[QGIS Commit] r14779 - in trunk/qgis/src: core/symbology-ng gui/symbology-ng ui/symbollayer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 28 15:14:36 EST 2010
Author: wonder
Date: 2010-11-28 12:14:36 -0800 (Sun, 28 Nov 2010)
New Revision: 14779
   trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.cpp
   trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.h
   trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
   trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h
   trunk/qgis/src/ui/symbollayer/widget_markerline.ui
[FEATURE] Allow the marker line symbol layer draw markers on each vertex.
Developed for Faunalia (http://www.faunalia.it) with funding from Regione Toscana - Sistema Informativo per la Gestione del Territorio e dell' Ambiente [RT-SIGTA].
For the project: "Sviluppo di prodotti software GIS open-source basati sui prodotti QuantumGIS e Postgis (CIG 037728516E)"
Modified: trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.cpp	2010-11-28 17:23:07 UTC (rev 14778)
+++ trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.cpp	2010-11-28 20:14:36 UTC (rev 14779)
@@ -215,6 +215,7 @@
   mInterval = interval;
   mMarker = NULL;
   mOffset = 0;
+  mPlacement = Interval;
   setSubSymbol( new QgsMarkerSymbolV2() );
@@ -237,6 +238,8 @@
   QgsMarkerLineSymbolLayerV2* x = new QgsMarkerLineSymbolLayerV2( rotate, interval );
   if ( props.contains( "offset" ) )
     x->setOffset( props["offset"].toDouble() );
+  if ( props.contains( "placement" ) )
+    x->setPlacement( props["placement"] == "vertex" ? Vertex : Interval );
   return x;
@@ -276,16 +279,22 @@
   if ( mOffset == 0 )
-    renderPolylineNoOffset( points, context );
+    if ( mPlacement == Vertex )
+      renderPolylineVertex( points, context );
+    else
+      renderPolylineInterval( points, context );
   else
     QPolygonF points2 = ::offsetLine( points, context.outputLineWidth( mOffset ) );
-    renderPolylineNoOffset( points2, context );
+      renderPolylineVertex( points2, context );
+    else
+      renderPolylineInterval( points2, context );
-void QgsMarkerLineSymbolLayerV2::renderPolylineNoOffset( const QPolygonF& points, QgsSymbolV2RenderContext& context )
+void QgsMarkerLineSymbolLayerV2::renderPolylineInterval( const QPolygonF& points, QgsSymbolV2RenderContext& context )
   QPointF lastPt = points[0];
   double lengthLeft = 0; // how much is left until next marker
@@ -344,12 +353,65 @@
+void QgsMarkerLineSymbolLayerV2::renderPolylineVertex( const QPolygonF& points, QgsSymbolV2RenderContext& context )
+  QPointF lastPt = points[0];
+  QgsRenderContext& rc = context.renderContext();
+  double origAngle = mMarker->angle();
+  double angle;
+  for ( int i = 0; i < points.count(); ++i )
+    const QPointF& pt = points[i];
+    // rotate marker (if desired)
+    if ( mRotateMarker )
+      if ( i == 0 )
+        const QPointF& nextPt = points[i+1];
+        if ( pt == nextPt )
+          continue;
+        angle = MyLine( pt, nextPt ).angle();
+      else if ( i == points.count() - 1 )
+        const QPointF& prevPt = points[i-1];
+        if ( pt == prevPt )
+          continue;
+        angle = MyLine( prevPt, pt ).angle();
+      else
+        if ( prevPt == pt || nextPt == pt )
+          continue;
+        // calc average angle between the previous and next point
+        double a1 = MyLine( prevPt, pt ).angle();
+        double a2 = MyLine( pt, nextPt ).angle();
+        double unitX = cos( a1 ) + cos( a2 ), unitY = sin( a1 ) + sin( a2 );
+        angle = atan2( unitY, unitX );
+      mMarker->setAngle( angle * 180 / M_PI );
+    mMarker->renderPoint( points.at( i ), rc, -1, context.selected() );
+  // restore original rotation
+  mMarker->setAngle( origAngle );
 QgsStringMap QgsMarkerLineSymbolLayerV2::properties() const
   QgsStringMap map;
   map["rotate"] = ( mRotateMarker ? "1" : "0" );
   map["interval"] = QString::number( mInterval );
   map["offset"] = QString::number( mOffset );
+  map["placement"] = ( mPlacement == Vertex ? "vertex" : "interval" );
   return map;
@@ -377,6 +439,7 @@
   QgsMarkerLineSymbolLayerV2* x = new QgsMarkerLineSymbolLayerV2( mRotateMarker, mInterval );
   x->setSubSymbol( mMarker->clone() );
   x->setOffset( mOffset );
+  x->setPlacement( mPlacement );
   return x;
Modified: trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.h
--- trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.h	2010-11-28 17:23:07 UTC (rev 14778)
+++ trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.h	2010-11-28 20:14:36 UTC (rev 14779)
@@ -85,6 +85,12 @@
     ~QgsMarkerLineSymbolLayerV2();
+    enum Placement
+      Interval,
+      Vertex
     // static stuff
     static QgsSymbolLayerV2* create( const QgsStringMap& properties = QgsStringMap() );
@@ -122,14 +128,19 @@
     double offset() const { return mOffset; }
     void setOffset( double offset ) { mOffset = offset; }
+    Placement placement() const { return mPlacement; }
+    void setPlacement( Placement p ) { mPlacement = p; }
   protected:
-    void renderPolylineNoOffset( const QPolygonF& points, QgsSymbolV2RenderContext& context );
+    void renderPolylineInterval( const QPolygonF& points, QgsSymbolV2RenderContext& context );
+    void renderPolylineVertex( const QPolygonF& points, QgsSymbolV2RenderContext& context );
     bool mRotateMarker;
     double mInterval;
     QgsMarkerSymbolV2* mMarker;
     double mOffset;
+    Placement mPlacement;
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp	2010-11-28 17:23:07 UTC (rev 14778)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp	2010-11-28 20:14:36 UTC (rev 14779)
@@ -359,6 +359,8 @@
   connect( btnChangeMarker, SIGNAL( clicked() ), this, SLOT( setMarker() ) );
   connect( chkRotateMarker, SIGNAL( clicked() ), this, SLOT( setRotate() ) );
   connect( spinOffset, SIGNAL( valueChanged( double ) ), this, SLOT( setOffset() ) );
+  connect( radInterval, SIGNAL( clicked() ), this, SLOT( setPlacement() ) );
+  connect( radVertex, SIGNAL( clicked() ), this, SLOT( setPlacement() ) );
 void QgsMarkerLineSymbolLayerV2Widget::setSymbolLayer( QgsSymbolLayerV2* layer )
@@ -373,7 +375,12 @@
   spinInterval->setValue( mLayer->interval() );
   chkRotateMarker->setChecked( mLayer->rotateMarker() );
   spinOffset->setValue( mLayer->offset() );
+  if ( mLayer->placement() == QgsMarkerLineSymbolLayerV2::Interval )
+    radInterval->setChecked( true );
+  else
+    radVertex->setChecked( true );
   updateMarker();
+  setPlacement(); // update gui
 QgsSymbolLayerV2* QgsMarkerLineSymbolLayerV2Widget::symbolLayer()
@@ -416,6 +423,13 @@
   btnChangeMarker->setIcon( icon );
+void QgsMarkerLineSymbolLayerV2Widget::setPlacement()
+  bool interval = radInterval->isChecked();
+  mLayer->setPlacement( interval ? QgsMarkerLineSymbolLayerV2::Interval : QgsMarkerLineSymbolLayerV2::Vertex );
+  spinInterval->setEnabled( interval );
+  emit changed();
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h	2010-11-28 17:23:07 UTC (rev 14778)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h	2010-11-28 20:14:36 UTC (rev 14779)
@@ -145,6 +145,7 @@
     void setMarker();
     void setRotate();
     void setOffset();
+    void setPlacement();
   protected:
Modified: trunk/qgis/src/ui/symbollayer/widget_markerline.ui
--- trunk/qgis/src/ui/symbollayer/widget_markerline.ui	2010-11-28 17:23:07 UTC (rev 14778)
+++ trunk/qgis/src/ui/symbollayer/widget_markerline.ui	2010-11-28 20:14:36 UTC (rev 14779)
@@ -6,16 +6,16 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>360</width>
-    <height>192</height>
+    <width>352</width>
+    <height>232</height>
    </rect>
   </property>
   <property name="windowTitle">
    <string>Form</string>
   </property>
-  <layout class="QVBoxLayout">
+  <layout class="QVBoxLayout" name="verticalLayout">
    <item>
-    <layout class="QGridLayout">
+    <layout class="QGridLayout" name="gridLayout">
      <item row="0" column="0">
       <widget class="QLabel" name="label">
        <property name="text">
@@ -30,44 +30,58 @@
        </property>
       </widget>
      </item>
-     <item row="0" column="2" rowspan="4">
-      <spacer>
-       <property name="orientation">
-        <enum>Qt::Horizontal</enum>
+     <item row="1" column="0" colspan="2">
+      <widget class="QLabel" name="label_2">
+       <property name="text">
+        <string>Marker placement</string>
        </property>
-       <property name="sizeType">
-        <enum>QSizePolicy::Preferred</enum>
+      </widget>
+     </item>
+     <item row="2" column="0">
+      <widget class="QRadioButton" name="radInterval">
+        <string>with interval</string>
        </property>
-       <property name="sizeHint" stdset="0">
-        <size>
-         <width>40</width>
-         <height>20</height>
-        </size>
+       <property name="checked">
+        <bool>true</bool>
        </property>
-      </spacer>
+      </widget>
      </item>
-     <item row="1" column="0">
-      <widget class="QLabel" name="label_2">
+     <item row="2" column="1">
+      <widget class="QDoubleSpinBox" name="spinInterval">
+       <property name="decimals">
+        <number>2</number>
+       </property>
+       <property name="maximum">
+        <double>100000.000000000000000</double>
+       </property>
+       <property name="value">
+        <double>1.000000000000000</double>
+       </property>
+      </widget>
+     </item>
+     <item row="3" column="0" colspan="2">
+      <widget class="QRadioButton" name="radVertex">
-        <string>Marker interval</string>
+        <string>on every vertex</string>
        </property>
       </widget>
      </item>
-     <item row="2" column="0" colspan="2">
+     <item row="4" column="0" colspan="2">
       <widget class="QCheckBox" name="chkRotateMarker">
         <string>Rotate marker</string>
        </property>
       </widget>
      </item>
-     <item row="3" column="0">
+     <item row="5" column="0">
       <widget class="QLabel" name="label_3">
         <string>Line offset</string>
        </property>
       </widget>
      </item>
-     <item row="3" column="1">
+     <item row="5" column="1">
       <widget class="QDoubleSpinBox" name="spinOffset">
         <number>2</number>
@@ -80,18 +94,21 @@
        </property>
       </widget>
      </item>
-     <item row="1" column="1">
-      <widget class="QDoubleSpinBox" name="spinInterval">
-       <property name="decimals">
-        <number>2</number>
+     <item row="0" column="2" rowspan="6">
+      <spacer>
+       <property name="orientation">
+        <enum>Qt::Horizontal</enum>
        </property>
-       <property name="maximum">
-        <double>100000.000000000000000</double>
+       <property name="sizeType">
+        <enum>QSizePolicy::Preferred</enum>
        </property>
-       <property name="value">
-        <double>1.000000000000000</double>
+       <property name="sizeHint" stdset="0">
+        <size>
+         <width>110</width>
+         <height>20</height>
+        </size>
        </property>
-      </widget>
+      </spacer>
      </item>
     </layout>
    </item>
@@ -112,7 +129,11 @@
  </widget>
  <tabstops>
   <tabstop>btnChangeMarker</tabstop>
+  <tabstop>radInterval</tabstop>
   <tabstop>spinInterval</tabstop>
+  <tabstop>radVertex</tabstop>
+  <tabstop>chkRotateMarker</tabstop>
+  <tabstop>spinOffset</tabstop>
  </tabstops>
  <resources/>
  <connections/>
More information about the QGIS-commit mailing list
