[QGIS Commit] r14377 - in trunk/qgis/src: app app/legend gui
svn_qgis at osgeo.org
Wed Oct 13 16:53:33 EDT 2010
Author: jef
Date: 2010-10-13 13:53:33 -0700 (Wed, 13 Oct 2010)
New Revision: 14377
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/gui/qgsmapcanvas.cpp
fix #3109
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2010-10-13 20:52:05 UTC (rev 14376)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2010-10-13 20:53:33 UTC (rev 14377)
@@ -155,7 +155,8 @@
// Turn off rendering to improve speed.
bool renderFlagState = mMapCanvas->renderFlag();
- mMapCanvas->setRenderFlag( false );
+ if ( renderFlagState )
+ mMapCanvas->setRenderFlag( false );
for ( QTreeWidgetItem* theItem = firstItem(); theItem; theItem = nextItem( theItem ) )
@@ -168,7 +169,8 @@
// Turn on rendering (if it was on previously)
- mMapCanvas->setRenderFlag( renderFlagState );
+ mMapCanvas->setRenderFlag( true );
QgsProject::instance()->dirty( true );
@@ -1483,8 +1485,6 @@
return;
- bool renderFlagState = mMapCanvas->renderFlag();
//if the text of a QgsLegendLayer has changed, change the display names of all its maplayers
// TODO: is this still necessary?
QgsLegendLayer* theLegendLayer = dynamic_cast<QgsLegendLayer *>( item ); //item is a legend layer
@@ -1497,13 +1497,16 @@
if ( item->data( 0, Qt::UserRole ).toInt() == item->checkState( 0 ) )
return;
+ bool renderFlagState = mMapCanvas->renderFlag();
QgsLegendGroup* lg = dynamic_cast<QgsLegendGroup *>( item ); //item is a legend group
if ( lg )
//set all the child layer files to the new check state
std::list<QgsLegendLayer*> subfiles = lg->legendLayers();
for ( std::list<QgsLegendLayer*>::iterator iter = subfiles.begin(); iter != subfiles.end(); ++iter )
#ifdef QGISDEBUG
@@ -1530,10 +1533,6 @@
- // If it was on, turn it back on, otherwise leave it
- // off, as turning it on causes a refresh.
- if ( renderFlagState )
- mMapCanvas->setRenderFlag( true );
item->setData( 0, Qt::UserRole, item->checkState( 0 ) );
@@ -1554,19 +1553,17 @@
static_cast<QgsLegendGroup*>( ll->parent() )->updateCheckState();
ll->parent()->setData( 0, Qt::UserRole, ll->parent()->checkState( 0 ) );
- mMapCanvas->freeze( false );
//update check state of the legend group
// update layer set
updateMapCanvasLayerSet();
+ // If it was on, turn it back on, otherwise leave it
+ // off, as turning it on causes a refresh.
void QgsLegend::openEditor()
@@ -1770,7 +1767,8 @@
foreach( QTreeWidgetItem *item, selectedItems() )
@@ -1790,5 +1788,6 @@
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-10-13 20:52:05 UTC (rev 14376)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-10-13 20:53:33 UTC (rev 14377)
@@ -3544,7 +3544,7 @@
void QgisApp::saveMapAsImage()
- QPair< QString,QString> myFileNameAndFilter = QgisGui::getSaveAsImageName( this, tr( "Choose a file name to save the map image as" ) );
+ QPair< QString, QString> myFileNameAndFilter = QgisGui::getSaveAsImageName( this, tr( "Choose a file name to save the map image as" ) );
if ( myFileNameAndFilter.first != "" )
//save the mapview to the selected file
@@ -3606,10 +3606,12 @@
// would otherwise cause two re-renders of the map, which can take a
// long time.
bool renderFlag = mapCanvas()->renderFlag();
- mapCanvas()->setRenderFlag( false );
+ if ( renderFlag )
+ mapCanvas()->setRenderFlag( false );
showNormal();
showMaximized();
- mapCanvas()->setRenderFlag( renderFlag );
+ if ( renderFlag )
+ mapCanvas()->setRenderFlag( true );
mPrevScreenModeMaximized = false;
else
@@ -4413,7 +4415,8 @@
QMap<QString, QgsMapLayer*> layers = QgsMapLayerRegistry::instance()->mapLayers();
for ( QMap<QString, QgsMapLayer*>::iterator it = layers.begin(); it != layers.end(); it++ )
@@ -4426,7 +4429,8 @@
void QgisApp::addVertex()
Modified: trunk/qgis/src/gui/qgsmapcanvas.cpp
--- trunk/qgis/src/gui/qgsmapcanvas.cpp 2010-10-13 20:52:05 UTC (rev 14376)
+++ trunk/qgis/src/gui/qgsmapcanvas.cpp 2010-10-13 20:53:33 UTC (rev 14377)
@@ -313,7 +313,7 @@
refresh();
-} // addLayer
+} // setLayerSet
void QgsMapCanvas::enableOverviewMode( QgsMapOverviewCanvas* overview )
