[QGIS Commit] r15678 - in trunk/qgis: i18n src/plugins/grass/modules-6.3 src/plugins/grass/modules-6.4 src/plugins/grass/modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Apr 7 04:41:09 EDT 2011
Author: pcav
Date: 2011-04-07 01:41:09 -0700 (Thu, 07 Apr 2011)
New Revision: 15678
Added:
   trunk/qgis/src/plugins/grass/modules-common/v.build.one.1.png
   trunk/qgis/src/plugins/grass/modules-common/v.build.one.qgm
   trunk/qgis/i18n/qgis_it.ts
   trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
   trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
More IT translation, one more GRASS module (thanks Markus Neteler)
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts	2011-04-06 21:13:34 UTC (rev 15677)
+++ trunk/qgis/i18n/qgis_it.ts	2011-04-07 08:41:09 UTC (rev 15678)
@@ -13565,7 +13565,7 @@
     <message>
         <location filename="../src/gui/qgscomposerview.cpp" line="401"/>
         <source>Remove item group</source>
-        <translation type="unfinished">Rimuovi oggetto dal gruppo</translation>
+        <translation>Rimuovi gruppo di oggetti</translation>
     </message>
     <message>
         <location filename="../src/gui/qgscomposerview.cpp" line="419"/>
@@ -18675,7 +18675,7 @@
     <message>
         <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3334"/>
         <source>%1:&amp;nbsp;missing value</source>
-        <translation>%1:&amp;nbsp;valore perso</translation>
+        <translation>%1:&amp;nbsp;valore mancante</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3341"/>
@@ -18779,7 +18779,7 @@
     <message>
         <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2068"/>
     </message>
 </context>
 <context>
@@ -30800,8 +30800,8 @@
         <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="708"/>
         <source>Coordinate reference system(CRS) of
 &quot;%1&quot; is invalid(see CRS of provider).</source>
-        <translation type="unfinished">Le coordinate di riferimento spaziale (CRS) di
-&quot;%1&quot; non sono valide (vedi il CRS del provider).</translation>
+        <translation type="unfinished">Il sistema di riferimento (CRS) di
+&quot;%1&quot; non è valido (vedi il CRS del provider).</translation>
     </message>
     <message>
         <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="709"/>
@@ -30952,7 +30952,7 @@
         <location filename="../src/plugins/spatialquery/qgsspatialquerydialogbase.ui" line="242"/>
         <source>Result feature ID&apos;s</source>
         <translatorcomment>(spero sia giusto)</translatorcomment>
-        <translation type="unfinished">Risultato dell&apos;ID dell&apos;oggetto</translation>
+        <translation>Risultato dell&apos;ID dell&apos;oggetto</translation>
     </message>
     <message>
         <location filename="../src/plugins/spatialquery/qgsspatialquerydialogbase.ui" line="273"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2011-04-06 21:13:34 UTC (rev 15677)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2011-04-07 08:41:09 UTC (rev 15678)
@@ -278,6 +278,7 @@
 		<section label="Develop map">
 			<section label="Topology management">
 				<grass name="v.build.all"/>
+				<grass name="v.build.one"/>
 			</section>
 			<section label="Toolset for cleaning topology of vector map">
 				<grass name="v.clean.break"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2011-04-06 21:13:34 UTC (rev 15677)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2011-04-07 08:41:09 UTC (rev 15678)
@@ -295,6 +295,7 @@
 			</section>
Added: trunk/qgis/src/plugins/grass/modules-common/v.build.one.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules-common/v.build.one.1.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules-common/v.build.one.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.build.one.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-common/v.build.one.qgm	2011-04-07 08:41:09 UTC (rev 15678)
@@ -0,0 +1,8 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Rebuild topology of a vector in mapset" module="v.build">
+	<option key="map"/>
+	<option key="option" answer="build" hidden="yes"/>
+	<option key="error"/>
+</qgisgrassmodule>
More information about the QGIS-commit mailing list
