
+ <string>Full path to the delimited text file</string>
+ </property>
+ <property name="whatsThis">
+ <string>Full path to the delimited text file. In order to properly parse the fields in the file, the delimiter must be defined prior to entering the file name. Use the Browse button to the right of this field to choose the input file.</string>
+ </property>
+ <property name="readOnly">
+ <bool>false</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="textLabelLayerName">
+ <property name="sizePolicy">
</sizepolicy>
</property>
- <string>Delimiter string</string>
+ <string>Layer name</string>
</property>
- <cstring>txtDelimiter</cstring>
+ </widget>
+ </item>
+ <item row="1" column="1">
+ <widget class="QLineEdit" name="txtLayerName">
+ <string>Name to display in the map legend</string>
</property>
+ <string>Name displayed in the map legend</string>
+ </property>
</widget>
</item>
+ <item row="0" column="3">
+ <widget class="QPushButton" name="btnBrowseForFile">
+ <property name="enabled">
+ <bool>true</bool>
+ </property>
+ <property name="maximumSize">
+ <size>
+ <width>16777215</width>
+ <height>16777215</height>
+ </size>
+ </property>
+ <string>Browse to find the delimited text file to be processed</string>
+ </property>
+ <string>Use this button to browse to the location of the delimited text file. This button will not be enabled until a delimiter has been entered in the <i>Delimiter</i> box. Once a file is chosen, the X and Y field drop-down boxes will be populated with the fields from the delimited text file.</string>
+ </property>
+ <string>Browse...</string>
+ </property>
+ <property name="flat">
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <item>
+ <widget class="QFrame" name="frame_select_delimiters">
+ <bool>true</bool>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_5">
+ <item row="0" column="0">
+ <widget class="QRadioButton" name="delimiterSelection">
+ <string>Selected delimiters</string>
+ </property>
+ <property name="checked">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1">
+ <widget class="QCheckBox" name="cbxDelimSemicolon">
+ <string>Semicolon</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QCheckBox" name="cbxDelimTab">
+ <string>Tab</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QCheckBox" name="cbxDelimSpace">
+ <string>Space</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="1">
+ <widget class="QCheckBox" name="cbxDelimComma">
+ <string>Comma</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="1">
+ <widget class="QCheckBox" name="cbxDelimColon">
+ <string>Colon</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="0">
<widget class="QLineEdit" name="txtDelimiter">
+ </property>
<sizepolicy hsizetype="Minimum" vsizetype="Fixed">
@@ -138,24 +184,30 @@
</property>
</widget>
</item>
- <widget class="QLabel" name="label_2">
+ <item row="3" column="0">
+ <widget class="QRadioButton" name="delimiterRegexp">
</sizepolicy>
</property>
+ <string>The delimiter is a regular expression</string>
+ </property>
+ </property>
- <string>Type</string>
+ <string>Regular expression</string>
</property>
- <cstring>delimiterPlain</cstring>
- </property>
</widget>
</item>
- <item row="0" column="3">
+ <item row="2" column="0">
<widget class="QRadioButton" name="delimiterPlain">
+ <bool>true</bool>
+ </property>
<string>The delimiter is taken as is</string>
</property>
@@ -165,18 +217,58 @@
<string>Plain characters</string>
</property>
+ </property>
</widget>
</item>
- <item row="0" column="4">
- <widget class="QRadioButton" name="delimiterRegexp">
- <string>The delimiter is a regular expression</string>
+ </layout>
+ </widget>
+ </item>
+ <item>
+ <widget class="QWidget" name="widget_5" native="true">
+ <bool>true</bool>
+ </property>
+ </sizepolicy>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_6">
+ <widget class="QSpinBox" name="rowCounter">
+ <property name="minimumSize">
+ <size>
+ <width>0</width>
+ <height>0</height>
+ </size>
</property>
+ <size>
+ </size>
</property>
+ <property name="wrapping">
+ </property>
+ <property name="value">
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_4">
+ <sizepolicy hsizetype="Minimum" vsizetype="Preferred">
+ </sizepolicy>
+ </property>
- <string>Regular expression</string>
+ <string>Start import at row</string>
</property>
</widget>
</item>
@@ -184,22 +276,16 @@
</widget>
</item>
<item>
- <widget class="QGroupBox" name="groupBox_2">
- <string>Geometry</string>
- </property>
+ <widget class="QWidget" name="widget_2" native="true">
<layout class="QGridLayout" name="gridLayout_2">
- <widget class="QLabel" name="textLabel2">
+ <item row="0" column="2">
+ <widget class="QLabel" name="textLabelx">
<string><p align="right">X field</p></string>
</property>
- <cstring>cmbXField</cstring>
- </property>
</widget>
</item>
<widget class="QComboBox" name="cmbXField">
<sizepolicy hsizetype="Expanding" vsizetype="Fixed">
@@ -224,7 +310,14 @@
</property>
</widget>
</item>
+ <item row="0" column="5">
+ <widget class="QLabel" name="textLabely">
+ <string><p align="right">Y field</p></string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="6">
<widget class="QComboBox" name="cmbYField">
@@ -249,16 +342,6 @@
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel2_2">
- <string><p align="right">Y field</p></string>
- </property>
- <cstring>cmbYField</cstring>
- </property>
- </widget>
- </item>
</layout>
</widget>
</item>
@@ -267,17 +350,10 @@
<string>Sample text</string>
</property>
- <cstring>txtSample</cstring>
- </property>
</widget>
</item>
<item>
- <widget class="QTextEdit" name="txtSample">
- <bool>true</bool>
- </property>
- </widget>
+ <widget class="QTableWidget" name="tblSample"/>
</item>
<item>
<widget class="QDialogButtonBox" name="buttonBox">
@@ -300,19 +376,109 @@
</customwidget>
</customwidgets>
<tabstops>
- <tabstop>txtFilePath</tabstop>
- <tabstop>btnBrowseForFile</tabstop>
- <tabstop>txtLayerName</tabstop>
- <tabstop>txtDelimiter</tabstop>
- <tabstop>delimiterPlain</tabstop>
- <tabstop>delimiterRegexp</tabstop>
<tabstop>cmbXField</tabstop>
<tabstop>cmbYField</tabstop>
- <tabstop>txtSample</tabstop>
<tabstop>buttonBox</tabstop>
</tabstops>
<resources>
<include location="delimited_text.qrc"/>
</resources>
- <connections/>
+ <connections>
+ <connection>
+ <sender>delimiterSelection</sender>
+ <signal>toggled(bool)</signal>
+ <receiver>cbxDelimSpace</receiver>
+ <slot>setEnabled(bool)</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>91</x>
+ <y>121</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>282</x>
+ <y>115</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>cbxDelimTab</receiver>
+ <hints>
+ <x>150</x>
+ <y>110</y>
+ </hint>
+ <x>277</x>
+ <y>149</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>cbxDelimSemicolon</receiver>
+ <hints>
+ <x>81</x>
+ <y>109</y>
+ </hint>
+ <x>281</x>
+ <y>175</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>cbxDelimComma</receiver>
+ <hints>
+ <x>59</x>
+ <y>114</y>
+ </hint>
+ <x>293</x>
+ <y>203</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>txtDelimiter</receiver>
+ <slot>setDisabled(bool)</slot>
+ <hints>
+ <x>109</x>
+ <y>114</y>
+ </hint>
+ <x>118</x>
+ <y>218</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>cbxDelimColon</receiver>
+ <hints>
+ <x>99</x>
+ <y>113</y>
+ </hint>
+ <x>301</x>
+ <y>225</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
Modified: trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
--- trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp 2010-11-14 14:48:12 UTC (rev 14641)
+++ trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp 2010-11-14 14:49:17 UTC (rev 14642)
@@ -151,19 +151,25 @@
QString xField = temp.size() ? temp[0].mid( temp[0].indexOf( "=" ) + 1 ) : "";
temp = parameters.filter( "yField=" );
QString yField = temp.size() ? temp[0].mid( temp[0].indexOf( "=" ) + 1 ) : "";
+ temp = parameters.filter( "skipLines=" );
+ QString skipLines = temp.size() ? temp[0].mid( temp[0].indexOf( "=" ) + 1 ) : "0";
// Decode the parts of the uri. Good if someone entered '=' as a delimiter, for instance.
mFileName = QUrl::fromPercentEncoding( mFileName.toUtf8() );
mDelimiter = QUrl::fromPercentEncoding( mDelimiter.toUtf8() );
mDelimiterType = QUrl::fromPercentEncoding( mDelimiterType.toUtf8() );
xField = QUrl::fromPercentEncoding( xField.toUtf8() );
yField = QUrl::fromPercentEncoding( yField.toUtf8() );
+ skipLines = QUrl::fromPercentEncoding( skipLines.toUtf8() );
+ mSkipLines = skipLines.toInt();
QgsDebugMsg( "Data source uri is " + uri );
QgsDebugMsg( "Delimited text file is: " + mFileName );
QgsDebugMsg( "Delimiter is: " + mDelimiter );
QgsDebugMsg( "Delimiter type is: " + mDelimiterType );
QgsDebugMsg( "xField is: " + xField );
QgsDebugMsg( "yField is: " + yField );
+ QgsDebugMsg( "skipLines is: " + QString::number( mSkipLines ) );
// if delimiter contains some special characters, convert them
if ( mDelimiterType == "regexp" )
@@ -221,6 +227,9 @@
if ( line.isEmpty() )
continue;
+ if ( lineNumber < mSkipLines + 1 )
+ continue;
if ( !hasFields )
// Get the fields from the header row and store them in the
@@ -230,8 +239,7 @@
int fieldPos = 0;
- for ( QStringList::Iterator it = fieldList.begin();
- it != fieldList.end(); ++it )
+ for ( QStringList::Iterator it = fieldList.begin(); it != fieldList.end(); ++it )
QString field = *it;
if ( field.length() > 0 )
@@ -401,7 +409,7 @@
feature.setFeatureId( mFid );
- QByteArray buffer;
+ QByteArray buffer;
QDataStream s( &buffer, static_cast<QIODevice::OpenMode>( QIODevice::WriteOnly ) ); // open on buffers's data
switch ( QgsApplication::endian() )
@@ -562,7 +570,9 @@
// Skip ahead one line since first record is always assumed to be
// the header record
mStream->seek( 0 );
- readLine( mStream );
+ int n = mSkipLines + 1;
+ while ( n-- )
+ readLine( mStream );
bool QgsDelimitedTextProvider::isValid()
Modified: trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.h
--- trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.h 2010-11-14 14:48:12 UTC (rev 14641)
+++ trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.h 2010-11-14 14:49:17 UTC (rev 14642)
@@ -201,6 +201,7 @@
int mGeomType;
long mNumberFeatures;
+ int mSkipLines;
//! Storage for any lines in the file that couldn't be loaded
QStringList mInvalidLines;
