[QGIS Commit] r14248 - in trunk/qgis/src: app/postgres core
providers/postgres ui
svn_qgis at osgeo.org
Sat Sep 18 14:20:24 EDT 2010
Author: jef
Date: 2010-09-18 18:20:24 +0000 (Sat, 18 Sep 2010)
New Revision: 14248
trunk/qgis/src/app/postgres/qgspgnewconnection.cpp
trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
trunk/qgis/src/app/postgres/qgspgsourceselect.h
trunk/qgis/src/core/qgsdatasourceuri.cpp
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/ui/qgspgnewconnectionbase.ui
[FEATURE] allow adding geometryless layers from postgres
Modified: trunk/qgis/src/app/postgres/qgspgnewconnection.cpp
--- trunk/qgis/src/app/postgres/qgspgnewconnection.cpp 2010-09-18 15:31:31 UTC (rev 14247)
+++ trunk/qgis/src/app/postgres/qgspgnewconnection.cpp 2010-09-18 18:20:24 UTC (rev 14248)
@@ -58,7 +58,8 @@
txtPort->setText( port );
cb_publicSchemaOnly->setChecked( settings.value( key + "/publicOnly", false ).toBool() );
cb_geometryColumnsOnly->setChecked( settings.value( key + "/geometrycolumnsOnly", false ).toBool() );
- // Ensure that cb_plublicSchemaOnly is set correctly
+ cb_allowGeometrylessTables->setChecked( settings.value( key + "/allowGeometrylessTables", true ).toBool() );
+ // Ensure that cb_publicSchemaOnly is set correctly
on_cb_geometryColumnsOnly_clicked();
cb_useEstimatedMetadata->setChecked( settings.value( key + "/estimatedMetadata", false ).toBool() );
@@ -125,6 +126,7 @@
settings.setValue( baseKey + "/password", chkStorePassword->isChecked() ? txtPassword->text() : "" );
settings.setValue( baseKey + "/publicOnly", cb_publicSchemaOnly->isChecked() );
settings.setValue( baseKey + "/geometryColumnsOnly", cb_geometryColumnsOnly->isChecked() );
+ settings.setValue( baseKey + "/allowGeometrylessTables", cb_allowGeometrylessTables->isChecked() );
settings.setValue( baseKey + "/sslmode", cbxSSLmode->itemData( cbxSSLmode->currentIndex() ).toInt() );
settings.setValue( baseKey + "/saveUsername", chkStoreUsername->isChecked() ? "true" : "false" );
settings.setValue( baseKey + "/savePassword", chkStorePassword->isChecked() ? "true" : "false" );
Modified: trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
--- trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2010-09-18 15:31:31 UTC (rev 14247)
+++ trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2010-09-18 18:20:24 UTC (rev 14248)
@@ -362,9 +362,9 @@
uri += QString( " estimatedmetadata=true" );
- uri += QString( " table=\"%1\".\"%2\" (%3) sql=%4" )
+ uri += QString( " table=\"%1\".\"%2\"%3 sql=%4" )
.arg( schemaName ).arg( tableName )
- .arg( geomColumnName )
+ .arg( geomColumnName.isEmpty() ? QString() : QString( " (%1)" ).arg( geomColumnName ) )
.arg( sql );
return uri;
@@ -429,6 +429,7 @@
bool searchPublicOnly = settings.value( key + "/publicOnly" ).toBool();
bool searchGeometryColumnsOnly = settings.value( key + "/geometryColumnsOnly" ).toBool();
+ bool allowGeometrylessTables = settings.value( key + "/allowGeometrylessTables", true ).toBool();
mUseEstimatedMetadata = settings.value( key + "/estimatedMetadata" ).toBool();
// Need to escape the password to allow for single quotes and backslashes
@@ -481,7 +482,7 @@
// get the list of suitable tables and columns and populate the UI
geomCol details;
- if ( getTableInfo( pd, searchGeometryColumnsOnly, searchPublicOnly ) )
+ if ( getTableInfo( pd, searchGeometryColumnsOnly, searchPublicOnly, allowGeometrylessTables ) )
// Start the thread that gets the geometry type for relations that
// may take a long time to return
@@ -604,7 +605,7 @@
return cols;
-bool QgsPgSourceSelect::getTableInfo( PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly )
+bool QgsPgSourceSelect::getTableInfo( PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly, bool allowGeometrylessTables )
int nColumns = 0;
int nGTables = 0;
@@ -797,6 +798,58 @@
result = 0;
+ if ( allowGeometrylessTables )
+ QString sql = "select "
+ "pg_class.relname"
+ ",pg_namespace.nspname"
+ ",pg_class.relkind"
+ " from "
+ " pg_class"
+ ",pg_namespace"
+ " where "
+ "pg_namespace.oid=pg_class.relnamespace"
+ " and has_schema_privilege( pg_namespace.nspname, 'usage' )"
+ " and has_table_privilege( '\"' || pg_namespace.nspname || '\".\"' || pg_class.relname || '\"', 'select' )"
+ " and pg_class.relkind in( 'v', 'r' )";
+ // user has select privilege
+ if ( searchPublicOnly )
+ sql += " and pg_namespace.nspname = 'public'";
+ QgsDebugMsg( "sql: " + sql );
+ result = PQexec( pg, sql.toUtf8() );
+ if ( PQresultStatus( result ) != PGRES_TUPLES_OK )
+ QMessageBox::warning( this,
+ tr( "Accessible tables could not be determined" ),
+ tr( "Database connection was successful, but the accessible tables could not be determined.\n\n"
+ "The error message from the database was:\n%1\n" )
+ .arg( QString::fromUtf8( PQresultErrorMessage( result ) ) ) );
+ if ( nColumns == 0 )
+ nColumns = -1;
+ else if ( PQntuples( result ) > 0 )
+ for ( int i = 0; i < PQntuples( result ); i++ )
+ QString table = QString::fromUtf8( PQgetvalue( result, i, 0 ) ); // relname
+ QString schema = QString::fromUtf8( PQgetvalue( result, i, 1 ) ); // nspname
+ QString relkind = QString::fromUtf8( PQgetvalue( result, i, 2 ) ); // relation kind
+ QgsDebugMsg( QString( "%1.%2: %3" ).arg( schema ).arg( table ).arg( relkind ) );
+ mTableModel.addTableEntry( tr( "No geometry" ), schema, table, QString::null, relkind == "v" ? pkCandidates( pg, schema, table ) : QStringList(), "" );
+ nColumns++;
+ PQclear( result );
+ result = 0;
Modified: trunk/qgis/src/app/postgres/qgspgsourceselect.h
--- trunk/qgis/src/app/postgres/qgspgsourceselect.h 2010-09-18 15:31:31 UTC (rev 14247)
+++ trunk/qgis/src/app/postgres/qgspgsourceselect.h 2010-09-18 18:20:24 UTC (rev 14248)
@@ -155,7 +155,7 @@
typedef QList<geomPair> geomCol;
/**Inserts information about the spatial tables into mTableModel*/
- bool getTableInfo( PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly );
+ bool getTableInfo( PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly, bool allowGeometrylessTables );
/** get primary key candidates (all int4 columns) */
QStringList pkCandidates( PGconn *pg, QString schemaName, QString viewName );
Modified: trunk/qgis/src/core/qgsdatasourceuri.cpp
--- trunk/qgis/src/core/qgsdatasourceuri.cpp 2010-09-18 15:31:31 UTC (rev 14247)
+++ trunk/qgis/src/core/qgsdatasourceuri.cpp 2010-09-18 18:20:24 UTC (rev 14248)
@@ -103,6 +103,10 @@
i++;
+ else
+ mGeometryColumn = QString::null;
else if ( pname == "key" )
@@ -439,9 +443,9 @@
theUri += QString( " estimatedmetadata=true" );
- theUri += QString( " table=%1 (%2) sql=%3" )
+ theUri += QString( " table=%1%2 sql=%3" )
.arg( quotedTablename() )
- .arg( mGeometryColumn )
+ .arg( mGeometryColumn.isNull() ? QString() : QString( " (%1)" ).arg( mGeometryColumn ) )
.arg( mSql );
return theUri;
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2010-09-18 15:31:31 UTC (rev 14247)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2010-09-18 18:20:24 UTC (rev 14248)
@@ -124,7 +124,7 @@
setCoordinateSystem();
QSettings settings;
- if ( settings.value( "/qgis/use_symbology_ng", false ).toBool() )
+ if ( settings.value( "/qgis/use_symbology_ng", false ).toBool() && geometryType() != QGis::NoGeometry )
// using symbology-ng!
setUsingRendererV2( true );
@@ -139,7 +139,7 @@
// if the default style failed to load or was disabled use some very basic defaults
- if ( !defaultLoadedFlag )
+ if ( !defaultLoadedFlag && geometryType() != QGis::NoGeometry )
// add single symbol renderer
if ( mUsingRendererV2 )
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-09-18 15:31:31 UTC (rev 14247)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-09-18 18:20:24 UTC (rev 14248)
@@ -72,7 +72,7 @@
mUri = QgsDataSourceURI( uri );
- /* populate members from the uri structure */
+ // populate members from the uri structure
mSchemaName = mUri.schema();
mTableName = mUri.table();
geometryColumn = mUri.geometryColumn();
@@ -390,6 +390,11 @@
bool fetchGeometry,
QString whereClause )
+ if ( fetchGeometry && geometryColumn.isNull() )
+ return false;
try
QString query = QString( "select %1" ).arg( quotedIdentifier( primaryKey ) );
@@ -548,7 +553,7 @@
QString whereClause;
- if ( !rect.isEmpty() )
+ if ( !rect.isEmpty() && !geometryColumn.isNull() )
if ( isGeography )
@@ -983,10 +988,16 @@
sql = QString( "SELECT "
"has_table_privilege(%1,'DELETE'),"
"has_any_column_privilege(%1,'UPDATE'),"
- "has_column_privilege(%1,%2,'UPDATE'),"
+ "%2"
"has_table_privilege(%1,'INSERT'),"
"current_schema()" )
- .arg( quotedValue( mQuery ) ).arg( quotedValue( geometryColumn ) );
+ .arg( quotedValue( mQuery ) )
+ .arg( geometryColumn.isNull()
+ ? QString( "" )
+ : QString( "has_column_privilege(%1,%2,'UPDATE')," )
+ .arg( quotedValue( geometryColumn ) )
else
@@ -2254,18 +2265,28 @@
connectionRW->PQexecNR( "BEGIN" );
// Prepare the INSERT statement
- QString insert = QString( "INSERT INTO %1(%2" )
- .arg( mQuery )
- .arg( quotedIdentifier( geometryColumn ) ),
- values = QString( ") VALUES (GeomFromWKB($1%1,%2)" )
- .arg( connectionRW->useWkbHex() ? "" : "::bytea" )
- .arg( srid );
+ QString insert = QString( "INSERT INTO %1(" ).arg( mQuery );
+ QString values;
+ QString delim = ",";
+ if ( !geometryColumn.isNull() )
+ insert += quotedIdentifier( geometryColumn );
+ values = QString( ") VALUES (GeomFromWKB($1%1,%2)" )
+ .arg( connectionRW->useWkbHex() ? "" : "::bytea" )
+ .arg( srid );
+ delim = ",";
+ else
+ delim = "";
int offset;
if ( primaryKeyType != "tid" && primaryKeyType != "oid" )
- insert += "," + quotedIdentifier( primaryKey );
- values += ",$2";
+ insert += delim + quotedIdentifier( primaryKey );
+ values += delim + "$2";
offset = 3;
else
@@ -2306,7 +2327,7 @@
break;
- insert += "," + quotedIdentifier( fieldname );
+ insert += delim + quotedIdentifier( fieldname );
QString defVal = defaultValue( it.key() ).toString();
@@ -2316,24 +2337,24 @@
if ( defVal.isNull() )
- values += ",NULL";
+ values += delim + "NULL";
else
- values += "," + defVal;
+ values += delim + defVal;
else if ( fit->typeName() == "geometry" )
- values += QString( ",geomfromewkt(%1)" ).arg( quotedValue( it->toString() ) );
+ values += QString( "%1geomfromewkt(%2)" ).arg( delim ).arg( quotedValue( it->toString() ) );
else if ( fit->typeName() == "geography" )
- values += QString( ",st_geographyfromewkt(%1)" ).arg( quotedValue( it->toString() ) );
+ values += QString( "%1st_geographyfromewkt(%2)" ).arg( delim ).arg( quotedValue( it->toString() ) );
else
- values += "," + quotedValue( it->toString() );
+ values += delim + quotedValue( it->toString() );
else
@@ -2341,19 +2362,21 @@
// value is not unique => add parameter
- values += QString( ",geomfromewkt($%1)" ).arg( defaultValues.size() + offset );
+ values += QString( "%1geomfromewkt($%2)" ).arg( delim ).arg( defaultValues.size() + offset );
- values += QString( ",st_geographyfromewkt($%1)" ).arg( defaultValues.size() + offset );
+ values += QString( "%1st_geographyfromewkt($%2)" ).arg( delim ).arg( defaultValues.size() + offset );
else
- values += QString( ",$%1" ).arg( defaultValues.size() + offset );
+ values += QString( "%1$%2" ).arg( delim ).arg( defaultValues.size() + offset );
defaultValues.append( defVal );
fieldId.append( it.key() );
+ delim = ",";
insert += values + ")";
@@ -2656,7 +2679,7 @@
QgsDebugMsg( "entering." );
- if ( isQuery )
+ if ( isQuery || geometryColumn.isNull() )
return false;
if ( !connectRW() )
@@ -2811,6 +2834,9 @@
QgsRectangle QgsPostgresProvider::extent()
+ if ( geometryColumn.isNull() )
+ return QgsRectangle();
if ( isGeography )
return QgsRectangle( -180.0, -90.0, 180.0, 90.0 );
@@ -2846,7 +2872,7 @@
// dateline extent() returns -180 to 180 (which appears right), but
// estimated_extent() returns eastern bound of data (>-180) and
// 180 degrees.
- if ( !ext.startsWith( "-180 ") && ext.contains( ",180 " ) )
+ if ( !ext.startsWith( "-180 " ) && ext.contains( ",180 " ) )
ext.clear();
@@ -2974,6 +3000,13 @@
bool QgsPostgresProvider::getGeometryDetails()
+ geomType = QGis::WKBNoGeometry;
+ valid = true;
+ return true;
QString fType( "" );
srid = "";
valid = false;
Modified: trunk/qgis/src/ui/qgspgnewconnectionbase.ui
--- trunk/qgis/src/ui/qgspgnewconnectionbase.ui 2010-09-18 15:31:31 UTC (rev 14247)
+++ trunk/qgis/src/ui/qgspgnewconnectionbase.ui 2010-09-18 18:20:24 UTC (rev 14248)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>323</width>
- <height>384</height>
+ <width>352</width>
+ <height>413</height>
</rect>
</property>
<property name="sizePolicy">
@@ -228,7 +228,7 @@
</item>
</layout>
</item>
- <item row="4" column="0">
+ <item row="5" column="0">
<widget class="QCheckBox" name="cb_useEstimatedMetadata">
<property name="toolTip">
<string>Use estimated table statistics for the layer metadata.</string>
@@ -249,6 +249,16 @@
</property>
</widget>
</item>
+ <item row="4" column="0">
+ <widget class="QCheckBox" name="cb_allowGeometrylessTables">
+ <property name="text">
+ <string>Allow geometryless tables</string>
+ </property>
+ <property name="checked">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
