[QGIS Commit] r14649 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 14 13:00:42 EST 2010
Author: timlinux
Date: 2010-11-14 10:00:42 -0800 (Sun, 14 Nov 2010)
New Revision: 14649
   trunk/qgis/src/ui/qgslabelingguibase.ui
reverted to svn trunk of this file
Modified: trunk/qgis/src/ui/qgslabelingguibase.ui
--- trunk/qgis/src/ui/qgslabelingguibase.ui	2010-11-14 17:54:31 UTC (rev 14648)
+++ trunk/qgis/src/ui/qgslabelingguibase.ui	2010-11-14 18:00:42 UTC (rev 14649)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>601</width>
-    <height>586</height>
+    <width>515</width>
+    <height>692</height>
    </rect>
   </property>
   <property name="windowTitle">
@@ -17,17 +17,7 @@
    <iconset>
     <normaloff>../../../../.designer/backup</normaloff>../../../../.designer/backup</iconset>
   </property>
-  <layout class="QGridLayout" name="gridLayout">
-   <item row="1" column="0">
-    <widget class="QDialogButtonBox" name="buttonBox">
-     <property name="orientation">
-      <enum>Qt::Horizontal</enum>
-     </property>
-     <property name="standardButtons">
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
-     </property>
-    </widget>
-   </item>
+  <layout class="QGridLayout" name="gridLayout_13">
    <item row="0" column="0">
     <widget class="QTabWidget" name="mTabWidget">
      <property name="currentIndex">
@@ -37,7 +27,7 @@
       <attribute name="title">
        <string>Label settings</string>
       </attribute>
-      <layout class="QGridLayout" name="gridLayout_2">
+      <layout class="QGridLayout" name="gridLayout_6">
         <widget class="QCheckBox" name="chkEnableLabeling">
          <property name="text">
@@ -46,377 +36,36 @@
         </widget>
        </item>
-        <widget class="QLabel" name="label_20">
-         <property name="text">
-          <string>Field with labels</string>
-         </property>
-         <property name="alignment">
-          <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
-         </property>
-        </widget>
+        <layout class="QHBoxLayout" name="horizontalLayout_11">
+         <item>
+          <widget class="QLabel" name="label_20">
+           <property name="text">
+            <string>Field with labels</string>
+           </property>
+           <property name="alignment">
+            <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
+           </property>
+          </widget>
+         </item>
+         <item>
+          <widget class="QComboBox" name="cboFieldName"/>
+         </item>
+         <item>
+          <spacer name="horizontalSpacer_5">
+           <property name="orientation">
+            <enum>Qt::Horizontal</enum>
+           </property>
+           <property name="sizeHint" stdset="0">
+            <size>
+             <width>40</width>
+             <height>20</height>
+            </size>
+           </property>
+          </spacer>
+         </item>
+        </layout>
        </item>
-       <item row="1" column="1">
-        <widget class="QComboBox" name="cboFieldName"/>
-       </item>
-       <item row="2" column="0" colspan="2">
-        <widget class="QGroupBox" name="groupBox_6">
-         <property name="title">
-          <string>Text style</string>
-         </property>
-         <layout class="QGridLayout" name="gridLayout_6">
-          <item row="0" column="0">
-           <widget class="QLabel" name="label_28">
-            <property name="sizePolicy">
-             <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
-              <horstretch>0</horstretch>
-              <verstretch>0</verstretch>
-             </sizepolicy>
-            </property>
-             <string>Font</string>
-            </property>
-            </property>
-           </widget>
-          </item>
-          <item row="0" column="1">
-           <widget class="QLabel" name="lblFontName">
-             <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
-              <horstretch>1</horstretch>
-             </sizepolicy>
-            </property>
-             <string>TextLabel</string>
-            </property>
-           </widget>
-          </item>
-          <item row="0" column="2">
-           <spacer name="horizontalSpacer_6">
-            </property>
-            <property name="sizeHint" stdset="0">
-             <size>
-              <width>40</width>
-              <height>20</height>
-             </size>
-            </property>
-           </spacer>
-          </item>
-          <item row="0" column="3">
-           <widget class="QToolButton" name="btnChangeFont">
-             <string>...</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QLabel" name="mFontSizeLabel">
-             <string>Font size</string>
-            </property>
-           </widget>
-          </item>
-          <item row="1" column="1" colspan="3">
-           <widget class="QDoubleSpinBox" name="mFontSizeSpinBox">
-            <property name="decimals">
-             <number>4</number>
-            </property>
-            <property name="maximum">
-             <double>999999999.000000000000000</double>
-            </property>
-           </widget>
-          </item>
-          <item row="1" column="4">
-           <widget class="QComboBox" name="mFontSizeUnitComboBox">
-            <item>
-              <string>In points</string>
-             </property>
-            </item>
-            <item>
-              <string>In map units</string>
-             </property>
-            </item>
-           </widget>
-          </item>
-          <item row="2" column="0">
-           <widget class="QLabel" name="label_29">
-             </sizepolicy>
-            </property>
-             <string>Color</string>
-            </property>
-            </property>
-           </widget>
-          </item>
-          <item row="2" column="1" colspan="4">
-           <layout class="QHBoxLayout" name="horizontalLayout_16">
-            <item>
-             <widget class="QgsColorButton" name="btnTextColor">
-               <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
-               </sizepolicy>
-              </property>
-               <string/>
-              </property>
-             </widget>
-            </item>
-            <item>
-             <spacer name="horizontalSpacer_7">
-              </property>
-              <property name="sizeType">
-               <enum>QSizePolicy::Preferred</enum>
-              </property>
-               <size>
-                <width>142</width>
-               </size>
-              </property>
-             </spacer>
-            </item>
-           </layout>
-          </item>
-          <item row="3" column="0">
-           <widget class="QLabel" name="label_30">
-             <string>Buffer</string>
-            </property>
-            </property>
-           </widget>
-          </item>
-          <item row="3" column="1" colspan="4">
-           <layout class="QHBoxLayout" name="horizontalLayout_17">
-            <item>
-             <widget class="QCheckBox" name="chkBuffer">
-               <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
-               </sizepolicy>
-              </property>
-               <string/>
-              </property>
-             </widget>
-            </item>
-            <item>
-             <widget class="QLabel" name="label_31">
-               <string>Size</string>
-              </property>
-              </property>
-             </widget>
-            </item>
-            <item>
-             <widget class="QDoubleSpinBox" name="spinBufferSize">
-              <property name="suffix">
-               <string> mm</string>
-              </property>
-             </widget>
-            </item>
-            <item>
-             <widget class="QLabel" name="label_32">
-              </property>
-              </property>
-             </widget>
-            </item>
-            <item>
-             <widget class="QgsColorButton" name="btnBufferColor">
-               </sizepolicy>
-              </property>
-              </property>
-             </widget>
-            </item>
-           </layout>
-          </item>
-          <item row="4" column="0" colspan="5">
-           <widget class="Line" name="line_4">
-            </property>
-           </widget>
-          </item>
-          <item row="5" column="0">
-           <widget class="QLabel" name="label_33">
-             </sizepolicy>
-            </property>
-             <string>Sample</string>
-            </property>
-            </property>
-           </widget>
-          </item>
-          <item row="5" column="1" colspan="2">
-           <widget class="QgsLabelPreview" name="lblFontPreview">
-             </sizepolicy>
-            </property>
-            <property name="minimumSize">
-             <size>
-              <width>30</width>
-              <height>30</height>
-             </size>
-            </property>
-             <string>Lorem Ipsum</string>
-            </property>
-             <set>Qt::AlignCenter</set>
-            </property>
-           </widget>
-          </item>
-         </layout>
-        </widget>
-       </item>
-        <widget class="QGroupBox" name="groupBox_7">
-          <string>Priority</string>
-         </property>
-         <layout class="QGridLayout" name="gridLayout_8">
-           <widget class="QLabel" name="label_34">
-             <string>Low</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QLabel" name="label_35">
-             <string>High</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QSlider" name="sliderPriority">
-             <number>10</number>
-            </property>
-            <property name="value">
-             <number>5</number>
-            </property>
-            </property>
-            <property name="tickPosition">
-             <enum>QSlider::TicksBelow</enum>
-            </property>
-            <property name="tickInterval">
-             <number>1</number>
-            </property>
-           </widget>
-          </item>
-         </layout>
-        </widget>
-       </item>
-       <item row="3" column="1">
-        <widget class="QGroupBox" name="groupBox_8">
-          <string>Scale-based visibility</string>
-         </property>
-         <layout class="QGridLayout" name="gridLayout_10">
-          <item row="0" column="0" colspan="2">
-           <widget class="QCheckBox" name="chkScaleBasedVisibility">
-             <string>Enabled</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QLabel" name="label_36">
-             <string>Minimum</string>
-            </property>
-            </property>
-           </widget>
-          </item>
-           <widget class="QSpinBox" name="spinScaleMin">
-            <property name="minimum">
-            </property>
-             <number>10000000</number>
-            </property>
-           </widget>
-          </item>
-           <widget class="QLabel" name="label_37">
-             <string>Maximum</string>
-            </property>
-            </property>
-           </widget>
-          </item>
-          <item row="2" column="1">
-           <widget class="QSpinBox" name="spinScaleMax">
-            </property>
-            </property>
-            </property>
-           </widget>
-          </item>
-         </layout>
-        </widget>
-       </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="tab_5">
-      <attribute name="title">
-       <string>Page</string>
-      </attribute>
-      <layout class="QGridLayout" name="gridLayout_3">
+       <item row="2" column="0">
         <widget class="QGroupBox" name="groupBox_5">
           <string>Placement</string>
@@ -686,7 +335,391 @@
          </layout>
         </widget>
        </item>
+       <item row="3" column="0">
+        <layout class="QGridLayout" name="gridLayout_8">
+         <item row="0" column="0" rowspan="2">
+          <widget class="QGroupBox" name="groupBox_6">
+           <property name="title">
+            <string>Text style</string>
+           </property>
+           <layout class="QGridLayout" name="gridLayout_9">
+            <item row="0" column="0">
+             <widget class="QLabel" name="label_28">
+              <property name="sizePolicy">
+               <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
+                <horstretch>0</horstretch>
+                <verstretch>0</verstretch>
+               </sizepolicy>
+              </property>
+               <string>Font</string>
+              </property>
+              </property>
+             </widget>
+            </item>
+            <item row="0" column="1">
+             <layout class="QHBoxLayout" name="horizontalLayout_15">
+              <item>
+               <widget class="QLabel" name="lblFontName">
+                 <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+                  <horstretch>1</horstretch>
+                 </sizepolicy>
+                </property>
+                 <string>TextLabel</string>
+                </property>
+               </widget>
+              </item>
+              <item>
+               <spacer name="horizontalSpacer_6">
+                </property>
+                 <size>
+                  <width>40</width>
+                 </size>
+                </property>
+               </spacer>
+              </item>
+              <item>
+               <widget class="QToolButton" name="btnChangeFont">
+                 <string>...</string>
+                </property>
+               </widget>
+              </item>
+             </layout>
+            </item>
+             <widget class="QLabel" name="label_29">
+               </sizepolicy>
+              </property>
+               <string>Color</string>
+              </property>
+              </property>
+             </widget>
+            </item>
+            <item row="2" column="1">
+             <layout class="QHBoxLayout" name="horizontalLayout_16">
+              <item>
+               <widget class="QgsColorButton" name="btnTextColor">
+                 <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+                 </sizepolicy>
+                </property>
+                 <string/>
+                </property>
+               </widget>
+              </item>
+              <item>
+               <spacer name="horizontalSpacer_7">
+                </property>
+                <property name="sizeType">
+                 <enum>QSizePolicy::Preferred</enum>
+                </property>
+                 <size>
+                  <width>142</width>
+                 </size>
+                </property>
+               </spacer>
+              </item>
+             </layout>
+            </item>
+             <widget class="QLabel" name="label_30">
+               <string>Buffer</string>
+              </property>
+              </property>
+             </widget>
+            </item>
+            <item row="3" column="1">
+             <layout class="QHBoxLayout" name="horizontalLayout_17">
+              <item>
+               <widget class="QCheckBox" name="chkBuffer">
+                 <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+                 </sizepolicy>
+                </property>
+                 <string/>
+                </property>
+               </widget>
+              </item>
+              <item>
+               <widget class="QLabel" name="label_31">
+                 <string>Size</string>
+                </property>
+                </property>
+               </widget>
+              </item>
+              <item>
+               <widget class="QDoubleSpinBox" name="spinBufferSize">
+                <property name="suffix">
+                 <string> mm</string>
+                </property>
+               </widget>
+              </item>
+              <item>
+               <widget class="QLabel" name="label_32">
+                </property>
+                </property>
+               </widget>
+              </item>
+              <item>
+               <widget class="QgsColorButton" name="btnBufferColor">
+                 </sizepolicy>
+                </property>
+                </property>
+               </widget>
+              </item>
+             </layout>
+            </item>
+            <item row="5" column="0">
+             <widget class="QLabel" name="label_33">
+               </sizepolicy>
+              </property>
+               <string>Sample</string>
+              </property>
+              </property>
+             </widget>
+            </item>
+            <item row="5" column="1">
+             <widget class="QgsLabelPreview" name="lblFontPreview">
+               </sizepolicy>
+              </property>
+              <property name="minimumSize">
+               <size>
+                <width>30</width>
+                <height>30</height>
+               </size>
+              </property>
+               <string>Lorem Ipsum</string>
+              </property>
+               <set>Qt::AlignCenter</set>
+              </property>
+             </widget>
+            </item>
+            <item row="4" column="0" colspan="2">
+             <widget class="Line" name="line_4">
+              </property>
+             </widget>
+            </item>
+            <item row="1" column="0">
+             <widget class="QLabel" name="mFontSizeLabel">
+               <string>Font size</string>
+              </property>
+             </widget>
+            </item>
+            <item row="1" column="1">
+             <layout class="QHBoxLayout" name="horizontalLayout">
+              <item>
+               <widget class="QDoubleSpinBox" name="mFontSizeSpinBox">
+                <property name="decimals">
+                 <number>4</number>
+                </property>
+                <property name="maximum">
+                 <double>999999999.000000000000000</double>
+                </property>
+               </widget>
+              </item>
+              <item>
+               <widget class="QComboBox" name="mFontSizeUnitComboBox">
+                <item>
+                  <string>In points</string>
+                 </property>
+                </item>
+                <item>
+                  <string>In map units</string>
+                 </property>
+                </item>
+               </widget>
+              </item>
+             </layout>
+            </item>
+           </layout>
+          </widget>
+         </item>
+          <widget class="QGroupBox" name="groupBox_7">
+            <string>Priority</string>
+           </property>
+           <layout class="QHBoxLayout" name="horizontalLayout_18">
+            <item>
+             <widget class="QLabel" name="label_34">
+               <string>Low</string>
+              </property>
+             </widget>
+            </item>
+            <item>
+             <widget class="QSlider" name="sliderPriority">
+               <number>10</number>
+              </property>
+              <property name="value">
+               <number>5</number>
+              </property>
+              </property>
+              <property name="tickPosition">
+               <enum>QSlider::TicksBelow</enum>
+              </property>
+              <property name="tickInterval">
+               <number>1</number>
+              </property>
+             </widget>
+            </item>
+            <item>
+             <widget class="QLabel" name="label_35">
+               <string>High</string>
+              </property>
+             </widget>
+            </item>
+           </layout>
+          </widget>
+         </item>
+          <widget class="QGroupBox" name="groupBox_8">
+            <string>Scale-based visibility</string>
+           </property>
+           <layout class="QGridLayout" name="gridLayout_10">
+            <item row="0" column="0" colspan="2">
+             <widget class="QCheckBox" name="chkScaleBasedVisibility">
+               <string>Enabled</string>
+              </property>
+             </widget>
+            </item>
+             <widget class="QLabel" name="label_36">
+               <string>Minimum</string>
+              </property>
+              </property>
+             </widget>
+            </item>
+             <widget class="QSpinBox" name="spinScaleMin">
+              <property name="minimum">
+              </property>
+               <number>10000000</number>
+              </property>
+             </widget>
+            </item>
+             <widget class="QLabel" name="label_37">
+               <string>Maximum</string>
+              </property>
+              </property>
+             </widget>
+            </item>
+             <widget class="QSpinBox" name="spinScaleMax">
+              </property>
+              </property>
+              </property>
+             </widget>
+            </item>
+           </layout>
+          </widget>
+         </item>
+        </layout>
+       </item>
+       <item row="4" column="0">
+        <widget class="QCheckBox" name="chkLabelPerFeaturePart">
+          <string>label every part of multi-part features</string>
+         </property>
+        </widget>
+       </item>
+        <widget class="QCheckBox" name="chkMergeLines">
+          <string>merge connected lines to avoid duplicate labels</string>
+         </property>
+        </widget>
+       </item>
+       <item row="6" column="0">
+        <widget class="QCheckBox" name="chkMultiLine">
+          <string>multiline labels</string>
+         </property>
+        </widget>
+       </item>
+       <item row="8" column="0">
         <layout class="QHBoxLayout" name="horizontalLayout_19">
          <item>
           <widget class="QLabel" name="label_19">
@@ -704,7 +737,7 @@
          </item>
         </layout>
        </item>
+       <item row="9" column="0">
         <layout class="QHBoxLayout" name="horizontalLayout_20">
          <item>
           <widget class="QCheckBox" name="chkNoObstacle">
@@ -741,28 +774,7 @@
          </item>
         </layout>
        </item>
-        <widget class="QCheckBox" name="chkLabelPerFeaturePart">
-          <string>label every part of multi-part features</string>
-         </property>
-        </widget>
-       </item>
-       <item row="4" column="0">
-        <widget class="QCheckBox" name="chkMergeLines">
-          <string>merge connected lines to avoid duplicate labels</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QCheckBox" name="chkMultiLine">
-          <string>multiline labels</string>
-         </property>
-        </widget>
-       </item>
-       <item row="6" column="0">
+       <item row="7" column="0">
         <widget class="QCheckBox" name="chkAddDirectionSymbol">
           <string>add direction symbol</string>
@@ -775,7 +787,7 @@
        <string>Data defined settings</string>
       </attribute>
-      <layout class="QGridLayout" name="gridLayout_5">
+      <layout class="QGridLayout" name="gridLayout_3">
         <widget class="QGroupBox" name="mFontAttributePropertiesGroupBox">
@@ -787,7 +799,7 @@
           <string>Font properties</string>
          </property>
-         <layout class="QFormLayout" name="formLayout">
+         <layout class="QGridLayout" name="gridLayout">
            <widget class="QLabel" name="mSizeLabel">
@@ -861,19 +873,12 @@
          </layout>
         </widget>
        </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="tab">
-       <string>Data defined </string>
-      </attribute>
-      <layout class="QFormLayout" name="formLayout_3">
         <widget class="QGroupBox" name="mBufferAttributesPropertiesGroupBox">
           <string>Buffer properties</string>
          </property>
-         <layout class="QFormLayout" name="formLayout_2">
+         <layout class="QGridLayout" name="gridLayout_2">
            <widget class="QLabel" name="mBufferSizeLabel">
@@ -897,29 +902,12 @@
          </layout>
         </widget>
        </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="tab_2">
-      </attribute>
-      <layout class="QGridLayout" name="gridLayout_4">
         <widget class="QGroupBox" name="mPositionAttributeGroupBox">
           <string>Position</string>
          </property>
-         <layout class="QFormLayout" name="formLayout_4">
-           <widget class="QLabel" name="mLabelDistanceLabel">
-             <string>Label distance</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QComboBox" name="mLabelDistanceComboBox"/>
-          </item>
+         <layout class="QGridLayout" name="gridLayout_4">
            <widget class="QLabel" name="mXCoordinateLabel">
@@ -960,6 +948,9 @@
           <item row="4" column="1">
            <widget class="QComboBox" name="mVerticalAlignmentComboBox"/>
           </item>
+           <widget class="QComboBox" name="mRotationComboBox"/>
+          </item>
            <widget class="QLabel" name="mRotationLabel">
@@ -967,16 +958,46 @@
             </property>
            </widget>
           </item>
-          <item row="5" column="1">
-           <widget class="QComboBox" name="mRotationComboBox"/>
+           <widget class="QComboBox" name="mLabelDistanceComboBox"/>
           </item>
+           <widget class="QLabel" name="mLabelDistanceLabel">
+             <string>Label distance</string>
+            </property>
+           </widget>
+          </item>
          </layout>
         </widget>
        </item>
+        <spacer name="verticalSpacer">
+          <enum>Qt::Vertical</enum>
+         </property>
+          <size>
+           <width>20</width>
+           <height>521</height>
+          </size>
+         </property>
+        </spacer>
+       </item>
       </layout>
      </widget>
     </widget>
    </item>
+    <widget class="QDialogButtonBox" name="buttonBox">
+     </property>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11"/>
More information about the QGIS-commit mailing list
