[QGIS Commit] r14666 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 14 17:45:13 EST 2010
Author: timlinux
Date: 2010-11-14 14:45:13 -0800 (Sun, 14 Nov 2010)
New Revision: 14666
   trunk/qgis/src/ui/qgsoptionsbase.ui
Remove stray shortcut indicator
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui	2010-11-14 22:45:06 UTC (rev 14665)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui	2010-11-14 22:45:13 UTC (rev 14666)
@@ -41,7 +41,7 @@
        <height>32</height>
       </size>
      </property>
-     <widget class="QWidget" name="tabWidgetPage1" native="true">
+     <widget class="QWidget" name="tabWidgetPage1">
       <attribute name="icon">
        <iconset resource="../../images/images.qrc">
         <normaloff>:/images/themes/default/propertyicons/general.png</normaloff>:/images/themes/default/propertyicons/general.png</iconset>
@@ -60,8 +60,8 @@
            <rect>
             <x>0</x>
             <y>0</y>
-            <width>746</width>
-            <height>530</height>
+            <width>749</width>
+            <height>558</height>
            </rect>
           </property>
           <layout class="QGridLayout" name="gridLayout_12">
@@ -166,7 +166,7 @@
            <item row="2" column="0">
             <widget class="QGroupBox" name="groupBox">
              <property name="title">
-              <string>&amp;Application</string>
+              <string>Application</string>
              </property>
              <layout class="QVBoxLayout" name="verticalLayout_9">
               <item>
@@ -325,7 +325,7 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabWidgetPage2" native="true">
+     <widget class="QWidget" name="tabWidgetPage2">
         <normaloff>:/images/themes/default/propertyicons/rendering.png</normaloff>:/images/themes/default/propertyicons/rendering.png</iconset>
@@ -344,8 +344,8 @@
            <rect>
             <x>0</x>
             <y>0</y>
-            <height>473</height>
+            <height>470</height>
            </rect>
           </property>
           <layout class="QGridLayout" name="gridLayout_8">
@@ -496,7 +496,7 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabWidgetPage3" native="true">
+     <widget class="QWidget" name="tabWidgetPage3">
         <normaloff>:/images/themes/default/propertyicons/map_tools.png</normaloff>:/images/themes/default/propertyicons/map_tools.png</iconset>
@@ -515,8 +515,8 @@
            <rect>
             <x>0</x>
             <y>0</y>
-            <height>490</height>
+            <height>487</height>
            </rect>
           </property>
           <layout class="QGridLayout" name="gridLayout_4">
@@ -776,7 +776,7 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabWidgetPage4" native="true">
+     <widget class="QWidget" name="tabWidgetPage4">
         <normaloff>:/images/themes/default/propertyicons/overlay.png</normaloff>:/images/themes/default/propertyicons/overlay.png</iconset>
@@ -795,8 +795,8 @@
            <rect>
             <x>0</x>
             <y>0</y>
-            <width>762</width>
-            <height>448</height>
+            <width>277</width>
+            <height>87</height>
            </rect>
           </property>
           <layout class="QGridLayout" name="gridLayout_10">
@@ -851,7 +851,7 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabWidgetPage5" native="true">
+     <widget class="QWidget" name="tabWidgetPage5">
         <normaloff>:/images/themes/default/propertyicons/digitising.png</normaloff>:/images/themes/default/propertyicons/digitising.png</iconset>
@@ -870,8 +870,8 @@
            <rect>
             <x>0</x>
             <y>0</y>
+            <width>744</width>
+            <height>446</height>
            </rect>
           </property>
           <layout class="QGridLayout" name="gridLayout_13">
@@ -1181,7 +1181,7 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabWidgetPage6" native="true">
+     <widget class="QWidget" name="tabWidgetPage6">
         <normaloff>:/images/themes/default/propertyicons/CRS.png</normaloff>:/images/themes/default/propertyicons/CRS.png</iconset>
@@ -1200,8 +1200,8 @@
            <rect>
             <x>0</x>
             <y>0</y>
-            <height>531</height>
+            <width>390</width>
+            <height>563</height>
            </rect>
           </property>
           <layout class="QGridLayout" name="gridLayout_15">
@@ -1277,7 +1277,7 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabWidgetPage7" native="true">
+     <widget class="QWidget" name="tabWidgetPage7">
         <normaloff>:/images/themes/default/propertyicons/locale.png</normaloff>:/images/themes/default/propertyicons/locale.png</iconset>
@@ -1296,7 +1296,7 @@
            <rect>
             <x>0</x>
             <y>0</y>
             <height>548</height>
            </rect>
           </property>
@@ -1368,7 +1368,7 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabWidgetPage8" native="true">
+     <widget class="QWidget" name="tabWidgetPage8">
         <normaloff>:/images/themes/default/propertyicons/network_and_proxy.png</normaloff>:/images/themes/default/propertyicons/network_and_proxy.png</iconset>
@@ -1387,8 +1387,8 @@
            <rect>
             <x>0</x>
             <y>0</y>
-            <height>538</height>
+            <width>353</width>
+            <height>535</height>
            </rect>
           </property>
           <layout class="QGridLayout" name="gridLayout_20">
More information about the QGIS-commit mailing list
