[QGIS Commit] r14411 - in trunk/qgis: i18n src/core/gps
svn_qgis at osgeo.org
Tue Oct 19 03:00:30 EDT 2010
Author: jef
Date: 2010-10-19 00:00:30 -0700 (Tue, 19 Oct 2010)
New Revision: 14411
trunk/qgis/i18n/qgis_de.ts
trunk/qgis/src/core/gps/qgsgpsdconnection.h
german translation fix
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2010-10-19 00:00:55 UTC (rev 14410)
+++ trunk/qgis/i18n/qgis_de.ts 2010-10-19 07:00:30 UTC (rev 14411)
@@ -6942,18 +6942,6 @@
Diese QGIS-Kopie enthält SpatiaLite-Unterstützung (%1).</translation>
</message>
<message>
- <source>
-This copy of QGIS has been built with QWT support (%1).</source>
- <translation type="obsolete">
-Diese QGIS-Kopie wurde mit QWT-Unterstützung (%1) erzeugt.</translation>
- </message>
- <message>
- <source>
-This copy of QGIS has been built without QWT support.</source>
-Diese QGIS-Kopie wurde ohne QWT-Unterstützung erzeugt.</translation>
- </message>
- <message>
<location filename="../src/app/qgisapp.cpp" line="2490"/>
<source>
This copy of QGIS writes debugging output.</source>
@@ -8315,22 +8303,6 @@
<context>
<name>QgsAttributeSelectionDialog</name>
<message>
- <source>Attribute</source>
- <translation type="obsolete">Attribut</translation>
- </message>
- <message>
- <source>Alias</source>
- <translation type="obsolete">Alias</translation>
- </message>
- <message>
- <source>Select all</source>
- <translation type="obsolete">Alles auswählen</translation>
- </message>
- <message>
- <source>Clear</source>
- <translation type="obsolete">Löschen</translation>
- </message>
- <message>
<location filename="../src/app/composer/qgsattributeselectiondialog.cpp" line="71"/>
<location filename="../src/app/composer/qgsattributeselectiondialog.cpp" line="76"/>
<location filename="../src/app/composer/qgsattributeselectiondialog.cpp" line="149"/>
@@ -8418,11 +8390,6 @@
<numerusform>Attributtabelle - %1 (%n Objekte gefunden)</numerusform>
</translation>
</message>
- <message>
- <source>Attribute table - %3 :: %1 / %2 features(s) selected</source>
- <comment>feature count</comment>
- <translation type="obsolete">Attributetabelle - %3 :: %1 / %2 Objekte</translation>
- </message>
<message numerus="yes">
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="144"/>
<source>Attribute table - %1 :: %n / %2 feature(s) selected</source>
@@ -8483,10 +8450,6 @@
<translation>Öffnet den Abfrageeditor</translation>
</message>
<message>
- <source>Help</source>
- <translation type="obsolete">Hilfe</translation>
- </message>
- <message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="99"/>
<source>Unselect all</source>
<translation>nichts auswählen</translation>
@@ -8597,10 +8560,6 @@
<translation>&Suchen</translation>
</message>
<message>
- <source>Show selected records only</source>
- <translation type="obsolete">Nur gewählte Datensätze zeigen</translation>
- </message>
- <message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="69"/>
<source>Advanced search</source>
<translation>Erweiterte Suche</translation>
@@ -8610,10 +8569,6 @@
<source>...</source>
<translation>...</translation>
</message>
- <message>
- <source>Search selected records only</source>
- <translation type="obsolete">Nur ausgewählte Datensätze durchsuchen</translation>
- </message>
</context>
<context>
<name>QgsAttributeTableModel</name>
@@ -11200,7 +11155,7 @@
%2
-Hinweis: Diese Nachricht für dies Datei in dieser Sitzung nicht erneut angezeigt.</translation>
+Hinweis: Diese Nachricht wird in dieser Sitzung für diese Datei nicht erneut angezeigt.</translation>
</message>
<message>
<location filename="../src/core/qgscoordinatetransform.cpp" line="419"/>
@@ -12130,14 +12085,6 @@
<source>Could not add the new field to the provider.</source>
<translation>Konnte neues Feld nicht hinzufügen.</translation>
</message>
- <message>
- <source>Error</source>
- <translation type="obsolete">Fehler</translation>
- </message>
- <message>
- <source>An error occured while evaluating the calculation string.</source>
- <translation type="obsolete">Fehler beim Überprüfen des Berechnungsausdrucks.</translation>
- </message>
</context>
<context>
<name>QgsFieldCalculatorBase</name>
@@ -12715,10 +12662,6 @@
<translation>Aktuelles Objekt zurücksetzen</translation>
</message>
<message>
- <source>GPS device port</source>
- <translation type="obsolete">GPS-Geräteport</translation>
- </message>
- <message>
<location filename="../src/ui/qgsgpsinformationwidgetbase.ui" line="297"/>
<source>GPS connection</source>
<translation>GPS-Verbindung</translation>
@@ -17886,52 +17829,52 @@
<context>
<name>QgsLegendLayer</name>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="364"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="383"/>
<source>&Zoom to layer extent</source>
<translation>Auf die Layerausdehnung &zoomen</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="367"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="386"/>
<source>&Zoom to best scale (100%)</source>
<translation>&Auf besten Maßstab zoomen (100%)</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="372"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="391"/>
<source>&Stretch using current extent</source>
<translation>Auf aktuelle Ausdehnung &strecken</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="377"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="396"/>
<source>&Show in overview</source>
<translation>&In der Übersicht anzeigen</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="384"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="403"/>
<source>&Remove</source>
<translation>&Entfernen</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="393"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="412"/>
<source>&Open attribute table</source>
<translation>&Attributtabelle öffnen</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="408"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="427"/>
<source>Save as...</source>
<translation>Speichern als...</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="411"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="430"/>
<source>Save selection as...</source>
<translation>Auswahl speichern als...</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="418"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="437"/>
<source>&Query...</source>
<translation>&Abfrage...</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegendlayer.cpp" line="425"/>
+ <location filename="../src/app/legend/qgslegendlayer.cpp" line="444"/>
<source>&Properties</source>
<translation>&Eigenschaften</translation>
</message>
@@ -23344,22 +23287,6 @@
<translation>&Löschen</translation>
</message>
<message>
- <source>Invalid Query</source>
- <translation type="obsolete">Ungültige Abfrage</translation>
- </message>
- <message>
- <source>Setting the query failed</source>
- <translation type="obsolete">Setzen der Abfrage gescheitert</translation>
- </message>
- <message>
- <source>No Query</source>
- <translation type="obsolete">Keine Abfrage</translation>
- </message>
- <message>
- <source>You must create a query before you can test it</source>
- <translation type="obsolete">Sie müssen eine Anfrage erstellen bevor Sie sie testen können</translation>
- </message>
- <message>
<location filename="../src/app/qgsquerybuilder.cpp" line="151"/>
<source>Query Result</source>
<translation>Abfrageergebnis</translation>
@@ -24828,26 +24755,6 @@
<translation>Pyramidenauflösungen</translation>
</message>
<message>
- <source><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><meta name="qrichtext" content="1" /><style type="text/css">
-p, li { white-space: pre-wrap; }
-</style></head><body style=" font-family:'Sans'; font-size:10pt; font-weight:400; font-style:normal;">
-<table border="0" style="-qt-table-type: root; margin-top:4px; margin-bottom:4px; margin-left:4px; margin-right:4px;">
-<tr>
-<td style="border: none;">
-<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p>
-<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></td></tr></table></body></html></source>
- <translation type="obsolete"><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//DE" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<tr>
-<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></td></tr></table></body></html></translation>
- </message>
- <message>
<location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1794"/>
<source>Build pyramids internally if possible</source>
<translation>Pyramiden wenn möglich intern erzeugen</translation>
@@ -24893,38 +24800,6 @@
<translation>Kein Datum</translation>
</message>
<message>
- <source>Chart Type</source>
- <translation type="obsolete">Diagrammtyp</translation>
- </message>
- <message>
- <source>Line graph</source>
- <translation type="obsolete">Kurvendiagramm</translation>
- </message>
- <message>
- <source>Bar chart</source>
- <translation type="obsolete">Balkendiagramm</translation>
- </message>
- <message>
- <source>Options</source>
- <translation type="obsolete">Optionen</translation>
- </message>
- <message>
- <source>Column count</source>
- <translation type="obsolete">Spaltenanzahl</translation>
- </message>
- <message>
- <source>Out of range OK?</source>
- <translation type="obsolete">Bereichsüberschreitung erlaubt?</translation>
- </message>
- <message>
- <source>Allow approximation</source>
- <translation type="obsolete">Approximation erlauben</translation>
- </message>
- <message>
- <source>Refresh</source>
- <translation type="obsolete">Aktualisieren</translation>
- </message>
- <message>
<location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="31"/>
<source>Restore Default Style</source>
<translation>Vorgabestil wiederherstellen</translation>
@@ -32178,10 +32053,6 @@
<translation>Vektor exportieren</translation>
</message>
<message>
- <source>Export vector table</source>
- <translation type="obsolete">Vektortabelle exportieren</translation>
- </message>
- <message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="193"/>
<source>Export vector to DXF</source>
<translation>Vektor als DXF exportieren</translation>
Modified: trunk/qgis/src/core/gps/qgsgpsdconnection.h
--- trunk/qgis/src/core/gps/qgsgpsdconnection.h 2010-10-19 00:00:55 UTC (rev 14410)
+++ trunk/qgis/src/core/gps/qgsgpsdconnection.h 2010-10-19 07:00:30 UTC (rev 14411)
@@ -18,7 +18,6 @@
#ifndef QGSGPSDCONNECTION_H
#define QGSGPSDCONNECTION_H
-#include "qgsgpsdconnection.h"
#include "qgsnmeaconnection.h"
#include <QAbstractSocket>
