[QGIS Commit] r14246 - trunk/qgis/src/providers/wfs
svn_qgis at osgeo.org
Sat Sep 18 06:03:56 EDT 2010
Author: mhugent
Date: 2010-09-18 10:03:56 +0000 (Sat, 18 Sep 2010)
New Revision: 14246
trunk/qgis/src/providers/wfs/qgswfsdata.cpp
trunk/qgis/src/providers/wfs/qgswfsprovider.cpp
trunk/qgis/src/providers/wfs/qgswfsprovider.h
Implement featureAtId for wfs provider
Modified: trunk/qgis/src/providers/wfs/qgswfsdata.cpp
--- trunk/qgis/src/providers/wfs/qgswfsdata.cpp 2010-09-18 08:59:37 UTC (rev 14245)
+++ trunk/qgis/src/providers/wfs/qgswfsdata.cpp 2010-09-18 10:03:56 UTC (rev 14246)
@@ -111,7 +111,6 @@
progressDialog->show();
- QByteArray readData;
int atEnd = 0;
while ( !atEnd )
@@ -119,10 +118,10 @@
atEnd = 1;
- readData = reply->readAll();
+ QByteArray readData = reply->readAll();
if ( readData.size() > 0 )
- XML_Parse( p, readData.data(), readData.size(), atEnd );
+ XML_Parse( p, readData.constData(), readData.size(), atEnd );
QCoreApplication::processEvents();
Modified: trunk/qgis/src/providers/wfs/qgswfsprovider.cpp
--- trunk/qgis/src/providers/wfs/qgswfsprovider.cpp 2010-09-18 08:59:37 UTC (rev 14245)
+++ trunk/qgis/src/providers/wfs/qgswfsprovider.cpp 2010-09-18 10:03:56 UTC (rev 14246)
@@ -76,6 +76,54 @@
delete mSpatialIndex;
+void QgsWFSProvider::copyFeature( QgsFeature* f, QgsFeature& feature, bool fetchGeometry, QgsAttributeList fetchAttributes )
+ if ( !f )
+ return;
+ //copy the geometry
+ QgsGeometry* geometry = f->geometry();
+ unsigned char *geom = geometry->asWkb();
+ int geomSize = geometry->wkbSize();
+ unsigned char* copiedGeom = new unsigned char[geomSize];
+ memcpy( copiedGeom, geom, geomSize );
+ feature.setGeometryAndOwnership( copiedGeom, geomSize );
+ //and the attributes
+ const QgsAttributeMap& attributes = f->attributeMap();
+ for ( QgsAttributeList::const_iterator it = fetchAttributes.begin(); it != fetchAttributes.end(); ++it )
+ feature.addAttribute( *it, attributes[*it] );
+ //id and valid
+ feature.setValid( true );
+ feature.setFeatureId( f->id() );
+bool QgsWFSProvider::featureAtId( int featureId,
+ QgsFeature& feature,
+ bool fetchGeometry,
+ QgsAttributeList fetchAttributes )
+ QMap<int, QgsFeature* >::iterator it = mFeatures.find( featureId );
+ if ( it == mFeatures.end() )
+ return false;
+ QgsFeature* f = it.value();
+ if ( !f )
+ return false;
+ copyFeature( f, feature, fetchGeometry, fetchAttributes );
+ return true;
bool QgsWFSProvider::nextFeature( QgsFeature& feature )
feature.setValid( false );
@@ -87,27 +135,19 @@
return 0;
- feature.setFeatureId( mFeatures[*mFeatureIterator]->id() );
+ QgsFeature* f = mFeatures[*mFeatureIterator];
+ ++mFeatureIterator;
+ if ( !f )
+ continue;
- //we need geometry anyway, e.g. for intersection tests
- QgsGeometry* geometry = mFeatures[*mFeatureIterator]->geometry();
- unsigned char *geom = geometry->asWkb();
- int geomSize = geometry->wkbSize();
- unsigned char* copiedGeom = new unsigned char[geomSize];
- memcpy( copiedGeom, geom, geomSize );
- feature.setGeometryAndOwnership( copiedGeom, geomSize );
+ copyFeature( f, feature, true, mAttributesToFetch );
- const QgsAttributeMap& attributes = mFeatures[*mFeatureIterator]->attributeMap();
- for ( QgsAttributeList::const_iterator it = mAttributesToFetch.begin(); it != mAttributesToFetch.end(); ++it )
- feature.addAttribute( *it, attributes[*it] );
- ++mFeatureIterator;
if ( mUseIntersect )
if ( feature.geometry() && feature.geometry()->intersects( mSpatialFilter ) )
- feature.setValid( true );
return true;
else
@@ -117,7 +157,6 @@
else
return true;
Modified: trunk/qgis/src/providers/wfs/qgswfsprovider.h
--- trunk/qgis/src/providers/wfs/qgswfsprovider.h 2010-09-18 08:59:37 UTC (rev 14245)
+++ trunk/qgis/src/providers/wfs/qgswfsprovider.h 2010-09-18 10:03:56 UTC (rev 14246)
@@ -57,6 +57,22 @@
bool useIntersect = false );
+ * Gets the feature at the given feature ID.
+ * @param featureId of the feature to be returned
+ * @param feature which will receive the data
+ * @param fetchGeometry flag which if true, will cause the geometry to be fetched from the provider
+ * @param fetchAttributes a list containing the indexes of the attribute fields to copy
+ * @return True when feature was found, otherwise false
+ * Default implementation traverses all features until it finds the one with correct ID.
+ * In case the provider supports reading the feature directly, override this function.
+ virtual bool featureAtId( int featureId,
+ bool fetchGeometry = true,
+ QgsAttributeList fetchAttributes = QgsAttributeList() );
* Get the next feature resulting from a select operation.
* @param feature feature which will receive data from the provider
* @return true when there was a feature to fetch, false when end was hit
@@ -189,6 +205,9 @@
/**This method tries to guess the geometry attribute and the other attribute names from the .gml file if no schema is present. Returns 0 in case of success*/
int guessAttributesFromFile( const QString& uri, QString& geometryAttribute, std::list<QString>& thematicAttributes ) const;
+ /**Copies feature attributes / geometry from f to feature*/
+ void copyFeature( QgsFeature* f, QgsFeature& feature, bool fetchGeometry, QgsAttributeList fetchAttributes );
//GML2 specific methods
int getExtentFromGML2( QgsRectangle* extent, const QDomElement& wfsCollectionElement ) const;
