[QGIS Commit] r15668 - in trunk/qgis: . doc scripts src
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Apr 4 03:25:27 EDT 2011
Author: jef
Date: 2011-04-04 00:25:27 -0700 (Mon, 04 Apr 2011)
New Revision: 15668
Added:
   trunk/qgis/src/crssync/
   trunk/qgis/INSTALL
   trunk/qgis/doc/linux.t2t
   trunk/qgis/scripts/scandeps.pl
update debian build dependencies in INSTALL
Modified: trunk/qgis/INSTALL
--- trunk/qgis/INSTALL	2011-04-04 07:23:56 UTC (rev 15667)
+++ trunk/qgis/INSTALL	2011-04-04 07:25:27 UTC (rev 15668)
@@ -1,9 +1,11 @@
 Quantum GIS (QGIS)
 Building QGIS from source - step by step
-Last update: 20110331
-Last change: 20110307
+Last update: 20110404
+Last change: 20110404
   1. Introduction
   2. Overview
   3. Building on GNU/Linux
@@ -31,7 +33,6 @@
   6. Authors and Acknowledgments
   1. Introduction
@@ -84,7 +85,6 @@
 - Flex
 - Bison
 Required build deps:
 - Qt >= 4.4.0
@@ -94,7 +94,6 @@
 - GDAL/OGR >= 1.4.x
 - Qwt >= 5.0
 Optional dependencies:
 - for GRASS plugin - GRASS >= 6.0.0 (libraries compiled with exceptions support on Linux 32bit)
@@ -106,7 +105,6 @@
 - for qgis mapserver - FastCGI
@@ -130,7 +128,7 @@
 in use for a while, you may need to just skip those steps which are irrelevant
 to you.
-/!\ Note: Refer to the section ''Building Debian packages'' for building
+/!\ Note: Refer to the section Building Debian packages for building
 debian packages.  Unless you plan to develop on QGIS, that is probably the
 easiest option to compile and install QGIS.
@@ -149,25 +147,19 @@
 Now update your local sources database:
   sudo apt-get update
   3.3. Install build dependencies
   || Distribution | install command for packages |
-  | hardy | ``apt-get install  bison cmake fcgi-dev flex grass-dev libexpat1-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-core libqt4-dev libqt4-gui libqt4-sql libsqlite3-dev proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4 python-sip4-dev sip4`` |
-  | intrepid | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-core libqt4-dev libqt4-gui libqt4-sql libqwt5-qt4-dev libsqlite3-dev proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4 python-sip4-dev sip4`` |
-  | jaunty | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-core libqt4-dev libqt4-gui libqt4-sql libqwt5-qt4-dev libsqlite3-dev proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4 python-sip4-dev sip4`` |
-  | karmic | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-core libqt4-dev libqt4-gui libqt4-sql libqwt5-qt4-dev libsqlite3-dev proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4 python-sip4-dev sip4`` |
-  | lenny | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-dev libqwt5-qt4-dev libsqlite3-dev pkg-config proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4-dev sip4`` |
-  | lucid | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev`` |
-  | maverick | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqtwebkit-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev`` |
-  | sid | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev`` |
-  | squeeze | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev`` |
+  | lenny | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-dev libqwt5-qt4-dev libsqlite3-dev pkg-config proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4-dev sip4 txt2tags`` |
+  | lucid | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
+  | maverick | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqtwebkit-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
+  | natty | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqtwebkit-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
+  | sid | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqtwebkit-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
+  | squeeze | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
 (extracted from the respective control files in debian/)
@@ -178,12 +170,10 @@
 designed to live alongside each other. This means that for example if you
 have them both installed you will have three qmake exe's:
   /usr/bin/qmake -> /etc/alternatives/qmake
   /usr/bin/qmake-qt3
   /usr/bin/qmake-qt4
 The same applies to all other Qt binaries. You will notice above that the
 canonical 'qmake' is managed by apt alternatives, so before we start to
 build QGIS, we need to make Qt4 the default. To return Qt3 to default later
@@ -192,7 +182,6 @@
 You can use apt alternatives to correct this so that the Qt4 version of
 applications is used in all cases:
   sudo update-alternatives --config qmake
   sudo update-alternatives --config uic
   sudo update-alternatives --config designer
@@ -203,7 +192,6 @@
   sudo update-alternatives --config lrelease
   sudo update-alternatives --config linguist
 Use the simple command line dialog that appears after running each of the
 above commands to select the Qt4 version of the relevant applications.
@@ -217,13 +205,11 @@
 You should also setup ccache to speed up compile times:
   cd /usr/local/bin
   sudo ln -s /usr/bin/ccache gcc
   sudo ln -s /usr/bin/ccache g++
   3.5. Prepare your development environment
@@ -231,11 +217,9 @@
 this case we will create a work environment for C++ development work like
 this:
   mkdir -p ${HOME}/dev/cpp
   cd ${HOME}/dev/cpp
 This directory path will be assumed for all instructions that follow.
@@ -249,22 +233,17 @@
 1. Anonymous Checkout
   cd ${HOME}/dev/cpp
   svn co https://svn.osgeo.org/qgis/trunk/qgis qgis
 2. Developer Checkout
   cd ${HOME}/dev/cpp
   svn co --username <yourusername> https://svn.osgeo.org/qgis/trunk/qgis qgis
 The first time you check out the source you will be prompted to accept the
 qgis.org certificate. Press 'p' to accept it permanently:
   Error validating server certificate for 'https://svn.qgis.org:443':
      - The certificate is not issued by a trusted authority. Use the
        fingerprint to validate the certificate manually!  Certificate
@@ -277,7 +256,6 @@
        accept (t)emporarily or accept (p)ermanently?
   3.7. Starting the compile
@@ -286,19 +264,15 @@
 you can use the binary packages of QGIS on your system along side with your
 development version. I suggest you do something similar:
   mkdir -p ${HOME}/apps
 Now we create a build directory and run ccmake:
   cd qgis
   mkdir build
   cd build
   ccmake ..
 When you run ccmake (note the .. is required!), a menu will appear where
 you can configure various aspects of the build. If you do not have root
 access or do not want to overwrite existing QGIS installs (by your
@@ -312,19 +286,15 @@
 Now on with the build:
   make
   make install
 It may take a little while to build depending on your platform.
 After that you can try to run QGIS:
   $HOME/apps/bin/qgis
 If all has worked properly the QGIS application should start up and appear
 on your screen.
@@ -338,22 +308,16 @@
 First you need to install the debian packaging tools once:
   apt-get install build-essential
 First you need to create an changelog entry for your distribution. For example for Ubuntu Lucid:
   dch -l ~lucid  --force-distribution --distribution lucid "lucid build"
 The QGIS packages will be created with:
   dpkg-buildpackage -us -uc -b
 /!\ Note: If dpkg-buildpackage complains about unmet build dependencies
 you can install them using apt-get and re-run the command.
@@ -364,11 +328,9 @@
 The packages are created in the parent directory (ie. one level up).
 Install them using dpkg.  E.g.:
   sudo debi
   3.9. A practical case: Building QGIS and GRASS from source on Ubuntu with ECW and MrSID formats support
@@ -384,58 +346,46 @@
 First you need to install the necessary packages required to download the source
 code and compile it. Open the terminal and issue the following command:
   sudo apt-get install build-essential g++ subversion
     3.9.2. Step 2: compile and install the ecw libraries
 Go to the ERDAS web site http://www.erdas.com/ and follow the links
-"'''products --> ECW JPEG2000 Codec SDK --> downloads'''"
-then download the "'''Image Compression SDK Source Code 3.3'''" (you'll need to make a registration
+"'products --> ECW JPEG2000 Codec SDK --> downloads'"
+then download the "'Image Compression SDK Source Code 3.3'" (you'll need to make a registration
 and accept a license).
 Uncompress the arquive in a proper location (this guide assumes
 that all the downloaded source code will be placed in the user home)
 and the enter the newly created folder
   cd /libecwj2-3.3
 Compile the code with the standard commands
   ./configure
 then
   make
 then
   sudo make install
 leave the folder
   cd ..
     3.9.3. Step 3: download the MrSID binaries
 Go to the LIZARDTECH web site http://www.lizardtech.com/ and follow the links
-"'''download --> Developer SDKs'''",
-then download the "'''GeoExpress SDK for Linux (x86) - gcc 4.1 32-bit'''"
+"'download --> Developer SDKs'",
+then download the "'GeoExpress SDK for Linux (x86) - gcc 4.1 32-bit'"
 (you'll need to make a registration and accept a license).
 Uncompress the downloaded file. The resulting directory name should be similar to "Geo_DSDK-7.0.0.2167"
@@ -446,32 +396,23 @@
 Download the latest gdal source code
   svn checkout https://svn.osgeo.org/gdal/trunk/gdal gdal
 then copy a few files from the MrSID binaries folder to the folder with the gdal source code
-('''replace "USERNAME" with your actual account username''')
+('replace "USERNAME" with your actual account username')
   cp /home/USERNAME/Geo_DSDK-7.0.0.2167/include/*.* /home/USERNAME/gdal/frmts/mrsid/
 enter the gdal source code folder
   cd /gdal
 and run configure with a few specific parameters
   ./configure --without-grass --with-mrsid=../Geo_DSDK-7.0.0.2167 --without-jp2mrsid
 at the end of the configuration process you should read something like
   GRASS support:             no
@@ -481,50 +422,36 @@
   MrSID support              yes
 then compile normally
   make
 and
   sudo make install
 finish the process by creating the necessary links to the most recent shared libraries
   sudo ldconfig
 at this point you may want to check if gdal was compiled correctly with MrSID and ECW
 support by issuing one (or both) of the following commands
   gdalinfo --formats | grep 'ECW'
   gdalinfo --formats | grep 'SID'
 leave the folder
   cd ..
     3.9.5. Step 5: compile and install GRASS
 Before downloading and compile GRASS source code you need to install a few
 other libraries and programs. We can do this trough apt
   sudo apt-get install flex bison libreadline5-dev libncurses5-dev lesstif2-dev debhelper dpatch libtiff4-dev \
   tcl8.4-dev tk8.4-dev fftw-dev xlibmesa-gl-dev libfreetype6-dev autoconf2.13 autotools-dev \
   libgdal1-dev proj libjpeg62-dev libpng12-dev libpq-dev unixodbc-dev doxygen fakeroot cmake \
@@ -532,46 +459,35 @@
   libqt4-dev libgsl0-dev python-qt4 swig python-wxversion python-wxgtk2.8 libwxgtk2.8-0 libwxbase2.8-0 tcl8.4-dev \
   tk8.4-dev tk8.4 libfftw3-dev libfftw3-3
 At this point we can get the GRASS source code: you may want to download it
 trough svn or maybe you want just to download the latest available source code arquive.
 For example the GRASS 6.4rc4 is available at http://grass.itc.it/grass64/source/grass-6.4.0RC4.tar.gz
 Uncompress the arquive, enter the newly created folder and run configure with a few specific parameters
   CFLAGS="-fexceptions" ./configure --with-tcltk-includes=/usr/include/tcl8.4 --with-proj-share=/usr/share/proj --with-gdal=/usr/local/bin/gdal-config \
   --with-python=/usr/bin/python2.5-config
 The additional gcc option -fexceptions is necessary to enable exceptions support in GRASS libraries. It is currently the only way to avoid QGIS crashes if a fatal error happens in GRASS library. See also http://trac.osgeo.org/grass/ticket/869
 Then as usual (it will take a while)
   make
 and
   sudo make install
 leave the folder
   cd ..
 you have now compiled and installed GRASS (also with the new wxpyhton interface) so you
 may want to give it a try
   grass64 -wxpython
     3.9.6. Step 6: compile and install QGIS
@@ -583,24 +499,18 @@
 uncompress the arquive and enter the newly created folder
   cd /qgis_1.1.0
 then run ccmake
   ccmake .
 press the "c" key, then when the option list will appear we need to manually
 configure the "GRASS_PREFIX" parameter. Scroll down until the "GRASS_PREFIX" will appear,
 press enter and manually set it to
   /usr/local/grass-6.4.0RC4
 then press enter again.
 Press the "c" again and the option "Press [g] to generate and exit" will appear.
@@ -608,26 +518,20 @@
 then as usual (it will take a while)
   make
 and
   sudo make install
 At the end of the process you should have QGIS and GRASS working with MrSID and ECW
 raster format support.
 To run QGIS just use this command
   qgis
   4. Building on Windows
@@ -665,7 +569,6 @@
 Download and install following packages:
   || Tool | Website |
   | CMake | http://www.cmake.org/files/v2.8/cmake-2.8.4-win32-x86.exe |
   | Flex | http://gnuwin32.sourceforge.net/downlinks/flex.php |
@@ -692,7 +595,6 @@
 - qwt5-devel-qt4
 - sip
 This will also select packages the above packages depend on.
 Additionally QGIS also needs the include file unistd.h, which normally
@@ -712,7 +614,6 @@
 variables create the following batch file (assuming the above packages were
 installed in the default locations):
   @echo off
   path %SYSTEMROOT%\system32;%SYSTEMROOT%;%SYSTEMROOT%\System32\Wbem;%PROGRAMFILES%\CMake 2.8\bin;%PROGRAMFILES%\subversion\bin;%PROGRAMFILES%\GnuWin32\bin
   set PYTHONPATH=
@@ -732,20 +633,15 @@
   @cmd
 Start the batch file and on the command prompt checkout the QGIS source from
 svn to the source directory qgis-trunk:
   svn co https://svn.osgeo.org/qgis/trunk/qgis qgis-trunk
 or using git-svn (from the git shell):
   git svn clone --username $USER --revision 15611:HEAD https://svn.osgeo.org/qgis/trunk/qgis
 Create a 'build' directory somewhere. This will be where all the build output
 will be generated.
@@ -785,25 +681,19 @@
     4.1.4. Packaging
-To create a windows 'all in one' standalone  package ''under ubuntu'' (yes you
+To create a windows 'all in one' standalone  package under ubuntu (yes you
 read correctly) do the following:
   sudo apt-get install nsis
 Now
   cd qgis/ms-windows/osgeo4w
 And run the nsis creation script:
   creatensis.pl
 When the script completes, it should have created a QGIS installer executable
 in the ms-windows directory (using the QGIS binaries from OSGEO4W).
@@ -816,13 +706,11 @@
 windows installation into the ms-windows file tree created by the creatensis
 script.
   cd ms-windows/
   rm -rf osgeo4w/unpacked/apps/qgis/*
   cp -r /tmp/qgis1.7.0/* osgeo4w/unpacked/apps/qgis/
   ./quickpackage.sh
 After this you should now have a nsis installer containing your own build
 of QGIS and all dependencies needed to run it on a windows machine.
@@ -882,11 +770,9 @@
 Edit C:\Qt\4.7.0\bin\qtvars.bat and add the following lines:
   set PATH=%PATH%;C:\msys\local\bin;c:\msys\local\lib
   set PATH=%PATH%;"C:\Program Files\Subversion\bin"
 I suggest you also add C:\Qt\4.7.0\bin\ to your Environment Variables Path in
 the windows system preferences.
@@ -898,11 +784,9 @@
 compile the debug version you have to go out of src directory and execute the
 following command:
   c:\Qt\4.7.0 make
     4.2.3. Flex and Bison
@@ -940,25 +824,21 @@
       4.2.4.3. Compile SIP
   c:\Qt\4.7.0\bin\qtvars.bat
   python configure.py -p win32-g++
   make
   make install
       4.2.4.4. Compile PyQt
   python configure.py
   make
   make install
       4.2.4.5. Final python notes
@@ -989,26 +869,20 @@
 Start a cmd.exe window ( Start -> Run -> cmd.exe ) Create development
 directory and move into it
   md c:\dev\cpp
   cd c:\dev\cpp
 Check out sources from SVN:
 For svn trunk:
 For svn 1.5 branch
   svn co https://svn.osgeo.org/qgis/branches/Release-1_5_0 qgis1.5.0
     4.2.8. Compiling
@@ -1018,28 +892,22 @@
 Start a cmd.exe window ( Start -> Run -> cmd.exe ) if you don't have one
 already.  Add paths to compiler and our MSYS environment:
 For ease of use add c:\Qt\4.7.0\bin\ to your system path in system
 properties so you can just type qtvars.bat when you open the cmd console.
 Create build directory and set it as current directory:
   cd c:\dev\cpp\qgis
   md build
   cd build
     4.2.9. Configuration
   cmakesetup ..
 Note: You must include the '..' above.
 Click 'Configure' button.  When asked, you should choose 'MinGW Makefiles' as
@@ -1061,11 +929,9 @@
     4.2.10. Compilation and installation
    make make install
     4.2.11. Run qgis.exe from the directory where it's installed (CMAKE_INSTALL_PREFIX)
@@ -1180,7 +1046,6 @@
 Run these commands:
   export PATH="/usr/local/bin:/usr/local/lib:$PATH"
   ./configure --prefix=/usr/local --bindir=/usr/local --with-includes=/usr/local/include --with-libs=/usr/local/lib --with-cxx --without-jpeg \
   --without-tiff --with-postgres=yes --with-postgres-includes=/local/pgsql/include --with-pgsql-libs=/local/pgsql/lib --with-opengl=windows --with-fftw \
@@ -1189,7 +1054,6 @@
   make
   make install
 It should get installed to c:\msys\local\grass-6.3.cvs
 By the way, these pages might be useful:
@@ -1210,24 +1074,19 @@
 To compile, I had to patch the sources: in file source/headers/timeval.h line 13.
 Change it from:
   #ifdef _WIN32
 to:
   #if defined(_WIN32) && defined(_MSC_VER)
 Now, in MSYS console, go to the source directory and run:
   make
   make install
       4.3.2.4. SQLITE
@@ -1257,13 +1116,11 @@
 Run from MSYS console in the source directory:
   ./configure
   make
   make install
       4.3.2.6. EXPAT
@@ -1275,13 +1132,11 @@
   ./configure
   make
   make install
       4.3.2.7. POSTGRES
@@ -1320,10 +1175,8 @@
 up compilation, but it's not automatic.  Whenever you type "make" (but NOT "make install"),
 instead type:
   make -j [n]
 Replace [n] with the number of cores and/or processors your Mac has.  On recent
 models with hyperthreading processors this can be double the physical count of
 processors and cores.
@@ -1346,10 +1199,8 @@
 PPC note: There appear to be issues with Qt Cocoa on PPC Macs.  QT Carbon
 is recommended on PPC Macs.
   http://qt.nokia.com/downloads
 If you want debug frameworks, Qt also provides a dmg with these.  These are in
 addition to the non-debug frameworks.
@@ -1361,11 +1212,9 @@
 these libraries will not be found.  To fix this problem,
 add symlinks to /usr/local:
   sudo ln -s /usr/lib/libQtUiTools.a /usr/local/lib/
   sudo ln -s /usr/lib/libQtCLucene.dylib /usr/local/lib/
 These should then be found automatically on Leopard and above.  Earlier systems
 may need some help by adding '-L/usr/local/lib' to CMAKE_SHARED_LINKER_FLAGS,
 CMAKE_MODULE_LINKER_FLAGS and CMAKE_EXE_LINKER_FLAGS in the cmake build.
@@ -1378,10 +1227,8 @@
 PROJ, GEOS, GDAL, SQLite3, and image libraries, as frameworks.  There is also
 a GSL framework.
   http://www.kyngchaos.com/wiki/software/frameworks
 Once downloaded, open and install the frameworks.
 William provides an additional installer package for Postgresql (for PostGIS support).
@@ -1389,17 +1236,13 @@
 Postgres + PostGIS server, all you need is the client-only package.
 It's available here:
   http://www.kyngchaos.com/wiki/software/postgres
 Also available is a GRASS application:
   http://www.kyngchaos.com/wiki/software/grass
     5.2.1. Additional Dependencies: General compatibility note
@@ -1423,19 +1266,15 @@
 Get the expat sources:
   http://sourceforge.net/project/showfiles.php?group_id=10127
 Double-click the source tarball to unpack, then, in Terminal.app, cd to the source folder and:
   ./configure
   make
   sudo make install
     5.2.3. Additional Dependencies: Python
@@ -1445,10 +1284,8 @@
 If installing from python.org, make sure you install at least the latest Python 2.x from
   http://www.python.org/download/
 Python 3 is a major change, and may have compatibility issues, so try it at your own risk.
@@ -1457,31 +1294,25 @@
 Retrieve the python bindings toolkit SIP from
   http://www.riverbankcomputing.com/software/sip/download
 Double-click the source tarball to unpack it, then, in Terminal.app, cd to the source folder
 and (this installs by default into the Python framework, and is appropriate only for
 python.org Python installs):
   python configure.py
   make
   sudo make install
 Leopard notes
 If building on Leopard, using Leopard's bundled Python, SIP wants to install in the
 system path -- this is not a good idea.  Use this configure command instead of the
 basic configure above:
   python configure.py -n -d /Library/Python/2.5/site-packages -b /usr/local/bin \
   -e /usr/local/include -v /usr/local/share/sip -s MacOSX10.5.sdk
 Snow Leopard notes
 Similar to Leopard, you should install outside the system Python path.
@@ -1489,62 +1320,48 @@
 and make sure to run the versioned python binary (this one responds to the
 'arch' command, 'python' does not). If you are using 32-bit Qt (Qt Carbon):
   python2.6 configure.py -n -d /Library/Python/2.6/site-packages -b /usr/local/bin \
   -e /usr/local/include -v /usr/local/share/sip --arch=i386 -s MacOSX10.6.sdk
 For 64-bit Qt (Qt Cocoa), use this configure line:
   -e /usr/local/include -v /usr/local/share/sip --arch=x86_64 -s MacOSX10.6.sdk
     5.2.5. Additional Dependencies: PyQt
 Retrieve the python bindings toolkit for Qt from
   http://www.riverbankcomputing.com/software/pyqt/download
   python configure.py
   yes
 There is a problem with the configuration that needs to be fixed now
 (it affects PyQwt compilation later).  Edit pyqtconfig.py and change the qt_dir line to:
       'qt_dir': '/usr',
 Then continue with compilation and installation (this is a good place to use
 parallel compilation, if you can):
   make
   sudo make install
 Leopard notes
 If building on Leopard, using Leopard's bundled Python, PyQt wants to install
 in the system path -- this is not a good idea.  Use this configure command
 instead of the basic configure above:
   python configure.py -d /Library/Python/2.5/site-packages -b /usr/local/bin
 If there is a problem with undefined symbols in QtOpenGL on Leopard, edit
 QtOpenGL/makefile and add -undefined dynamic_lookup to LFLAGS.
 Then make again.
@@ -1557,27 +1374,21 @@
 'arch' command, which is important for pyuic4, 'python' does not).
   python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch i386
   python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch x86_64
     5.2.6. Additional Dependencies: Qwt/PyQwt
 The GPS tracking feature uses Qwt.  Some popular 3rd-party plugins use PyQwt.
 You can take care of both with the PyQwt source from:
   http://pyqwt.sourceforge.net/
 Double-click the tarball to unpack it.  The following assumes PyQwt v5.2.0 (comes with Qwt 5.2.1).
 Normal compilation does both Qwt and PyQwt at the same time, but Qwt is statically linked
 into PyQwt, and Qgis can't use it.  So, we need to split the build.
@@ -1587,49 +1398,39 @@
 qmake).  Scroll down to the 'release/debug mode' block.  Edit the last 'CONFIG +='
 line, within an 'else' block, and change 'debug' to 'release'.  Like so:
       else {
           CONFIG           += release     # release/debug
 Also uncomment (remove # prefix) the line 'CONFIG += QwtDll'.  Like so:
   CONFIG           += QwtDll
 If you are building for Qt Carbon 32bit on Snow Leopard, add a line at the bottom:
   CONFIG += x86
 Save and close.
 Now, cd into the qwt-5.2 subdir in a Terminal.  Type these commands to build and install:
   qmake -spec macx-g++
   make
   sudo make install
   sudo install_name_tool -id /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib \
 The Qwt shared library is now installed in /usr/local/qwt-5.x.x[-svn] (x.x is the
 minor.point version, and it may be an SVN version).  Remember this for QGIS and PyQwt configuration.
 Now for PyQwt.  Still in the Terminal:
   cd ../configure
   python configure.py --extra-include-dirs=/usr/local/qwt-5.2.1-svn/include \
   --extra-lib-dirs=/usr/local/qwt-5.2.1-svn/lib --extra-libs=qwt
   make
   sudo make install
 Make sure to use the qwt install path from the Qwt build above.
 Snow Leopard note
@@ -1638,13 +1439,11 @@
 it will default to a combination that does not work (ie x86_64 for a Carbon Qt).
 This is not needed for Qt Cocoa. Configure as follows:
   python configure.py --extra-cflags="-arch i386" --extra-cxxflags="-arch i386" \
   --extra-lflags="-arch i386" --extra-include-dirs=/usr/local/qwt-5.2.1-svn/include \
     5.2.7. Additional Dependencies: Bison
@@ -1653,41 +1452,33 @@
 The version of bison available by default on Mac OS X 10.4 is too old so you need to
 get a more recent one on your system. Download at least version 2.3 from:
   ftp.gnu.org/gnu/bison/
 Now build and install it to a prefix of /usr/local.Ê Double-click the source
 tarball to unpack it, then cd to the source folder and:
   make
   sudo make install
   5.3. Install CMake for OSX
 Get the latest source release from here:
   http://www.cmake.org/cmake/resources/software.html
 Binary installers are available for OS X, but they are not recommended
 (2.4 versions install in /usr instead of /usr/local, and 2.6 versions are a
 strange application). Instead, download the source, double-click the source tarball,
   ./bootstrap --docdir=/share/doc/CMake --mandir=/share/man
   make
   sudo make install
   5.4. Install subversion for OSX
@@ -1698,35 +1489,27 @@
 build of svn. If you are a GUI inclined person you may want to grab their gui
 client too. Get the command line client here:
   curl -O http://ufpr.dl.sourceforge.net/sourceforge/macsvn/Subversion_1.4.2.zip
 Once downloaded open the zip file and run the installer.
 You also need to install BerkleyDB available from the same
 http://sourceforge.net/projects/macsvn/ (website). At the time of writing the
 file was here:
   curl -O http://ufpr.dl.sourceforge.net/sourceforge/macsvn/Berkeley_DB_4.5.20.zip
 Once again unzip this and run the installer therein.
 Lastly we need to ensure that the svn commandline executeable is in the path.
 Add the following line to the end of /etc/bashrc using sudo:
   sudo vim /etc/bashrc
 And add this line to the bottom before saving and quiting:
   export PATH=/usr/local/bin:$PATH:/usr/local/pgsql/bin
 /usr/local/bin needs to be first in the path so that the newer bison (that will
 be built from source further down) is found before the bison (which is very
 old) that is installed by MacOSX
@@ -1740,28 +1523,21 @@
 Now we are going to check out the sources for QGIS. First we will create a
 directory for working in (or some folder of your choice):
   mkdir -p ~/dev/cpp cd ~/dev/cpp
 Now we check out the sources:
 Trunk:
 For a release branch version x.y.z:
   svn co https://svn.qgis.org/qgis/branches/Release-x_y_z qgis-x.y.z
 The first time you check out QGIS sources you will probably get a message like
 this:
    - The certificate is not issued by a trusted authority. Use the fingerprint to
      validate the certificate manually!  Certificate information:
@@ -1771,7 +1547,6 @@
    - Fingerprint: 2f:cd:f1:5a:c7:64:da:2b:d1:34:a5:20:c6:15:67:28:33:ea:7a:9b
      (R)eject, accept (t)emporarily or accept (p)ermanently?
 I suggest you press 'p' to accept the key permanently.
@@ -1785,7 +1560,6 @@
 building into a pre-existing ${HOME}/Applications directory.
 In a Terminal cd to the qgis source folder previously downloaded, then:
   mkdir build
   cd build
   cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release \
@@ -1795,7 +1569,6 @@
   -D QWT_INCLUDE_DIR=/usr/local/qwt-5.2.1-svn/include \
 This will automatically find and use the previously installed frameworks, and the GRASS
 application if installed.
@@ -1803,7 +1576,6 @@
 (minimum GRASS version as stated in the Qgis requirements, substitute the GRASS
 path and version as required):
   -D CMAKE_BUILD_TYPE=MinSizeRel \
   -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_MAPSERVER=TRUE \
@@ -1812,11 +1584,9 @@
   -D GRASS_PREFIX=/user/local/grass-6.4.0 \
 Snow Leopard note: To handle 32-bit Qt (Carbon), create a 32bit python wrapper
 script and add arch flags to the configuration:
   sudo cat >/usr/local/bin/python32 <<EOF
   #!/bin/sh
   exec arch -i386 /usr/bin/python2.6 \${1+"\$@"}
@@ -1832,7 +1602,6 @@
   -D CMAKE_OSX_ARCHITECTURES=i386 -D PYTHON_EXECUTABLE=/usr/local/bin/python32 \
 Bundling note: Older Qt versions may have problems with some Qt plugins and Qgis.
 The way to handle this is to bundle Qt inside the Qgis application.  You can do this now
 or wait to see if there are immediate crashes when running Qgis.  It's also a good
@@ -1841,34 +1610,26 @@
 To bundle Qt, add the following line before the last line in the above cmake configurations:
   -D QGIS_MACAPP_BUNDLE=1 \
   5.7. Building
 Now we can start the build process (remember the parallel compilation note at
 the beginning, this is a good place to use it, if you can):
   make
 If all built without errors you can then install it:
   make install
 or, for a /Applications build:
   sudo make install
@@ -1898,7 +1659,3 @@
  - Tim Sutton 2006
  - Debian package section: Juergen Fischer 2008
Modified: trunk/qgis/doc/linux.t2t
--- trunk/qgis/doc/linux.t2t	2011-04-04 07:23:56 UTC (rev 15667)
+++ trunk/qgis/doc/linux.t2t	2011-04-04 07:25:27 UTC (rev 15668)
@@ -44,15 +44,12 @@
 == Install build dependencies ==
-| hardy | ``apt-get install  bison cmake fcgi-dev flex grass-dev libexpat1-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-core libqt4-dev libqt4-gui libqt4-sql libsqlite3-dev proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4 python-sip4-dev sip4`` |
-| intrepid | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-core libqt4-dev libqt4-gui libqt4-sql libqwt5-qt4-dev libsqlite3-dev proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4 python-sip4-dev sip4`` |
-| jaunty | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-core libqt4-dev libqt4-gui libqt4-sql libqwt5-qt4-dev libsqlite3-dev proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4 python-sip4-dev sip4`` |
-| karmic | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-core libqt4-dev libqt4-gui libqt4-sql libqwt5-qt4-dev libsqlite3-dev proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4 python-sip4-dev sip4`` |
-| lenny | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-dev libqwt5-qt4-dev libsqlite3-dev pkg-config proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4-dev sip4`` |
-| lucid | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev`` |
-| maverick | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqtwebkit-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev`` |
-| sid | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev`` |
-| squeeze | ``apt-get install  bison cmake flex grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev`` |
+| lenny | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libqt4-dev libqwt5-qt4-dev libsqlite3-dev pkg-config proj pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip4-dev sip4 txt2tags`` |
+| lucid | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
+| maverick | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqtwebkit-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
+| natty | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqtwebkit-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
+| sid | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqtwebkit-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
+| squeeze | ``apt-get install bison cmake doxygen flex graphviz grass-dev libexpat1-dev libfcgi-dev libgdal1-dev libgeos-dev libgsl0-dev libpq-dev libproj-dev libqt4-dev libqwt5-qt4-dev libspatialite-dev libsqlite3-dev pkg-config pyqt4-dev-tools python python-dev python-qt4 python-qt4-dev python-sip python-sip-dev txt2tags`` |
 (extracted from the respective control files in ``debian/``)
Modified: trunk/qgis/scripts/scandeps.pl
--- trunk/qgis/scripts/scandeps.pl	2011-04-04 07:23:56 UTC (rev 15667)
+++ trunk/qgis/scripts/scandeps.pl	2011-04-04 07:25:27 UTC (rev 15668)
@@ -51,7 +51,7 @@
 	push @dep, $dep;
-	print O "| $dist | ``apt-get install " . join( " ", @dep ) . "`` |\n";
+	print O "| $dist | ``apt-get install" . join( " ", @dep ) . "`` |\n";
 while(<I>) {
More information about the QGIS-commit mailing list
