[QGIS Commit] r14450 - in trunk/qgis/python/plugins/GdalTools: . tools
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Oct 29 18:07:56 EDT 2010
Author: brushtyler
Date: 2010-10-29 15:07:56 -0700 (Fri, 29 Oct 2010)
New Revision: 14450
   trunk/qgis/python/plugins/GdalTools/__init__.py
   trunk/qgis/python/plugins/GdalTools/tools/doMerge.py
   trunk/qgis/python/plugins/GdalTools/tools/doTranslate.py
   trunk/qgis/python/plugins/GdalTools/tools/doWarp.py
applied the patch suggested in ticket #3151,
fix in translate to use the GdalTools_utils to get the crs,
managed invalid extent in merge tool
Modified: trunk/qgis/python/plugins/GdalTools/__init__.py
--- trunk/qgis/python/plugins/GdalTools/__init__.py	2010-10-29 21:40:17 UTC (rev 14449)
+++ trunk/qgis/python/plugins/GdalTools/__init__.py	2010-10-29 22:07:56 UTC (rev 14450)
@@ -22,7 +22,7 @@
 def description():
   return "Integrate gdal tools into qgis"
 def version():
-  return "Version 1.2.10"
+  return "Version 1.2.15"
 def qgisMinimumVersion():
   return "1.0"
 def classFactory(iface):
Modified: trunk/qgis/python/plugins/GdalTools/tools/doMerge.py
--- trunk/qgis/python/plugins/GdalTools/tools/doMerge.py	2010-10-29 21:40:17 UTC (rev 14449)
+++ trunk/qgis/python/plugins/GdalTools/tools/doMerge.py	2010-10-29 22:07:56 UTC (rev 14450)
@@ -18,6 +18,7 @@
       BasePluginWidget.__init__(self, self.iface, "gdal_merge.py")
       self.outputFormat = Utils.fillRasterOutputFormat()
+      self.extent = None
       self.setParamsStatus(
@@ -33,6 +34,7 @@
       self.connect(self.selectInputFilesButton, SIGNAL("clicked()"), self.fillInputFilesEdit)
       self.connect(self.selectOutputFileButton, SIGNAL("clicked()"), self.fillOutputFileEdit)
+      self.connect(self.intersectCheck, SIGNAL("stateChanged(int)"), self.refreshExtent)
   def fillInputFilesEdit(self):
       lastUsedFilter = Utils.FileFilter.lastUsedRasterFilter()
@@ -42,13 +44,27 @@
       Utils.FileFilter.setLastUsedRasterFilter(lastUsedFilter)
       self.inputFilesEdit.setText(files.join(","))
+      self.intersectCheck.setEnabled( files.count() > 1 )
+      self.refreshExtent()
+  def refreshExtent(self):
+      files = self.inputFilesEdit.text().split( "," )
       if files.count() < 2:
         self.intersectCheck.setChecked( False )
-        self.intersectCheck.setEnabled( False )
-      else:
-        self.intersectCheck.setEnabled( True )
-        (self.xmax, self.ymax, self.xmin, self.ymin) = self.getExtent()
+        return
+      self.extent = self.getExtent()
+      self.someValueChanged()
+      if not self.intersectCheck.isChecked():
+        return
+      if self.extent == None:
+        QMessageBox.warning( self, self.tr( "Error retrieving the extent" ), self.tr( 'GDAL was unable to retrieve the extent from any file. \nThe "Use intersected extent" option will be unchecked.' ) )
+        self.intersectCheck.setChecked( False )
+      elif self.extent.isEmpty():
+        QMessageBox.warning( self, self.tr( "Empty extent" ), self.tr( 'The computed extent is empty. \nDisable the "Use intersected extent" option to have a nonempty output.' ) )
   def fillOutputFileEdit(self):
@@ -63,8 +79,12 @@
   def getArguments(self):
       arguments = QStringList()
       if self.intersectCheck.isChecked():
-        arguments << "-ul_lr"
-        arguments << str( self.xmin ) << str( self.ymax ) << str( self.xmax ) << str( self.ymin )
+        if self.extent != None:
+          arguments << "-ul_lr"
+          arguments << str( self.extent.xMinimum() )
+          arguments << str( self.extent.yMaximum() )
+          arguments << str( self.extent.xMaximum() )
+          arguments << str( self.extent.yMinimum() )
       if self.noDataCheck.isChecked():
         arguments << "-n"
         arguments << str(self.noDataSpin.value())
@@ -117,21 +137,14 @@
     i = 0
-    while i < files.count():
-      if i == 0:
-        rect1 = self.getRectangle( files[ 0 ] )
-        rect2 = self.getRectangle( files[ 1 ] )
-        res = rect1.intersect( rect2 )
-        rect1 = res
-        i = 2
+    res = rect2 = None
+    for fileName in files:
+      if res == None:
+        res = self.getRectangle( fileName )
         continue
-      rect2 = self.getRectangle( files[ i ] )
-      i = i + 1
+      rect2 = self.getRectangle( fileName )
+      if rect2 == None:
+        continue
+      res = res.intersect( rect2 )
-    xMax = res.xMaximum()
-    xMin = res.xMinimum()
-    yMax = res.yMaximum()
-    yMin = res.yMinimum()
-    return ( xMax, yMax, xMin, yMin )
+    return res
Modified: trunk/qgis/python/plugins/GdalTools/tools/doTranslate.py
--- trunk/qgis/python/plugins/GdalTools/tools/doTranslate.py	2010-10-29 21:40:17 UTC (rev 14449)
+++ trunk/qgis/python/plugins/GdalTools/tools/doTranslate.py	2010-10-29 22:07:56 UTC (rev 14450)
@@ -114,12 +114,12 @@
         return
       Utils.FileFilter.setLastUsedRasterFilter( lastUsedFilter )
-      # get SRS for target file if necessary and possible
-      self.targetSRSEdit.setText( Utils.getRasterSRS( self, inputFile ) )
       self.inputLayerCombo.setCurrentIndex(-1)
       self.inputLayerCombo.setEditText( inputFile )
+      # get SRS for target file if necessary and possible
+      self.refreshTargetSRS()
   def fillInputDir( self ):
       inputDir = Utils.FileDialog.getExistingDirectory( self, self.tr( "Select the input directory with files to Translate" ))
       if inputDir.isEmpty():
@@ -154,10 +154,13 @@
       self.outputFileEdit.setText( outputDir )
   def fillTargetSRSEditDefault(self, index):
-      if index >= 0 and index in self.layers:
-        layer = self.layers[index]
-        self.targetSRSEdit.setText("EPSG:" + str(layer.srs().epsg()))
+      if index < 0:
+        return
+  def refreshTargetSRS(self):
+      self.targetSRSEdit.setText( Utils.getRasterSRS( self, self.getInputFileName() ) )
   def fillTargetSRSEdit(self):
       dialog = SRSDialog( "Select the target SRS" )
       if dialog.exec_():
Modified: trunk/qgis/python/plugins/GdalTools/tools/doWarp.py
--- trunk/qgis/python/plugins/GdalTools/tools/doWarp.py	2010-10-29 21:40:17 UTC (rev 14449)
+++ trunk/qgis/python/plugins/GdalTools/tools/doWarp.py	2010-10-29 22:07:56 UTC (rev 14450)
@@ -44,6 +44,7 @@
+      self.connect(self.inputLayerCombo, SIGNAL("currentIndexChanged(int)"), self.fillSourceSRSEditDefault)
       self.connect(self.selectInputFileButton, SIGNAL("clicked()"), self.fillInputFile)
       self.connect(self.selectSourceSRSButton, SIGNAL("clicked()"), self.fillSourceSRSEdit)
@@ -100,12 +101,12 @@
         return
-      # get SRS for source file if necessary and possible
-      self.sourceSRSEdit.setText( Utils.getRasterSRS( self, inputFile ) )
       self.inputLayerCombo.setEditText(inputFile)
+      # get SRS for source file if necessary and possible
+      self.refreshSourceSRS()
       outputFile = Utils.FileDialog.getSaveFileName(self, self.tr( "Select the raster file to save the results to" ), Utils.FileFilter.allRastersFilter(), lastUsedFilter )
@@ -144,6 +145,16 @@
       if dialog.exec_():
         self.sourceSRSEdit.setText(dialog.getProjection())
+  def fillSourceSRSEditDefault(self, index):
+      if index < 0:
+        return
+  def refreshSourceSRS(self):
+      crs = Utils.getRasterSRS( self, self.getInputFileName() )
+      self.sourceSRSEdit.setText( crs )
+      self.sourceSRSCheck.setChecked( not crs.isEmpty() )
       if dialog.exec_():
@@ -164,7 +175,7 @@
         arguments << "-wm"
         arguments << str(self.cacheSpin.value())
       if self.resizeGroupBox.isChecked():
-       	arguments << "-ts"
+        arguments << "-ts"
         arguments << str( self.widthSpin.value() )
         arguments << str( self.heightSpin.value() )
       if self.multithreadCheck.isChecked():
More information about the QGIS-commit mailing list
