[QGIS Commit] r14691 - in trunk/qgis: . scripts
svn_qgis at osgeo.org
Tue Nov 16 15:20:27 EST 2010
Author: jef
Date: 2010-11-16 12:20:27 -0800 (Tue, 16 Nov 2010)
New Revision: 14691
trunk/qgis/CMakeLists.txt
trunk/qgis/scripts/prepare-commit.sh
add some git support
Modified: trunk/qgis/CMakeLists.txt
--- trunk/qgis/CMakeLists.txt 2010-11-16 14:19:15 UTC (rev 14690)
+++ trunk/qgis/CMakeLists.txt 2010-11-16 20:20:27 UTC (rev 14691)
@@ -429,6 +429,7 @@
# create qgssvnversion.h
FIND_FILE(SVN_MARKER entries PATHS ${CMAKE_SOURCE_DIR}/.svn)
+FIND_FILE(GIT_MARKER index PATHS ${CMAKE_SOURCE_DIR}/.git)
IF (SVN_MARKER)
# See if we have svn installed
@@ -436,26 +437,41 @@
IF(SVNVERSION)
IF(MSVC)
- ADD_CUSTOM_COMMAND(
- OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
- COMMAND for /f usebackq %%a in "(`\"${SVNVERSION}\"`)" do echo \#define QGSSVNVERSION \"%%a\" >${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
- MAIN_DEPENDENCY ${SVN_MARKER}
- WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
+ ADD_CUSTOM_COMMAND(
+ OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
+ COMMAND for /f usebackq %%a in "(`\"${SVNVERSION}\"`)" do echo \#define QGSSVNVERSION \"%%a\" >${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
+ MAIN_DEPENDENCY ${SVN_MARKER}
+ WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
ELSE(MSVC)
- COMMAND echo \\\#define QGSSVNVERSION \\\"`${SVNVERSION}`\\\" >${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
+ COMMAND echo \\\#define QGSSVNVERSION \\\"`${SVNVERSION}`\\\" >${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
ENDIF(MSVC)
ELSE(SVNVERSION)
MESSAGE(STATUS "svnversion not found - version will be unknown")
FILE(WRITE ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h "#define QGSSVNVERSION \"unknown\"")
ENDIF (SVNVERSION)
ELSE (SVN_MARKER)
- FILE(WRITE ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h "#define QGSSVNVERSION \"exported\"")
+ IF (GIT_MARKER)
+ FIND_PROGRAM(GIT git PATHS c:/cygwin/bin)
+ IF(GIT)
+ COMMAND echo \\\#define QGSSVNVERSION \\\"`${GIT} svn info | sed -ne "s/Revision: //p"`\\\" >${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
+ MAIN_DEPENDENCY ${GIT_MARKER}
+ ELSE(GIT)
+ MESSAGE(STATUS "git marker, but no git found - version will be unknown")
+ FILE(WRITE ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h "#define QGSSVNVERSION \"unknown\"")
+ ENDIF(GIT)
+ ELSE (GIT_MARKER)
+ FILE(WRITE ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h "#define QGSSVNVERSION \"exported\"")
+ ENDIF (GIT_MARKER)
ENDIF (SVN_MARKER)
ADD_CUSTOM_TARGET(svnversion ALL DEPENDS ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h)
Modified: trunk/qgis/scripts/prepare-commit.sh
--- trunk/qgis/scripts/prepare-commit.sh 2010-11-16 14:19:15 UTC (rev 14690)
+++ trunk/qgis/scripts/prepare-commit.sh 2010-11-16 20:20:27 UTC (rev 14691)
@@ -17,7 +17,14 @@
set -e
# determine changed files
-MODIFIED=$(svn status | sed -ne "s/^[MA] *//p")
+if [ -d .svn ]; then
+ MODIFIED=$(svn status | sed -ne "s/^[MA] *//p")
+elif [ -d .git ]; then
+ MODIFIED=$(git status | sed -rne "s/^# (modified|new file): *//p")
+else
+ echo No working copy
+ exit 1
+fi
if [ -z "$MODIFIED" ]; then
echo nothing was modified
@@ -25,8 +32,13 @@
fi
# save original changes
-REV=$(svn info | sed -ne "s/Revision: //p")
-svn diff >r$REV.diff
+ REV=$(svn info | sed -ne "s/Revision: //p")
+ svn diff >r$REV.diff
+ REV=$(git svn info | sed -ne "s/Revision //p")
+ git diff >r$REV.diff
+fi
ASTYLEDIFF=astyle.r$REV.diff
>$ASTYLEDIFF
