[QGIS Commit] r14753 - trunk/qgis/i18n
svn_qgis at osgeo.org
Tue Nov 23 13:40:03 EST 2010
Author: macho
Date: 2010-11-23 10:40:03 -0800 (Tue, 23 Nov 2010)
New Revision: 14753
trunk/qgis/i18n/qgis_is.ts
translation update: even more .is by thordur
Modified: trunk/qgis/i18n/qgis_is.ts
--- trunk/qgis/i18n/qgis_is.ts 2010-11-23 14:41:39 UTC (rev 14752)
+++ trunk/qgis/i18n/qgis_is.ts 2010-11-23 18:40:03 UTC (rev 14753)
@@ -151,7 +151,7 @@
<location filename="../python/plugins/fTools/tools/frmVectorSplit.ui" line="61"/>
<location filename="../src/plugins/ogr_converter/dialog.cpp" line="119"/>
<source>Browse</source>
- <translation type="unfinished"></translation>
+ <translation>Fletta</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmGeoprocessing.ui" line="20"/>
@@ -251,7 +251,7 @@
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="17"/>
<source>Join Attributes</source>
+ <translation>Sameina eigindir</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="28"/>
@@ -267,35 +267,35 @@
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="54"/>
<source>Join data</source>
+ <translation>Sameina gögn</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="62"/>
<location filename="../python/plugins/fTools/tools/frmSpatialJoin.ui" line="41"/>
<source>Join vector layer</source>
+ <translation>Sameina vigur lag</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="79"/>
<source>Join dbf table</source>
+ <translation>Sameina gagnagrunnstöflu</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="114"/>
<source>Join field</source>
+ <translation>Sameina svæði</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="158"/>
<location filename="../python/plugins/fTools/tools/frmSpatialJoin.ui" line="177"/>
<source>Output table</source>
+ <translation>Úttakstafla</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="164"/>
<location filename="../python/plugins/fTools/tools/frmSpatialJoin.ui" line="183"/>
<source>Only keep matching records</source>
+ <translation>Halda aðeins í samsvarandi færslur</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmJoinAttributes.ui" line="174"/>
@@ -314,19 +314,19 @@
</message>
<message>
<source>creating new selection</source>
+ <translation>búa til nýtt val</translation>
</message>
<message>
<source>removing from current selection</source>
+ <translation>fjarlægja úr núverandi vali</translation>
</message>
<message>
<source>Select by location</source>
+ <translation>Velja eftir staðsetningu</translation>
</message>
<message>
<source>Select features in:</source>
+ <translation>Velja fitjur í:</translation>
</message>
<message>
<source>that intersect features in:</source>
@@ -338,19 +338,19 @@
</message>
<message>
<source>Please specify input layer</source>
+ <translation>Vinsamlega tiltakið inntakslag</translation>
</message>
<message>
<source>Please specify select layer</source>
+ <translation>Vinsamlega tiltakið val lag</translation>
</message>
<message>
<source>Sum line lengths</source>
+ <translation>Leggja saman línulengdir</translation>
</message>
<message>
<source>Sum Line Lengths In Polyons</source>
+ <translation>Leggja saman línulengdir í marghyrningum</translation>
</message>
<message>
<source>Please specify input polygon vector layer</source>
@@ -366,7 +366,7 @@
</message>
<message>
<source>length field</source>
+ <translation>Lengdarsvæði</translation>
</message>
<message>
<source>Random selection within subsets</source>
@@ -394,15 +394,15 @@
</message>
<message>
<source>density</source>
+ <translation>þéttleiki</translation>
</message>
<message>
<source>field</source>
+ <translation>svæði</translation>
</message>
<message>
<source>Unknown layer type...</source>
+ <translation>Óþekkt lagtegund...</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmMeanCoords.ui" line="41"/>
@@ -3016,13 +3016,13 @@
<message>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="43"/>
<source>Source</source>
+ <translation>Uppruni</translation>
</message>
<message>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="55"/>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="261"/>
<source>Layer</source>
+ <translation>Lag</translation>
</message>
<message>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="65"/>
@@ -3034,13 +3034,13 @@
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="95"/>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="248"/>
</message>
<message>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="121"/>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="205"/>
<source>Format</source>
+ <translation>Forsníða</translation>
</message>
<message>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="136"/>
@@ -3055,7 +3055,7 @@
<message>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="150"/>
<source>Directory</source>
+ <translation>Skráarsafn</translation>
</message>
<message>
<location filename="../src/plugins/ogr_converter/ogrconverterguibase.ui" line="193"/>
@@ -9840,37 +9840,37 @@
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="41"/>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="73"/>
<source>Map</source>
+ <translation>Kort</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="47"/>
<source>Preview</source>
+ <translation>Forskoðun</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="63"/>
<source>Update preview</source>
+ <translation>Uppfæra forskoðun</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="79"/>
<source>Width</source>
- <translation type="unfinished">Vídd</translation>
+ <translation>Vídd</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="95"/>
<source>Height</source>
+ <translation>Hæð</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="117"/>
<source>Scale</source>
+ <translation>Skali</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="137"/>
<source>Rotation</source>
+ <translation>Snúningur</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="172"/>
@@ -9960,12 +9960,12 @@
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="589"/>
<source>Line color</source>
+ <translation>Línulitur</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="471"/>
<source>Font...</source>
+ <translation>Leturgerð...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermapwidgetbase.ui" line="478"/>
@@ -10498,43 +10498,43 @@
<message>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="31"/>
<source>mm</source>
+ <translation>mm</translation>
</message>
<message>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="32"/>
<source>inch</source>
+ <translation>tomma</translation>
</message>
<message>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="35"/>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="235"/>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="339"/>
<source>Landscape</source>
+ <translation>Lárétt</translation>
</message>
<message>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="36"/>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="343"/>
<source>Portrait</source>
+ <translation>Lóðrétt</translation>
</message>
<message>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="77"/>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="473"/>
<source>Solid</source>
+ <translation>Heilt</translation>
</message>
<message>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="78"/>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="477"/>
<source>Dots</source>
+ <translation>Punktar</translation>
</message>
<message>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="79"/>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="481"/>
<source>Crosses</source>
+ <translation>Krossar</translation>
</message>
<message>
<location filename="../src/app/composer/qgscompositionwidget.cpp" line="114"/>
@@ -20149,7 +20149,7 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="14"/>
<source>Options</source>
+ <translation>Stillingar</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="144"/>
@@ -30988,7 +30988,7 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="19"/>
<source>Attribute field</source>
+ <translation>Eigindasvæði</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="20"/>
