[QGIS Commit] r14683 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org
Mon Nov 15 06:12:03 EST 2010
Author: brushtyler
Date: 2010-11-15 03:12:03 -0800 (Mon, 15 Nov 2010)
New Revision: 14683
trunk/qgis/src/plugins/grass/qgsgrassregionbase.ui
added usage message into selection GRASS gui
Modified: trunk/qgis/src/plugins/grass/qgsgrassregionbase.ui
--- trunk/qgis/src/plugins/grass/qgsgrassregionbase.ui 2010-11-15 10:45:32 UTC (rev 14682)
+++ trunk/qgis/src/plugins/grass/qgsgrassregionbase.ui 2010-11-15 11:12:03 UTC (rev 14683)
@@ -7,7 +7,7 @@
<x>0</x>
<y>0</y>
<width>445</width>
- <height>348</height>
+ <height>388</height>
</rect>
</property>
<property name="windowTitle">
@@ -20,7 +20,7 @@
<string>Extent</string>
</property>
<layout class="QGridLayout" name="gridLayout">
- <item row="0" column="2">
+ <item row="1" column="2">
<widget class="QLabel" name="textLabel1">
<property name="sizePolicy">
<sizepolicy hsizetype="Fixed" vsizetype="Fixed">
@@ -33,7 +33,7 @@
</property>
</widget>
</item>
- <item row="1" column="0">
+ <item row="2" column="0">
<widget class="QLabel" name="textLabel2">
@@ -52,10 +52,10 @@
</property>
</widget>
</item>
- <item row="1" column="1" colspan="2">
+ <item row="2" column="1" colspan="2">
<widget class="QLineEdit" name="mWest"/>
</item>
- <item row="1" column="4">
+ <item row="2" column="4">
<widget class="QLabel" name="textLabel3">
@@ -68,10 +68,10 @@
</property>
</widget>
</item>
- <item row="1" column="5">
+ <item row="2" column="5">
<widget class="QLineEdit" name="mEast"/>
</item>
- <item row="2" column="2">
+ <item row="3" column="2">
<widget class="QLabel" name="textLabel4">
@@ -84,12 +84,20 @@
</property>
</widget>
</item>
- <item row="2" column="3" colspan="2">
+ <item row="3" column="3" colspan="2">
<widget class="QLineEdit" name="mSouth"/>
</item>
- <item row="0" column="3" colspan="2">
+ <item row="1" column="3" colspan="2">
<widget class="QLineEdit" name="mNorth"/>
</item>
+ <item row="0" column="0" colspan="6">
+ <widget class="QLabel" name="label_3">
+ <property name="text">
+ <string>Select the extent by dragging on canvas
+or change the following values</string>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
