[QGIS Commit] r14734 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 21 17:33:42 EST 2010
Author: cfarmer
Date: 2010-11-21 14:33:42 -0800 (Sun, 21 Nov 2010)
New Revision: 14734
   trunk/qgis/python/plugins/fTools/tools/doRandPoints.py
   trunk/qgis/python/plugins/fTools/tools/frmRandPoints.ui
Removes extraneous minimum distance option (not currently a real option) from random points tool. Addresses #3213
Modified: trunk/qgis/python/plugins/fTools/tools/doRandPoints.py
--- trunk/qgis/python/plugins/fTools/tools/doRandPoints.py	2010-11-21 22:22:27 UTC (rev 14733)
+++ trunk/qgis/python/plugins/fTools/tools/doRandPoints.py	2010-11-21 22:33:42 UTC (rev 14734)
@@ -116,10 +116,7 @@
                 value = self.spnUnstratified.value()
             else:
                 QMessageBox.information(self, self.tr("Random Points"), self.tr("Unknown layer type..."))
-            if self.chkMinimum.isChecked():
-                minimum = self.spnMinimum.value()
-            else:
-                minimum = 0.00
+            minimum = 0.00
             self.progressBar.setValue(10)
             self.randomize(inLayer, outPath, minimum, design, value)
             self.progressBar.setValue(100)
Modified: trunk/qgis/python/plugins/fTools/tools/frmRandPoints.ui
--- trunk/qgis/python/plugins/fTools/tools/frmRandPoints.ui	2010-11-21 22:22:27 UTC (rev 14733)
+++ trunk/qgis/python/plugins/fTools/tools/frmRandPoints.ui	2010-11-21 22:33:42 UTC (rev 14734)
@@ -1,188 +1,168 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>Dialog</class>
- <widget class="QDialog" name="Dialog" >
-  <property name="windowModality" >
+ <widget class="QDialog" name="Dialog">
+  <property name="windowModality">
    <enum>Qt::NonModal</enum>
   </property>
-  <property name="geometry" >
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>373</width>
+    <width>384</width>
     <height>435</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Generate Random Points</string>
   </property>
-  <property name="sizeGripEnabled" >
+  <property name="sizeGripEnabled">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout" name="gridLayout" >
-   <item row="0" column="0" >
-    <widget class="QLabel" name="label_3" >
-     <property name="sizePolicy" >
-      <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+  <layout class="QGridLayout" name="gridLayout">
+   <item row="0" column="0">
+    <widget class="QLabel" name="label_3">
+     <property name="sizePolicy">
+      <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
        <horstretch>0</horstretch>
        <verstretch>0</verstretch>
       </sizepolicy>
      </property>
-     <property name="text" >
+     <property name="text">
       <string>Input Boundary Layer</string>
      </property>
     </widget>
    </item>
-   <item row="1" column="0" colspan="2" >
-    <widget class="QComboBox" name="inShape" />
+   <item row="1" column="0" colspan="2">
+    <widget class="QComboBox" name="inShape"/>
    </item>
-   <item row="2" column="0" colspan="2" >
-    <layout class="QHBoxLayout" >
-     <item>
-      <widget class="QCheckBox" name="chkMinimum" >
-       <property name="enabled" >
-        <bool>false</bool>
-       </property>
-        <string>Minimum distance between points</string>
-       </property>
-      </widget>
-     </item>
-     <item>
-      <widget class="QSpinBox" name="spnMinimum" >
-       </property>
-      </widget>
-     </item>
-    </layout>
-   </item>
-   <item row="3" column="0" colspan="2" >
-    <widget class="QGroupBox" name="groupBox" >
-     <property name="title" >
+   <item row="2" column="0" colspan="2">
+    <widget class="QGroupBox" name="groupBox">
+     <property name="title">
       <string>Sample Size</string>
      </property>
-     <layout class="QGridLayout" >
-       <widget class="QLabel" name="label" >
-        <property name="font" >
+     <layout class="QGridLayout">
+       <widget class="QLabel" name="label">
+        <property name="font">
          <font>
           <pointsize>9</pointsize>
           <weight>75</weight>
           <bold>true</bold>
          </font>
         </property>
          <string>Unstratified Sampling Design (Entire layer)</string>
         </property>
        </widget>
       </item>
-      <item row="1" column="0" >
+      <item row="1" column="0">
+       <layout class="QHBoxLayout">
         <item>
-         <widget class="QRadioButton" name="rdoUnstratified" >
+         <widget class="QRadioButton" name="rdoUnstratified">
            <string>Use this number of points</string>
           </property>
-          <property name="checked" >
+          <property name="checked">
            <bool>true</bool>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QSpinBox" name="spnUnstratified" >
+         <widget class="QSpinBox" name="spnUnstratified">
+          <property name="enabled">
            <bool>true</bool>
           </property>
-          <property name="minimum" >
+          <property name="minimum">
            <number>1</number>
           </property>
-          <property name="maximum" >
+          <property name="maximum">
            <number>9999</number>
           </property>
          </widget>
         </item>
        </layout>
       </item>
-      <item row="2" column="0" >
-       <widget class="QLabel" name="label_4" >
+      <item row="2" column="0">
+       <widget class="QLabel" name="label_4">
          <font>
           <weight>75</weight>
           <bold>true</bold>
          </font>
         </property>
          <string>Stratified Sampling Design (Individual polygons)</string>
         </property>
        </widget>
       </item>
-      <item row="3" column="0" >
+      <item row="3" column="0">
         <item>
-         <widget class="QRadioButton" name="rdoStratified" >
+         <widget class="QRadioButton" name="rdoStratified">
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QSpinBox" name="spnStratified" >
+         <widget class="QSpinBox" name="spnStratified">
            <bool>false</bool>
           </property>
            <number>1</number>
           </property>
           </property>
          </widget>
         </item>
        </layout>
       </item>
-      <item row="4" column="0" >
+      <item row="4" column="0">
         <item>
-         <widget class="QRadioButton" name="rdoDensity" >
+         <widget class="QRadioButton" name="rdoDensity">
            <string>Use this density of points</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QDoubleSpinBox" name="spnDensity" >
+         <widget class="QDoubleSpinBox" name="spnDensity">
            <bool>false</bool>
           </property>
-          <property name="decimals" >
+          <property name="decimals">
            <number>4</number>
           </property>
            <double>0.000100000000000</double>
           </property>
-          <property name="singleStep" >
+          <property name="singleStep">
           </property>
-          <property name="value" >
+          <property name="value">
           </property>
          </widget>
         </item>
        </layout>
       </item>
-      <item row="5" column="0" >
+      <item row="5" column="0">
         <item>
-         <widget class="QRadioButton" name="rdoField" >
+         <widget class="QRadioButton" name="rdoField">
            <string>Use value from input field</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QComboBox" name="cmbField" >
+         <widget class="QComboBox" name="cmbField">
            <bool>false</bool>
           </property>
          </widget>
@@ -192,56 +172,56 @@
      </layout>
     </widget>
    </item>
-    <widget class="QLabel" name="label_2" >
+    <widget class="QLabel" name="label_2">
       </sizepolicy>
      </property>
       <string>Output Shapefile</string>
      </property>
     </widget>
    </item>
-   <item row="5" column="0" colspan="2" >
+   <item row="4" column="0" colspan="2">
      <item>
-      <widget class="QLineEdit" name="outShape" >
-       <property name="readOnly" >
+      <widget class="QLineEdit" name="outShape">
+       <property name="readOnly">
         <bool>true</bool>
        </property>
       </widget>
      </item>
      <item>
-      <widget class="QToolButton" name="toolOut" >
+      <widget class="QToolButton" name="toolOut">
         <string>Browse</string>
        </property>
       </widget>
      </item>
     </layout>
    </item>
-   <item row="6" column="0" >
-    <widget class="QProgressBar" name="progressBar" >
+    <widget class="QProgressBar" name="progressBar">
       <number>24</number>
      </property>
-     <property name="alignment" >
+     <property name="alignment">
       <set>Qt::AlignCenter</set>
      </property>
-     <property name="textVisible" >
+     <property name="textVisible">
       <bool>true</bool>
      </property>
     </widget>
    </item>
-   <item row="6" column="1" >
-    <widget class="QDialogButtonBox" name="buttonBox_2" >
-     <property name="orientation" >
+   <item row="5" column="1">
+    <widget class="QDialogButtonBox" name="buttonBox_2">
+     <property name="orientation">
       <enum>Qt::Horizontal</enum>
      </property>
-     <property name="standardButtons" >
+     <property name="standardButtons">
       <set>QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
      </property>
     </widget>
@@ -256,11 +236,11 @@
    <receiver>Dialog</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>133</x>
      <y>408</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>215</x>
      <y>290</y>
     </hint>
@@ -272,11 +252,11 @@
    <slot>close()</slot>
    <hints>
      <x>59</x>
      <y>408</y>
     </hint>
      <x>132</x>
      <y>239</y>
     </hint>
@@ -288,11 +268,11 @@
    <receiver>spnUnstratified</receiver>
    <slot>setEnabled(bool)</slot>
    <hints>
      <x>102</x>
      <y>161</y>
     </hint>
      <x>218</x>
      <y>164</y>
     </hint>
@@ -304,11 +284,11 @@
    <receiver>spnStratified</receiver>
    <hints>
      <x>101</x>
      <y>219</y>
     </hint>
      <x>247</x>
      <y>223</y>
     </hint>
@@ -320,43 +300,27 @@
    <receiver>cmbField</receiver>
    <hints>
      <x>150</x>
      <y>280</y>
     </hint>
      <x>219</x>
      <y>281</y>
     </hint>
    </hints>
   </connection>
   <connection>
-   <sender>chkMinimum</sender>
-   <signal>toggled(bool)</signal>
-   <receiver>spnMinimum</receiver>
-   <slot>setEnabled(bool)</slot>
-   <hints>
-     <x>172</x>
-     <y>74</y>
-    </hint>
-     <x>260</x>
-     <y>80</y>
-    </hint>
-   </hints>
-  </connection>
-  <connection>
    <sender>rdoDensity</sender>
    <receiver>spnDensity</receiver>
    <hints>
      <x>96</x>
      <y>251</y>
     </hint>
      <x>221</x>
      <y>254</y>
     </hint>
More information about the QGIS-commit mailing list
