[QGIS Commit] r14313 - in trunk/qgis: images/north_arrows
resources/context_help src/app src/app/attributetable
src/core src/core/composer src/core/raster
src/core/symbology-ng src/plugins/georeferencer
src/plugins/gps_importer src/python
svn_qgis at osgeo.org
Wed Sep 29 16:39:42 EDT 2010
Author: jef
Date: 2010-09-29 20:39:42 +0000 (Wed, 29 Sep 2010)
New Revision: 14313
trunk/qgis/images/north_arrows/CMakeLists.txt
trunk/qgis/resources/context_help/MapServerExport-es_ES
trunk/qgis/resources/context_help/QgsVectorLayerProperties-pt_BR
trunk/qgis/resources/context_help/QgsWMSSourceSelect-pt_BR
trunk/qgis/resources/context_help/eVisDatabaseConnectionGui-es_ES
trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/core/composer/qgscomposerlegend.cpp
trunk/qgis/src/core/qgsmaplayer.cpp
trunk/qgis/src/core/qgssearchtreenode.cpp
trunk/qgis/src/core/qgssearchtreenode.h
trunk/qgis/src/core/raster/qgscolorrampshader.h
trunk/qgis/src/core/raster/qgsrastershader.cpp
trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp
trunk/qgis/src/core/symbology-ng/qgsrulebasedrendererv2.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.h
trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.cpp
trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.cpp
trunk/qgis/src/python/qgspythonutilsimpl.cpp
automatic indentation update (r13658-r14312)
Modified: trunk/qgis/images/north_arrows/CMakeLists.txt
--- trunk/qgis/images/north_arrows/CMakeLists.txt 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/images/north_arrows/CMakeLists.txt 2010-09-29 20:39:42 UTC (rev 14313)
@@ -1,5 +1,5 @@
-FILE (GLOB PNGIMAGES *.png)
-INSTALL (FILES ${PNGIMAGES}
- DESTINATION ${QGIS_DATA_DIR}/images/north_arrows)
+FILE (GLOB PNGIMAGES *.png)
+INSTALL (FILES ${PNGIMAGES}
+ DESTINATION ${QGIS_DATA_DIR}/images/north_arrows)
Modified: trunk/qgis/resources/context_help/MapServerExport-es_ES
--- trunk/qgis/resources/context_help/MapServerExport-es_ES 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/resources/context_help/MapServerExport-es_ES 2010-09-29 20:39:42 UTC (rev 14313)
@@ -1,38 +1,38 @@
-<h3>Exportar un proyecto de QGIS a archivo de mapa de MapServer</h3>
-<p>
-Esta herramienta le permite exportar un proyecto guardado de QGIS a map de MapServer
-Sólo se necesitan el <b>Archivo de mapa</b> y el <b>archivo de proyecto de QGIS</b>.
-</p>
-Marque la casilla <label>Usar proyecto actual</label> o introduzca la ruta completa a
-el archivo del proyecto de QGIS (.qgs) que quiera exportar. Puede usar el botón de la
-derecha para buscar el archivo de proyecto de QGIS.
-<h4>Archivo de mapa</h4>
-<label>Archivo de mapa</label> Introduzca el nombre del archivo de mapa a crear. Puede
-usar el botón de la derecha para navegar hasta el directorio en que que quiera crear
-el archivo de mapa.
-<h4>Mapa</h4>
-Estos valores se escriben en el archivo de mapa en los lugares adecuados para establecer cosas
-tales como el tamaño de la imagen de salida, las unidades o el tipo de imagen.
-<dl>
- <dt><label>Nombre</label></dt>
- <dd>Un nombre para el mapa. Este nombre se antepone a todas las imágenes generadas por MapServer.</dd>
- <dt><label>Anchura</label></dt>
- <dd>Anchura de la imagen de salida en píxeles.</dd>
- <dt><label>Altura</label></dt>
- <dd>Altura de la imagen de salida en píxeles.</dd>
- <dt><label>Unidades</label></dt>
- <dd>Unidades de medida usadas para la salida.</dd>
- <dt><label>Imagen type</label></dt>
- <dd>Formato para la imagen de salida generada por MapServer</dd>
-</dl>
-<h4>Rutas</h4>
-<dl>
- <dt><label>Plantilla</label></dt>
- <dd>Ruta completa al archivo de plantilla de MapServer a usar con el archivo de mapa.</dd>
- <dt><label>Encabezado</label></dt>
- <dd>Ruta completa al archivo de encabezado de MapServer a usar con el archivo de mapa.</dd>
- <dt><label>Pie de página</label></dt>
- <dd>Ruta completa al archivo de pie de página de MapServer a usar con el archivo de mapa.</dd>
+<h3>Exportar un proyecto de QGIS a archivo de mapa de MapServer</h3>
+<p>
+Esta herramienta le permite exportar un proyecto guardado de QGIS a map de MapServer
+Sólo se necesitan el <b>Archivo de mapa</b> y el <b>archivo de proyecto de QGIS</b>.
+</p>
+Marque la casilla <label>Usar proyecto actual</label> o introduzca la ruta completa a
+el archivo del proyecto de QGIS (.qgs) que quiera exportar. Puede usar el botón de la
+derecha para buscar el archivo de proyecto de QGIS.
+<h4>Archivo de mapa</h4>
+<label>Archivo de mapa</label> Introduzca el nombre del archivo de mapa a crear. Puede
+usar el botón de la derecha para navegar hasta el directorio en que que quiera crear
+el archivo de mapa.
+<h4>Mapa</h4>
+Estos valores se escriben en el archivo de mapa en los lugares adecuados para establecer cosas
+tales como el tamaño de la imagen de salida, las unidades o el tipo de imagen.
+<dl>
+ <dt><label>Nombre</label></dt>
+ <dd>Un nombre para el mapa. Este nombre se antepone a todas las imágenes generadas por MapServer.</dd>
+ <dt><label>Anchura</label></dt>
+ <dd>Anchura de la imagen de salida en píxeles.</dd>
+ <dt><label>Altura</label></dt>
+ <dd>Altura de la imagen de salida en píxeles.</dd>
+ <dt><label>Unidades</label></dt>
+ <dd>Unidades de medida usadas para la salida.</dd>
+ <dt><label>Imagen type</label></dt>
+ <dd>Formato para la imagen de salida generada por MapServer</dd>
+</dl>
+<h4>Rutas</h4>
+<dl>
+ <dt><label>Plantilla</label></dt>
+ <dd>Ruta completa al archivo de plantilla de MapServer a usar con el archivo de mapa.</dd>
+ <dt><label>Encabezado</label></dt>
+ <dd>Ruta completa al archivo de encabezado de MapServer a usar con el archivo de mapa.</dd>
+ <dt><label>Pie de página</label></dt>
+ <dd>Ruta completa al archivo de pie de página de MapServer a usar con el archivo de mapa.</dd>
Modified: trunk/qgis/resources/context_help/QgsVectorLayerProperties-pt_BR
--- trunk/qgis/resources/context_help/QgsVectorLayerProperties-pt_BR 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/resources/context_help/QgsVectorLayerProperties-pt_BR 2010-09-29 20:39:42 UTC (rev 14313)
@@ -1,77 +1,77 @@
-<h3>Propriedades da Camada Vetorial</h3>
-Este diálogo permite você trabalhar com propriedades e configurações de camadas vetoriais.
-<p>
-<a href="#symbology">Simbologia</a><br/>
-<a href="#labels">Rótulos</a><br/>
-<a href="#attributes">Atributos</a><br/>
-<a href="#general">Geral</a><br/>
-<a href="#metadata">Metadados</a><br/>
-<a href="#actions">Ações</a><br/>
-<a href="#diagram">Diagrama de Sobreposição</a><br/>
-<a name="symbology">
-<h4>Symbology</h4>
-</a>
-Para alterar a simbologia de uma camada, basta clicar duas vezes sobre a entrada da legenda e o diálogo de vetor <label>Layer Properties</label> aparecerá.<p>
+<h3>Propriedades da Camada Vetorial</h3>
+Este diálogo permite você trabalhar com propriedades e configurações de camadas vetoriais.
+<p>
+<a href="#symbology">Simbologia</a><br/>
+<a href="#labels">Rótulos</a><br/>
+<a href="#attributes">Atributos</a><br/>
+<a href="#general">Geral</a><br/>
+<a href="#metadata">Metadados</a><br/>
+<a href="#actions">Ações</a><br/>
+<a href="#diagram">Diagrama de Sobreposição</a><br/>
+<a name="symbology">
+<h4>Symbology</h4>
+</a>
+Para alterar a simbologia de uma camada, basta clicar duas vezes sobre a entrada da legenda e o diálogo de vetor <label>Layer Properties</label> aparecerá.<p>
Dentro deste diálogo você pode definir o estilo de sua camada de vetorial. Dependendo da opção de processamento selecionada, você tem a possibilidade de também classificar suas feições de mapa.
-<h5>Tipo de legenda</h5>
+<h5>Tipo de legenda</h5>
O QGIS suporta um número de renderizadores de simbologia para controlar como as características do vetor são exibidas. Atualmente, os renderizadores disponíveis são as seguintes:
-<ul>
+<ul>
<li><label>Símbolo simples</label> - um único estilo é aplicado a cada objeto na camada.
<li><label>Sómbolo graduado</label> - objetos dentro da camada são exibidos com símbolos diferentes classificados pelos valores de um campo particular.
<li><label>Cor contínua</label> - objetos dentro da camada são exibidos com um gradiente de cores classificados por valores numéricos dentro de um campo especificado.
<li><label>Valor único</label> - objetos são classificados pelos valores únicos dentro de um campo especificado com cada valor com um símbolo diferente.
-</ul>
-<h5>Nova simbologia</h5>
+</ul>
+<h5>Nova simbologia</h5>
Click <label>Nova simbologia</label> botão para usar a aplicação de nova simbologia para a camada.
-<h5>Transparência do vetor</h5>
+<h5>Transparência do vetor</h5>
O QGIS permite definir uma transparência para cada camada vetorial. Isso pode ser feito com o controle deslizante <label>Transparência</label>. Isto é muito útil para sobrepor várias camadas de vetorais.
-<h5>Salvar estilos</h5>
-Depois de ter seu estilo camada definido você pode salvar o seu estilo de camada para um arquivo separado (com extensão *. QML). Pra efetuar isso, use o botão <label>Salvar estilo...</label>. Não precisa dizer que <label>Carregar estilo...</label> carregará seu estilo de camada salvo.<br/>
+<h5>Salvar estilos</h5>
+Depois de ter seu estilo camada definido você pode salvar o seu estilo de camada para um arquivo separado (com extensão *. QML). Pra efetuar isso, use o botão <label>Salvar estilo...</label>. Não precisa dizer que <label>Carregar estilo...</label> carregará seu estilo de camada salvo.<br/>
Se você deseja utilizar sempre um estilo particular, sempre que uma camada for carregada, use o botão <label>Salvar como padrão</label> para torná-lo seu estilo padrão. Além disso, se você fizer alterações para o estilo que você não gostou, use o botão <label>Restaurar Estilo Padrão</label> para reverter ao estilo padrão.
-<a name="labels">
-<h4>Rótulos</h4>
-</a>
-A guia Rótulos permite que você ative características de rotulagem e controle uma série de opções relacionadas a fontes, a posição, estilo, alinhamento e afastamento.<br/>
-Marque a caixa<label>Mostra Rótulos</label>para habilitar a rotulagem.
-<h5>Opções básicas de rotulagem</h5>
-Escolha o campo com o rótulo.<p>
-Selecione o botão <label>Fonte</label> e <label>Cor</label> para definir fonte e cor. Você pode também mudar o ângulo de posicionamento do rótulo de texto.<p>
-Se têm rótulos que se estendem por várias linhas, marque <label>Rótulo multilinhas?</label>. O QGIS irá verificar se há uma linha de retorno verdadeira em seu campo de rótulo e inserir a linha de quebra de acordo. Uma verdadeira linha de retorno é um caractere \n (e não dois caracteres distintos, como uma folga \n seguida do caractere).
-<h5>Posicionamento</h5>
-Altera a colocação de rótulos, selecionando um dos botões de seleção no grupo <label>Posicionamento</label>.
-<h5>Unidades de tamanho da fonte</h5>
-A <label>Unidades de tamanho da fonte</label> permite você selecionar entre <label>Pontos</label> ou <label>Unidades do mapa</label>.
-<h5>Buffer nos rótulos</h5>
+<a name="labels">
+<h4>Rótulos</h4>
+</a>
+A guia Rótulos permite que você ative características de rotulagem e controle uma série de opções relacionadas a fontes, a posição, estilo, alinhamento e afastamento.<br/>
+Marque a caixa<label>Mostra Rótulos</label>para habilitar a rotulagem.
+<h5>Opções básicas de rotulagem</h5>
+Escolha o campo com o rótulo.<p>
+Selecione o botão <label>Fonte</label> e <label>Cor</label> para definir fonte e cor. Você pode também mudar o ângulo de posicionamento do rótulo de texto.<p>
+Se têm rótulos que se estendem por várias linhas, marque <label>Rótulo multilinhas?</label>. O QGIS irá verificar se há uma linha de retorno verdadeira em seu campo de rótulo e inserir a linha de quebra de acordo. Uma verdadeira linha de retorno é um caractere \n (e não dois caracteres distintos, como uma folga \n seguida do caractere).
+<h5>Posicionamento</h5>
+Altera a colocação de rótulos, selecionando um dos botões de seleção no grupo <label>Posicionamento</label>.
+<h5>Unidades de tamanho da fonte</h5>
+A <label>Unidades de tamanho da fonte</label> permite você selecionar entre <label>Pontos</label> ou <label>Unidades do mapa</label>.
+<h5>Buffer nos rótulos</h5>
Colocar buffer os rótulos significa colocar um alo em torno das letras para torná-las mais visíveis. Para colocar buffer nos rótulos:
-<ol>
+<ol>
<li>Clique na caixa <label>Buffer nos rótulos</label> para habilitar o Beffer
<li>Escolha um tamanho para o buffer usando a caixa de rotação.
<li>Escolha uma cor clicando em <label>Cor</label> e escolha a cor desejada no seletor de cores. Você pode também definir alguma transparência para o buffer se preferir.
<li>Clique <label>Aplicar</label> para ver se você gosta das modificações
-</ol>
+</ol>
Observe que você também pode especificar o tamanho do buffer em unidades do mapa se funcionar melhor para você.
-<h5>Posicionamento de dados definidos, propriedades, buffer, a posição</h5>
+<h5>Posicionamento de dados definidos, propriedades, buffer, a posição</h5>
As entradas restantes na aba <label>Rótulo</label> lhe permitem controlar a aparência dos rótulos usando atributos armazenados na camada. As entradas de início <label>Dados definidos</label> permite que você defina os parâmetros para os rótulos usando os campos na camada.
-<a name="attributes">
-<h4>Atributos</h4>
-</a>
-Com a aba <label>Atributos</label> os atributos do conjunto de dados selecionados podem ser manipulados. Os botões <label>Nova coluna</label> e <label>Excluir coluna</label> podem ser usados, quando o conjunto de dados estiver em modo de edição. A biblioteca OGR tem suporte para adicionar novas colunas, mas não removê-las, se você tiver uma versão do GADL > = 1.6 instalada. Caso contrário, apenas as colunas de camadas de PostGIS podem ser editadas.<p>
-O botão <label>Alternar para o modo de edição</label> aciona este modo.<p>
-Dentro da aba Atributos, você encontra também uma edição de elementos da coluna. Esta coluna pode ser utilizado para definir valores ou um intervalo de valores que podem ser adicionados ao atributo específico da coluna da tabela. Se você clicar o botão <label>edit widget</label> um diálogo se abre, onde você pode definir elementos diferentes. Estes elementos são:<br/>
-<ul>
-<li><label>Editar linha</label> um campo de edição que permite inserir texto simples (ou restringir para números de atributos numéricos).
+<a name="attributes">
+<h4>Atributos</h4>
+</a>
+Com a aba <label>Atributos</label> os atributos do conjunto de dados selecionados podem ser manipulados. Os botões <label>Nova coluna</label> e <label>Excluir coluna</label> podem ser usados, quando o conjunto de dados estiver em modo de edição. A biblioteca OGR tem suporte para adicionar novas colunas, mas não removê-las, se você tiver uma versão do GADL > = 1.6 instalada. Caso contrário, apenas as colunas de camadas de PostGIS podem ser editadas.<p>
+O botão <label>Alternar para o modo de edição</label> aciona este modo.<p>
+Dentro da aba Atributos, você encontra também uma edição de elementos da coluna. Esta coluna pode ser utilizado para definir valores ou um intervalo de valores que podem ser adicionados ao atributo específico da coluna da tabela. Se você clicar o botão <label>edit widget</label> um diálogo se abre, onde você pode definir elementos diferentes. Estes elementos são:<br/>
+<ul>
+<li><label>Editar linha</label> um campo de edição que permite inserir texto simples (ou restringir para números de atributos numéricos).
<li><label>Classificação</label> Exibe uma caixa de combinação com os valores utilizados para a classificação, se você tiver escolhido <label>valor único</label> como o tipo de legenda na aba simbologia da caixa de diálogo propriedades.
<li><label>Intervalo</label> Permite definir valores numéricos de um intervalo específico. A edição de um elemento pode ser uma barra ou uma caixa de giro.
<li><label>Valor único</label> O usuário pode selecionar um dos valores já utilizados na tabela de atributos. Se ativado <label>editável</label> editar uma linha é mostrado com o apoio autocompletar, mas valores adicionais são possíveis, caso contrário, uma caixa de combinação é utilizada.
@@ -82,34 +82,34 @@
<li><label>Ocultar</label> A coluna de atributo oculto é invisível para o usuário.
<li><label>Caixa</label> A caixa é mostrada. O valor que representa o estado da caixa no atributo deve ser inserido.
<li><label>Editar texto</label> Um texto de campo editável é mostrado, que permite a digitação de texto multilinhas.
-</ul>
-<a name="general">
-<h4>Geral</h4>
-</a>
-A aba Geral permite que você mude o nome para exibição, defina escala dependente das opções de renderização, crie um índice espacial do arquivo vetorial (somente para os formatos suportados e OGR PostGIS) e exiba ou alterae a projeção de uma camada vetorial específica.<p>
-Você pode também filtrar expressões usando o <label>Construtor de consulta</label>.
-<h5>Subdefinir</h5>
+</ul>
+<a name="general">
+<h4>Geral</h4>
+</a>
+A aba Geral permite que você mude o nome para exibição, defina escala dependente das opções de renderização, crie um índice espacial do arquivo vetorial (somente para os formatos suportados e OGR PostGIS) e exiba ou alterae a projeção de uma camada vetorial específica.<p>
+Você pode também filtrar expressões usando o <label>Construtor de consulta</label>.
+<h5>Subdefinir</h5>
O Botão <label>Construtor de consulta</label> permite limitar as características de uma camada de um subconjunto de correspondência de uma expressão.
-<a name="metadata">
-<h4>Metadados</h4>
-</a>
+<a name="metadata">
+<h4>Metadados</h4>
+</a>
A aba <label>Metadados</label> contém informações sobre a camada, incluindo detalhes sobre o tipo e localização, número de feições, tipo de feição e as capacidades de edição. O SRC da camada, fornecendo informações de projeção, é exibido nessa aba. Esta é uma maneira rápida para obter informações sobre a camada.
-<a name="actions">
-<h4>Ações</h4>
-</a>
-O QGIS fornece a capacidade de executar uma ação com base nos atributos de uma feição. Isso pode ser usado para executar qualquer número de ações, por exemplo, executar um programa com os argumentos construídos a partir dos atributos de um recurso ou passar parâmetros para uma ferramenta de relatórios da web.<br/>
-Ações são úteis quando você frequentemente deseja executar um aplicativo externo ou exibir uma página da web com base em um ou mais valores em sua camada de vetor. Um exemplo está realizando uma pesquisa com base em um valor de atributo.<p>
+<a name="actions">
+<h4>Ações</h4>
+</a>
+O QGIS fornece a capacidade de executar uma ação com base nos atributos de uma feição. Isso pode ser usado para executar qualquer número de ações, por exemplo, executar um programa com os argumentos construídos a partir dos atributos de um recurso ou passar parâmetros para uma ferramenta de relatórios da web.<br/>
+Ações são úteis quando você frequentemente deseja executar um aplicativo externo ou exibir uma página da web com base em um ou mais valores em sua camada de vetor. Um exemplo está realizando uma pesquisa com base em um valor de atributo.<p>
Consulte o Guia do Usuário para mais informações.
-<h5>Usando ações</h5>
-As ações podem ser invocadas a partir do diálogo <label>Identificar Resultados</label>.
-<a name="diagram">
-<h4>Diagrama de Sobreposição</h4>
-</a>
-A aba Diagram permite que você adicione um gráfico sobreposição a uma camada de vetor. Para ativar esse recurso, abra <label>Gerenciador de complementos</label> e selecione o complemento <label>Diagrama de Sobreposição</label>. Depois disso, há uma nova aba de diálogo na camada vetorial <label>Propriedades da camada</label> onde as configurações para os diagramas podem ser inseridas.<p>
+<h5>Usando ações</h5>
+As ações podem ser invocadas a partir do diálogo <label>Identificar Resultados</label>.
+<a name="diagram">
+<h4>Diagrama de Sobreposição</h4>
+</a>
+A aba Diagram permite que você adicione um gráfico sobreposição a uma camada de vetor. Para ativar esse recurso, abra <label>Gerenciador de complementos</label> e selecione o complemento <label>Diagrama de Sobreposição</label>. Depois disso, há uma nova aba de diálogo na camada vetorial <label>Propriedades da camada</label> onde as configurações para os diagramas podem ser inseridas.<p>
A implementação atual de diagramas fornece suporte para gráficos do tipo pizza e barras e para o aumento linear do tamanho do diagrama de acordo com um atributo de classificação.
Modified: trunk/qgis/resources/context_help/QgsWMSSourceSelect-pt_BR
--- trunk/qgis/resources/context_help/QgsWMSSourceSelect-pt_BR 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/resources/context_help/QgsWMSSourceSelect-pt_BR 2010-09-29 20:39:42 UTC (rev 14313)
@@ -1,37 +1,37 @@
-<h3>Criar uma nova conexão WMS</h3>
-Camadas WMS podem ser adicionadas de forma simples, contanto que você saiba a URL para acessar o servidor WMS, você tenha uma conexão com esse servidor, e o servidor HTTP entenda o o mecanismo de transporte de dados.<p>
+<h3>Criar uma nova conexão WMS</h3>
+Camadas WMS podem ser adicionadas de forma simples, contanto que você saiba a URL para acessar o servidor WMS, você tenha uma conexão com esse servidor, e o servidor HTTP entenda o o mecanismo de transporte de dados.<p>
O QGIS atualmente pode atuar como um cliente WMS que compreende servidores WMS 1.1, 1.1.1 e 1.3.
-<p>
-<a href="#serv">Servidores</a><br/>
-<a href="#load">Carregar camadas WMS</a><br/>
-<a href="#lay">Ordem da camada</a><br/>
-<a href="#search">Buscador de servidores</a><br/>
-<a name="serv">
-<h4>Servidores</h4>
-</a>
-Para definir um novo servidor WMS na seção <label>Conexões de servidores</label> selecione <label>Novo</label>. Em seguida, insira os parâmetros para se conectar ao servidor WMS desejado.<p>
-Você pode adicionar alguns servidores para rodar, clicando no botão <label>Adicionar servidores padrão</label>. Isso adicionará pelo menos três servidores WMS para você usar, incluindo o servidor WMS da NASA (JPL).<p>
+<p>
+<a href="#serv">Servidores</a><br/>
+<a href="#load">Carregar camadas WMS</a><br/>
+<a href="#lay">Ordem da camada</a><br/>
+<a href="#search">Buscador de servidores</a><br/>
+<a name="serv">
+<h4>Servidores</h4>
+</a>
+Para definir um novo servidor WMS na seção <label>Conexões de servidores</label> selecione <label>Novo</label>. Em seguida, insira os parâmetros para se conectar ao servidor WMS desejado.<p>
+Você pode adicionar alguns servidores para rodar, clicando no botão <label>Adicionar servidores padrão</label>. Isso adicionará pelo menos três servidores WMS para você usar, incluindo o servidor WMS da NASA (JPL).<p>
Uma vez que a nova WMS conexão com o servidor foi criada, ela será preservada para futuras seções do QGIS.
-<a name="load">
-<h5>Carregar camadas WMS</h5>
-</a>
-Selecione o botão <label>Conectar</label> para recuperar as capacidades do servidor selecionado. Isso inclui a codificação de imagens, camadas, Estilos de camadas e projeções.<br/>
-Enquanto ocorre o download de dados do servidor WMS, o progresso pode ser visualizado no canto inferior esquerdo da janela do complemento WMS.<p>
-A seção <label>Codificação da imagem</label> agora lista os formatos que são suportados pelo cliente e servidor.<br/>
-Escolha um dependendo de suas exigências de precisão da imagem.<p>
-Você pode selecionar várias camadas ao mesmo tempo, elas serão combinadas com o servidor WMS e transmitidas ao QGIS de uma vez.<p>
-Cada camada WMS pode ser apresentada em vários SRCs, dependendo da capacidade do servidor WMS. Para escolher um SRC, selecione <label>Mudar...</label>
-<a name="lay">
-<h4>Ordem de camada</h4>
-</a>
+<a name="load">
+<h5>Carregar camadas WMS</h5>
+</a>
+Selecione o botão <label>Conectar</label> para recuperar as capacidades do servidor selecionado. Isso inclui a codificação de imagens, camadas, Estilos de camadas e projeções.<br/>
+Enquanto ocorre o download de dados do servidor WMS, o progresso pode ser visualizado no canto inferior esquerdo da janela do complemento WMS.<p>
+A seção <label>Codificação da imagem</label> agora lista os formatos que são suportados pelo cliente e servidor.<br/>
+Escolha um dependendo de suas exigências de precisão da imagem.<p>
+Você pode selecionar várias camadas ao mesmo tempo, elas serão combinadas com o servidor WMS e transmitidas ao QGIS de uma vez.<p>
+Cada camada WMS pode ser apresentada em vários SRCs, dependendo da capacidade do servidor WMS. Para escolher um SRC, selecione <label>Mudar...</label>
+<a name="lay">
+<h4>Ordem de camada</h4>
+</a>
Nesta aba, você pode mudar a ordem das camadas WMS carregadas.
-<a name="search">
-<h4>Buscar servidor</h4>
-</a>
-Nesta aba, você pode procurar por servidores WMS. É possível inserir uma sequência de pesquisa em um campo de texto e clicar o botão <label>Buscar</label>.<p>
-Para visualizar os resultados, selecione uma entrada na tabela, pressione o botão <label>Adicionar linha selecionada a lista WMS</label> e retornar para a aba <label>Servidores</label>.<p>
+<a name="search">
+<h4>Buscar servidor</h4>
+</a>
+Nesta aba, você pode procurar por servidores WMS. É possível inserir uma sequência de pesquisa em um campo de texto e clicar o botão <label>Buscar</label>.<p>
+Para visualizar os resultados, selecione uma entrada na tabela, pressione o botão <label>Adicionar linha selecionada a lista WMS</label> e retornar para a aba <label>Servidores</label>.<p>
Você só precisa solicitar a lista de camadas, clicando no botão <label>Conectar</label>.
Modified: trunk/qgis/resources/context_help/eVisDatabaseConnectionGui-es_ES
--- trunk/qgis/resources/context_help/eVisDatabaseConnectionGui-es_ES 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/resources/context_help/eVisDatabaseConnectionGui-es_ES 2010-09-29 20:39:42 UTC (rev 14313)
@@ -1 +1 @@
-<h3>Conexión a base de datos</h3>
+<h3>Conexión a base de datos</h3>
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -81,8 +81,8 @@
QgisApp::instance()->addDockWidget( Qt::BottomDockWidgetArea, mDock );
- setWindowTitle( tr ("Attribute table - %3 :: %1 / %2 features(s) selected", "feature count").
- arg( mView->selectionModel()->selectedRows().size() ).arg( mModel->rowCount() ).arg( mLayer->name() ));
+ setWindowTitle( tr( "Attribute table - %3 :: %1 / %2 features(s) selected", "feature count" ).
+ arg( mView->selectionModel()->selectedRows().size() ).arg( mModel->rowCount() ).arg( mLayer->name() ) );
mRemoveSelectionButton->setIcon( getThemeIcon( "/mActionUnselectAttributes.png" ) );
mSelectedToTopButton->setIcon( getThemeIcon( "/mActionSelectedToTop.png" ) );
@@ -305,8 +305,8 @@
mSelectionModel->select( selection, QItemSelectionModel::ClearAndSelect );// | QItemSelectionModel::Columns);
mView->setSelectionModel( mSelectionModel );
/*for (int i = 0; i < mModel->rowCount(); ++i)
@@ -354,8 +354,8 @@
updateRowSelection( first, last, 3 );
mView->setSelectionMode( QAbstractItemView::NoSelection );
return;
@@ -406,8 +406,8 @@
void QgsAttributeTableDialog::updateRowSelection( int first, int last, int clickType )
@@ -628,15 +628,16 @@
QVariant::Type fldType = flds[fldIndex].type();
bool numeric = ( fldType == QVariant::Int || fldType == QVariant::Double );
QString sensString = "ILIKE";
- if (cbxCaseSensitive->isChecked()) {
- sensString = "LIKE";
+ if ( cbxCaseSensitive->isChecked() )
+ sensString = "LIKE";
QString str = QString( "%1 %2 '%3'" )
.arg( QgsSearchTreeNode::quotedColumnRef( fieldName ) )
.arg( numeric ? "=" : sensString )
.arg( numeric ? mQuery->displayText().replace( "'", "''" ) :
- "%" + mQuery->displayText().replace ("'", "''") + "%" ); // escape quotes
+ "%" + mQuery->displayText().replace( "'", "''" ) + "%" ); // escape quotes
doSearch( str );
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -55,8 +55,8 @@
#include <qwt_plot_canvas.h>
#include <qwt_array.h>
#include <qwt_legend.h>
-#include <qwt_plot.h>
-#include <qwt_plot_curve.h>
+#include <qwt_plot.h>
+#include <qwt_plot_curve.h>
#include <qwt_plot_grid.h>
const char * const ident =
@@ -206,7 +206,7 @@
mMapCanvas = theCanvas;
mPixelSelectorTool = 0;
- if( mMapCanvas )
+ if ( mMapCanvas )
mPixelSelectorTool = new QgsPixelSelectorTool( theCanvas );
connect( mPixelSelectorTool, SIGNAL( pixelSelected( int, int ) ), this, SLOT( pixelSelected( int, int ) ) );
@@ -281,7 +281,7 @@
QSettings settings;
settings.setValue( "/Windows/RasterLayerProperties/geometry", saveGeometry() );
settings.setValue( "/Windows/RasterLayerProperties/row", listWidget->currentRow() );
- if( mPixelSelectorTool )
+ if ( mPixelSelectorTool )
delete mPixelSelectorTool;
@@ -1650,7 +1650,7 @@
void QgsRasterLayerProperties::on_pbnAddValuesFromDisplay_clicked()
- if( mMapCanvas && mPixelSelectorTool )
+ if ( mMapCanvas && mPixelSelectorTool )
mMapCanvas->setMapTool( mPixelSelectorTool );
//Need to work around the modality of the dialog but can not just hide() it.
@@ -1855,23 +1855,23 @@
QgsDebugMsg( "entered." );
QwtPlot * mypPlot = new QwtPlot( mChartWidget );
- mypPlot->canvas()->setCursor(Qt::ArrowCursor);
+ mypPlot->canvas()->setCursor( Qt::ArrowCursor );
//ensure all children get removed
mypPlot->setAutoDelete( true );
QVBoxLayout *mpHistogramLayout = new QVBoxLayout( mChartWidget );
mpHistogramLayout->setContentsMargins( 0, 0, 0, 0 );
mpHistogramLayout->addWidget( mypPlot );
mChartWidget->setLayout( mpHistogramLayout );
- mypPlot->setTitle( QObject::tr( "Raster Histogram") );
+ mypPlot->setTitle( QObject::tr( "Raster Histogram" ) );
mypPlot->insertLegend( new QwtLegend(), QwtPlot::BottomLegend );
// Set axis titles
- mypPlot->setAxisTitle( QwtPlot::xBottom, QObject::tr("Pixel Value") );
- mypPlot->setAxisTitle( QwtPlot::yLeft, QObject::tr("Frequency") );
+ mypPlot->setAxisTitle( QwtPlot::xBottom, QObject::tr( "Pixel Value" ) );
+ mypPlot->setAxisTitle( QwtPlot::yLeft, QObject::tr( "Frequency" ) );
mypPlot->setAxisAutoScale( QwtPlot::xBottom );
mypPlot->setAxisAutoScale( QwtPlot::yLeft );
// add a grid
QwtPlotGrid * myGrid = new QwtPlotGrid();
- myGrid->attach(mypPlot);
+ myGrid->attach( mypPlot );
// Explanation:
// We use the gdal histogram creation routine is called for each selected
// layer. Currently the hist is hardcoded
@@ -1902,24 +1902,24 @@
// scan through to get counts from layers' histograms
for ( int myIteratorInt = 1;
- myIteratorInt <= myBandCountInt;
- ++myIteratorInt )
+ myIteratorInt <= myBandCountInt;
+ ++myIteratorInt )
QgsRasterBandStats myRasterBandStats = mRasterLayer->bandStatistics( myIteratorInt );
mRasterLayer->populateHistogram( myIteratorInt, BINCOUNT, myIgnoreOutOfRangeFlag, myThoroughBandScanFlag );
QwtPlotCurve * mypCurve = new QwtPlotCurve( tr( "Band %1" ).arg( myIteratorInt ) );
mypCurve->setRenderHint( QwtPlotItem::RenderAntialiased );
- mypCurve->setPen(QPen( myColors.at( myIteratorInt ) ) );
+ mypCurve->setPen( QPen( myColors.at( myIteratorInt ) ) );
QwtArray<double> myX2Data;//qwtarray is just a wrapped qvector
QwtArray<double> myY2Data;//qwtarray is just a wrapped qvector
for ( int myBin = 0; myBin < BINCOUNT; myBin++ )
int myBinValue = myRasterBandStats.histogramVector->at( myBin );
- myX2Data.append( double( myBin) );
- myY2Data.append( double( myBinValue) );
+ myX2Data.append( double( myBin ) );
+ myY2Data.append( double( myBinValue ) );
- mypCurve->setData(myX2Data,myY2Data);
- mypCurve->attach(mypPlot);
+ mypCurve->setData( myX2Data, myY2Data );
+ mypCurve->attach( mypPlot );
mypPlot->replot();
disconnect( mRasterLayer, SIGNAL( progressUpdate( int ) ), mHistogramProgress, SLOT( setValue( int ) ) );
@@ -2206,15 +2206,15 @@
activateWindow();
//Get the pixel values and add a new entry to the transparency table
QMap< QString, QString > myPixelMap;
mMapCanvas->unsetMapTool( mPixelSelectorTool );
mRasterLayer->identify( mMapCanvas->getCoordinateTransform( )->toMapCoordinates( x, y ), myPixelMap );
- if( tableTransparency->columnCount() == 2 )
+ if ( tableTransparency->columnCount() == 2 )
- QString myValue = myPixelMap[ mRasterLayer->grayBandName() ];
- if( myValue != tr( "out of extent" ) )
+ QString myValue = myPixelMap[ mRasterLayer->grayBandName()];
+ if ( myValue != tr( "out of extent" ) )
tableTransparency->insertRow( tableTransparency->rowCount() );
tableTransparency->setItem( tableTransparency->rowCount() - 1, tableTransparency->columnCount() - 1, new QTableWidgetItem( "100.0" ) );
@@ -2223,14 +2223,14 @@
else
- QString myValue = myPixelMap[ mRasterLayer->redBandName() ];
+ QString myValue = myPixelMap[ mRasterLayer->redBandName()];
tableTransparency->setItem( tableTransparency->rowCount() - 1, 0, new QTableWidgetItem( myValue ) );
- tableTransparency->setItem( tableTransparency->rowCount() - 1, 1, new QTableWidgetItem( myPixelMap[ mRasterLayer->greenBandName() ] ) );
- tableTransparency->setItem( tableTransparency->rowCount() - 1, 2, new QTableWidgetItem( myPixelMap[ mRasterLayer->blueBandName() ] ) );
+ tableTransparency->setItem( tableTransparency->rowCount() - 1, 1, new QTableWidgetItem( myPixelMap[ mRasterLayer->greenBandName()] ) );
+ tableTransparency->setItem( tableTransparency->rowCount() - 1, 2, new QTableWidgetItem( myPixelMap[ mRasterLayer->blueBandName()] ) );
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2010-09-29 20:39:42 UTC (rev 14313)
@@ -89,7 +89,7 @@
/** \brief slot executed when the three band standard deviation radio button is pressed. */
void on_rbtnThreeBandStdDev_toggled( bool );
- void pixelSelected( int x, int y);
+ void pixelSelected( int x, int y );
/** \brief this slot clears min max values from gui */
void sboxSingleBandStdDev_valueChanged( double );
@@ -226,7 +226,7 @@
class QgsPixelSelectorTool: public QgsMapTool
- Q_OBJECT
+ Q_OBJECT
public:
QgsPixelSelectorTool( QgsMapCanvas* );
@@ -237,7 +237,7 @@
signals:
/** \brief Alter the listener ( raster properties dialog ) that a mouse click was registered */
private:
QgsMapCanvas * mMapCanvas;
Modified: trunk/qgis/src/core/composer/qgscomposerlegend.cpp
--- trunk/qgis/src/core/composer/qgscomposerlegend.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/core/composer/qgscomposerlegend.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -28,12 +28,12 @@
#include <QPainter>
QgsComposerLegend::QgsComposerLegend( QgsComposition* composition )
- : QgsComposerItem( composition )
- , mTitle( tr( "Legend" ) )
- , mBoxSpace( 2 )
- , mLayerSpace( 3 )
- , mSymbolSpace( 2 )
- , mIconLabelSpace( 2 )
+ : QgsComposerItem( composition )
+ , mTitle( tr( "Legend" ) )
+ , mBoxSpace( 2 )
+ , mLayerSpace( 3 )
+ , mSymbolSpace( 2 )
+ , mIconLabelSpace( 2 )
//QStringList idList = layerIdList();
//mLegendModel.setLayerSet( idList );
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -845,7 +845,7 @@
QgsDebugMsg( "cache Image set!" );
if ( mpCacheImage == thepImage )
return;
if ( mpCacheImage )
delete mpCacheImage;
Modified: trunk/qgis/src/core/qgssearchtreenode.cpp
--- trunk/qgis/src/core/qgssearchtreenode.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/core/qgssearchtreenode.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -375,7 +375,7 @@
-bool QgsSearchTreeNode::checkAgainst( const QMap<int,QgsField>& fields, const QMap<int, QVariant>& attributes, QgsGeometry* geom )
+bool QgsSearchTreeNode::checkAgainst( const QMap<int, QgsField>& fields, const QMap<int, QVariant>& attributes, QgsGeometry* geom )
QgsFeature f;
f.setAttributeMap( attributes );
Modified: trunk/qgis/src/core/qgssearchtreenode.h
--- trunk/qgis/src/core/qgssearchtreenode.h 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/core/qgssearchtreenode.h 2010-09-29 20:39:42 UTC (rev 14313)
@@ -151,7 +151,7 @@
bool checkAgainst( const QgsFieldMap& fields, QgsFeature &f );
//! @note deprecated
- bool checkAgainst( const QMap<int,QgsField>& fields, const QMap<int, QVariant>& attributes, QgsGeometry* geom = 0 );
+ bool checkAgainst( const QMap<int, QgsField>& fields, const QMap<int, QVariant>& attributes, QgsGeometry* geom = 0 );
//! checks if there were errors during evaluation
bool hasError() { return ( !mError.isEmpty() ); }
@@ -166,7 +166,7 @@
bool getValue( QgsSearchTreeValue& value, QgsSearchTreeNode* node,
- const QMap<int,QgsField>& fields, const QMap<int,QVariant>& attributes, QgsGeometry* geom = 0 );
+ const QMap<int, QgsField>& fields, const QMap<int, QVariant>& attributes, QgsGeometry* geom = 0 );
//! return a list of referenced columns in the tree
//! @note added in 1.5
@@ -202,7 +202,7 @@
QgsSearchTreeValue valueAgainst( const QgsFieldMap& fields, QgsFeature &f );
- QgsSearchTreeValue valueAgainst( const QMap<int,QgsField>& fields, const QMap<int,QVariant>& attributes, QgsGeometry* geom = 0 );
+ QgsSearchTreeValue valueAgainst( const QMap<int, QgsField>& fields, const QMap<int, QVariant>& attributes, QgsGeometry* geom = 0 );
//! strips mText when node is of string type
void stripText();
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.h
--- trunk/qgis/src/core/raster/qgscolorrampshader.h 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.h 2010-09-29 20:39:42 UTC (rev 14313)
@@ -44,8 +44,8 @@
//! default constructor
ColorRampItem() {}
//! convenience constructor - added in v1.6
- ColorRampItem( double val, QColor col, QString lbl = QString() ) : label(lbl), value(val), color(col) {}
+ ColorRampItem( double val, QColor col, QString lbl = QString() ) : label( lbl ), value( val ), color( col ) {}
QString label;
double value;
QColor color;
Modified: trunk/qgis/src/core/raster/qgsrastershader.cpp
--- trunk/qgis/src/core/raster/qgsrastershader.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/core/raster/qgsrastershader.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -82,7 +82,7 @@
void QgsRasterShader::setRasterShaderFunction( QgsRasterShaderFunction* theFunction )
QgsDebugMsg( "called." );
if ( mRasterShaderFunction == theFunction )
return;
Modified: trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -355,11 +355,11 @@
QList<double> breaks;
if ( classes < 1 )
- breaks.append( maximum );
- return breaks;
+ breaks.append( maximum );
+ return breaks;
- int minimumCount = (int) classes / 3;
+ int minimumCount = ( int ) classes / 3;
double shrink = 0.75;
double highBias = 1.5;
double adjustBias = 0.5 + 1.5 * highBias;
@@ -381,11 +381,11 @@
cell = qMax( qAbs( minimum ), qAbs( maximum ) );
if ( adjustBias >= 1.5 * h + 0.5 )
- U = 1 + (1.0/(1 + h));
+ U = 1 + ( 1.0 / ( 1 + h ) );
else
- U = 1 + (1.5 / (1 + adjustBias));
+ U = 1 + ( 1.5 / ( 1 + adjustBias ) );
small = dx < ( cell * U * qMax( 1, divisions ) * 1e-07 * 3.0 );
@@ -417,13 +417,13 @@
double base = pow( 10.0, floor( log10( cell ) ) );
double unit = base;
- if ( ( 2 * base ) - cell < h * ( cell - unit ) )
+ if (( 2 * base ) - cell < h * ( cell - unit ) )
unit = 2.0 * base;
- if ( ( 5 * base ) - cell < adjustBias * ( cell - unit ) )
+ if (( 5 * base ) - cell < adjustBias * ( cell - unit ) )
unit = 5.0 * base;
- if ( ( 10.0 * base ) - cell < h * ( cell - unit ) )
+ if (( 10.0 * base ) - cell < h * ( cell - unit ) )
unit = 10.0 * base;
@@ -470,7 +470,7 @@
double maximumBreak = end * unit;
int count = ceil( maximumBreak - minimumBreak ) / unit;
- for ( int i = 1; i < count+1; i++ )
+ for ( int i = 1; i < count + 1; i++ )
breaks.append( minimumBreak + i * unit );
@@ -509,7 +509,7 @@
minimum = qMin( values[i], minimum ); // could use precomputed max and min
maximum = qMax( values[i], maximum ); // but have to go through entire list anyway
- mean = mean / (double) n;
+ mean = mean / ( double ) n;
double sd = 0.0;
for ( int i = 0; i < n; i++ )
@@ -519,10 +519,10 @@
stdDev = sqrt( stdDev / n );
- QList<double> breaks = _calcPrettyBreaks( ( minimum - mean ) / stdDev, ( maximum - mean ) / stdDev, classes );
+ QList<double> breaks = _calcPrettyBreaks(( minimum - mean ) / stdDev, ( maximum - mean ) / stdDev, classes );
for ( int i = 0; i < breaks.count(); i++ )
- labels.append( (int) breaks[i]);
+ labels.append(( int ) breaks[i] );
breaks[i] = ( breaks[i] * stdDev ) + mean;
@@ -547,8 +547,8 @@
if ( classes < 1 )
- return breaks;
+ return breaks;
int n = values.count();
@@ -560,20 +560,20 @@
// for now, sample at least maximumSize values or a 10% sample, whichever
// is larger. This will produce a more representative sample for very large
// layers, but could end up being computationally intensive...
- n = qMax( maximumSize, (int) ( (double) n * 0.10 ) );
+ n = qMax( maximumSize, ( int )(( double ) n * 0.10 ) );
QgsDebugMsg( QString( "natural breaks (jenks) sample size: %1" ).arg( n ) );
sample.append( minimum );
sample.append( maximum );
- for ( int i = 0; i < n-2; i++ )
+ for ( int i = 0; i < n - 2; i++ )
// pick a random integer from 0 to n
- int c = (int) ( (double) rand() / ( (double) RAND_MAX + 1 ) * n - 1 );
+ int c = ( int )(( double ) rand() / (( double ) RAND_MAX + 1 ) * n - 1 );
sample.append( values[i+c] );
else
- sample = values;
+ sample = values;
// sort the values
qSort( sample );
@@ -587,13 +587,13 @@
QList<double > tempOne;
QList<double > tempTwo;
- for (int j = 0; j < classes + 1; j++)
+ for ( int j = 0; j < classes + 1; j++ )
- tempOne.append(0.0);
- tempTwo.append(0.0);
+ tempOne.append( 0.0 );
+ tempTwo.append( 0.0 );
- matrixOne.append(tempOne);
- matrixTwo.append(tempTwo);
+ matrixOne.append( tempOne );
+ matrixTwo.append( tempTwo );
for ( int i = 1; i < classes + 1; i++ )
@@ -622,7 +622,7 @@
s1 += val;
w += 1.0;
- v = s2 - (s1 * s1) / w;
+ v = s2 - ( s1 * s1 ) / w;
i4 = i3 - 1;
if ( i4 != 0.0 )
@@ -643,7 +643,7 @@
for ( int i = 0; i < classes; i++ )
- breaks.append(0.0);
+ breaks.append( 0.0 );
breaks[classes - 1] = sample[sample.length() - 1];
@@ -704,15 +704,15 @@
// calculate the breaks
if ( mode == Quantile )
- breaks = _calcQuantileBreaks( values, classes );
+ breaks = _calcQuantileBreaks( values, classes );
else if ( mode == Jenks )
- breaks = _calcJenksBreaks( values, classes, minimum, maximum );
+ breaks = _calcJenksBreaks( values, classes, minimum, maximum );
else if ( mode == StdDev )
- breaks = _calcStdDevBreaks( values, classes, labels );
+ breaks = _calcStdDevBreaks( values, classes, labels );
else
Modified: trunk/qgis/src/core/symbology-ng/qgsrulebasedrendererv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsrulebasedrendererv2.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/core/symbology-ng/qgsrulebasedrendererv2.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -355,7 +355,7 @@
QList<QgsRuleBasedRendererV2::Rule> QgsRuleBasedRendererV2::refineRuleScales( QgsRuleBasedRendererV2::Rule& initialRule, QList<int> scales )
- qSort(scales); // make sure the scales are in ascending order
+ qSort( scales ); // make sure the scales are in ascending order
QList<Rule> rules;
int oldScale = initialRule.scaleMinDenom();
int maxDenom = initialRule.scaleMaxDenom();
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -12,7 +12,7 @@
* (at your option) any later version. *
-/* $Id: qgsgeoreftoolmovepoint.cpp 13187 2010-03-28 22:14:44Z jef $ */
+/* $Id$ */
#include "qgsmapcanvas.h"
@@ -33,9 +33,9 @@
-bool QgsGeorefToolMovePoint::isCanvas(QgsMapCanvas *canvas)
+bool QgsGeorefToolMovePoint::isCanvas( QgsMapCanvas *canvas )
- return (mCanvas == canvas);
+ return ( mCanvas == canvas );
void QgsGeorefToolMovePoint::canvasMoveEvent( QMouseEvent *e )
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.h
--- trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.h 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.h 2010-09-29 20:39:42 UTC (rev 14313)
@@ -12,7 +12,7 @@
-/* $Id: qgsgeoreftoolmovepoint.h 13187 2010-03-28 22:14:44Z jef $ */
+/* $Id$ */
#ifndef QGSGEOREFTOOLMOVEPOINT_H
#define QGSGEOREFTOOLMOVEPOINT_H
@@ -34,7 +34,7 @@
void canvasMoveEvent( QMouseEvent *e );
void canvasReleaseEvent( QMouseEvent *e );
- bool isCanvas(QgsMapCanvas *);
+ bool isCanvas( QgsMapCanvas * );
signals:
void pointPressed( const QPoint &p );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -570,38 +570,38 @@
flippedPixelCoords[i] = QgsPoint( pixelCoords[i].x(), -pixelCoords[i].y() );
QgsLeastSquares::projective( mapCoords, flippedPixelCoords, mParameters.H );
// Invert the homography matrix using adjoint matrix
double *H = mParameters.H;
double adjoint[9];
- adjoint[0] = H[4]*H[8] - H[5]*H[7];
- adjoint[1] = -H[1]*H[8] + H[2]*H[7];
- adjoint[2] = H[1]*H[5] - H[2]*H[4];
+ adjoint[0] = H[4] * H[8] - H[5] * H[7];
+ adjoint[1] = -H[1] * H[8] + H[2] * H[7];
+ adjoint[2] = H[1] * H[5] - H[2] * H[4];
- adjoint[3] = -H[3]*H[8] + H[5]*H[6];
- adjoint[4] = H[0]*H[8] - H[2]*H[6];
- adjoint[5] = -H[0]*H[5] + H[2]*H[3];
+ adjoint[3] = -H[3] * H[8] + H[5] * H[6];
+ adjoint[4] = H[0] * H[8] - H[2] * H[6];
+ adjoint[5] = -H[0] * H[5] + H[2] * H[3];
- adjoint[6] = H[3]*H[7] - H[4]*H[6];
- adjoint[7] = -H[0]*H[7] + H[1]*H[6];
- adjoint[8] = H[0]*H[4] - H[1]*H[3];
+ adjoint[6] = H[3] * H[7] - H[4] * H[6];
+ adjoint[7] = -H[0] * H[7] + H[1] * H[6];
+ adjoint[8] = H[0] * H[4] - H[1] * H[3];
- double det = H[0]*adjoint[0] + H[3]*adjoint[1] + H[6]*adjoint[2];
+ double det = H[0] * adjoint[0] + H[3] * adjoint[1] + H[6] * adjoint[2];
- if (std::abs(det) < 1024.0*std::numeric_limits<double>::epsilon())
+ if ( std::abs( det ) < 1024.0*std::numeric_limits<double>::epsilon() )
mParameters.hasInverse = false;
else
mParameters.hasInverse = true;
- double oo_det = 1.0/det;
+ double oo_det = 1.0 / det;
for ( int i = 0; i < 9; i++ )
- mParameters.Hinv[i] = adjoint[i]*oo_det;
+ mParameters.Hinv[i] = adjoint[i] * oo_det;
return true;
@@ -630,7 +630,7 @@
if ( !t->hasInverse )
- for (int i = 0; i < nPointCount; ++i )
+ for ( int i = 0; i < nPointCount; ++i )
panSuccess[i] = false;
@@ -639,22 +639,22 @@
H = t->Hinv;
- double Z = x[i]*H[6] + y[i]*H[7] + H[8];
+ double Z = x[i] * H[6] + y[i] * H[7] + H[8];
// Projects to infinity?
- if ( std::abs(Z) < 1024.0*std::numeric_limits<double>::epsilon() )
+ if ( std::abs( Z ) < 1024.0*std::numeric_limits<double>::epsilon() )
continue;
- double X = (x[i]*H[0] + y[i]*H[1] + H[2]) / Z;
- double Y = (x[i]*H[3] + y[i]*H[4] + H[5]) / Z;
+ double X = ( x[i] * H[0] + y[i] * H[1] + H[2] ) / Z;
+ double Y = ( x[i] * H[3] + y[i] * H[4] + H[5] ) / Z;
x[i] = X;
y[i] = Y;
panSuccess[i] = true;
Modified: trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.cpp
--- trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -131,7 +131,7 @@
// or convert between waypoints/tracks=
case 4:
- int convertType = cmbCONVType->itemData(cmbCONVType->currentIndex()).toInt();
+ int convertType = cmbCONVType->itemData( cmbCONVType->currentIndex() ).toInt();
emit convertGPSFile( leCONVInput->text(),
convertType,
@@ -331,10 +331,10 @@
void QgsGPSPluginGui::populateCONVDialog()
- cmbCONVType->addItem(tr("Waypoints from a route"), QVariant(int(0)));
- cmbCONVType->addItem(tr("Waypoints from a track"), QVariant(int(3)));
- cmbCONVType->addItem(tr("Route from waypoints"), QVariant(int(1)));
- cmbCONVType->addItem(tr("Track from waypoints"), QVariant(int(2)));
+ cmbCONVType->addItem( tr( "Waypoints from a route" ), QVariant( int( 0 ) ) );
+ cmbCONVType->addItem( tr( "Waypoints from a track" ), QVariant( int( 3 ) ) );
+ cmbCONVType->addItem( tr( "Route from waypoints" ), QVariant( int( 1 ) ) );
+ cmbCONVType->addItem( tr( "Track from waypoints" ), QVariant( int( 2 ) ) );
void QgsGPSPluginGui::populateULLayerComboBox()
Modified: trunk/qgis/src/python/qgspythonutilsimpl.cpp
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp 2010-09-29 20:29:43 UTC (rev 14312)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp 2010-09-29 20:39:42 UTC (rev 14313)
@@ -70,7 +70,7 @@
QStringList newpaths;
newpaths << pythonPath() << homePythonPath();
newpaths += pluginpaths;
- runString( "sys.path = [\"" + newpaths.join("\", \"") + "\"] + sys.path" );
+ runString( "sys.path = [\"" + newpaths.join( "\", \"" ) + "\"] + sys.path" );
// import SIP
if ( !runString( "from sip import wrapinstance, unwrapinstance",
@@ -405,7 +405,7 @@
QStringList QgsPythonUtilsImpl::extraPluginsPaths()
const char* cpaths = getenv( "QGIS_PLUGINPATH" );
- if (cpaths == NULL)
+ if ( cpaths == NULL )
return QStringList();
QString paths = QString::fromLocal8Bit( cpaths );
