[QGIS Commit] r14803 - trunk/qgis/src/app
svn_qgis at osgeo.org
Tue Nov 30 04:03:17 EST 2010
Author: jef
Date: 2010-11-30 01:03:17 -0800 (Tue, 30 Nov 2010)
New Revision: 14803
trunk/qgis/src/app/qgisapp.cpp
fix r14798: label tools work independently from current layer. Thanks Marco!
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-11-29 21:49:36 UTC (rev 14802)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-11-30 09:03:17 UTC (rev 14803)
@@ -3956,14 +3956,14 @@
// alter labeling - save the changes
labelGui.layerSettings().writeToLayer( vlayer );
- activateDeactivateLayerRelatedActions( layer );
// trigger refresh
if ( mMapCanvas )
mMapCanvas->refresh();
+ activateDeactivateLayerRelatedActions( layer );
void QgisApp::attributeTable()
@@ -6129,6 +6129,36 @@
void QgisApp::activateDeactivateLayerRelatedActions( QgsMapLayer* layer )
+ bool enableMove = false, enableRotate = false, enableChange = false;
+ QMap<QString, QgsMapLayer*> layers = QgsMapLayerRegistry::instance()->mapLayers();
+ for ( QMap<QString, QgsMapLayer*>::iterator it = layers.begin(); it != layers.end(); it++ )
+ QgsVectorLayer *vlayer = qobject_cast<QgsVectorLayer *>( it.value() );
+ if ( !vlayer || !vlayer->isEditable() || vlayer->customProperty( "labeling" ).toString() != QString( "pal" ) )
+ continue;
+ int colX, colY, colAng;
+ enableMove =
+ enableMove ||
+ ( qobject_cast<QgsMapToolMoveLabel*>( mMapTools.mMoveLabel ) &&
+ qobject_cast<QgsMapToolMoveLabel*>( mMapTools.mMoveLabel )->layerIsMoveable( vlayer, colX, colY ) );
+ enableRotate =
+ enableRotate ||
+ ( qobject_cast<QgsMapToolRotateLabel*>( mMapTools.mRotateLabel ) &&
+ qobject_cast<QgsMapToolRotateLabel*>( mMapTools.mRotateLabel )->layerIsRotatable( vlayer, colAng ) );
+ enableChange = true;
+ if ( enableMove && enableRotate && enableChange )
+ break;
+ mActionMoveLabel->setEnabled( enableMove );
+ mActionRotateLabel->setEnabled( enableRotate );
+ mActionChangeLabelProperties->setEnabled( enableChange );
if ( !layer )
mActionSelect->setEnabled( false );
@@ -6254,29 +6284,11 @@
dprovider->capabilities() & QgsVectorDataProvider::AddFeatures );
mActionMergeFeatureAttributes->setEnabled( layerHasSelection );
- if ( layer->customProperty( "labeling" ).toString() == QString( "pal" ) )
- int colX, colY, colAng;
- mActionMoveLabel->setEnabled( qobject_cast<QgsMapToolMoveLabel*>( mMapTools.mMoveLabel ) && qobject_cast<QgsMapToolMoveLabel*>( mMapTools.mMoveLabel )->layerIsMoveable( layer, colX, colY ) );
- mActionRotateLabel->setEnabled( qobject_cast<QgsMapToolRotateLabel*>( mMapTools.mRotateLabel ) && qobject_cast<QgsMapToolRotateLabel*>( mMapTools.mMoveLabel )->layerIsRotatable( layer, colAng ) );
- mActionChangeLabelProperties->setEnabled( true );
- else
- mActionMoveLabel->setEnabled( false );
- mActionRotateLabel->setEnabled( false );
- mActionChangeLabelProperties->setEnabled( false );
else
mActionMergeFeatures->setEnabled( false );
mActionMergeFeatureAttributes->setEnabled( false );
// moving enabled if geometry changes are supported
