[QGIS Commit] r14375 - trunk/qgis/src/core
svn_qgis at osgeo.org
Wed Oct 13 15:41:02 EDT 2010
Author: timlinux
Date: 2010-10-13 12:41:02 -0700 (Wed, 13 Oct 2010)
New Revision: 14375
trunk/qgis/src/core/qgscoordinatereferencesystem.h
Fixed some typos in docs
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.h
--- trunk/qgis/src/core/qgscoordinatereferencesystem.h 2010-10-13 19:40:16 UTC (rev 14374)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.h 2010-10-13 19:41:02 UTC (rev 14375)
@@ -179,13 +179,13 @@
/*! This is a globbing function to try to find a record in the database
* that matches a CRS defined only by a proj4string. The goal is to
* learn what the tbl_srs.srs_id value is for the CRS. Internally
- * the source CRS is converted to and OGR srs object using the proj4string
+ * the source CRS is converted to an OGR srs object using the proj4string call
* and then every record in the database that matches projection and ellipsoid
* will be converted to an OGR srs in turn and compared to the source CRS.
* There are some gotchas with using ogr isSame() srs comparison, but
* its more effective than using straight string comparison of proj4params.
* @note The ellipsoid and projection acronyms must be set as well as the proj4string!
- * @return lomg the SrsId of the matched CRS
+ * @return long the SrsId of the matched CRS
long findMatchingProj();
