[QGIS Commit] r14647 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 14 12:54:16 EST 2010
Author: timlinux
Date: 2010-11-14 09:54:16 -0800 (Sun, 14 Nov 2010)
New Revision: 14647
   trunk/qgis/src/ui/qgslabelingguibase.ui
In progress update of label dialog
Modified: trunk/qgis/src/ui/qgslabelingguibase.ui
--- trunk/qgis/src/ui/qgslabelingguibase.ui	2010-11-14 17:38:22 UTC (rev 14646)
+++ trunk/qgis/src/ui/qgslabelingguibase.ui	2010-11-14 17:54:16 UTC (rev 14647)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>515</width>
-    <height>692</height>
+    <width>601</width>
+    <height>586</height>
    </rect>
   </property>
   <property name="windowTitle">
@@ -17,7 +17,17 @@
    <iconset>
     <normaloff>../../../../.designer/backup</normaloff>../../../../.designer/backup</iconset>
   </property>
-  <layout class="QGridLayout" name="gridLayout_13">
+  <layout class="QGridLayout" name="gridLayout">
+   <item row="1" column="0">
+    <widget class="QDialogButtonBox" name="buttonBox">
+     <property name="orientation">
+      <enum>Qt::Horizontal</enum>
+     </property>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
    <item row="0" column="0">
     <widget class="QTabWidget" name="mTabWidget">
      <property name="currentIndex">
@@ -27,7 +37,7 @@
       <attribute name="title">
        <string>Label settings</string>
       </attribute>
-      <layout class="QGridLayout" name="gridLayout_6">
+      <layout class="QGridLayout" name="gridLayout_2">
         <widget class="QCheckBox" name="chkEnableLabeling">
          <property name="text">
@@ -36,36 +46,377 @@
         </widget>
        </item>
-        <layout class="QHBoxLayout" name="horizontalLayout_11">
-         <item>
-          <widget class="QLabel" name="label_20">
-           <property name="text">
-            <string>Field with labels</string>
-           </property>
-           <property name="alignment">
-            <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
-           </property>
-          </widget>
-         </item>
-         <item>
-          <widget class="QComboBox" name="cboFieldName"/>
-         </item>
-         <item>
-          <spacer name="horizontalSpacer_5">
-           <property name="orientation">
-            <enum>Qt::Horizontal</enum>
-           </property>
-           <property name="sizeHint" stdset="0">
-            <size>
-             <width>40</width>
-             <height>20</height>
-            </size>
-           </property>
-          </spacer>
-         </item>
-        </layout>
+        <widget class="QLabel" name="label_20">
+         <property name="text">
+          <string>Field with labels</string>
+         </property>
+         <property name="alignment">
+          <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
+         </property>
+        </widget>
        </item>
-       <item row="2" column="0">
+       <item row="1" column="1">
+        <widget class="QComboBox" name="cboFieldName"/>
+       </item>
+       <item row="2" column="0" colspan="2">
+        <widget class="QGroupBox" name="groupBox_6">
+         <property name="title">
+          <string>Text style</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout_6">
+          <item row="0" column="0">
+           <widget class="QLabel" name="label_28">
+            <property name="sizePolicy">
+             <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
+              <horstretch>0</horstretch>
+              <verstretch>0</verstretch>
+             </sizepolicy>
+            </property>
+             <string>Font</string>
+            </property>
+            </property>
+           </widget>
+          </item>
+          <item row="0" column="1">
+           <widget class="QLabel" name="lblFontName">
+             <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+              <horstretch>1</horstretch>
+             </sizepolicy>
+            </property>
+             <string>TextLabel</string>
+            </property>
+           </widget>
+          </item>
+          <item row="0" column="2">
+           <spacer name="horizontalSpacer_6">
+            </property>
+            <property name="sizeHint" stdset="0">
+             <size>
+              <width>40</width>
+              <height>20</height>
+             </size>
+            </property>
+           </spacer>
+          </item>
+          <item row="0" column="3">
+           <widget class="QToolButton" name="btnChangeFont">
+             <string>...</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QLabel" name="mFontSizeLabel">
+             <string>Font size</string>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="1" colspan="3">
+           <widget class="QDoubleSpinBox" name="mFontSizeSpinBox">
+            <property name="decimals">
+             <number>4</number>
+            </property>
+            <property name="maximum">
+             <double>999999999.000000000000000</double>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="4">
+           <widget class="QComboBox" name="mFontSizeUnitComboBox">
+            <item>
+              <string>In points</string>
+             </property>
+            </item>
+            <item>
+              <string>In map units</string>
+             </property>
+            </item>
+           </widget>
+          </item>
+          <item row="2" column="0">
+           <widget class="QLabel" name="label_29">
+             </sizepolicy>
+            </property>
+             <string>Color</string>
+            </property>
+            </property>
+           </widget>
+          </item>
+          <item row="2" column="1" colspan="4">
+           <layout class="QHBoxLayout" name="horizontalLayout_16">
+            <item>
+             <widget class="QgsColorButton" name="btnTextColor">
+               <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+               </sizepolicy>
+              </property>
+               <string/>
+              </property>
+             </widget>
+            </item>
+            <item>
+             <spacer name="horizontalSpacer_7">
+              </property>
+              <property name="sizeType">
+               <enum>QSizePolicy::Preferred</enum>
+              </property>
+               <size>
+                <width>142</width>
+               </size>
+              </property>
+             </spacer>
+            </item>
+           </layout>
+          </item>
+          <item row="3" column="0">
+           <widget class="QLabel" name="label_30">
+             <string>Buffer</string>
+            </property>
+            </property>
+           </widget>
+          </item>
+          <item row="3" column="1" colspan="4">
+           <layout class="QHBoxLayout" name="horizontalLayout_17">
+            <item>
+             <widget class="QCheckBox" name="chkBuffer">
+               <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+               </sizepolicy>
+              </property>
+               <string/>
+              </property>
+             </widget>
+            </item>
+            <item>
+             <widget class="QLabel" name="label_31">
+               <string>Size</string>
+              </property>
+              </property>
+             </widget>
+            </item>
+            <item>
+             <widget class="QDoubleSpinBox" name="spinBufferSize">
+              <property name="suffix">
+               <string> mm</string>
+              </property>
+             </widget>
+            </item>
+            <item>
+             <widget class="QLabel" name="label_32">
+              </property>
+              </property>
+             </widget>
+            </item>
+            <item>
+             <widget class="QgsColorButton" name="btnBufferColor">
+               </sizepolicy>
+              </property>
+              </property>
+             </widget>
+            </item>
+           </layout>
+          </item>
+          <item row="4" column="0" colspan="5">
+           <widget class="Line" name="line_4">
+            </property>
+           </widget>
+          </item>
+          <item row="5" column="0">
+           <widget class="QLabel" name="label_33">
+             </sizepolicy>
+            </property>
+             <string>Sample</string>
+            </property>
+            </property>
+           </widget>
+          </item>
+          <item row="5" column="1" colspan="2">
+           <widget class="QgsLabelPreview" name="lblFontPreview">
+             </sizepolicy>
+            </property>
+            <property name="minimumSize">
+             <size>
+              <width>30</width>
+              <height>30</height>
+             </size>
+            </property>
+             <string>Lorem Ipsum</string>
+            </property>
+             <set>Qt::AlignCenter</set>
+            </property>
+           </widget>
+          </item>
+         </layout>
+        </widget>
+       </item>
+        <widget class="QGroupBox" name="groupBox_7">
+          <string>Priority</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout_8">
+           <widget class="QLabel" name="label_34">
+             <string>Low</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QLabel" name="label_35">
+             <string>High</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QSlider" name="sliderPriority">
+             <number>10</number>
+            </property>
+            <property name="value">
+             <number>5</number>
+            </property>
+            </property>
+            <property name="tickPosition">
+             <enum>QSlider::TicksBelow</enum>
+            </property>
+            <property name="tickInterval">
+             <number>1</number>
+            </property>
+           </widget>
+          </item>
+         </layout>
+        </widget>
+       </item>
+       <item row="3" column="1">
+        <widget class="QGroupBox" name="groupBox_8">
+          <string>Scale-based visibility</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout_10">
+          <item row="0" column="0" colspan="2">
+           <widget class="QCheckBox" name="chkScaleBasedVisibility">
+             <string>Enabled</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QLabel" name="label_36">
+             <string>Minimum</string>
+            </property>
+            </property>
+           </widget>
+          </item>
+           <widget class="QSpinBox" name="spinScaleMin">
+            <property name="minimum">
+            </property>
+             <number>10000000</number>
+            </property>
+           </widget>
+          </item>
+           <widget class="QLabel" name="label_37">
+             <string>Maximum</string>
+            </property>
+            </property>
+           </widget>
+          </item>
+          <item row="2" column="1">
+           <widget class="QSpinBox" name="spinScaleMax">
+            </property>
+            </property>
+            </property>
+           </widget>
+          </item>
+         </layout>
+        </widget>
+       </item>
+      </layout>
+     </widget>
+     <widget class="QWidget" name="tab_5">
+      <attribute name="title">
+       <string>Page</string>
+      </attribute>
+      <layout class="QGridLayout" name="gridLayout_3">
         <widget class="QGroupBox" name="groupBox_5">
           <string>Placement</string>
@@ -335,391 +686,7 @@
          </layout>
         </widget>
        </item>
-       <item row="3" column="0">
-        <layout class="QGridLayout" name="gridLayout_8">
-         <item row="0" column="0" rowspan="2">
-          <widget class="QGroupBox" name="groupBox_6">
-           <property name="title">
-            <string>Text style</string>
-           </property>
-           <layout class="QGridLayout" name="gridLayout_9">
-            <item row="0" column="0">
-             <widget class="QLabel" name="label_28">
-              <property name="sizePolicy">
-               <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
-                <horstretch>0</horstretch>
-                <verstretch>0</verstretch>
-               </sizepolicy>
-              </property>
-               <string>Font</string>
-              </property>
-              </property>
-             </widget>
-            </item>
-            <item row="0" column="1">
-             <layout class="QHBoxLayout" name="horizontalLayout_15">
-              <item>
-               <widget class="QLabel" name="lblFontName">
-                 <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
-                  <horstretch>1</horstretch>
-                 </sizepolicy>
-                </property>
-                 <string>TextLabel</string>
-                </property>
-               </widget>
-              </item>
-              <item>
-               <spacer name="horizontalSpacer_6">
-                </property>
-                 <size>
-                  <width>40</width>
-                 </size>
-                </property>
-               </spacer>
-              </item>
-              <item>
-               <widget class="QToolButton" name="btnChangeFont">
-                 <string>...</string>
-                </property>
-               </widget>
-              </item>
-             </layout>
-            </item>
-             <widget class="QLabel" name="label_29">
-               </sizepolicy>
-              </property>
-               <string>Color</string>
-              </property>
-              </property>
-             </widget>
-            </item>
-            <item row="2" column="1">
-             <layout class="QHBoxLayout" name="horizontalLayout_16">
-              <item>
-               <widget class="QgsColorButton" name="btnTextColor">
-                 <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
-                 </sizepolicy>
-                </property>
-                 <string/>
-                </property>
-               </widget>
-              </item>
-              <item>
-               <spacer name="horizontalSpacer_7">
-                </property>
-                <property name="sizeType">
-                 <enum>QSizePolicy::Preferred</enum>
-                </property>
-                 <size>
-                  <width>142</width>
-                 </size>
-                </property>
-               </spacer>
-              </item>
-             </layout>
-            </item>
-             <widget class="QLabel" name="label_30">
-               <string>Buffer</string>
-              </property>
-              </property>
-             </widget>
-            </item>
-            <item row="3" column="1">
-             <layout class="QHBoxLayout" name="horizontalLayout_17">
-              <item>
-               <widget class="QCheckBox" name="chkBuffer">
-                 <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
-                 </sizepolicy>
-                </property>
-                 <string/>
-                </property>
-               </widget>
-              </item>
-              <item>
-               <widget class="QLabel" name="label_31">
-                 <string>Size</string>
-                </property>
-                </property>
-               </widget>
-              </item>
-              <item>
-               <widget class="QDoubleSpinBox" name="spinBufferSize">
-                <property name="suffix">
-                 <string> mm</string>
-                </property>
-               </widget>
-              </item>
-              <item>
-               <widget class="QLabel" name="label_32">
-                </property>
-                </property>
-               </widget>
-              </item>
-              <item>
-               <widget class="QgsColorButton" name="btnBufferColor">
-                 </sizepolicy>
-                </property>
-                </property>
-               </widget>
-              </item>
-             </layout>
-            </item>
-            <item row="5" column="0">
-             <widget class="QLabel" name="label_33">
-               </sizepolicy>
-              </property>
-               <string>Sample</string>
-              </property>
-              </property>
-             </widget>
-            </item>
-            <item row="5" column="1">
-             <widget class="QgsLabelPreview" name="lblFontPreview">
-               </sizepolicy>
-              </property>
-              <property name="minimumSize">
-               <size>
-                <width>30</width>
-                <height>30</height>
-               </size>
-              </property>
-               <string>Lorem Ipsum</string>
-              </property>
-               <set>Qt::AlignCenter</set>
-              </property>
-             </widget>
-            </item>
-            <item row="4" column="0" colspan="2">
-             <widget class="Line" name="line_4">
-              </property>
-             </widget>
-            </item>
-            <item row="1" column="0">
-             <widget class="QLabel" name="mFontSizeLabel">
-               <string>Font size</string>
-              </property>
-             </widget>
-            </item>
-            <item row="1" column="1">
-             <layout class="QHBoxLayout" name="horizontalLayout">
-              <item>
-               <widget class="QDoubleSpinBox" name="mFontSizeSpinBox">
-                <property name="decimals">
-                 <number>4</number>
-                </property>
-                <property name="maximum">
-                 <double>999999999.000000000000000</double>
-                </property>
-               </widget>
-              </item>
-              <item>
-               <widget class="QComboBox" name="mFontSizeUnitComboBox">
-                <item>
-                  <string>In points</string>
-                 </property>
-                </item>
-                <item>
-                  <string>In map units</string>
-                 </property>
-                </item>
-               </widget>
-              </item>
-             </layout>
-            </item>
-           </layout>
-          </widget>
-         </item>
-          <widget class="QGroupBox" name="groupBox_7">
-            <string>Priority</string>
-           </property>
-           <layout class="QHBoxLayout" name="horizontalLayout_18">
-            <item>
-             <widget class="QLabel" name="label_34">
-               <string>Low</string>
-              </property>
-             </widget>
-            </item>
-            <item>
-             <widget class="QSlider" name="sliderPriority">
-               <number>10</number>
-              </property>
-              <property name="value">
-               <number>5</number>
-              </property>
-              </property>
-              <property name="tickPosition">
-               <enum>QSlider::TicksBelow</enum>
-              </property>
-              <property name="tickInterval">
-               <number>1</number>
-              </property>
-             </widget>
-            </item>
-            <item>
-             <widget class="QLabel" name="label_35">
-               <string>High</string>
-              </property>
-             </widget>
-            </item>
-           </layout>
-          </widget>
-         </item>
-          <widget class="QGroupBox" name="groupBox_8">
-            <string>Scale-based visibility</string>
-           </property>
-           <layout class="QGridLayout" name="gridLayout_10">
-            <item row="0" column="0" colspan="2">
-             <widget class="QCheckBox" name="chkScaleBasedVisibility">
-               <string>Enabled</string>
-              </property>
-             </widget>
-            </item>
-             <widget class="QLabel" name="label_36">
-               <string>Minimum</string>
-              </property>
-              </property>
-             </widget>
-            </item>
-             <widget class="QSpinBox" name="spinScaleMin">
-              <property name="minimum">
-              </property>
-               <number>10000000</number>
-              </property>
-             </widget>
-            </item>
-             <widget class="QLabel" name="label_37">
-               <string>Maximum</string>
-              </property>
-              </property>
-             </widget>
-            </item>
-             <widget class="QSpinBox" name="spinScaleMax">
-              </property>
-              </property>
-              </property>
-             </widget>
-            </item>
-           </layout>
-          </widget>
-         </item>
-        </layout>
-       </item>
-       <item row="4" column="0">
-        <widget class="QCheckBox" name="chkLabelPerFeaturePart">
-          <string>label every part of multi-part features</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QCheckBox" name="chkMergeLines">
-          <string>merge connected lines to avoid duplicate labels</string>
-         </property>
-        </widget>
-       </item>
-       <item row="6" column="0">
-        <widget class="QCheckBox" name="chkMultiLine">
-          <string>multiline labels</string>
-         </property>
-        </widget>
-       </item>
-       <item row="8" column="0">
         <layout class="QHBoxLayout" name="horizontalLayout_19">
          <item>
           <widget class="QLabel" name="label_19">
@@ -737,7 +704,7 @@
          </item>
         </layout>
        </item>
-       <item row="9" column="0">
         <layout class="QHBoxLayout" name="horizontalLayout_20">
          <item>
           <widget class="QCheckBox" name="chkNoObstacle">
@@ -774,7 +741,28 @@
          </item>
         </layout>
        </item>
-       <item row="7" column="0">
+        <widget class="QCheckBox" name="chkLabelPerFeaturePart">
+          <string>label every part of multi-part features</string>
+         </property>
+        </widget>
+       </item>
+       <item row="4" column="0">
+        <widget class="QCheckBox" name="chkMergeLines">
+          <string>merge connected lines to avoid duplicate labels</string>
+         </property>
+        </widget>
+       </item>
+        <widget class="QCheckBox" name="chkMultiLine">
+          <string>multiline labels</string>
+         </property>
+        </widget>
+       </item>
+       <item row="6" column="0">
         <widget class="QCheckBox" name="chkAddDirectionSymbol">
           <string>add direction symbol</string>
@@ -787,7 +775,7 @@
        <string>Data defined settings</string>
       </attribute>
-      <layout class="QGridLayout" name="gridLayout_3">
+      <layout class="QGridLayout" name="gridLayout_5">
         <widget class="QGroupBox" name="mFontAttributePropertiesGroupBox">
@@ -799,7 +787,7 @@
           <string>Font properties</string>
          </property>
-         <layout class="QGridLayout" name="gridLayout">
+         <layout class="QFormLayout" name="formLayout">
            <widget class="QLabel" name="mSizeLabel">
@@ -873,12 +861,19 @@
          </layout>
         </widget>
        </item>
+      </layout>
+     </widget>
+     <widget class="QWidget" name="tab">
+       <string>Data defined </string>
+      </attribute>
+      <layout class="QFormLayout" name="formLayout_3">
         <widget class="QGroupBox" name="mBufferAttributesPropertiesGroupBox">
           <string>Buffer properties</string>
          </property>
-         <layout class="QGridLayout" name="gridLayout_2">
+         <layout class="QFormLayout" name="formLayout_2">
            <widget class="QLabel" name="mBufferSizeLabel">
@@ -902,12 +897,29 @@
          </layout>
         </widget>
        </item>
+      </layout>
+     </widget>
+     <widget class="QWidget" name="tab_2">
+      </attribute>
+      <layout class="QGridLayout" name="gridLayout_4">
         <widget class="QGroupBox" name="mPositionAttributeGroupBox">
           <string>Position</string>
          </property>
-         <layout class="QGridLayout" name="gridLayout_4">
+         <layout class="QFormLayout" name="formLayout_4">
+           <widget class="QLabel" name="mLabelDistanceLabel">
+             <string>Label distance</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="mLabelDistanceComboBox"/>
+          </item>
            <widget class="QLabel" name="mXCoordinateLabel">
@@ -948,9 +960,6 @@
           <item row="4" column="1">
            <widget class="QComboBox" name="mVerticalAlignmentComboBox"/>
           </item>
-           <widget class="QComboBox" name="mRotationComboBox"/>
-          </item>
            <widget class="QLabel" name="mRotationLabel">
@@ -958,46 +967,16 @@
             </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="mLabelDistanceComboBox"/>
+          <item row="5" column="1">
+           <widget class="QComboBox" name="mRotationComboBox"/>
           </item>
-           <widget class="QLabel" name="mLabelDistanceLabel">
-             <string>Label distance</string>
-            </property>
-           </widget>
-          </item>
          </layout>
         </widget>
        </item>
-        <spacer name="verticalSpacer">
-          <enum>Qt::Vertical</enum>
-         </property>
-          <size>
-           <width>20</width>
-           <height>521</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
       </layout>
      </widget>
     </widget>
    </item>
-    <widget class="QDialogButtonBox" name="buttonBox">
-     </property>
-     <property name="standardButtons">
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
-     </property>
-    </widget>
-   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11"/>
More information about the QGIS-commit mailing list
