[QGIS Commit] r14392 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sun Oct 17 20:05:19 EDT 2010
Author: jef
Date: 2010-10-17 17:05:19 -0700 (Sun, 17 Oct 2010)
New Revision: 14392
trunk/qgis/src/app/qgssinglesymboldialog.cpp
trunk/qgis/src/app/qgssinglesymboldialog.h
trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
change list to view in single symbol dialog
Modified: trunk/qgis/src/app/qgssinglesymboldialog.cpp
--- trunk/qgis/src/app/qgssinglesymboldialog.cpp 2010-10-18 00:02:01 UTC (rev 14391)
+++ trunk/qgis/src/app/qgssinglesymboldialog.cpp 2010-10-18 00:05:19 UTC (rev 14392)
@@ -30,11 +30,48 @@
#include <QPainter>
#include <QImage>
#include <QFileDialog>
-#include <QListWidgetItem>
#include <QKeyEvent>
+#include <QAbstractListModel>
#define DO_NOT_USE_STR "<off>"
+class QgsMarkerListModel : public QAbstractListModel
+ public:
+ QgsMarkerListModel( QObject* parent ) : QAbstractListModel( parent )
+ mMarkers = QgsMarkerCatalogue::instance()->list();
+ int rowCount( const QModelIndex & parent = QModelIndex() ) const
+ return mMarkers.size();
+ QVariant data( const QModelIndex & index, int role = Qt::DisplayRole ) const
+ QString marker = mMarkers.at( index.row() );
+ if ( role == Qt::DecorationRole ) // icon
+ QPen pen( QColor( 0, 0, 255 ) );
+ QBrush brush( QColor( 220, 220, 220 ), Qt::SolidPattern );
+ return QPixmap::fromImage( QgsMarkerCatalogue::instance()->imageMarker( marker, 18, pen, brush ) );
+ else if ( role == Qt::UserRole || role == Qt::ToolTipRole )
+ return marker;
+ return QVariant();
+ protected:
+ QStringList mMarkers;
QgsSingleSymbolDialog::QgsSingleSymbolDialog(): QDialog(), mVectorLayer( 0 )
setupUi( this );
@@ -71,8 +108,8 @@
connect( btnFillColor, SIGNAL( clicked() ), this, SLOT( selectFillColor() ) );
connect( outlinewidthspinbox, SIGNAL( valueChanged( double ) ), this, SLOT( resendSettingsChanged() ) );
connect( mLabelEdit, SIGNAL( textChanged( const QString& ) ), this, SLOT( resendSettingsChanged() ) );
- connect( lstSymbols, SIGNAL( currentItemChanged( QListWidgetItem *, QListWidgetItem * ) ),
- this, SLOT( symbolChanged( QListWidgetItem *, QListWidgetItem * ) ) );
+ connect( lstSymbols, SIGNAL( currentChanged( const QModelIndex & , const QModelIndex & ) ),
+ this, SLOT( symbolChanged( const QModelIndex & , const QModelIndex & ) ) );
connect( mPointSizeSpinBox, SIGNAL( valueChanged( double ) ), this, SLOT( resendSettingsChanged() ) );
connect( mPointSizeUnitsCheckBox, SIGNAL( toggled( bool ) ), this, SLOT( resendSettingsChanged() ) );
connect( mRotationClassificationComboBox, SIGNAL( currentIndexChanged( const QString & ) ),
@@ -95,33 +132,9 @@
void QgsSingleSymbolDialog::refreshMarkers()
- lstSymbols->blockSignals( true );
- lstSymbols->clear();
+ QgsMarkerListModel *m = new QgsMarkerListModel( lstSymbols );
+ lstSymbols->setModel( m );
- QPen pen( QColor( 0, 0, 255 ) );
- QBrush brush( QColor( 220, 220, 220 ), Qt::SolidPattern );
- int size = 18;
- int myCounter = 0;
- QStringList ml = QgsMarkerCatalogue::instance()->list();
- for ( QStringList::iterator it = ml.begin(); it != ml.end(); ++it )
- QPixmap myPixmap = QPixmap::fromImage( QgsMarkerCatalogue::instance()->imageMarker( *it, size, pen, brush ) );
- QListWidgetItem * mypItem = new QListWidgetItem( lstSymbols );
- QIcon myIcon;
- myIcon.addPixmap( myPixmap );
- mypItem->setIcon( myIcon );
- mypItem->setText( "" );
- mypItem->setToolTip( *it );
- //store the symbol offset in the UserData role for later retrieval
- mypItem->setData( Qt::UserRole, *it );
- mypItem->setFlags( Qt::ItemIsSelectable | Qt::ItemIsEnabled );
- if ( mVectorLayer && mVectorLayer->geometryType() != QGis::Point )
- break;
- ++myCounter;
// Find out the numerical fields of mVectorLayer, and populate the ComboBoxes
QgsVectorDataProvider *provider = mVectorLayer->dataProvider();
if ( provider )
@@ -283,9 +296,10 @@
// Apply point symbol
- if ( lstSymbols->isEnabled() && lstSymbols->currentItem() )
+ if ( lstSymbols->isEnabled() && lstSymbols->currentIndex().isValid() )
- sy->setNamedPointSymbol( lstSymbols->currentItem()->data( Qt::UserRole ).toString() ) ;
+ QAbstractItemModel *m = lstSymbols->model();
+ sy->setNamedPointSymbol( m->data( lstSymbols->currentIndex(), Qt::UserRole ).toString() );
if ( mPointSizeSpinBox->isEnabled() )
@@ -376,12 +390,15 @@
// Set point symbol
QString mySymbolName = sy->pointSymbolName();
- for ( int i = 0; i < lstSymbols->count(); ++i )
+ for ( int i = 0; i < m->rowCount(); i++ )
- if ( lstSymbols->item( i )->data( Qt::UserRole ).toString() == ( mySymbolName ) )
+ QModelIndex idx( m->index( i, 0 ) );
+ if ( m->data( idx, Qt::UserRole ).toString() == mySymbolName )
- lstSymbols->setCurrentItem( lstSymbols->item( i ) );
- lstSymbols->item( i )->setBackground( QBrush( Qt::cyan ) );
+ lstSymbols->setCurrentIndex( idx );
+ // m->setData( idx, Qt::UserRole+1, Qt::cyan );
break;
@@ -478,9 +495,14 @@
if ( mLabelEdit->isEnabled() && mLabelEdit->text() != sy->label() )
mLabelEdit->setEnabled( false );
- if ( lstSymbols->isEnabled() && lstSymbols->currentItem()->data( Qt::UserRole ).toString() != sy->pointSymbolName() )
- lstSymbols->setEnabled( false );
+ if ( m->data( lstSymbols->currentIndex(), Qt::UserRole ).toString() != sy->pointSymbolName() )
+ lstSymbols->setEnabled( false );
if ( mPointSizeSpinBox->isEnabled() && !doubleNear( mPointSizeSpinBox->value(), sy->pointSize() ) )
mPointSizeSpinBox->setEnabled( false );
@@ -612,14 +634,12 @@
mLabelEdit->setText( label );
-void QgsSingleSymbolDialog::symbolChanged
-( QListWidgetItem * current, QListWidgetItem * previous )
+void QgsSingleSymbolDialog::symbolChanged( const QModelIndex ¤t, const QModelIndex &previous )
- current->setBackground( QBrush( Qt::cyan ) );
- if ( previous )
- previous->setBackground( QBrush( Qt::white ) );
+ QgsDebugMsg( QString( "symbol changed to %1:%2" ).arg( current.row() ).arg( m->data( current, Qt::UserRole ).toString() ) );
+ // m->setData( current, Qt::UserRole+1, Qt::cyan );
+ // m->setData( prev, Qt::UserRole+1, Qt::white );
emit settingsChanged();
Modified: trunk/qgis/src/app/qgssinglesymboldialog.h
--- trunk/qgis/src/app/qgssinglesymboldialog.h 2010-10-18 00:02:01 UTC (rev 14391)
+++ trunk/qgis/src/app/qgssinglesymboldialog.h 2010-10-18 00:05:19 UTC (rev 14392)
@@ -75,7 +75,7 @@
void selectOutlineColor();
void selectFillColor();
void selectTextureImage();
- void symbolChanged( QListWidgetItem * current, QListWidgetItem * previous );
+ void symbolChanged( const QModelIndex ¤t, const QModelIndex &previous );
private:
/** Default constructor is private, do not use this */
QgsSingleSymbolDialog();
Modified: trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
--- trunk/qgis/src/ui/qgssinglesymboldialogbase.ui 2010-10-18 00:02:01 UTC (rev 14391)
+++ trunk/qgis/src/ui/qgssinglesymboldialogbase.ui 2010-10-18 00:05:19 UTC (rev 14392)
@@ -6,7 +6,7 @@
<rect>
<x>0</x>
<y>0</y>
- <width>360</width>
+ <width>366</width>
<height>470</height>
</rect>
</property>
@@ -33,8 +33,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>337</width>
- <height>616</height>
+ <width>350</width>
+ <height>604</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_5">
@@ -50,40 +50,6 @@
<string>Point Symbol</string>
</property>
<layout class="QGridLayout" name="gridLayout_4">
- <item row="0" column="0" colspan="3">
- <widget class="QListWidget" name="lstSymbols">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Expanding" vsizetype="MinimumExpanding">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="dragDropMode">
- <enum>QAbstractItemView::DragDrop</enum>
- </property>
- <property name="alternatingRowColors">
- <bool>false</bool>
- </property>
- <property name="iconSize">
- <size>
- <width>0</width>
- <height>-1</height>
- </size>
- </property>
- <property name="resizeMode">
- <enum>QListView::Adjust</enum>
- </property>
- <property name="viewMode">
- <enum>QListView::IconMode</enum>
- </property>
- <property name="uniformItemSizes">
- <bool>true</bool>
- </property>
- <property name="wordWrap">
- </property>
- </widget>
- </item>
<item row="1" column="0">
<widget class="QLabel" name="textLabel1_2">
<property name="text">
@@ -120,6 +86,40 @@
<item row="2" column="2">
<layout class="QHBoxLayout" name="horizontalLayout"/>
</item>
+ <item row="0" column="0" colspan="3">
+ <widget class="QListView" name="lstSymbols">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="MinimumExpanding">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="dragDropMode">
+ <enum>QAbstractItemView::DragDrop</enum>
+ </property>
+ <property name="alternatingRowColors">
+ <bool>false</bool>
+ </property>
+ <property name="iconSize">
+ <size>
+ <width>0</width>
+ <height>-1</height>
+ </size>
+ </property>
+ <property name="resizeMode">
+ <enum>QListView::Adjust</enum>
+ </property>
+ <property name="viewMode">
+ <enum>QListView::IconMode</enum>
+ </property>
+ <property name="uniformItemSizes">
+ <bool>true</bool>
+ </property>
+ <property name="wordWrap">
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
