[QGIS Commit] r14283 - in trunk/qgis: python/core src/app
src/app/attributetable src/core
svn_qgis at osgeo.org
Sat Sep 25 16:09:20 EDT 2010
Author: jef
Date: 2010-09-25 20:09:20 +0000 (Sat, 25 Sep 2010)
New Revision: 14283
Added:
trunk/qgis/src/app/qgsfeatureaction.cpp
trunk/qgis/src/app/qgsfeatureaction.h
trunk/qgis/python/core/qgsattributeaction.sip
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
trunk/qgis/src/app/qgsidentifyresults.cpp
trunk/qgis/src/app/qgsidentifyresults.h
trunk/qgis/src/app/qgsmaptoolidentify.cpp
trunk/qgis/src/core/qgsattributeaction.cpp
trunk/qgis/src/core/qgsattributeaction.h
trunk/qgis/src/core/qgsfeature.cpp
trunk/qgis/src/core/qgsvectorlayer.cpp
allow attribute and alias names in actions
Modified: trunk/qgis/python/core/qgsattributeaction.sip
--- trunk/qgis/python/core/qgsattributeaction.sip 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/python/core/qgsattributeaction.sip 2010-09-25 20:09:20 UTC (rev 14283)
@@ -37,7 +37,7 @@
#include "qgsattributeaction.h"
%End
public:
- QgsAttributeAction();
+ QgsAttributeAction( QgsVectorLayer * );
//! Destructor
virtual ~QgsAttributeAction();
@@ -53,16 +53,17 @@
// index into values which indicates which value in the values vector
// is to be used if the action has a default placeholder.
// @note added to python API in 1.6 (without executePython parameter)
- void doAction( int index, const QList< QPair<QString, QString> > &values,
+ void doAction( int index,
+ const QMap<int, QVariant> &values,
int defaultValueIndex = 0 );
//! Removes all actions
void clearActions();
- //! Expands the given action, replacing all %'s with the value as
- // given.
- static QString expandAction( QString action, const QList< QPair<QString, QString> > &values,
- uint defaultValueIndex );
+ //! Expands the given action, replacing all %'s with the value as given.
+ QString expandAction( QString action,
+ uint defaultValueIndex );
//! Writes the actions out in XML format
bool writeXML( QDomNode& layer_node, QDomDocument& doc ) const;
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/app/CMakeLists.txt 2010-09-25 20:09:20 UTC (rev 14283)
@@ -26,6 +26,7 @@
qgsgraduatedsymboldialog.cpp
qgshelpviewer.cpp
+ qgsfeatureaction.cpp
qgslabeldialog.cpp
qgslabelengineconfigdialog.cpp
qgslabelinggui.cpp
@@ -155,6 +156,7 @@
qgsgraduatedsymboldialog.h
qgshelpviewer.h
+ qgsfeatureaction.h
qgslabeldialog.h
qgsmanageconnectionsdialog.h
qgsmaptoolidentify.h
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2010-09-25 20:09:20 UTC (rev 14283)
@@ -499,14 +499,11 @@
void QgsAttributeTableModel::executeAction( int action, const QModelIndex &idx ) const
- QList< QPair<QString, QString> > attributes;
+ QgsAttributeMap attributes;
for ( int i = 0; i < mAttributes.size(); i++ )
- attributes << QPair<QString, QString>(
- mLayer->pendingFields()[ mAttributes[i] ].name(),
- data( index( idx.row(), i ), Qt::EditRole ).toString()
+ attributes.insert( i, data( index( idx.row(), i ), Qt::EditRole ) );
mLayer->actions()->doAction( action, attributes, fieldIdx( idx.column() ) );
Added: trunk/qgis/src/app/qgsfeatureaction.cpp
--- trunk/qgis/src/app/qgsfeatureaction.cpp (rev 0)
+++ trunk/qgis/src/app/qgsfeatureaction.cpp 2010-09-25 20:09:20 UTC (rev 14283)
@@ -0,0 +1,42 @@
+ qgsfeatureaction.cpp - description
+ begin : 2010-09-20
+ copyright : (C) 2010 by Jürgen E. Fischer
+ email : jef at norbit dot de
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+/* $Id$ */
+#include "qgsfeatureaction.h"
+#include "qgsvectorlayer.h"
+#include "qgsidentifyresults.h"
+QgsFeatureAction::QgsFeatureAction( const QString &name, QgsIdentifyResults *results, QgsVectorLayer *vl, int action, QTreeWidgetItem *featItem )
+ : QAction( name, results )
+ , mLayer( vl )
+ , mAction( action )
+ results->retrieveAttributes( featItem, mAttributes, mIdx );
+QgsFeatureAction::QgsFeatureAction( const QString &name, QgsFeature &f, QgsVectorLayer *layer, int action, QObject *parent )
+ : QAction( name, parent )
+ , mLayer( layer )
+ mAttributes = f.attributeMap();
+void QgsFeatureAction::execute()
+ mLayer->actions()->doAction( mAction, mAttributes, mIdx );
Added: trunk/qgis/src/app/qgsfeatureaction.h
--- trunk/qgis/src/app/qgsfeatureaction.h (rev 0)
+++ trunk/qgis/src/app/qgsfeatureaction.h 2010-09-25 20:09:20 UTC (rev 14283)
@@ -0,0 +1,49 @@
+ qgsfeatureaction.h - description
+/* $Id$ */
+#ifndef QGSFEATUREACTION_H
+#define QGSFEATUREACTION_H
+#include "qgsfeature.h"
+#include <QList>
+#include <QPair>
+#include <QAction>
+class QgsIdentifyResults;
+class QgsVectorLayer;
+class QTreeWidgetItem;
+class QgsFeatureAction : public QAction
+ Q_OBJECT
+ public:
+ QgsFeatureAction( const QString &name, QgsFeature &f, QgsVectorLayer *vl, int action, QObject *parent );
+ QgsFeatureAction( const QString &name, QgsIdentifyResults *results, QgsVectorLayer *vl, int action, QTreeWidgetItem *featItem );
+ public slots:
+ void execute();
+ private:
+ QgsVectorLayer *mLayer;
+ int mAction;
+ int mIdx;
+ QgsAttributeMap mAttributes;
+#endif
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp 2010-09-25 20:09:20 UTC (rev 14283)
@@ -28,6 +28,7 @@
#include "qgsattributedialog.h"
#include "qgsmapcanvas.h"
#include <QCloseEvent>
#include <QLabel>
@@ -44,20 +45,6 @@
#include "qgslogger.h"
-QgsFeatureAction::QgsFeatureAction( const QString &name, QgsIdentifyResults *results, QgsVectorLayer *vl, int action, QTreeWidgetItem *featItem )
- : QAction( name, results )
- , mLayer( vl )
- , mAction( action )
- results->retrieveAttributes( featItem, mAttributes, mIdx );
-void QgsFeatureAction::execute()
- mLayer->actions()->doAction( mAction, mAttributes, mIdx );
class QgsIdentifyResultsDock : public QDockWidget
public:
@@ -82,9 +69,9 @@
// actions (if any) [userrole: "actions"]
// edit [userrole: "edit"]
// action [userrole: "action", idx]
-// name value
-// name value
-// name value
+// displayname [userroles: fieldIdx, original name] displayvalue [userrole: original value]
// feature
// derived attributes (if any)
// name value
@@ -145,61 +132,74 @@
return 0;
-void QgsIdentifyResults::addFeature( QgsMapLayer *layer, int fid,
- QString displayField, QString displayValue,
- const QMap<QString, QString> &attributes,
+void QgsIdentifyResults::addFeature( QgsVectorLayer *vlayer, int fid,
+ const QgsAttributeMap &attributes,
const QMap<QString, QString> &derivedAttributes )
- QTreeWidgetItem *layItem = layerItem( layer );
- QgsVectorLayer *vlayer = qobject_cast<QgsVectorLayer *>( layer );
- QgsRasterLayer *rlayer = qobject_cast<QgsRasterLayer *>( layer );
+ QTreeWidgetItem *layItem = layerItem( vlayer );
if ( layItem == 0 )
- layItem = new QTreeWidgetItem( QStringList() << QString::number( lstResults->topLevelItemCount() ) << layer->name() );
- layItem->setData( 0, Qt::UserRole, QVariant::fromValue( qobject_cast<QObject *>( layer ) ) );
+ layItem = new QTreeWidgetItem( QStringList() << QString::number( lstResults->topLevelItemCount() ) << vlayer->name() );
+ layItem->setData( 0, Qt::UserRole, QVariant::fromValue( qobject_cast<QObject *>( vlayer ) ) );
lstResults->addTopLevelItem( layItem );
- if ( vlayer )
- connect( vlayer, SIGNAL( layerDeleted() ), this, SLOT( layerDestroyed() ) );
- connect( vlayer, SIGNAL( layerCrsChanged() ), this, SLOT( layerDestroyed() ) );
- connect( vlayer, SIGNAL( featureDeleted( int ) ), this, SLOT( featureDeleted( int ) ) );
- connect( vlayer, SIGNAL( attributeValueChanged( int, int, const QVariant & ) ), this, SLOT( attributeValueChanged( int, int, const QVariant & ) ) );
- connect( vlayer, SIGNAL( editingStarted() ), this, SLOT( editingToggled() ) );
- connect( vlayer, SIGNAL( editingStopped() ), this, SLOT( editingToggled() ) );
- else
- connect( layer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
- connect( layer, SIGNAL( layerCrsChanged() ), this, SLOT( layerDestroyed() ) );
+ connect( vlayer, SIGNAL( layerDeleted() ), this, SLOT( layerDestroyed() ) );
+ connect( vlayer, SIGNAL( layerCrsChanged() ), this, SLOT( layerDestroyed() ) );
+ connect( vlayer, SIGNAL( featureDeleted( int ) ), this, SLOT( featureDeleted( int ) ) );
+ connect( vlayer, SIGNAL( attributeValueChanged( int, int, const QVariant & ) ), this, SLOT( attributeValueChanged( int, int, const QVariant & ) ) );
+ connect( vlayer, SIGNAL( editingStarted() ), this, SLOT( editingToggled() ) );
+ connect( vlayer, SIGNAL( editingStopped() ), this, SLOT( editingToggled() ) );
- QTreeWidgetItem *featItem = new QTreeWidgetItem( QStringList() << displayField << displayValue );
+ QTreeWidgetItem *featItem = new QTreeWidgetItem;
featItem->setData( 0, Qt::UserRole, fid );
layItem->addChild( featItem );
- if ( !rlayer || rlayer->providerKey() != "wms" )
+ for ( QgsAttributeMap::const_iterator it = attributes.begin(); it != attributes.end(); it++ )
- for ( QMap<QString, QString>::const_iterator it = attributes.begin(); it != attributes.end(); it++ )
+ QTreeWidgetItem *attrItem = new QTreeWidgetItem( QStringList() << QString::number( it.key() ) << it.value().toString() );
+ const QgsFieldMap &fields = vlayer->pendingFields();
+ QgsFieldMap::const_iterator fit = fields.find( it.key() );
+ if ( fit == fields.constEnd() )
- QTreeWidgetItem *attrItem = new QTreeWidgetItem( QStringList() << it.key() << it.value() );
- if ( vlayer )
- attrItem->setData( 0, Qt::UserRole, vlayer->fieldNameIndex( it.key() ) );
- featItem->addChild( attrItem );
+ delete attrItem;
+ continue;
- else
- QTreeWidgetItem *attrItem = new QTreeWidgetItem( QStringList() << attributes.begin().key() << "" );
+ attrItem->setData( 0, Qt::DisplayRole, vlayer->attributeDisplayName( it.key() ) );
+ attrItem->setData( 0, Qt::UserRole, fit->name() );
+ attrItem->setData( 0, Qt::UserRole + 1, it.key() );
+ QVariant value = it.value();
+ attrItem->setData( 1, Qt::UserRole, value );
+ switch ( vlayer->editType( it.key() ) )
+ case QgsVectorLayer::Hidden:
+ // skip the item
+ delete attrItem;
+ continue;
+ case QgsVectorLayer::ValueMap:
+ value = vlayer->valueMap( it.key() ).key( it->toString(), QString( "(%1)" ).arg( it->toString() ) );
+ break;
+ default:
+ break;
+ attrItem->setData( 1, Qt::DisplayRole, value );
+ if ( fit->name() == vlayer->displayField() )
+ featItem->setText( 0, attrItem->text( 0 ) );
+ featItem->setText( 1, attrItem->text( 1 ) );
- QTextBrowser *tb = new QTextBrowser( attrItem->treeWidget() );
- tb->setHtml( attributes.begin().value() );
- attrItem->treeWidget()->setItemWidget( attrItem, 1, tb );
if ( derivedAttributes.size() >= 0 )
@@ -214,33 +214,81 @@
- if ( vlayer )
+ QTreeWidgetItem *actionItem = new QTreeWidgetItem( QStringList() << tr( "(Actions)" ) );
+ actionItem->setData( 0, Qt::UserRole, "actions" );
+ featItem->addChild( actionItem );
+ QTreeWidgetItem *editItem = new QTreeWidgetItem( QStringList() << "" << ( vlayer->isEditable() ? tr( "Edit feature form" ) : tr( "View feature form" ) ) );
+ editItem->setIcon( 0, QgisApp::getThemeIcon( vlayer->isEditable() ? "/mIconEditable.png" : "/mIconEditable.png" ) );
+ editItem->setData( 0, Qt::UserRole, "edit" );
+ actionItem->addChild( editItem );
+ for ( int i = 0; i < vlayer->actions()->size(); i++ )
- QTreeWidgetItem *actionItem = new QTreeWidgetItem( QStringList() << tr( "(Actions)" ) );
- actionItem->setData( 0, Qt::UserRole, "actions" );
- featItem->addChild( actionItem );
+ const QgsAction &action = vlayer->actions()->at( i );
- QTreeWidgetItem *editItem = new QTreeWidgetItem( QStringList() << "" << ( vlayer->isEditable() ? tr( "Edit feature form" ) : tr( "View feature form" ) ) );
- editItem->setIcon( 0, QgisApp::getThemeIcon( vlayer->isEditable() ? "/mIconEditable.png" : "/mIconEditable.png" ) );
- editItem->setData( 0, Qt::UserRole, "edit" );
- actionItem->addChild( editItem );
+ if ( !action.runable() )
+ continue;
- for ( int i = 0; i < vlayer->actions()->size(); i++ )
+ QTreeWidgetItem *twi = new QTreeWidgetItem( QStringList() << "" << action.name() );
+ twi->setIcon( 0, QgisApp::getThemeIcon( "/mAction.png" ) );
+ twi->setData( 0, Qt::UserRole, "action" );
+ twi->setData( 0, Qt::UserRole + 1, QVariant::fromValue( i ) );
+ actionItem->addChild( twi );
+ highlightFeature( featItem );
+void QgsIdentifyResults::addFeature( QgsRasterLayer *layer,
+ QString label,
+ const QMap<QString, QString> &attributes,
+ const QMap<QString, QString> &derivedAttributes )
+ QTreeWidgetItem *layItem = layerItem( layer );
+ if ( layItem == 0 )
+ layItem = new QTreeWidgetItem( QStringList() << QString::number( lstResults->topLevelItemCount() ) << layer->name() );
+ layItem->setData( 0, Qt::UserRole, QVariant::fromValue( qobject_cast<QObject *>( layer ) ) );
+ lstResults->addTopLevelItem( layItem );
+ connect( layer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
+ connect( layer, SIGNAL( layerCrsChanged() ), this, SLOT( layerDestroyed() ) );
+ QTreeWidgetItem *featItem = new QTreeWidgetItem( QStringList() << label << "" );
+ featItem->setData( 0, Qt::UserRole, -1 );
+ layItem->addChild( featItem );
+ if ( layer && layer->providerKey() == "wms" )
+ QTreeWidgetItem *attrItem = new QTreeWidgetItem( QStringList() << attributes.begin().key() << "" );
+ featItem->addChild( attrItem );
+ QTextBrowser *tb = new QTextBrowser( attrItem->treeWidget() );
+ tb->setHtml( attributes.begin().value() );
+ attrItem->treeWidget()->setItemWidget( attrItem, 1, tb );
+ else
+ for ( QMap<QString, QString>::const_iterator it = attributes.begin(); it != attributes.end(); it++ )
- const QgsAction &action = vlayer->actions()->at( i );
+ featItem->addChild( new QTreeWidgetItem( QStringList() << it.key() << it.value() ) );
- if ( !action.runable() )
- continue;
+ if ( derivedAttributes.size() >= 0 )
+ QTreeWidgetItem *derivedItem = new QTreeWidgetItem( QStringList() << tr( "(Derived)" ) );
+ derivedItem->setData( 0, Qt::UserRole, "derived" );
+ featItem->addChild( derivedItem );
- QTreeWidgetItem *twi = new QTreeWidgetItem( QStringList() << "" << action.name() );
- twi->setIcon( 0, QgisApp::getThemeIcon( "/mAction.png" ) );
- twi->setData( 0, Qt::UserRole, "action" );
- twi->setData( 0, Qt::UserRole + 1, QVariant::fromValue( i ) );
- actionItem->addChild( twi );
+ for ( QMap< QString, QString>::const_iterator it = derivedAttributes.begin(); it != derivedAttributes.end(); it++ )
+ derivedItem->addChild( new QTreeWidgetItem( QStringList() << it.key() << it.value() ) );
- highlightFeature( featItem );
void QgsIdentifyResults::editingToggled()
@@ -484,7 +532,7 @@
void QgsIdentifyResults::doAction( QTreeWidgetItem *item, int action )
int idx;
QTreeWidgetItem *featItem = retrieveAttributes( item, attributes, idx );
if ( !featItem )
return;
@@ -570,7 +618,7 @@
-QTreeWidgetItem *QgsIdentifyResults::retrieveAttributes( QTreeWidgetItem *item, QList< QPair<QString, QString> > &attributes, int &idx )
+QTreeWidgetItem *QgsIdentifyResults::retrieveAttributes( QTreeWidgetItem *item, QgsAttributeMap &attributes, int &idx )
QTreeWidgetItem *featItem = featureItem( item );
if ( !featItem )
@@ -585,8 +633,8 @@
if ( item->childCount() > 0 )
continue;
if ( item == lstResults->currentItem() )
- idx = attributes.size();
- attributes << QPair<QString, QString>( item->data( 0, Qt::DisplayRole ).toString(), item->data( 1, Qt::DisplayRole ).toString() );
+ idx = item->data( 0, Qt::UserRole + 1 ).toInt();
+ attributes.insert( item->data( 0, Qt::UserRole + 1 ).toInt(), item->data( 1, Qt::DisplayRole ) );
return featItem;
@@ -939,13 +987,23 @@
QClipboard *clipboard = QApplication::clipboard();
QString text;
+ QgsVectorLayer *vlayer = vectorLayer( lstResults->currentItem() );
+ if ( !vlayer )
+ return;
int idx;
retrieveAttributes( lstResults->currentItem(), attributes, idx );
- for ( QList< QPair<QString, QString> >::iterator it = attributes.begin(); it != attributes.end(); it++ )
- text += QString( "%1: %2\n" ).arg( it->first ).arg( it->second );
+ continue;
+ text += QString( "%1: %2\n" ).arg( fit->name() ).arg( it.value().toString() );
QgsDebugMsg( QString( "set clipboard: %1" ).arg( text ) );
Modified: trunk/qgis/src/app/qgsidentifyresults.h
--- trunk/qgis/src/app/qgsidentifyresults.h 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/app/qgsidentifyresults.h 2010-09-25 20:09:20 UTC (rev 14283)
@@ -22,6 +22,7 @@
#include "ui_qgsidentifyresultsbase.h"
#include "qgscontexthelp.h"
#include <QWidget>
#include <QList>
@@ -31,8 +32,8 @@
class QAction;
class QMenu;
-class QgsMapLayer;
+class QgsRasterLayer;
class QgsRubberBand;
class QgsMapCanvas;
class QDockWidget;
@@ -53,9 +54,13 @@
~QgsIdentifyResults();
- /** Add add feature */
- void addFeature( QgsMapLayer *layer, int fid,
+ /** Add add feature from vector layer */
+ void addFeature( QgsVectorLayer *layer, int fid,
+ const QMap< QString, QString > &derivedAttributes );
+ /** Add add feature from other layer */
+ void addFeature( QgsRasterLayer *layer, QString label,
const QMap< QString, QString > &attributes,
@@ -104,7 +109,7 @@
/* Item in tree was clicked */
void itemClicked( QTreeWidgetItem *lvi, int column );
- QTreeWidgetItem *retrieveAttributes( QTreeWidgetItem *item, QList< QPair<QString, QString> > &attributes, int ¤tIdx );
+ QTreeWidgetItem *retrieveAttributes( QTreeWidgetItem *item, QgsAttributeMap &attributes, int ¤tIdx );
void on_buttonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
@@ -132,21 +137,4 @@
QDockWidget *mDock;
-class QgsFeatureAction : public QAction
- Q_OBJECT
- public:
- QgsFeatureAction( const QString &name, QgsIdentifyResults *results, QgsVectorLayer *vl, int action, QTreeWidgetItem *featItem );
- public slots:
- void execute();
- private:
- QgsVectorLayer *mLayer;
- int mAction;
- int mIdx;
- QList< QPair<QString, QString> > mAttributes;
#endif
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp 2010-09-25 20:09:20 UTC (rev 14283)
@@ -209,7 +209,6 @@
identifyValue = QGis::DEFAULT_IDENTIFY_RADIUS;
int featureCount = 0;
- const QgsFieldMap& fields = layer->pendingFields();
// init distance/area calculator
QgsDistanceArea calc;
@@ -254,38 +253,8 @@
featureCount++;
int fid = f_it->id();
- QString displayField, displayValue;
- QMap<QString, QString> attributes, derivedAttributes;
+ QMap<QString, QString> derivedAttributes;
- const QgsAttributeMap& attr = f_it->attributeMap();
- for ( QgsAttributeMap::const_iterator it = attr.begin(); it != attr.end(); ++it )
- QString attributeName = layer->attributeDisplayName( it.key() );
- QString attributeValue = it->isNull() ? "NULL" : it->toString();
- switch ( layer->editType( it.key() ) )
- case QgsVectorLayer::Hidden:
- continue;
- case QgsVectorLayer::ValueMap:
- attributeValue = layer->valueMap( it.key() ).key( it->toString(), QString( "(%1)" ).arg( it->toString() ) );
- break;
- default:
- break;
- if ( fields[it.key()].name() == layer->displayField() )
- displayField = attributeName;
- displayValue = attributeValue;
- attributes.insert( attributeName, attributeValue );
// Calculate derived attributes and insert:
// measure distance or area depending on geometry type
if ( layer->geometryType() == QGis::Line )
@@ -331,7 +300,7 @@
derivedAttributes.insert( tr( "feature id" ), fid < 0 ? tr( "new feature" ) : QString::number( fid ) );
- results()->addFeature( layer, fid, displayField, displayValue, attributes, derivedAttributes );
+ results()->addFeature( layer, fid, f_it->attributeMap(), derivedAttributes );
QgsDebugMsg( "Feature count on identify: " + QString::number( featureCount ) );
@@ -392,7 +361,7 @@
if ( res )
derivedAttributes.insert( tr( "(clicked coordinate)" ), idPoint.toString() );
- results()->addFeature( layer, -1, type, "", attributes, derivedAttributes );
+ results()->addFeature( layer, type, attributes, derivedAttributes );
return res;
Modified: trunk/qgis/src/core/qgsattributeaction.cpp
--- trunk/qgis/src/core/qgsattributeaction.cpp 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/core/qgsattributeaction.cpp 2010-09-25 20:09:20 UTC (rev 14283)
@@ -30,6 +30,7 @@
#include "qgsrunprocess.h"
static const char * const ident_ = "$Id$";
@@ -38,7 +39,7 @@
mActions << QgsAction( type, name, action, capture );
-void QgsAttributeAction::doAction( int index, const QList< QPair<QString, QString> > &values,
+void QgsAttributeAction::doAction( int index, const QgsAttributeMap &attributes,
int defaultValueIndex, void ( *executePython )( const QString & ) )
if ( index < 0 || index >= size() )
@@ -61,7 +62,7 @@
// The QgsRunProcess instance created by this static function
// deletes itself when no longer needed.
- QString expandedAction = expandAction( action.action(), values, defaultValueIndex );
+ QString expandedAction = expandAction( action.action(), attributes, defaultValueIndex );
if ( action.type() == QgsAction::GenericPython )
if ( executePython )
@@ -79,7 +80,7 @@
-QString QgsAttributeAction::expandAction( QString action, const QList< QPair<QString, QString> > &values,
+QString QgsAttributeAction::expandAction( QString action, const QgsAttributeMap &attributes,
uint clickedOnValue )
// This function currently replaces all %% characters in the action
@@ -98,19 +99,29 @@
// for the actual substitutions.
QString expanded_action;
- if ( clickedOnValue >= 0 && clickedOnValue < static_cast<unsigned int>( values.size() ) )
- expanded_action = action.replace( "%%", values[clickedOnValue].second );
+ if ( clickedOnValue >= 0 && attributes.contains( clickedOnValue ) )
+ expanded_action = action.replace( "%%", attributes[clickedOnValue].toString() );
else
expanded_action = action;
- for ( int i = 0; i < values.size(); ++i )
+ const QgsFieldMap &fields = mLayer->pendingFields();
+ continue;
// Check for a replace a quoted version and a non-quoted version.
- QString to_replace_1 = "[%" + values[i].first + "]";
- QString to_replace_2 = "%" + values[i].first;
+ QString to_replace_1 = "[%" + fit->name() + "]";
+ QString to_replace_2 = "%" + fit->name() + "%";
+ QString to_replace_3 = "%" + mLayer->attributeDisplayName( it.key() ) + "%";
+ QString to_replace_4 = "[%" + mLayer->attributeDisplayName( it.key() ) + "%]";
- expanded_action = expanded_action.replace( to_replace_1, values[i].second );
- expanded_action = expanded_action.replace( to_replace_2, values[i].second );
+ expanded_action = expanded_action.replace( to_replace_1, it.value().toString() );
+ expanded_action = expanded_action.replace( to_replace_2, it.value().toString() );
+ expanded_action = expanded_action.replace( to_replace_3, it.value().toString() );
+ expanded_action = expanded_action.replace( to_replace_4, it.value().toString() );
return expanded_action;
Modified: trunk/qgis/src/core/qgsattributeaction.h
--- trunk/qgis/src/core/qgsattributeaction.h 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/core/qgsattributeaction.h 2010-09-25 20:09:20 UTC (rev 14283)
@@ -27,12 +27,13 @@
#include <QString>
#include <QObject>
-#include <QList>
-#include <QPair>
+#include <qgsfeature.h>
class QDomNode;
class QDomDocument;
class QgsPythonUtils;
/** \ingroup core
* Utility class that encapsulates an action based on vector attributes.
@@ -95,7 +96,7 @@
public:
//! Constructor
- QgsAttributeAction() {}
+ QgsAttributeAction( QgsVectorLayer *layer ) : mLayer( layer ) {}
//! Destructor
virtual ~QgsAttributeAction() {}
@@ -111,16 +112,19 @@
// @note parameter executePython deprecated (and missing in python binding)
- int defaultValueIndex = 0, void ( *executePython )( const QString & ) = 0 );
+ int defaultValueIndex = 0,
+ void ( *executePython )( const QString & ) = 0 );
void clearActions() { mActions.clear(); }
// given.
@@ -136,6 +140,7 @@
private:
QList<QgsAction> mActions;
static void ( *smPythonExecute )( const QString & );
Modified: trunk/qgis/src/core/qgsfeature.cpp
--- trunk/qgis/src/core/qgsfeature.cpp 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/core/qgsfeature.cpp 2010-09-25 20:09:20 UTC (rev 14283)
@@ -23,24 +23,24 @@
QgsFeature::QgsFeature( int id, QString typeName )
- : mFid( id ),
- mGeometry( 0 ),
- mOwnsGeometry( 0 ),
- mValid( false ),
- mDirty( 0 ),
- mTypeName( typeName )
+ : mFid( id )
+ , mGeometry( 0 )
+ , mOwnsGeometry( 0 )
+ , mValid( false )
+ , mDirty( 0 )
+ , mTypeName( typeName )
// NOOP
QgsFeature::QgsFeature( QgsFeature const & rhs )
- : mFid( rhs.mFid ),
- mAttributes( rhs.mAttributes ),
- mGeometry( 0 ),
- mOwnsGeometry( false ),
- mValid( rhs.mValid ),
- mDirty( rhs.mDirty ),
- mTypeName( rhs.mTypeName )
+ : mFid( rhs.mFid )
+ , mAttributes( rhs.mAttributes )
+ , mGeometry( 0 )
+ , mOwnsGeometry( false )
+ , mValid( rhs.mValid )
+ , mDirty( rhs.mDirty )
+ , mTypeName( rhs.mTypeName )
// copy embedded geometry
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2010-09-25 17:24:49 UTC (rev 14282)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2010-09-25 20:09:20 UTC (rev 14283)
@@ -111,7 +111,7 @@
mVertexMarkerOnlyForSelection( false ),
mFetching( false )
- mActions = new QgsAttributeAction;
+ mActions = new QgsAttributeAction( this );
// if we're given a provider type, try to create and bind one to this layer
if ( ! mProviderKey.isEmpty() )
