[QGIS Commit] r14698 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Nov 17 10:05:17 EST 2010
Author: mhugent
Date: 2010-11-17 07:05:17 -0800 (Wed, 17 Nov 2010)
New Revision: 14698
Added:
   trunk/qgis/src/app/qgslabelpropertydialog.cpp
   trunk/qgis/src/app/qgslabelpropertydialog.h
Forgot to add two files in last commit
Added: trunk/qgis/src/app/qgslabelpropertydialog.cpp
--- trunk/qgis/src/app/qgslabelpropertydialog.cpp	                        (rev 0)
+++ trunk/qgis/src/app/qgslabelpropertydialog.cpp	2010-11-17 15:05:17 UTC (rev 14698)
@@ -0,0 +1,314 @@
+                          qgslabelpropertydialog.cpp
+    begin                : 2010-11-12
+    copyright            : (C) 2010 by Marco Hugentobler
+    email                : marco dot hugentobler at sourcepole dot ch
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+#include "qgslabelpropertydialog.h"
+#include "qgsmaplayerregistry.h"
+#include "qgsmaprenderer.h"
+#include <QColorDialog>
+#include <QFontDialog>
+QgsLabelPropertyDialog::QgsLabelPropertyDialog( const QString& layerId, int featureId, QgsMapRenderer* renderer, QWidget * parent, Qt::WindowFlags f ):
+    QDialog( parent, f ), mMapRenderer( renderer ), mCurrentLabelField( -1 )
+  setupUi( this );
+  fillHaliComboBox();
+  fillValiComboBox();
+  init( layerId, featureId );
+QgsLabelPropertyDialog::~QgsLabelPropertyDialog()
+void QgsLabelPropertyDialog::init( const QString& layerId, int featureId )
+  if( !mMapRenderer )
+    return;
+  //get feature attributes
+  QgsVectorLayer* vlayer = dynamic_cast<QgsVectorLayer*>( QgsMapLayerRegistry::instance()->mapLayer( layerId ) );
+  if( !vlayer )
+    return;
+  QgsFeature f;
+  if( !vlayer->featureAtId( featureId, f, false, true ) )
+    return;
+  const QgsAttributeMap& attributeValues = f.attributeMap();
+  QgsAttributeMap::const_iterator attIt = attributeValues.constBegin();
+  //get layerproperties. Problem: only for pallabeling...
+  QgsPalLabeling* lbl = dynamic_cast<QgsPalLabeling*>( mMapRenderer->labelingEngine() );
+  if( !lbl )
+    return;
+  blockElementSignals( true );
+  //get label field and fill line edit
+  QString labelFieldName = vlayer->customProperty( "labeling/fieldName" ).toString();
+  if( !labelFieldName.isEmpty() )
+    mCurrentLabelField = vlayer->fieldNameIndex( labelFieldName );
+    mLabelTextLineEdit->setText( attributeValues[mCurrentLabelField].toString() );
+    const QgsFieldMap& layerFields = vlayer->pendingFields();
+    switch( layerFields[mCurrentLabelField].type() )
+      case QVariant::Double:
+        mLabelTextLineEdit->setValidator( new QDoubleValidator( this ) );
+        break;
+      case QVariant::Int:
+      case QVariant::UInt:
+      case QVariant::LongLong:
+        mLabelTextLineEdit->setValidator( new QIntValidator( this ) );
+        break;
+  //get attributes of the feature and fill data defined values
+  QgsPalLayerSettings& layerSettings = lbl->layer( layerId );
+  mLabelFont = layerSettings.textFont;
+  //set all the gui elements to the default values
+  mFontSizeSpinBox->setValue( layerSettings.textFont.pointSizeF() );
+  mBufferColorButton->setColor( layerSettings.textColor );
+  mLabelDistanceSpinBox->setValue( layerSettings.dist );
+  mBufferSizeSpinBox->setValue( layerSettings.bufferSize );
+  mHaliComboBox->setCurrentIndex( mHaliComboBox->findText("Left") );
+  mValiComboBox->setCurrentIndex( mValiComboBox->findText("Bottom") );
+  disableGuiElements();
+  mDataDefinedProperties = layerSettings.dataDefinedProperties;
+  QMap< QgsPalLayerSettings::DataDefinedProperties, int >::const_iterator propIt = mDataDefinedProperties.constBegin();
+  for(; propIt != mDataDefinedProperties.constEnd(); ++propIt )
+    switch( propIt.key() )
+      case QgsPalLayerSettings::Size:
+        mFontSizeSpinBox->setEnabled( true );
+        mLabelFont.setPointSizeF( attributeValues[propIt.value()].toDouble() );
+        mFontSizeSpinBox->setValue( attributeValues[propIt.value()].toDouble() );
+        break;
+      case QgsPalLayerSettings::BufferSize:
+        mBufferSizeSpinBox->setEnabled( true );
+        mBufferSizeSpinBox->setValue( attributeValues[propIt.value()].toDouble() );
+        break;
+      case QgsPalLayerSettings::PositionX:
+        mXCoordSpinBox->setEnabled( true );
+        mXCoordSpinBox->setValue( attributeValues[propIt.value()].toDouble() );
+        break;
+      case QgsPalLayerSettings::PositionY:
+        mYCoordSpinBox->setEnabled( true );
+        mYCoordSpinBox->setValue( attributeValues[propIt.value()].toDouble() );
+        break;
+      case QgsPalLayerSettings::LabelDistance:
+        mLabelDistanceSpinBox->setEnabled( true );
+        mLabelDistanceSpinBox->setValue( attributeValues[propIt.value()].toDouble() );
+        break;
+      case QgsPalLayerSettings::Hali:
+        mHaliComboBox->setEnabled( true );
+        mHaliComboBox->setCurrentIndex( mHaliComboBox->findText( attributeValues[propIt.value()].toString() ) );
+        break;
+      case QgsPalLayerSettings::Vali:
+        mValiComboBox->setEnabled( true );
+        mValiComboBox->setCurrentIndex( mValiComboBox->findText( attributeValues[propIt.value()].toString() ) );
+        break;
+      case QgsPalLayerSettings::BufferColor:
+        mBufferColorButton->setEnabled( true );
+        mBufferColorButton->setColor( QColor( attributeValues[propIt.value()].toString() ) );
+        break;
+      case QgsPalLayerSettings::Color:
+        mFontColorButton->setEnabled( true );
+        mFontColorButton->setColor( QColor( attributeValues[propIt.value()].toString() ) );
+        break;
+      case QgsPalLayerSettings::Rotation:
+        mRotationSpinBox->setEnabled( true );
+        mRotationSpinBox->setValue( attributeValues[propIt.value()].toDouble() );
+        break;
+      //font related properties
+      case QgsPalLayerSettings::Bold:
+        mLabelFont.setBold( attributeValues[propIt.value()].toBool() );
+        break;
+      case QgsPalLayerSettings::Italic:
+        mLabelFont.setItalic( attributeValues[propIt.value()].toBool() );
+        break;
+      case QgsPalLayerSettings::Underline:
+        mLabelFont.setUnderline( attributeValues[propIt.value()].toBool() );
+        break;
+      case QgsPalLayerSettings::Strikeout:
+        mLabelFont.setStrikeOut( attributeValues[propIt.value()].toBool() );
+        break;
+      case QgsPalLayerSettings::Family:
+        mLabelFont.setFamily( attributeValues[propIt.value()].toString() );
+        break;
+  mFontPushButton->setEnabled( labelFontEditingPossible() );
+  blockElementSignals( false );
+void QgsLabelPropertyDialog::disableGuiElements()
+  mFontSizeSpinBox->setEnabled( false );
+  mBufferSizeSpinBox->setEnabled( false );
+  mFontPushButton->setEnabled( false );
+  mFontColorButton->setEnabled( false );
+  mBufferColorButton->setEnabled( false );
+  mLabelDistanceSpinBox->setEnabled( false );
+  mXCoordSpinBox->setEnabled( false );
+  mYCoordSpinBox->setEnabled( false );
+  mHaliComboBox->setEnabled( false );
+  mValiComboBox->setEnabled( false );
+  mRotationSpinBox->setEnabled( false );
+void QgsLabelPropertyDialog::blockElementSignals( bool block )
+  mFontSizeSpinBox->blockSignals( block );
+  mBufferSizeSpinBox->blockSignals( block );
+  mFontPushButton->blockSignals( block );
+  mBufferColorButton->blockSignals( block );
+  mLabelDistanceSpinBox->blockSignals( block );
+  mXCoordSpinBox->blockSignals( block );
+  mYCoordSpinBox->blockSignals( block );
+  mHaliComboBox->blockSignals( block );
+  mValiComboBox->blockSignals( block );
+  mRotationSpinBox->blockSignals( block );
+void QgsLabelPropertyDialog::fillHaliComboBox()
+  mHaliComboBox->addItem( "Left" );
+  mHaliComboBox->addItem( "Center" );
+  mHaliComboBox->addItem( "Right" );
+void QgsLabelPropertyDialog::fillValiComboBox()
+  mValiComboBox->addItem( "Bottom" );
+  mValiComboBox->addItem( "Base" );
+  mValiComboBox->addItem( "Half" );
+  mValiComboBox->addItem( "Top" );
+void QgsLabelPropertyDialog::on_mLabelDistanceSpinBox_valueChanged( double d )
+void QgsLabelPropertyDialog::on_mXCoordSpinBox_valueChanged( double d )
+  insertChangedValue( QgsPalLayerSettings::PositionX, d );
+void QgsLabelPropertyDialog::on_mYCoordSpinBox_valueChanged( double d )
+  insertChangedValue( QgsPalLayerSettings::PositionY, d );
+void QgsLabelPropertyDialog::on_mFontSizeSpinBox_valueChanged( double d )
+  insertChangedValue( QgsPalLayerSettings::Size, d );
+void QgsLabelPropertyDialog::on_mBufferSizeSpinBox_valueChanged( double d )
+void QgsLabelPropertyDialog::on_mRotationSpinBox_valueChanged( double d )
+  insertChangedValue( QgsPalLayerSettings::Rotation, d );
+void QgsLabelPropertyDialog::on_mFontPushButton_clicked()
+  bool ok;
+  mLabelFont = QFontDialog::getFont( &ok, mLabelFont, 0, tr("Label font") );
+  if( ok )
+    insertChangedValue( QgsPalLayerSettings::Size, mLabelFont.pointSizeF() );
+    insertChangedValue( QgsPalLayerSettings::Bold, mLabelFont.bold() );
+    insertChangedValue( QgsPalLayerSettings::Italic, mLabelFont.italic() );
+    insertChangedValue( QgsPalLayerSettings::Underline, mLabelFont.underline() );
+void QgsLabelPropertyDialog::on_mFontColorButton_clicked()
+  QColor c = QColorDialog::getColor ( mFontColorButton->color(), 0, tr("Font color"), QColorDialog::ShowAlphaChannel );
+  if( c.isValid() )
+    mFontColorButton->setColor( c );
+    insertChangedValue( QgsPalLayerSettings::Color, c.name() );
+void QgsLabelPropertyDialog::on_mBufferColorButton_clicked()
+  QColor c = QColorDialog::getColor ( mBufferColorButton->color(), 0, tr("Buffer color"), QColorDialog::ShowAlphaChannel );
+  if( c.isValid() )
+    insertChangedValue( QgsPalLayerSettings::BufferColor, c.name() );
+void QgsLabelPropertyDialog::on_mHaliComboBox_currentIndexChanged( const QString& text )
+  insertChangedValue( QgsPalLayerSettings::Hali, text );
+void QgsLabelPropertyDialog::on_mValiComboBox_currentIndexChanged( const QString& text )
+  insertChangedValue( QgsPalLayerSettings::Vali, text );
+void QgsLabelPropertyDialog::on_mLabelTextLineEdit_textChanged ( const QString& text )
+  if( mCurrentLabelField != -1 )
+    mChangedProperties.insert( mCurrentLabelField, text );
+void QgsLabelPropertyDialog::insertChangedValue( QgsPalLayerSettings::DataDefinedProperties p, QVariant value )
+   QMap< QgsPalLayerSettings::DataDefinedProperties, int >::const_iterator ddIt = mDataDefinedProperties.find( p );
+   if( ddIt != mDataDefinedProperties.constEnd() )
+    mChangedProperties.insert( ddIt.value(), value );
+bool QgsLabelPropertyDialog::labelFontEditingPossible() const
+  return( mDataDefinedProperties.contains( QgsPalLayerSettings:: Size ) || mDataDefinedProperties.contains( QgsPalLayerSettings::Bold )
+          || mDataDefinedProperties.contains( QgsPalLayerSettings::Italic ) || mDataDefinedProperties.contains( QgsPalLayerSettings::Underline )
+          ||  mDataDefinedProperties.contains( QgsPalLayerSettings::Strikeout )
+          || mDataDefinedProperties.contains( QgsPalLayerSettings::Family ) );
Added: trunk/qgis/src/app/qgslabelpropertydialog.h
--- trunk/qgis/src/app/qgslabelpropertydialog.h	                        (rev 0)
+++ trunk/qgis/src/app/qgslabelpropertydialog.h	2010-11-17 15:05:17 UTC (rev 14698)
@@ -0,0 +1,79 @@
+                          qgslabelpropertydialog.h
+#ifndef QGSLABELPROPERTYDIALOG_H
+#define QGSLABELPROPERTYDIALOG_H
+#include "ui_qgslabelpropertydialogbase.h"
+#include "qgsfeature.h"
+#include "qgspallabeling.h"
+#include <QDialog>
+class QgsMapRenderer;
+/**A dialog to enter data defined label attributes*/
+class QgsLabelPropertyDialog: public QDialog, private Ui::QgsLabelPropertyDialogBase
+  Q_OBJECT
+  public:
+    QgsLabelPropertyDialog( const QString& layerId, int featureId, QgsMapRenderer* renderer, QWidget * parent = 0, Qt::WindowFlags f = 0 );
+    ~QgsLabelPropertyDialog();
+    /**Returns properties changed by the user*/
+    const QgsAttributeMap& changedProperties() const { return mChangedProperties; }
+  private slots:
+    void on_mLabelDistanceSpinBox_valueChanged( double d );
+    void on_mXCoordSpinBox_valueChanged( double d );
+    void on_mYCoordSpinBox_valueChanged( double d );
+    void on_mFontSizeSpinBox_valueChanged( double d );
+    void on_mBufferSizeSpinBox_valueChanged( double d );
+    void on_mRotationSpinBox_valueChanged( double d );
+    void on_mFontPushButton_clicked();
+    void on_mFontColorButton_clicked();
+    void on_mBufferColorButton_clicked();
+    void on_mHaliComboBox_currentIndexChanged( const QString& text );
+    void on_mValiComboBox_currentIndexChanged( const QString& text );
+    void on_mLabelTextLineEdit_textChanged ( const QString& text );
+  private:
+    /**Sets activation / values to the gui elements depending on the label settings and feature values*/
+    void init( const QString& layerId, int featureId );
+    void disableGuiElements();
+    /**Block / unblock all input element signals*/
+    void blockElementSignals( bool block );
+    void fillHaliComboBox();
+    void fillValiComboBox();
+    /**Insert changed value into mChangedProperties*/
+    void insertChangedValue( QgsPalLayerSettings::DataDefinedProperties p, QVariant value );
+    /**Returns true if any font related setting is contained in mDataDefinedProperties*/
+    bool labelFontEditingPossible() const;
+    QgsMapRenderer* mMapRenderer;
+    QgsAttributeMap mChangedProperties;
+    QMap< QgsPalLayerSettings::DataDefinedProperties, int > mDataDefinedProperties;
+    QFont mLabelFont;
+    /**Label field for the current layer (or -1 if none)*/
+    int mCurrentLabelField;
+#endif // QGSLAYERPROPERTYDIALOG_H
More information about the QGIS-commit mailing list
