[QGIS Commit] r14716 -
docs/trunk/english_us/developer_cookbook/source
svn_qgis at osgeo.org
Fri Nov 19 12:40:58 EST 2010
Author: wonder
Date: 2010-11-19 09:40:58 -0800 (Fri, 19 Nov 2010)
New Revision: 14716
Added:
docs/trunk/english_us/developer_cookbook/source/pluginlayer.rst
docs/trunk/english_us/developer_cookbook/source/index.rst
Basic plugin layer docs. Contributed by Pirmin Kalberer.
Modified: docs/trunk/english_us/developer_cookbook/source/index.rst
--- docs/trunk/english_us/developer_cookbook/source/index.rst 2010-11-19 13:34:55 UTC (rev 14715)
+++ docs/trunk/english_us/developer_cookbook/source/index.rst 2010-11-19 17:40:58 UTC (rev 14716)
@@ -21,6 +21,7 @@
composer
expressions
measure
+ pluginlayer
plugins
Indices and tables
Added: docs/trunk/english_us/developer_cookbook/source/pluginlayer.rst
--- docs/trunk/english_us/developer_cookbook/source/pluginlayer.rst (rev 0)
+++ docs/trunk/english_us/developer_cookbook/source/pluginlayer.rst 2010-11-19 17:40:58 UTC (rev 14716)
@@ -0,0 +1,52 @@
+.. _pluginlayer:
+Using Plugin Layers
+If your plugin uses its own methods to render a map layer, writing your own layer type based on QgsPluginLayer might be the best way to implement that.
+**TODO:**
+ Check correctness and elaborate on good use cases for QgsPluginLayer, ...
+Subclassing QgsPluginLayer
+Below is an example of a minimal QgsPluginLayer implementation. It is an excerpt of the `Watermark example plugin <http://github.com/sourcepole/qgis-watermark-plugin>`_::
+ class WatermarkPluginLayer(QgsPluginLayer):
+ LAYER_TYPE="watermark"
+ def __init__(self):
+ QgsPluginLayer.__init__(self, WatermarkPluginLayer.LAYER_TYPE, "Watermark plugin layer")
+ self.setValid(True)
+ def draw(self, rendererContext):
+ image = QImage("myimage.png")
+ painter = rendererContext.painter()
+ painter.save()
+ painter.drawImage(10, 10, image)
+ painter.restore()
+ return True
+Methods for reading and writing specific information to the project file can also be added::
+ def readXml(self, node):
+ def writeXml(self, node, doc):
+When loading a project containing such a layer, a factory class is needed::
+ class WatermarkPluginLayerType(QgsPluginLayerType):
+ QgsPluginLayerType.__init__(self, WatermarkPluginLayer.LAYER_TYPE)
+ def createLayer(self):
+ return WatermarkPluginLayer()
+You can also add code for displaying custom information in the layer properties::
+ def showLayerProperties(self, layer):
